01-21-2013, 17:06 | #4 (permalink) |
Freak Poster Join Date: Jun 2010 Location: india
Member: 1334683 Status: Offline Sonork: hasubhai Thanks Meter: 144 | brother brother, first unlock your device and then you need to change its pm and then convert your device thanks and regards |
The Following User Says Thank You to hasubhai For This Useful Post: |
01-21-2013, 17:16 | #5 (permalink) | |
No Life Poster Join Date: Jun 2009 Location: SouthAmericaUnlockers Age: 52
Member: 1057178 Status: Offline Sonork: Kfe~Labs Co.- Thanks Meter: 568 | Quote:
The Fact: ATF Not Support this Infineon based for lbf.- @hasubhai are you tested this solution with log? Thnks in advance polaco Last edited by el-polaco; 01-21-2013 at 17:26. | |
01-22-2013, 01:54 | #7 (permalink) | |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | Quote:
Maybe very soon enough... Code: VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Booting Phone... CPU ID Response: A200341100 CPU Type: XG110 2.1B Phone Booted at after First attempt... ****************************************************** START INFINEON BUS CHECK ****************************************************** Sending PBL 37888 bytes... PBL Successfully Sent... Unique Data: 41021631058087000E10 Sending SBL 65024 bytes... SBL Successfully Sent... Flash Chip Manufacturer: Samsung Electronics Corp. Flash Chip Type: K8S6415ETC 64 Mbit (4Mb x 16) NOR Extended Information: Multiple Bank / Burst / 1.8v Dumping: PMM Plain Dumping: PMM Protected PMM Dump Done... Reading Simlock Information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ength: 15-digits NCK Unlock: True ****************************************************** INFINEON BUS CHECK DONE ****************************************************** Waiting for Phone to Go Online... Elapsed Time: 1s Elapsed Time: 2s Elapsed Time: 3s Elapsed Time: 4s Elapsed Time: 5s Elapsed Time: 6s Elapsed Time: 7s Elapsed Time: 8s Elapsed Time: 9s Elapsed Time: 10s ================================================ Basic Phone Information ================================================ MCU Version: V 06.53 14-09-11 RH-125 (c) Nokia IMEI Plain : 352723046433042 IMEI Spare : A352723046433040 IMEI SV : 33527230464330469F Phone Type : RH-125 ================================================ Extended Phone Information ================================================ Product Serial Number: 00A0438AI Product Code : 059B7C7 Module Code : 0204343 Basic Production Code: 059B7Z8 PPM SW Version : V 06.53 14-09-11 RH-125 (c) Nokia UA ADSP Version : p V 06.53\n14-09-11\nRH-125\n(c) NMP\nua MCU SW Version : V 06.53 14-09-11 RH-125 (c) Nokia HW Version : 1000 UEM Version : 1328 UPP Version : 8850 LCD Version : TPO:BOHAIv80 HX5081 ================================================== Decrypt XGOLD PM 120 HASHES for Brute Force Unlock ================================================== Decrypting PM 120... PM 120 HASHES Extracted Successfully C01848CB5C6655E41E0842BC202D81ADB34172A5 A5E5FE5B0E94A16C8C4017FCC6AE90C3D2735AC0 D20C065C2699478A52D6481C4585A88F0C03BD09 07C41B7818B84620036B999C8623A0E6C25AC247 A67FA86100F22F84C6ED5ED34924D7C1A956478F F274255D3A45B758F0F9729F0BD6063B4AE0D44A 42AF9C21E3199536B74DEA88A2F48CA6E7C88C8A 20D51AC6C78142B25767B28BD39E1F6C2CD84E46 Log Files for Local Brute Force Saved to: C:\AdvanceBox Turbo Flasher\Nokia\Bruteforce\352723046433042\352723046433042.job C:\AdvanceBox Turbo Flasher\Nokia\Bruteforce\352723046433042\352723046433042.log C:\AdvanceBox Turbo Flasher\Nokia\Bruteforce\352723046433042\352723046433042.bcl C:\AdvanceBox Turbo Flasher\Nokia\Bruteforce\352723046433042\352723046433042.sha Command Line for ighashgpu: Saved as MS Batch File: 352723046433042_ighashgpu.bat Command Line for oclHashcat-lite64 (AMD Cards 64-Bit OS): Saved as MS Batch File: 352723046433042_AMD_oclHashcat_64-bit.bat Command Line for oclHashcat-lite32 (AMD Cards 32-Bit OS): Saved as MS Batch File: 352723046433042_AMD_oclHashcat_32-bit.bat Command Line for cudaHashcat-lite64 (NVIDIA Cards 64-Bit OS): Saved as MS Batch File: 352723046433042_NVIDIA_cudaHashcat_64-bit.bat Command Line for cudaHashcat-lite32 (NVIDIA Cards 32-Bit OS): Saved as MS Batch File: 352723046433042_NVIDIA_cudaHashcat_32-bit.bat Process Done! | |
The Following User Says Thank You to Advance-Box For This Useful Post: |
01-22-2013, 09:31 | #9 (permalink) |
Junior Member Join Date: Apr 2011 Location: qatar Age: 34
Member: 1548584 Status: Offline Sonork: sahil786786 Thanks Meter: 0 | the device is unlocked but sometime its showing low network or no network. do you have any solution of this fault. thanks in advance |
01-22-2013, 10:35 | #10 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @hasubhai @sahil786786 Look at Post #1... it is RH-125 ... it is not 1661, but 1616 which is Infineon Phone and not DCT4 UPP... |
03-01-2013, 23:40 | #14 (permalink) |
Junior Member Join Date: Sep 2011
Member: 1664218 Status: Offline Thanks Meter: 4 | Excuse my stupidity but after doing this http://forum.gsmhosting.com/vbb/f609...ml#post9131414 I run the batch files on a good PC with a good video card to get the NCK? if yes then I have two more Qs -How do I enter the NCK via FBUS if it can't be entered using the keypad? and -Is there a chance that some Nokia 1616 are 20 digits code and can't be unlocked? Regards and thank you very much for your time, I just love ATF!!! |
