Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 04-15-2013, 09:26   #1 (permalink)
moon_sns's Avatar
Member: 1297994
Sonork: 100.1614596
Thanks Meter: 32
Nokia 205 RM-862 successfully flash by ATF
no error.ATF is best device for Nokia
The Following User Says Thank You to moon_sns For This Useful Post:
Old 04-15-2013, 10:10   #2 (permalink)
himanshu taldar's Avatar
Member: 422762
Sonork: 100.1593904
Thanks Meter: 958
where to download rm-862 flash file, could not find it on ATF support site.
Old 04-15-2013, 10:22   #3 (permalink)
Member: 762819
Thanks Meter: 230
Dear, u can easily find flash files in NaviFirm Plus. Download it from there.
Old 04-15-2013, 10:22   #4 (permalink)
moon_sns's Avatar
Member: 1297994
Sonork: 100.1614596
Thanks Meter: 32
download file by Navifirm
Old 04-15-2013, 10:23   #5 (permalink)
chandan_123's Avatar
Member: 801212
Sonork: 100.1657902
Thanks Meter: 646
Bro use latest navifirm............1.7ver
Old 04-15-2013, 10:27   #6 (permalink)
Member: 422762
Sonork: 100.1593904
Thanks Meter: 958
I am using navifirmplus 1.7 by epicbuzines, there is no flash file for rm-862.
which navifirm u are using?
Edit - Thanks i got it navifirm 1.9 found Flash files.
br
Old 04-15-2013, 11:00   #7 (permalink)
moon_sns's Avatar
Member: 1297994
Sonork: 100.1614596
Thanks Meter: 32
see this bro and click thanks
Old 12-05-2013, 10:44   #8 (permalink)
Member: 2029498
Thanks Meter: 9
Number of Image Files: 3
Processing Image File :
rm862__04.51.mcusw
rm862__04.51.ppm_c6
rm862__04.51.image_c6_059P9W6
AUTO SELECTED DEAD USB FLASHING...
If Phone Booting does not Start in 5 Seconds,
Then Perform Steps 1, 2, 3 and 4...
1. Remove USB and Battery...
2. Insert USB.
3. Insert Battery. (Some phones boot automatically)
4. Please Power on phone shortly...
Unable to detect "Nokia USB Flashing Generic"
Old 12-26-2013, 13:09   #9 (permalink)
Formingus's Avatar
Member: 322417
Thanks Meter: 737
rm862__04.51.mcusw
rm862__04.51.ppm_c6
2. Insert USB.
Change USB Port at last worked for me
rm863__04.51.mcusw
rm863__04.51.ppm_c6
rm863__04.51.image_c6_059Q199
2. Insert USB.
Infineon USB Boot: F00A1FB300020303010100FF
Sending PBL...
PBL Successfully Sent...
Sending SBL...
SBL Successfully Sent...
Setting Transmission Speed Done...
Flash Chip Manufacturer: Intel Electronics Corp.
Flash Boot Successful...
Unique Data: 02502418A9062824
Original Product Code: 059Q199
Reading : CCC... OK!
Reading : HWC... OK!
Reading : NPC... OK!
RPL Backup was Successful...
Plain RPL saved to:
C:\AdvanceBox Turbo Flasher\Nokia\Backup\353700054190804\3537000541908 04_20829.rpl
Certificate Block Saved to:
C:\AdvanceBox Turbo Flasher\Nokia\Backup\353700054190804\3537000541908 04_CERTIFICATE_E6C67838.bin
PM Block Saved to:
C:\AdvanceBox Turbo Flasher\Nokia\Backup\353700054190804\3537000541908 04_PMM_PROT_82F96625.bin
Security Code: 12345
Data Sections : 04
Current File : rm863__04.51.mcusw
Compile Name: rm863__04.51.mcusw_ebl_psi.fls
Image Type : Main Firmware
Data Size : 25955720 Bytes
Sending Certificate Block
FIRMWARE Certificate Block Sent Successfully...
Processing Section 01
FIRMWARE Erase Block: 0x40000000~0x4001FFFE
Start Erasing...
Erasing Please Wait...
Block Erase Done...
Preparing Data Blocks...
Data Size: 131072 bytes
Data Checksum: 274A
Uploading Data Blocks to phone...
Block Write Successful...
FIRMWARE Data Blocks uploaded to phone...
Processing Section 02
FIRMWARE Erase Block: 0x40040000~0x4005FFFE
Start Erasing...
Block Erase Done...
Data Checksum: 7A62
Processing Section 03
FIRMWARE Erase Block: 0x40060000~0x4015FFFE
Start Erasing...
Block Erase Done...
Data Size: 1048576 bytes
Data Checksum: A90B
Processing Section 04
FIRMWARE Erase Block: 0x40280000~0x419FFFFE
Start Erasing...
Block Erase Done...
Data Size: 24641536 bytes
Data Checksum: ED10
Processing Section 05
FIRMWARE Erase Block: 0x43E20000~0x43E5FFFE
Start Erasing...
Block Erase Done...
Data Verification Successful...
Data Sections : 01
Current File : rm863__04.51.ppm_c6
Compile Name: package_c6.ppm_ebl_psi.fls
Image Type : PPM Image
Data Size : 4482820 Bytes
PPM Certificate Block Sent Successfully...
PPM Erase Block: 0x41A00000~0x4203FFFE
Start Erasing...
Block Erase Done...
Data Size: 4479476 bytes
Data Checksum: B8D7
PPM Data Blocks uploaded to phone...
Data Sections : 01
Current File : rm863__04.51.image_c6_059Q199
Compile Name: package_c6_059Q199.image.fls
Image Type : CONTENT Package
Data Size : 16387344 Bytes
CONTENT Certificate Block Sent Successfully...
CONTENT Erase Block: 0x42040000~0x43E1FFFE
Start Erasing...
Block Erase Done...
Data Size: 16384000 bytes
Data Checksum: A7EB
CONTENT Data Blocks uploaded to phone...
CONTENT Erase Block: 0x43E60000~0x43F3FFFE
Start Erasing...
Block Erase Done...
Total Flashing Time (Erase + Flashing) : 00:06:30
(Booting time is NOT Included)
Waiting for Phone to Start-Up..(Max 150 seconds)
Br Formingus
Old 05-17-2014, 16:05   #10 (permalink)
Member: 1320421
Thanks Meter: 6
I use ATF v11.20 but infineon list not found Nokia 205 Rm-862
Anyone help me
can i update
Old 05-17-2014, 16:31   #11 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Thanks Meter: 16,486
Anyone help me
can i update
Nokia 205 is inside Infineon Tab... Install Full Setup v11.30, FULL SETUP and DO NOT JUST UPDATE EXE
Page generated in 0.32915 seconds with 8 queries
