05-14-2016, 13:26 | #1 (permalink) |
Banned Join Date: Nov 2010 Location: :::LONDON:::
Member: 1442994 Status: Offline Thanks Meter: 899 | NOKIA 201 flashing error Code: Number of Image Files: 3 Processing Image File : rm799__11.81.mcusw Processing Image File : rm799__11.81.ppm_c7 Processing Image File : rm799__11.81_004.image_c7_vodafone_pt_v2_9p147 AUTO SELECTED DEAD USB FLASHING... If Phone Booting does not Start in 5 Seconds, Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... Infineon USB Boot: F00A1FB300020303010100FF Sending PBL... PBL Successfully Sent... Sending SBL... SBL Successfully Sent... Setting Transmission Speed Done... Flash Chip Manufacturer: Intel Electronics Corp. Flash Boot Successful... Unique Data: 12300417160A2813 Original Product Code: 059P147 Reading : CCC... OK! Reading : HWC... OK! Reading : NPC... OK! RPL Backup was Successful... Plain RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\354558054429435\354558054429435_131225.rpl Certificate Block Saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\354558054429435\354558054429435_CERTIFICATE_C24097C9.bin PM Block Saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\354558054429435\354558054429435_PMM_PROT_56DC8215.bin Security Code: 12345 Data Sections : 04 Current File : rm799__11.81.mcusw Compile Name: rm799__11.81.mcusw_ebl_psi.fls Image Type : Main Firmware Data Size : 26217864 Bytes Sending Certificate Block FIRMWARE Certificate Block Sent Successfully... Processing Section 01 FIRMWARE Erase Block: 0x40000000~0x4001FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 131072 bytes Data Checksum: CC39 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 02 FIRMWARE Erase Block: 0x40040000~0x4005FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 131072 bytes Data Checksum: 7A46 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 03 FIRMWARE Erase Block: 0x40060000~0x4015FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 1048576 bytes Data Checksum: AC8F Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 04 FIRMWARE Erase Block: 0x40280000~0x41A3FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 24903680 bytes Data Checksum: C47F Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 05 FIRMWARE Erase Block: 0x43E20000~0x43E5FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Data Verification Successful... Data Sections : 01 Current File : rm799__11.81.ppm_c7 Compile Name: package_c7.ppm_ebl_psi.fls Image Type : PPM Image Data Size : 5796452 Bytes Sending Certificate Block PPM Certificate Block Sent Successfully... Processing Section 01 PPM Erase Block: 0x41A40000~0x4217FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 5793108 bytes Data Checksum: 9259 Uploading Data Blocks to phone... Block Write Successful... PPM Data Blocks uploaded to phone... Data Verification Successful... Data Sections : 01 Current File : rm799__11.81_004.image_c7_vodafone_pt_v2_9p147 Compile Name: package_c7_voda_pt.image.fls Image Type : CONTENT Package Data Size : 17566992 Bytes Sending Certificate Block CONTENT Certificate Block Sent Successfully... Processing Section 01 CONTENT Erase Block: 0x42180000~0x43E1FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 17563648 bytes Data Checksum: 5C26 Uploading Data Blocks to phone... Block Write Successful... CONTENT Data Blocks uploaded to phone... Processing Section 02 CONTENT Erase Block: 0x43E60000~0x43F3FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Data Verification Successful... Total Flashing Time (Erase + Flashing) : 00:05:44 (Booting time is NOT Included) Waiting for Phone to Start-Up..(Max 150 seconds) WARNING: Phone is not in the Required Mode... Disconnect the Phone and Power it Up Manually. Scanning USB Ports... ====================================================== ERROR: Active Phone Handle was NOT DETECTED ====================================================== TIP: Make sure that Phone USB Connection Mode is OVI Suite Mode or PC Suite Mode ====================================================== ====================================================== Selected VPL File: RM799_059P147_11.81_004.vpl ====================================================== Variant Details : RM-799 VAR EURO-C7 PT VODAFONE SL PINK Software Version : 11.81 Product Type : RM-799 Product Code : 059P147 Variant Version : 004 PLZ HELP |
