10-29-2014, 13:03 | #1 (permalink) |
No Life Poster Join Date: May 2011 Location: KPK Mardan Age: 36
Member: 1582572 Status: Offline Sonork: 100.1609641 Thanks Meter: 573 | Nokia 206 Security Test Failed ? ================================================ Basic Phone Information ================================================ MCU Version: V 04.52 30-06-13 RM-872 (c) Nokia IMEI Plain : 353660064208600 IMEI Spare : A353660064208600 IMEI SV : 33536600642086011F IMEI (2nd) : 353660064208618 IMEI Spare : A353660064208610 IMEI SV : 33536600642086111F Phone Model: KŪ 206 Category : Entry Phone Type : RM-872 ================================================ Extended Phone Information ================================================ Product Serial Number: 5EBE4F4BH Product Code : 059Q4L3 Module Code : 0205283 Basic Production Code: 059P6H2 Long Production SN : 0 PPM SW Version : V 04.52 30-06-13 RM-872 (c) Nokia M2 BT MCM Version : 19b5-22012 MCU SW Version : V 04.52 30-06-13 RM-872 (c) Nokia HW Version : 1601 RFIC Version : 68 LCD Version : TPO Content Pack Version : Content: m2_059Q4J7 V 04.52 30-06-13 RM-872 (c) Nokia Bluetooth ID : 20:A9:9B5:8A6 CS Type : GSM900, GSM1800 ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 800000000004000B ASIC : 11 PROVIDER : Default Test Operator LOCK COUNTERS: KEYPRESS 0/3, FBUS 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK_TYPE : PA_SIMLOC30 (20-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : FAILED > Try SX4 "PM AUTH" > Then Write PM 1 and 309 SECURITY_CODE : 12345 PHONE_MODE : TEST ================================================ Dynamic Camera Configuration ================================================ DCC ID : 01029704 DCC Ver: 008013 |
10-30-2014, 16:37 | #2 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Solution: 1. Backup Full PM of this phone 2. Get Full PM from the same model and REMOVE PM120 (SIMLOCK) from it 3. Bus Check phone to get TEST MODE and then Write Full PM without PM120 4. Factory Reset Phone Follow these 4 steps and than Scan Phone... ان شاء الله Security Test will be Passed |
The Following User Says Thank You to ..::Angel::.. For This Useful Post: |
10-30-2014, 16:45 | #3 (permalink) | |
No Life Poster Join Date: Jan 2014 Location: Pakistan Age: 26
Member: 2105681 Status: Offline Sonork: Stoped Using... Thanks Meter: 909 | Quote:
02-20-2015, 08:27 | #7 (permalink) |
Member: 1582572 Status: Offline Sonork: 100.1609641 Thanks Meter: 573 | Field : 3 Sub : 0 Byte(s): 4 - Ok Field : 4 Sub : 3 Byte(s): 12 - Ok Field : 4 Sub : 4 Byte(s): 8 - Ok Field : 4 Sub : 5 Byte(s): 8 - Ok Field : 4 Sub : 6 Byte(s): 8 - Ok Field : 4 Sub : 9 Byte(s): 8 - Ok Field : 4 Sub : 18 Byte(s): 80 - Ok Field : 4 Sub : 19 Byte(s): 4 - Ok Field : 4 Sub : 26 Byte(s): 132 - Ok Field : 8 Sub : 0 Byte(s): 4 - Ok Field : 8 Sub : 1 Byte(s): 16 - Ok Field : 8 Sub : 2 Byte(s): 16 - Ok Field : 8 Sub : 3 Byte(s): 128 - Ok Field : 8 Sub : 4 Byte(s): 128 - Ok Field : 8 Sub : 7 Byte(s): 4 - Ok Field : 8 Sub : 8 Byte(s): 8 - Ok Field : 8 Sub : 9 Byte(s): 8 - Ok Field : 8 Sub : 10 Byte(s): 32 - Ok Field : 8 Sub : 11 Byte(s): 4 - Ok Field : 8 Sub : 12 Byte(s): 4 - Ok Field : 11 Sub : 0 Byte(s): 4 - Ok Field : 11 Sub : 1 Byte(s): 4 - Ok Field : 11 Sub : 2 Byte(s): 4 - Ok Field : 11 Sub : 3 Byte(s): 4 - Ok Field : 11 Sub : 4 Byte(s): 244 - Ok Field : 13 Sub : 0 Byte(s): 4 - Ok Field : 13 Sub : 1 Byte(s): 4 - Ok Field : 13 Sub : 2 Byte(s): 4 - Ok Field : 13 Sub : 3 Byte(s): 4 - Ok Field : 13 Sub : 4 Byte(s): 4 - Ok Field : 13 Sub : 5 Byte(s): 4 - Ok Field : 13 Sub : 6 Byte(s): 4 - Ok Field : 13 Sub : 7 Byte(s): 4 - Ok Field : 13 Sub : 8 Byte(s): 4 - Ok Field : 13 Sub : 9 Byte(s): 4 - Ok Field : 13 Sub : 10 Byte(s): 4 - Ok Field : 13 Sub : 11 Byte(s): 48 - Ok Field : 13 Sub : 12 Byte(s): 4 - Ok Field : 13 Sub : 13 Byte(s): 4 - Ok Field : 13 Sub : 14 Byte(s): 4 - Ok Field : 13 Sub : 15 Byte(s): 888 - Ok Field : 13 Sub : 16 Byte(s): 4 - Ok Field : 13 Sub : 17 Byte(s): 4 - Ok Field : 13 Sub : 18 Byte(s): 4 - Ok Field : 13 Sub : 19 Byte(s): 8 - Ok Field : 13 Sub : 20 Byte(s): 4 - Ok Field : 13 Sub : 21 Byte(s): 4 - Ok Field : 13 Sub : 22 Byte(s): 4 - Ok Field : 13 Sub : 23 Byte(s): 4 - Ok Field : 13 Sub : 24 Byte(s): 4 - Ok Field : 13 Sub : 25 Byte(s): 4 - Ok Field : 13 Sub : 26 Byte(s): 4 - Ok Field : 13 Sub : 27 Byte(s): 4 - Ok Field : 13 Sub : 28 Byte(s): 4 - Ok Field : 13 Sub : 29 Byte(s): 4 - Ok Field : 13 Sub : 30 Byte(s): 4 - Ok Field : 13 Sub : 31 Byte(s): 4 - Ok Field : 13 Sub : 32 Byte(s): 4 - Ok Field : 13 Sub : 33 Byte(s): 4 - Ok Field : 13 Sub : 34 Byte(s): 4 - Ok Field : 13 Sub : 35 Byte(s): 4 - Ok Field : 13 Sub : 36 Byte(s): 4 - Ok Field : 13 Sub : 37 Byte(s): 4 - Ok Field : 13 Sub : 38 Byte(s): 4 - Ok Field : 13 Sub : 39 Byte(s): 4 - Ok Field : 13 Sub : 40 Byte(s): 4 - Ok Field : 13 Sub : 41 Byte(s): 4 - Ok Field : 13 Sub : 42 Byte(s): 4 - Ok Field : 13 Sub : 43 Byte(s): 4 - Ok Field : 13 Sub : 44 Byte(s): 4 - Ok Field : 13 Sub : 45 Byte(s): 4 - Ok Field : 13 Sub : 46 Byte(s): 4 - Ok Field : 13 Sub : 47 Byte(s): 4 - Ok Field : 13 Sub : 48 Byte(s): 4 - Ok Field : 13 Sub : 49 Byte(s): 4 - Ok Field : 13 Sub : 50 Byte(s): 4 - Ok Field : 13 Sub : 51 Byte(s): 4 - Ok Field : 13 Sub : 52 Byte(s): 4 - Ok Field : 13 Sub : 53 Byte(s): 4 - Ok Field : 13 Sub : 54 Byte(s): 4 - Ok Field : 13 Sub : 55 Byte(s): 4 - Ok Field : 13 Sub : 56 Byte(s): 4 - Ok Field : 13 Sub : 57 Byte(s): 4 - Ok Field : 13 Sub : 58 Byte(s): 4 - Ok Field : 13 Sub : 59 Byte(s): 4 - Ok Field : 13 Sub : 60 Byte(s): 4 - Ok Field : 13 Sub : 61 Byte(s): 4 - Ok Field : 13 Sub : 62 Byte(s): 4 - Ok Field : 13 Sub : 63 Byte(s): 4 - Ok Field : 13 Sub : 64 Byte(s): 4 - Ok Field : 13 Sub : 65 Byte(s): 4 - Ok Field : 13 Sub : 66 Byte(s): 4 - Ok Field : 13 Sub : 67 Byte(s): 4 - Ok Field : 13 Sub : 68 Byte(s): 4 - Ok Field : 13 Sub : 69 Byte(s): 4 - Ok Field : 13 Sub : 70 Byte(s): 4 - Ok Field : 13 Sub : 71 Byte(s): 4 - Ok Field : 13 Sub : 72 Byte(s): 4 - Ok Field : 13 Sub : 73 Byte(s): 4 - Ok Field : 13 Sub : 74 Byte(s): 4 - Ok Field : 13 Sub : 75 Byte(s): 4 - Ok Field : 13 Sub : 76 Byte(s): 4 - Ok Field : 13 Sub : 77 Byte(s): 4 - Ok Field : 13 Sub : 78 Byte(s): 4 - Ok Field : 13 Sub : 79 Byte(s): 4 - Ok Field : 13 Sub : 80 Byte(s): 4 - Ok Field : 13 Sub : 81 Byte(s): 4 - Ok Field : 13 Sub : 82 Byte(s): 4 - Ok Field : 13 Sub : 83 Byte(s): 4 - Ok Field : 13 Sub : 84 Byte(s): 4 - Ok Field : 13 Sub : 85 Byte(s): 4 - Ok Field : 13 Sub : 86 Byte(s): 4 - Ok Field : 13 Sub : 87 Byte(s): 4 - Ok Field : 13 Sub : 88 Byte(s): 4 - Ok Field : 13 Sub : 89 Byte(s): 4 - Ok Field : 13 Sub : 90 Byte(s): 4 - Ok Field : 13 Sub : 91 Byte(s): 4 - Ok Field : 13 Sub : 92 Byte(s): 4 - Ok Field : 13 Sub : 93 Byte(s): 4 - Ok Field : 13 Sub : 94 Byte(s): 4 - Ok Field : 13 Sub : 95 Byte(s): 4 - Ok Field : 13 Sub : 96 Byte(s): 4 - Ok Field : 13 Sub : 97 Byte(s): 4 - Ok Field : 13 Sub : 98 Byte(s): 4 - Ok Field : 13 Sub : 99 Byte(s): 4 - Ok Field : 13 Sub : 100 Byte(s): 4 - Ok Field : 13 Sub : 101 Byte(s): 4 - Ok Field : 13 Sub : 102 Byte(s): 4 - Ok Field : 13 Sub : 103 Byte(s): 4 - Ok Field : 13 Sub : 104 Byte(s): 4 - Ok Field : 13 Sub : 105 Byte(s): 4 - Ok Field : 13 Sub : 106 Byte(s): 4 - Ok Field : 13 Sub : 107 Byte(s): 4 - Ok Field : 13 Sub : 108 Byte(s): 4 - Ok Field : 13 Sub : 109 Byte(s): 4 - Ok Field : 13 Sub : 110 Byte(s): 4 - Ok Field : 13 Sub : 111 Byte(s): 4 - Ok Field : 13 Sub : 112 Byte(s): 4 - Ok Field : 13 Sub : 113 Byte(s): 4 - Ok Field : 13 Sub : 114 Byte(s): 4 - Ok Field : 13 Sub : 115 Byte(s): 4 - Ok Field : 13 Sub : 116 Byte(s): 4 - Ok Field : 13 Sub : 117 Byte(s): 4 - Ok Field : 13 Sub : 118 Byte(s): 4 - Ok Field : 13 Sub : 119 Byte(s): 4 - Ok Field : 13 Sub : 120 Byte(s): 4 - Ok Field : 13 Sub : 121 Byte(s): 4 - Ok Field : 13 Sub : 122 Byte(s): 4 - Ok Field : 13 Sub : 123 Byte(s): 8 - Ok Field : 13 Sub : 124 Byte(s): 4 - Ok Field : 13 Sub : 125 Byte(s): 4 - Ok Field : 13 Sub : 126 Byte(s): 4 - Ok Field : 13 Sub : 127 Byte(s): 4 - Ok Field : 13 Sub : 128 Byte(s): 4 - Ok Field : 13 Sub : 129 Byte(s): 4 - Ok Field : 13 Sub : 130 Byte(s): 4 - Ok Field : 13 Sub : 131 Byte(s): 4 - Ok Field : 13 Sub : 132 Byte(s): 4 - Ok Field : 13 Sub : 133 Byte(s): 4 - Ok Field : 13 Sub : 134 Byte(s): 4 - Ok Field : 13 Sub : 135 Byte(s): 4 - Ok Field : 13 Sub : 136 Byte(s): 4 - Ok Field : 13 Sub : 137 Byte(s): 4 - Ok Field : 13 Sub : 138 Byte(s): 4 - Ok Field : 13 Sub : 139 Byte(s): 4 - Ok Field : 13 Sub : 140 Byte(s): 4 - Ok Field : 13 Sub : 141 Byte(s): 4 - Ok Field : 13 Sub : 142 Byte(s): 4 - Ok Field : 13 Sub : 143 Byte(s): 4 - Ok Field : 13 Sub : 144 Byte(s): 4 - Ok Field : 13 Sub : 145 Byte(s): 8 - Ok Field : 13 Sub : 146 Byte(s): 4 - Ok Field : 13 Sub : 147 Byte(s): 4 - Ok Field : 13 Sub : 148 Byte(s): 4 - Ok Field : 13 Sub : 149 Byte(s): 4 - Ok Field : 13 Sub : 150 Byte(s): 4 - Ok Field : 13 Sub : 151 Byte(s): 4 - Ok Field : 13 Sub : 152 Byte(s): 4 - Ok Field : 13 Sub : 153 Byte(s): 4 - Ok Field : 13 Sub : 154 Byte(s): 4 - Ok Field : 13 Sub : 155 Byte(s): 4 - Ok Field : 13 Sub : 156 Byte(s): 4 - Ok Field : 13 Sub : 157 Byte(s): 4 - Ok Field : 13 Sub : 158 Byte(s): 4 - Ok Field : 13 Sub : 159 Byte(s): 4 - Ok Field : 13 Sub : 160 Byte(s): 4 - Ok Field : 13 Sub : 161 Byte(s): 4 - Ok Field : 13 Sub : 162 Byte(s): 4 - Ok Field : 13 Sub : 163 Byte(s): 4 - Ok Field : 13 Sub : 164 Byte(s): 4 - Ok Field : 13 Sub : 165 Byte(s): 4 - Ok Field : 13 Sub : 166 Byte(s): 4 - Ok Field : 24 Sub : 0 Byte(s): 4 - Ok Field : 42 Sub : 0 Byte(s): 4 - Ok Field : 42 Sub : 1 Byte(s): 12 - Ok Field : 42 Sub : 2 Byte(s): 36 - Ok Field : 42 Sub : 3 Byte(s): 36 - Ok Field : 42 Sub : 4 Byte(s): 36 - Ok Field : 42 Sub : 5 Byte(s): 36 - Ok Field : 42 Sub : 6 Byte(s): 36 - Ok Field : 42 Sub : 7 Byte(s): 40 - Ok Field : 42 Sub : 8 Byte(s): 40 - Ok Field : 42 Sub : 9 Byte(s): 40 - Ok Field : 42 Sub : 10 Byte(s): 40 - Ok Field : 42 Sub : 11 Byte(s): 40 - Ok Field : 42 Sub : 12 Byte(s): 40 - Ok Field : 42 Sub : 13 Byte(s): 40 - Ok Field : 42 Sub : 14 Byte(s): 40 - Ok Field : 42 Sub : 15 Byte(s): 40 - Ok Field : 42 Sub : 16 Byte(s): 40 - Ok Field : 42 Sub : 17 Byte(s): 40 - Ok Field : 42 Sub : 18 Byte(s): 40 - Ok Field : 42 Sub : 19 Byte(s): 40 - Ok Field : 42 Sub : 20 Byte(s): 40 - Ok Field : 42 Sub : 21 Byte(s): 40 - Ok Field : 42 Sub : 22 Byte(s): 40 - Ok Field : 42 Sub : 23 Byte(s): 40 - Ok Field : 42 Sub : 24 Byte(s): 40 - Ok Field : 42 Sub : 25 Byte(s): 40 - Ok Field : 42 Sub : 26 Byte(s): 40 - Ok Field : 49 Sub : 1 Byte(s): 4 - Ok Field : 49 Sub : 2 Byte(s): 4 - Ok Field : 54 Sub : 0 Byte(s): 4 - Ok Field : 54 Sub : 2 Byte(s): 24 - Ok Field : 96 Sub : 0 Byte(s): 4 - Ok Field : 96 Sub : 1 Byte(s): 20 - Ok Field : 107 Sub : 0 Byte(s): 24 - Ok Field : 107 Sub : 1 Byte(s): 92 - Ok Field : 107 Sub : 2 Byte(s): 72 - Ok Field : 107 Sub : 3 Byte(s): 72 - Ok Field : 107 Sub : 25 Byte(s): 136 - Ok Field : 107 Sub : 26 Byte(s): 12 - Ok Field : 111 Sub : 1 Byte(s): 4 - Ok Field : 116 Sub : 0 Byte(s): 4 - Ok Field : 116 Sub : 1 Byte(s): 12 - Ok Field : 116 Sub : 2 Byte(s): 36 - Ok Field : 116 Sub : 3 Byte(s): 36 - Ok Field : 116 Sub : 4 Byte(s): 36 - Ok Field : 116 Sub : 5 Byte(s): 36 - Ok Field : 116 Sub : 6 Byte(s): 36 - Ok Field : 116 Sub : 7 Byte(s): 40 - Ok Field : 116 Sub : 8 Byte(s): 40 - Ok Field : 116 Sub : 9 Byte(s): 40 - Ok Field : 116 Sub : 10 Byte(s): 40 - Ok Field : 116 Sub : 11 Byte(s): 40 - Ok Field : 116 Sub : 12 Byte(s): 40 - Ok Field : 116 Sub : 13 Byte(s): 40 - Ok Field : 116 Sub : 14 Byte(s): 40 - Ok Field : 116 Sub : 15 Byte(s): 40 - Ok Field : 116 Sub : 16 Byte(s): 40 - Ok Field : 117 Sub : 5 Byte(s): 12 - Ok Field : 117 Sub : 6 Byte(s): 8 - Ok Field : 117 Sub : 16 Byte(s): 64 - Ok Field : 117 Sub : 22 Byte(s): 12 - Ok Field : 117 Sub : 23 Byte(s): 8 - Ok Field : 163 Sub : 0 Byte(s): 8 - Ok Field : 193 Sub : 2 Byte(s): 8 - Ok Field : 193 Sub : 3 Byte(s): 32 - Ok Field : 193 Sub : 4 Byte(s): 32 - Ok Field : 193 Sub : 9 Byte(s): 64 - Ok Field : 202 Sub : 0 Byte(s): 4 - Ok Field : 217 Sub : 0 Byte(s): 32 - Ok Field : 218 Sub : 0 Byte(s): 4 - Ok Field : 238 Sub : 1 Byte(s): 4 - Ok Field : 239 Sub : 0 Byte(s): 4 - Ok Field : 239 Sub : 1 Byte(s): 6912 - Ok Field : 239 Sub : 2 Byte(s): 6912 - Ok Field : 239 Sub : 3 Byte(s): 6912 - Ok Field : 239 Sub : 4 Byte(s): 6912 - Ok Field : 301 Sub : 0 Byte(s): 4 - Ok Field : 301 Sub : 1 Byte(s): 12 - Ok Field : 301 Sub : 2 Byte(s): 36 - Ok Field : 301 Sub : 3 Byte(s): 36 - Ok Field : 301 Sub : 4 Byte(s): 36 - Ok Field : 301 Sub : 5 Byte(s): 36 - Ok Field : 301 Sub : 6 Byte(s): 36 - Ok Field : 301 Sub : 7 Byte(s): 40 - Ok Field : 301 Sub : 8 Byte(s): 40 - Ok Field : 301 Sub : 9 Byte(s): 40 - Ok Field : 301 Sub : 10 Byte(s): 40 - Ok Field : 301 Sub : 11 Byte(s): 40 - Ok Field : 301 Sub : 12 Byte(s): 40 - Ok Field : 301 Sub : 13 Byte(s): 40 - Ok Field : 301 Sub : 14 Byte(s): 40 - Ok Field : 301 Sub : 15 Byte(s): 40 - Ok Field : 301 Sub : 16 Byte(s): 40 - Ok Field : 308 Sub : 0 Byte(s): 4 - Ok Field : 308 Sub : 1 Byte(s): 4 - Ok Field : 308 Sub : 3 Byte(s): 4 - Ok Field : 308 Sub : 4 Byte(s): 4 - Ok Field : 308 Sub : 5 Byte(s): 12 - Ok Field : 308 Sub : 6 Byte(s): 4 - Ok Field : 308 Sub : 7 Byte(s): 4 - Ok Field : 308 Sub : 8 Byte(s): 4 - Ok Field : 308 Sub : 9 Byte(s): 40 - Ok Field : 322 Sub : 0 Byte(s): 4 - Ok Field : 339 Sub : 0 Byte(s): 512 - Ok Field : 339 Sub : 1 Byte(s): 512 - Ok Field : 341 Sub : 0 Byte(s): 4 - Ok Field : 341 Sub : 5 Byte(s): 4 - Ok Field : 341 Sub : 6 Byte(s): 2380 - Ok Field : 354 Sub : 0 Byte(s): 20 - Ok Field : 355 Sub : 0 Byte(s): 22916 - Failed Field : 362 Sub : 0 Byte(s): 4 - Ok Field : 362 Sub : 1 Byte(s): 120 - Ok Field : 364 Sub : 0 Byte(s): 4 - Ok Field : 364 Sub : 1 Byte(s): 12 - Ok Field : 364 Sub : 2 Byte(s): 36 - Ok Field : 364 Sub : 3 Byte(s): 36 - Ok Field : 364 Sub : 4 Byte(s): 36 - Ok Field : 364 Sub : 5 Byte(s): 36 - Ok Field : 364 Sub : 6 Byte(s): 36 - Ok Field : 364 Sub : 7 Byte(s): 40 - Ok Field : 364 Sub : 8 Byte(s): 40 - Ok Field : 364 Sub : 9 Byte(s): 40 - Ok Field : 364 Sub : 10 Byte(s): 40 - Ok Field : 364 Sub : 11 Byte(s): 40 - Ok Field : 364 Sub : 12 Byte(s): 40 - Ok Field : 364 Sub : 13 Byte(s): 40 - Ok Field : 364 Sub : 14 Byte(s): 40 - Ok Field : 364 Sub : 15 Byte(s): 40 - Ok Field : 364 Sub : 16 Byte(s): 40 - Ok Field : 364 Sub : 17 Byte(s): 40 - Ok Field : 364 Sub : 18 Byte(s): 40 - Ok Field : 364 Sub : 19 Byte(s): 40 - Ok Field : 364 Sub : 20 Byte(s): 40 - Ok Field : 364 Sub : 21 Byte(s): 40 - Ok Field : 364 Sub : 22 Byte(s): 40 - Ok Field : 364 Sub : 23 Byte(s): 40 - Ok Field : 364 Sub : 24 Byte(s): 40 - Ok Field : 364 Sub : 25 Byte(s): 40 - Ok Field : 364 Sub : 26 Byte(s): 40 - Ok Field : 365 Sub : 0 Byte(s): 4 - Ok Field : 365 Sub : 1 Byte(s): 12 - Ok Field : 365 Sub : 2 Byte(s): 36 - Ok Field : 365 Sub : 3 Byte(s): 36 - Ok Field : 365 Sub : 4 Byte(s): 36 - Ok Field : 365 Sub : 5 Byte(s): 36 - Ok Field : 365 Sub : 6 Byte(s): 36 - Ok Field : 365 Sub : 7 Byte(s): 40 - Ok Field : 365 Sub : 8 Byte(s): 40 - Ok Field : 365 Sub : 9 Byte(s): 40 - Ok Field : 365 Sub : 10 Byte(s): 40 - Ok Field : 365 Sub : 11 Byte(s): 40 - Ok Field : 365 Sub : 12 Byte(s): 40 - Ok Field : 365 Sub : 13 Byte(s): 40 - Ok Field : 365 Sub : 14 Byte(s): 40 - Ok Field : 365 Sub : 15 Byte(s): 40 - Ok Field : 365 Sub : 16 Byte(s): 40 - Ok Field : 374 Sub : 0 Byte(s): 4 - Ok Field : 383 Sub : 1 Byte(s): 256 - Ok Field : 383 Sub : 3 Byte(s): 256 - Ok Field : 383 Sub : 4 Byte(s): 256 - Ok Field : 383 Sub : 5 Byte(s): 256 - Ok Field : 383 Sub : 6 Byte(s): 256 - Ok Field : 383 Sub : 7 Byte(s): 256 - Ok Field : 383 Sub : 8 Byte(s): 256 - Ok Field : 383 Sub : 9 Byte(s): 256 - Ok Field : 383 Sub : 10 Byte(s): 256 - Ok Field : 383 Sub : 11 Byte(s): 256 - Ok Field : 383 Sub : 12 Byte(s): 256 - Ok Field : 383 Sub : 13 Byte(s): 256 - Ok Field : 383 Sub : 14 Byte(s): 256 - Ok Field : 383 Sub : 15 Byte(s): 256 - Ok Field : 383 Sub : 16 Byte(s): 256 - Ok Field : 383 Sub : 17 Byte(s): 256 - Ok Field : 383 Sub : 18 Byte(s): 256 - Ok Field : 383 Sub : 19 Byte(s): 256 - Ok Field : 383 Sub : 20 Byte(s): 256 - Ok Field : 383 Sub : 21 Byte(s): 256 - Ok Field : 383 Sub : 22 Byte(s): 256 - Ok Field : 383 Sub : 23 Byte(s): 256 - Ok Field : 383 Sub : 24 Byte(s): 256 - Ok Field : 383 Sub : 25 Byte(s): 256 - Ok Field : 383 Sub : 26 Byte(s): 256 - Ok Field : 383 Sub : 27 Byte(s): 256 - Ok Field : 383 Sub : 28 Byte(s): 256 - Ok Field : 383 Sub : 29 Byte(s): 256 - Ok Field : 383 Sub : 30 Byte(s): 256 - Ok Field : 383 Sub : 31 Byte(s): 256 - Ok Field : 383 Sub : 32 Byte(s): 256 - Ok Field : 383 Sub : 33 Byte(s): 256 - Ok Field : 383 Sub : 34 Byte(s): 256 - Ok Field : 383 Sub : 35 Byte(s): 256 - Ok Field : 383 Sub : 36 Byte(s): 256 - Ok Field : 383 Sub : 37 Byte(s): 256 - Ok Field : 383 Sub : 38 Byte(s): 256 - Ok Field : 383 Sub : 39 Byte(s): 256 - Ok Field : 383 Sub : 40 Byte(s): 256 - Ok Field : 383 Sub : 41 Byte(s): 256 - Ok Field : 383 Sub : 42 Byte(s): 256 - Ok Field : 383 Sub : 43 Byte(s): 256 - Ok Field : 383 Sub : 44 Byte(s): 256 - Ok Field : 383 Sub : 45 Byte(s): 256 - Ok Field : 383 Sub : 46 Byte(s): 256 - Ok Field : 383 Sub : 47 Byte(s): 256 - Ok Field : 383 Sub : 48 Byte(s): 256 - Ok Field : 383 Sub : 49 Byte(s): 256 - Ok Field : 383 Sub : 50 Byte(s): 256 - Ok Field : 383 Sub : 51 Byte(s): 256 - Ok Field : 383 Sub : 52 Byte(s): 256 - Ok Field : 383 Sub : 53 Byte(s): 256 - Ok Field : 383 Sub : 54 Byte(s): 256 - Ok Field : 383 Sub : 55 Byte(s): 256 - Ok Field : 383 Sub : 56 Byte(s): 256 - Ok Field : 383 Sub : 57 Byte(s): 256 - Ok Field : 383 Sub : 58 Byte(s): 256 - Ok Field : 383 Sub : 59 Byte(s): 256 - Ok Field : 383 Sub : 60 Byte(s): 256 - Ok Field : 383 Sub : 61 Byte(s): 256 - Ok Field : 383 Sub : 62 Byte(s): 256 - Ok Field : 383 Sub : 63 Byte(s): 256 - Ok Field : 383 Sub : 64 Byte(s): 256 - Ok Field : 383 Sub : 65 Byte(s): 256 - Ok Field : 383 Sub : 66 Byte(s): 256 - Ok Field : 383 Sub : 67 Byte(s): 256 - Ok Field : 383 Sub : 68 Byte(s): 256 - Ok Field : 383 Sub : 69 Byte(s): 256 - Ok Field : 383 Sub : 70 Byte(s): 256 - Ok Field : 383 Sub : 71 Byte(s): 256 - Ok Field : 383 Sub : 72 Byte(s): 256 - Ok Field : 383 Sub : 73 Byte(s): 256 - Ok Field : 383 Sub : 74 Byte(s): 256 - Ok Field : 383 Sub : 75 Byte(s): 256 - Ok Field : 383 Sub : 76 Byte(s): 256 - Ok Field : 383 Sub : 77 Byte(s): 256 - Ok Field : 383 Sub : 78 Byte(s): 256 - Ok Field : 383 Sub : 79 Byte(s): 256 - Ok Field : 383 Sub : 80 Byte(s): 256 - Ok Field : 383 Sub : 81 Byte(s): 256 - Ok Field : 383 Sub : 82 Byte(s): 256 - Ok Field : 383 Sub : 83 Byte(s): 256 - Ok Field : 383 Sub : 84 Byte(s): 256 - Ok Field : 383 Sub : 85 Byte(s): 256 - Ok Field : 383 Sub : 86 Byte(s): 256 - Ok Field : 383 Sub : 87 Byte(s): 256 - Ok Field : 383 Sub : 88 Byte(s): 256 - Ok Field : 383 Sub : 89 Byte(s): 256 - Ok Field : 383 Sub : 90 Byte(s): 256 - Ok Field : 383 Sub : 91 Byte(s): 256 - Ok Field : 383 Sub : 92 Byte(s): 256 - Ok Field : 383 Sub : 93 Byte(s): 256 - Ok Field : 383 Sub : 94 Byte(s): 256 - Ok Field : 383 Sub : 95 Byte(s): 256 - Ok Field : 383 Sub : 96 Byte(s): 256 - Ok Field : 383 Sub : 97 Byte(s): 256 - Ok Field : 383 Sub : 98 Byte(s): 256 - Ok Field : 383 Sub : 99 Byte(s): 256 - Ok Field : 383 Sub : 100 Byte(s): 256 - Ok Field : 383 Sub : 101 Byte(s): 256 - Ok Field : 383 Sub : 102 Byte(s): 256 - Ok Field : 383 Sub : 103 Byte(s): 256 - Ok Field : 383 Sub : 104 Byte(s): 256 - Ok Field : 383 Sub : 105 Byte(s): 256 - Ok Field : 383 Sub : 106 Byte(s): 256 - Ok Field : 383 Sub : 107 Byte(s): 256 - Ok Field : 383 Sub : 108 Byte(s): 256 - Ok Field : 383 Sub : 109 Byte(s): 256 - Ok Field : 383 Sub : 110 Byte(s): 256 - Ok Field : 383 Sub : 111 Byte(s): 256 - Ok Field : 383 Sub : 112 Byte(s): 256 - Ok Field : 383 Sub : 113 Byte(s): 256 - Ok Field : 383 Sub : 114 Byte(s): 256 - Ok Field : 383 Sub : 115 Byte(s): 256 - Ok Field : 383 Sub : 116 Byte(s): 256 - Ok Field : 383 Sub : 117 Byte(s): 256 - Ok Field : 383 Sub : 118 Byte(s): 256 - Ok Field : 383 Sub : 119 Byte(s): 256 - Ok Field : 383 Sub : 120 Byte(s): 256 - Ok Field : 383 Sub : 121 Byte(s): 256 - Ok Field : 383 Sub : 122 Byte(s): 256 - Ok Field : 383 Sub : 123 Byte(s): 256 - Ok Field : 383 Sub : 124 Byte(s): 256 - Ok Field : 383 Sub : 125 Byte(s): 256 - Ok Field : 383 Sub : 126 Byte(s): 256 - Ok Field : 383 Sub : 127 Byte(s): 256 - Ok Field : 383 Sub : 128 Byte(s): 256 - Ok Field : 383 Sub : 129 Byte(s): 256 - Ok Field : 383 Sub : 130 Byte(s): 256 - Ok Field : 383 Sub : 131 Byte(s): 256 - Ok Field : 383 Sub : 132 Byte(s): 256 - Ok Field : 383 Sub : 133 Byte(s): 256 - Ok Field : 383 Sub : 134 Byte(s): 256 - Ok Field : 383 Sub : 135 Byte(s): 256 - Ok Field : 383 Sub : 136 Byte(s): 256 - Ok Field : 383 Sub : 137 Byte(s): 256 - Ok Field : 383 Sub : 138 Byte(s): 256 - Ok Field : 383 Sub : 139 Byte(s): 256 - Ok Field : 383 Sub : 140 Byte(s): 256 - Ok Field : 383 Sub : 141 Byte(s): 256 - Ok Field : 383 Sub : 142 Byte(s): 256 - Ok Field : 383 Sub : 143 Byte(s): 256 - Ok Field : 383 Sub : 144 Byte(s): 256 - Ok Field : 383 Sub : 145 Byte(s): 256 - Ok Field : 383 Sub : 146 Byte(s): 256 - Ok Field : 383 Sub : 147 Byte(s): 256 - Ok Field : 383 Sub : 148 Byte(s): 256 - Ok Field : 383 Sub : 149 Byte(s): 256 - Ok Field : 383 Sub : 150 Byte(s): 256 - Ok Field : 383 Sub : 151 Byte(s): 256 - Ok Field : 383 Sub : 152 Byte(s): 256 - Ok Field : 383 Sub : 153 Byte(s): 256 - Ok Field : 383 Sub : 154 Byte(s): 256 - Ok Field : 383 Sub : 155 Byte(s): 256 - Ok Field : 383 Sub : 156 Byte(s): 256 - Ok Field : 383 Sub : 157 Byte(s): 256 - Ok Field : 383 Sub : 158 Byte(s): 256 - Ok Field : 383 Sub : 159 Byte(s): 256 - Ok Field : 383 Sub : 160 Byte(s): 256 - Ok Field : 383 Sub : 161 Byte(s): 256 - Ok Field : 383 Sub : 162 Byte(s): 256 - Ok Field : 383 Sub : 163 Byte(s): 256 - Ok Field : 383 Sub : 164 Byte(s): 256 - Ok Field : 383 Sub : 165 Byte(s): 256 - Ok Field : 383 Sub : 166 Byte(s): 256 - Ok Field : 383 Sub : 167 Byte(s): 256 - Ok Field : 383 Sub : 168 Byte(s): 256 - Ok Field : 383 Sub : 169 Byte(s): 256 - Ok Field : 383 Sub : 170 Byte(s): 256 - Ok Field : 383 Sub : 171 Byte(s): 256 - Ok Field : 383 Sub : 172 Byte(s): 256 - Ok Field : 383 Sub : 173 Byte(s): 256 - Ok Field : 383 Sub : 174 Byte(s): 256 - Ok Field : 383 Sub : 175 Byte(s): 256 - Ok Field : 383 Sub : 176 Byte(s): 256 - Ok Field : 383 Sub : 177 Byte(s): 256 - Ok Field : 383 Sub : 178 Byte(s): 256 - Ok Field : 383 Sub : 179 Byte(s): 256 - Ok Field : 390 Sub : 0 Byte(s): 256 - Ok Field : 390 Sub : 1 Byte(s): 256 - Ok Field : 390 Sub : 2 Byte(s): 256 - Ok Field : 390 Sub : 3 Byte(s): 256 - Ok Field : 390 Sub : 4 Byte(s): 256 - Ok Field : 390 Sub : 5 Byte(s): 256 - Ok Field : 390 Sub : 6 Byte(s): 256 - Ok Field : 390 Sub : 7 Byte(s): 256 - Ok Field : 390 Sub : 8 Byte(s): 256 - Ok Field : 390 Sub : 9 Byte(s): 256 - Ok Field : 390 Sub : 10 Byte(s): 256 - Ok Field : 390 Sub : 11 Byte(s): 256 - Ok Field : 390 Sub : 12 Byte(s): 256 - Ok Field : 390 Sub : 13 Byte(s): 256 - Ok Field : 390 Sub : 14 Byte(s): 256 - Ok Field : 390 Sub : 15 Byte(s): 256 - Ok Field : 390 Sub : 16 Byte(s): 256 - Ok Field : 390 Sub : 17 Byte(s): 256 - Ok Field : 390 Sub : 18 Byte(s): 256 - Ok Field : 390 Sub : 19 Byte(s): 256 - Ok Field : 390 Sub : 20 Byte(s): 256 - Ok Field : 390 Sub : 21 Byte(s): 256 - Ok Field : 390 Sub : 22 Byte(s): 256 - Ok Field : 390 Sub : 23 Byte(s): 256 - Ok Field : 390 Sub : 24 Byte(s): 256 - Ok Field : 390 Sub : 25 Byte(s): 256 - Ok Field : 390 Sub : 26 Byte(s): 256 - Ok Field : 390 Sub : 27 Byte(s): 256 - Ok Field : 390 Sub : 28 Byte(s): 256 - Ok Field : 390 Sub : 29 Byte(s): 256 - Ok Field : 390 Sub : 30 Byte(s): 256 - Ok Field : 390 Sub : 31 Byte(s): 256 - Ok Field : 390 Sub : 32 Byte(s): 256 - Ok Field : 390 Sub : 33 Byte(s): 256 - Ok Field : 390 Sub : 34 Byte(s): 256 - Ok Field : 390 Sub : 35 Byte(s): 256 - Ok Field : 390 Sub : 36 Byte(s): 256 - Ok Field : 390 Sub : 37 Byte(s): 256 - Ok Field : 390 Sub : 38 Byte(s): 256 - Ok Field : 390 Sub : 39 Byte(s): 256 - Ok Field : 390 Sub : 40 Byte(s): 256 - Ok Field : 390 Sub : 41 Byte(s): 256 - Ok Field : 390 Sub : 42 Byte(s): 256 - Ok Field : 390 Sub : 43 Byte(s): 256 - Ok Field : 390 Sub : 44 Byte(s): 256 - Ok Field : 390 Sub : 45 Byte(s): 256 - Ok Field : 390 Sub : 46 Byte(s): 256 - Ok Field : 390 Sub : 47 Byte(s): 256 - Ok Field : 390 Sub : 48 Byte(s): 256 - Ok Field : 390 Sub : 49 Byte(s): 256 - Ok Field : 390 Sub : 50 Byte(s): 256 - Ok Field : 390 Sub : 51 Byte(s): 256 - Ok Field : 390 Sub : 52 Byte(s): 256 - Ok Field : 390 Sub : 53 Byte(s): 256 - Ok Field : 390 Sub : 54 Byte(s): 256 - Ok Field : 390 Sub : 55 Byte(s): 256 - Ok Field : 390 Sub : 56 Byte(s): 256 - Ok Field : 390 Sub : 57 Byte(s): 256 - Ok Field : 390 Sub : 58 Byte(s): 256 - Ok Field : 390 Sub : 59 Byte(s): 256 - Ok Field : 390 Sub : 60 Byte(s): 256 - Ok Field : 390 Sub : 61 Byte(s): 256 - Ok Field : 390 Sub : 62 Byte(s): 256 - Ok Field : 390 Sub : 63 Byte(s): 256 - Ok Field : 390 Sub : 64 Byte(s): 256 - Ok Field : 390 Sub : 65 Byte(s): 256 - Ok Field : 390 Sub : 66 Byte(s): 256 - Ok Field : 390 Sub : 67 Byte(s): 256 - Ok Field : 390 Sub : 68 Byte(s): 256 - Ok Field : 390 Sub : 69 Byte(s): 256 - Ok Field : 390 Sub : 70 Byte(s): 256 - Ok Field : 390 Sub : 71 Byte(s): 256 - Ok Field : 390 Sub : 72 Byte(s): 256 - Ok Field : 390 Sub : 73 Byte(s): 256 - Ok Field : 390 Sub : 74 Byte(s): 256 - Ok Field : 390 Sub : 75 Byte(s): 256 - Ok Field : 390 Sub : 76 Byte(s): 256 - Ok Field : 390 Sub : 77 Byte(s): 256 - Ok Field : 390 Sub : 78 Byte(s): 256 - Ok Field : 390 Sub : 79 Byte(s): 256 - Ok Field : 390 Sub : 80 Byte(s): 256 - Ok Field : 390 Sub : 81 Byte(s): 256 - Ok Field : 390 Sub : 82 Byte(s): 256 - Ok Field : 390 Sub : 83 Byte(s): 256 - Ok Field : 390 Sub : 84 Byte(s): 256 - Ok Field : 390 Sub : 85 Byte(s): 256 - Ok Field : 390 Sub : 86 Byte(s): 256 - Ok Field : 390 Sub : 87 Byte(s): 256 - Ok Field : 390 Sub : 88 Byte(s): 256 - Ok Field : 390 Sub : 89 Byte(s): 256 - Ok Field : 390 Sub : 90 Byte(s): 256 - Ok Field : 390 Sub : 91 Byte(s): 256 - Ok Field : 390 Sub : 92 Byte(s): 256 - Ok Field : 390 Sub : 93 Byte(s): 256 - Ok Field : 390 Sub : 94 Byte(s): 256 - Ok Field : 390 Sub : 95 Byte(s): 256 - Ok Field : 390 Sub : 96 Byte(s): 256 - Ok Field : 390 Sub : 97 Byte(s): 256 - Ok Field : 390 Sub : 98 Byte(s): 256 - Ok Field : 390 Sub : 99 Byte(s): 256 - Ok Field : 390 Sub : 100 Byte(s): 256 - Ok Field : 390 Sub : 101 Byte(s): 256 - Ok Field : 390 Sub : 102 Byte(s): 256 - Ok Field : 390 Sub : 103 Byte(s): 256 - Ok Field : 390 Sub : 104 Byte(s): 256 - Ok Field : 390 Sub : 105 Byte(s): 256 - Ok Field : 390 Sub : 106 Byte(s): 256 - Ok Field : 390 Sub : 107 Byte(s): 256 - Ok Field : 390 Sub : 108 Byte(s): 256 - Ok Field : 390 Sub : 109 Byte(s): 256 - Ok Field : 390 Sub : 110 Byte(s): 256 - Ok Field : 390 Sub : 111 Byte(s): 256 - Ok Field : 390 Sub : 112 Byte(s): 256 - Ok Field : 390 Sub : 113 Byte(s): 256 - Ok Field : 390 Sub : 114 Byte(s): 256 - Ok Field : 390 Sub : 115 Byte(s): 256 - Ok Field : 390 Sub : 116 Byte(s): 256 - Ok Field : 390 Sub : 117 Byte(s): 256 - Ok Field : 390 Sub : 118 Byte(s): 256 - Ok Field : 390 Sub : 119 Byte(s): 256 - Ok Field : 390 Sub : 120 Byte(s): 256 - Ok Field : 390 Sub : 121 Byte(s): 256 - Ok Field : 390 Sub : 122 Byte(s): 256 - Ok Field : 390 Sub : 123 Byte(s): 256 - Ok Field : 390 Sub : 124 Byte(s): 256 - Ok Field : 390 Sub : 125 Byte(s): 256 - Ok Field : 390 Sub : 126 Byte(s): 256 - Ok Field : 390 Sub : 127 Byte(s): 256 - Ok Field : 390 Sub : 128 Byte(s): 256 - Ok Field : 390 Sub : 129 Byte(s): 256 - Ok Field : 390 Sub : 130 Byte(s): 256 - Ok Field : 390 Sub : 131 Byte(s): 256 - Ok Field : 390 Sub : 132 Byte(s): 256 - Ok Field : 390 Sub : 133 Byte(s): 256 - Ok Field : 390 Sub : 134 Byte(s): 256 - Ok Field : 390 Sub : 135 Byte(s): 256 - Ok Field : 390 Sub : 136 Byte(s): 256 - Ok Field : 390 Sub : 137 Byte(s): 256 - Ok Field : 390 Sub : 138 Byte(s): 256 - Ok Field : 390 Sub : 139 Byte(s): 256 - Ok Field : 390 Sub : 140 Byte(s): 256 - Ok Field : 390 Sub : 141 Byte(s): 256 - Ok Field : 390 Sub : 142 Byte(s): 256 - Ok Field : 390 Sub : 143 Byte(s): 256 - Ok Field : 390 Sub : 144 Byte(s): 256 - Ok Field : 390 Sub : 145 Byte(s): 256 - Ok Field : 390 Sub : 146 Byte(s): 256 - Ok Field : 390 Sub : 147 Byte(s): 256 - Ok Field : 390 Sub : 148 Byte(s): 256 - Ok Field : 390 Sub : 149 Byte(s): 256 - Ok Field : 390 Sub : 150 Byte(s): 256 - Ok Field : 390 Sub : 151 Byte(s): 256 - Ok Field : 390 Sub : 152 Byte(s): 256 - Ok Field : 390 Sub : 153 Byte(s): 256 - Ok Field : 390 Sub : 154 Byte(s): 256 - Ok Field : 390 Sub : 155 Byte(s): 256 - Ok Field : 390 Sub : 156 Byte(s): 256 - Ok Field : 390 Sub : 157 Byte(s): 256 - Ok Field : 390 Sub : 158 Byte(s): 256 - Ok Field : 390 Sub : 159 Byte(s): 256 - Ok Field : 390 Sub : 160 Byte(s): 256 - Ok Field : 390 Sub : 161 Byte(s): 256 - Ok Field : 390 Sub : 162 Byte(s): 256 - Ok Field : 390 Sub : 163 Byte(s): 256 - Ok Field : 390 Sub : 164 Byte(s): 256 - Ok Field : 390 Sub : 165 Byte(s): 256 - Ok Field : 390 Sub : 166 Byte(s): 256 - Ok Field : 390 Sub : 167 Byte(s): 256 - Ok Field : 390 Sub : 168 Byte(s): 256 - Ok Field : 390 Sub : 169 Byte(s): 256 - Ok Field : 390 Sub : 170 Byte(s): 256 - Ok Field : 390 Sub : 171 Byte(s): 256 - Ok Field : 390 Sub : 172 Byte(s): 256 - Ok Field : 390 Sub : 173 Byte(s): 256 - Ok Field : 390 Sub : 174 Byte(s): 256 - Ok Field : 390 Sub : 175 Byte(s): 256 - Ok Field : 390 Sub : 176 Byte(s): 256 - Ok Field : 390 Sub : 177 Byte(s): 256 - Ok Field : 390 Sub : 178 Byte(s): 256 - Ok Field : 390 Sub : 179 Byte(s): 256 - Ok Field : 390 Sub : 180 Byte(s): 256 - Ok Field : 390 Sub : 181 Byte(s): 256 - Ok Field : 390 Sub : 182 Byte(s): 256 - Ok Field : 390 Sub : 183 Byte(s): 256 - Ok Field : 390 Sub : 184 Byte(s): 256 - Ok Field : 390 Sub : 185 Byte(s): 256 - Ok Field : 390 Sub : 186 Byte(s): 256 - Ok Field : 390 Sub : 187 Byte(s): 256 - Ok Field : 390 Sub : 188 Byte(s): 256 - Ok Field : 390 Sub : 189 Byte(s): 256 - Ok Field : 390 Sub : 190 Byte(s): 256 - Ok Field : 390 Sub : 191 Byte(s): 256 - Ok Field : 390 Sub : 192 Byte(s): 256 - Ok Field : 390 Sub : 193 Byte(s): 256 - Ok Field : 390 Sub : 194 Byte(s): 256 - Ok Field : 390 Sub : 195 Byte(s): 256 - Ok Field : 390 Sub : 196 Byte(s): 256 - Ok Field : 390 Sub : 197 Byte(s): 256 - Ok Field : 390 Sub : 198 Byte(s): 256 - Ok Field : 390 Sub : 199 Byte(s): 256 - Ok Field : 390 Sub : 200 Byte(s): 256 - Ok Field : 390 Sub : 201 Byte(s): 256 - Ok Field : 390 Sub : 202 Byte(s): 256 - Ok Field : 390 Sub : 203 Byte(s): 256 - Ok Field : 390 Sub : 204 Byte(s): 256 - Ok Field : 390 Sub : 205 Byte(s): 256 - Ok Field : 390 Sub : 206 Byte(s): 256 - Ok Field : 390 Sub : 207 Byte(s): 256 - Ok Field : 390 Sub : 208 Byte(s): 256 - Ok Field : 390 Sub : 209 Byte(s): 256 - Ok Field : 390 Sub : 210 Byte(s): 256 - Ok Field : 390 Sub : 211 Byte(s): 256 - Ok Field : 390 Sub : 212 Byte(s): 256 - Ok Field : 390 Sub : 213 Byte(s): 256 - Ok Field : 390 Sub : 214 Byte(s): 256 - Ok Field : 390 Sub : 215 Byte(s): 256 - Ok Field : 390 Sub : 216 Byte(s): 256 - Ok Field : 390 Sub : 217 Byte(s): 256 - Ok Field : 390 Sub : 218 Byte(s): 256 - Ok Field : 390 Sub : 219 Byte(s): 256 - Ok Field : 390 Sub : 220 Byte(s): 256 - Ok Field : 390 Sub : 221 Byte(s): 256 - Ok Field : 390 Sub : 222 Byte(s): 256 - Ok Field : 390 Sub : 223 Byte(s): 256 - Ok Field : 390 Sub : 224 Byte(s): 256 - Ok Field : 390 Sub : 225 Byte(s): 256 - Ok Field : 390 Sub : 226 Byte(s): 256 - Ok Field : 390 Sub : 227 Byte(s): 256 - Ok Field : 390 Sub : 228 Byte(s): 256 - Ok Field : 390 Sub : 229 Byte(s): 256 - Ok Field : 390 Sub : 230 Byte(s): 256 - Ok Field : 390 Sub : 231 Byte(s): 256 - Ok Field : 390 Sub : 232 Byte(s): 256 - Ok Field : 390 Sub : 233 Byte(s): 256 - Ok Field : 390 Sub : 234 Byte(s): 256 - Ok Field : 390 Sub : 235 Byte(s): 256 - Ok Field : 390 Sub : 236 Byte(s): 256 - Ok Field : 390 Sub : 237 Byte(s): 256 - Ok Field : 390 Sub : 238 Byte(s): 256 - Ok Field : 390 Sub : 239 Byte(s): 256 - Ok Field : 390 Sub : 240 Byte(s): 256 - Ok Field : 390 Sub : 241 Byte(s): 256 - Ok Field : 390 Sub : 242 Byte(s): 256 - Ok Field : 390 Sub : 243 Byte(s): 256 - Ok Field : 390 Sub : 244 Byte(s): 256 - Ok Field : 390 Sub : 245 Byte(s): 256 - Ok Field : 390 Sub : 246 Byte(s): 256 - Ok Field : 390 Sub : 247 Byte(s): 256 - Ok Field : 390 Sub : 248 Byte(s): 256 - Ok Field : 390 Sub : 249 Byte(s): 256 - Ok Field : 390 Sub : 250 Byte(s): 256 - Ok Field : 390 Sub : 251 Byte(s): 256 - Ok Field : 390 Sub : 252 Byte(s): 256 - Ok Field : 390 Sub : 253 Byte(s): 256 - Ok Field : 390 Sub : 254 Byte(s): 256 - Ok Field : 390 Sub : 255 Byte(s): 256 - Ok Field : 390 Sub : 256 Byte(s): 256 - Ok Field : 390 Sub : 257 Byte(s): 256 - Ok Field : 390 Sub : 258 Byte(s): 256 - Ok Field : 390 Sub : 259 Byte(s): 256 - Ok Field : 390 Sub : 260 Byte(s): 256 - Ok Field : 390 Sub : 261 Byte(s): 256 - Ok Field : 390 Sub : 262 Byte(s): 256 - Ok Field : 390 Sub : 263 Byte(s): 256 - Ok Field : 390 Sub : 264 Byte(s): 256 - Ok Field : 390 Sub : 265 Byte(s): 256 - Ok Field : 390 Sub : 266 Byte(s): 256 - Ok Field : 390 Sub : 267 Byte(s): 256 - Ok Field : 390 Sub : 268 Byte(s): 256 - Ok Field : 390 Sub : 269 Byte(s): 256 - Ok Field : 390 Sub : 270 Byte(s): 256 - Ok Field : 390 Sub : 271 Byte(s): 256 - Ok Field : 390 Sub : 272 Byte(s): 256 - Ok Field : 390 Sub : 273 Byte(s): 256 - Ok Field : 390 Sub : 274 Byte(s): 256 - Ok Field : 390 Sub : 275 Byte(s): 256 - Ok Field : 390 Sub : 276 Byte(s): 256 - Ok Field : 390 Sub : 277 Byte(s): 256 - Ok Field : 390 Sub : 278 Byte(s): 256 - Ok Field : 390 Sub : 279 Byte(s): 256 - Ok Field : 390 Sub : 280 Byte(s): 256 - Ok Field : 390 Sub : 281 Byte(s): 256 - Ok Field : 390 Sub : 282 Byte(s): 256 - Ok Field : 390 Sub : 283 Byte(s): 256 - Ok Field : 390 Sub : 284 Byte(s): 256 - Ok Field : 390 Sub : 285 Byte(s): 256 - Ok Field : 390 Sub : 286 Byte(s): 256 - Ok Field : 390 Sub : 287 Byte(s): 256 - Ok Field : 390 Sub : 288 Byte(s): 256 - Ok Field : 390 Sub : 289 Byte(s): 256 - Ok Field : 390 Sub : 290 Byte(s): 256 - Ok Field : 390 Sub : 291 Byte(s): 256 - Ok Field : 390 Sub : 292 Byte(s): 256 - Ok Field : 390 Sub : 293 Byte(s): 256 - Ok Field : 390 Sub : 294 Byte(s): 256 - Ok Field : 390 Sub : 295 Byte(s): 256 - Ok Field : 390 Sub : 296 Byte(s): 256 - Ok Field : 390 Sub : 297 Byte(s): 256 - Ok Field : 390 Sub : 298 Byte(s): 256 - Ok Field : 390 Sub : 299 Byte(s): 256 - Ok Field : 390 Sub : 300 Byte(s): 256 - Ok Field : 390 Sub : 301 Byte(s): 256 - Ok Field : 390 Sub : 302 Byte(s): 256 - Ok Field : 390 Sub : 303 Byte(s): 256 - Ok Field : 390 Sub : 304 Byte(s): 256 - Ok Field : 390 Sub : 305 Byte(s): 256 - Ok Field : 390 Sub : 306 Byte(s): 256 - Ok Field : 390 Sub : 307 Byte(s): 256 - Ok Field : 390 Sub : 308 Byte(s): 256 - Ok Field : 390 Sub : 309 Byte(s): 256 - Ok Field : 390 Sub : 310 Byte(s): 256 - Ok Field : 390 Sub : 311 Byte(s): 256 - Ok Field : 390 Sub : 312 Byte(s): 256 - Ok Field : 390 Sub : 313 Byte(s): 256 - Ok Field : 390 Sub : 314 Byte(s): 256 - Ok Field : 390 Sub : 315 Byte(s): 256 - Ok Field : 390 Sub : 316 Byte(s): 256 - Ok Field : 390 Sub : 317 Byte(s): 256 - Ok Field : 390 Sub : 318 Byte(s): 256 - Ok Field : 390 Sub : 319 Byte(s): 256 - Ok Field : 390 Sub : 320 Byte(s): 256 - Ok Field : 390 Sub : 321 Byte(s): 256 - Ok Field : 390 Sub : 322 Byte(s): 256 - Ok Field : 390 Sub : 323 Byte(s): 256 - Ok Field : 390 Sub : 324 Byte(s): 256 - Ok Field : 390 Sub : 325 Byte(s): 256 - Ok Field : 390 Sub : 326 Byte(s): 256 - Ok Field : 390 Sub : 327 Byte(s): 256 - Ok Field : 390 Sub : 328 Byte(s): 256 - Ok Field : 390 Sub : 329 Byte(s): 256 - Ok Field : 390 Sub : 330 Byte(s): 256 - Ok Field : 390 Sub : 331 Byte(s): 256 - Ok Field : 390 Sub : 332 Byte(s): 256 - Ok Field : 390 Sub : 333 Byte(s): 256 - Ok Field : 390 Sub : 334 Byte(s): 256 - Ok Field : 390 Sub : 335 Byte(s): 256 - Ok Field : 390 Sub : 336 Byte(s): 256 - Ok Field : 390 Sub : 337 Byte(s): 256 - Ok Field : 390 Sub : 338 Byte(s): 256 - Ok Field : 390 Sub : 339 Byte(s): 256 - Ok Field : 390 Sub : 340 Byte(s): 256 - Ok Field : 390 Sub : 341 Byte(s): 256 - Ok Field : 390 Sub : 342 Byte(s): 256 - Ok Field : 390 Sub : 343 Byte(s): 256 - Ok Field : 390 Sub : 344 Byte(s): 256 - Ok Field : 390 Sub : 345 Byte(s): 256 - Ok Field : 390 Sub : 346 Byte(s): 256 - Ok Field : 390 Sub : 347 Byte(s): 256 - Ok Field : 390 Sub : 348 Byte(s): 256 - Ok Field : 390 Sub : 349 Byte(s): 256 - Ok Field : 390 Sub : 350 Byte(s): 256 - Ok Field : 390 Sub : 351 Byte(s): 256 - Ok Field : 390 Sub : 352 Byte(s): 256 - Ok Field : 390 Sub : 353 Byte(s): 256 - Ok Field : 390 Sub : 354 Byte(s): 256 - Ok Field : 390 Sub : 355 Byte(s): 256 - Ok Field : 390 Sub : 356 Byte(s): 256 - Ok Field : 390 Sub : 357 Byte(s): 256 - Ok Field : 390 Sub : 358 Byte(s): 256 - Ok Field : 390 Sub : 359 Byte(s): 256 - Ok Field : 390 Sub : 360 Byte(s): 256 - Ok Field : 390 Sub : 361 Byte(s): 256 - Ok Field : 390 Sub : 362 Byte(s): 256 - Ok Field : 390 Sub : 363 Byte(s): 256 - Ok Field : 390 Sub : 364 Byte(s): 256 - Ok Field : 390 Sub : 365 Byte(s): 256 - Ok Field : 390 Sub : 366 Byte(s): 256 - Ok Field : 390 Sub : 367 Byte(s): 256 - Ok Field : 390 Sub : 368 Byte(s): 256 - Ok Field : 390 Sub : 369 Byte(s): 256 - Ok Field : 390 Sub : 370 Byte(s): 256 - Ok Field : 390 Sub : 371 Byte(s): 256 - Ok Field : 390 Sub : 372 Byte(s): 256 - Ok Field : 390 Sub : 373 Byte(s): 256 - Ok Field : 390 Sub : 374 Byte(s): 256 - Ok Field : 390 Sub : 375 Byte(s): 256 - Ok Field : 390 Sub : 376 Byte(s): 256 - Ok Field : 390 Sub : 377 Byte(s): 256 - Ok Field : 390 Sub : 378 Byte(s): 256 - Ok Field : 390 Sub : 379 Byte(s): 256 - Ok Field : 390 Sub : 380 Byte(s): 256 - Ok Field : 390 Sub : 381 Byte(s): 256 - Ok Field : 390 Sub : 382 Byte(s): 256 - Ok Field : 390 Sub : 383 Byte(s): 256 - Ok Field : 390 Sub : 384 Byte(s): 256 - Ok Field : 390 Sub : 385 Byte(s): 256 - Ok Field : 390 Sub : 386 Byte(s): 256 - Ok Field : 390 Sub : 387 Byte(s): 256 - Ok Field : 390 Sub : 388 Byte(s): 256 - Ok Field : 390 Sub : 389 Byte(s): 256 - Ok Field : 390 Sub : 390 Byte(s): 256 - Ok Field : 390 Sub : 391 Byte(s): 256 - Ok Field : 390 Sub : 392 Byte(s): 256 - Ok Field : 390 Sub : 393 Byte(s): 256 - Ok Field : 390 Sub : 394 Byte(s): 256 - Ok Field : 390 Sub : 395 Byte(s): 256 - Ok Field : 390 Sub : 396 Byte(s): 256 - Ok Field : 390 Sub : 397 Byte(s): 256 - Ok Field : 390 Sub : 398 Byte(s): 256 - Ok Field : 390 Sub : 399 Byte(s): 256 - Ok Field : 390 Sub : 400 Byte(s): 256 - Ok Field : 390 Sub : 401 Byte(s): 256 - Ok Field : 390 Sub : 402 Byte(s): 256 - Ok Field : 390 Sub : 403 Byte(s): 256 - Ok Field : 390 Sub : 404 Byte(s): 256 - Ok Field : 390 Sub : 405 Byte(s): 256 - Ok Field : 390 Sub : 406 Byte(s): 256 - Ok Field : 390 Sub : 407 Byte(s): 256 - Ok Field : 390 Sub : 408 Byte(s): 256 - Ok Field : 390 Sub : 409 Byte(s): 256 - Ok Field : 390 Sub : 410 Byte(s): 256 - Ok Field : 390 Sub : 411 Byte(s): 256 - Ok Field : 390 Sub : 412 Byte(s): 256 - Ok Field : 390 Sub : 413 Byte(s): 256 - Ok Field : 390 Sub : 414 Byte(s): 256 - Ok Field : 390 Sub : 415 Byte(s): 256 - Ok Field : 390 Sub : 416 Byte(s): 256 - Ok Field : 390 Sub : 417 Byte(s): 256 - Ok Field : 390 Sub : 418 Byte(s): 256 - Ok Field : 390 Sub : 419 Byte(s): 256 - Ok Field : 390 Sub : 420 Byte(s): 256 - Ok Field : 390 Sub : 421 Byte(s): 256 - Ok Field : 390 Sub : 422 Byte(s): 256 - Ok Field : 390 Sub : 423 Byte(s): 256 - Ok Field : 390 Sub : 424 Byte(s): 256 - Ok Field : 390 Sub : 425 Byte(s): 256 - Ok Field : 390 Sub : 426 Byte(s): 256 - Ok Field : 390 Sub : 427 Byte(s): 256 - Ok Field : 390 Sub : 428 Byte(s): 256 - Ok Field : 390 Sub : 429 Byte(s): 256 - Ok Field : 390 Sub : 430 Byte(s): 256 - Ok Field : 390 Sub : 431 Byte(s): 256 - Ok Field : 390 Sub : 432 Byte(s): 256 - Ok Field : 390 Sub : 433 Byte(s): 256 - Ok Field : 390 Sub : 434 Byte(s): 256 - Ok Field : 390 Sub : 435 Byte(s): 256 - Ok Field : 390 Sub : 436 Byte(s): 256 - Ok Field : 390 Sub : 437 Byte(s): 256 - Ok Field : 390 Sub : 438 Byte(s): 256 - Ok Field : 390 Sub : 439 Byte(s): 256 - Ok Field : 390 Sub : 440 Byte(s): 256 - Ok Field : 390 Sub : 441 Byte(s): 256 - Ok Field : 390 Sub : 442 Byte(s): 256 - Ok Field : 390 Sub : 443 Byte(s): 256 - Ok Field : 390 Sub : 444 Byte(s): 256 - Ok Field : 390 Sub : 445 Byte(s): 256 - Ok Field : 390 Sub : 446 Byte(s): 256 - Ok Field : 390 Sub : 447 Byte(s): 256 - Ok Field : 390 Sub : 448 Byte(s): 256 - Ok Field : 390 Sub : 449 Byte(s): 256 - Ok Field : 390 Sub : 450 Byte(s): 256 - Ok Field : 390 Sub : 451 Byte(s): 256 - Ok Field : 390 Sub : 452 Byte(s): 256 - Ok Field : 390 Sub : 453 Byte(s): 256 - Ok Field : 390 Sub : 454 Byte(s): 256 - Ok Field : 390 Sub : 455 Byte(s): 256 - Ok Field : 390 Sub : 456 Byte(s): 256 - Ok Field : 390 Sub : 457 Byte(s): 256 - Ok Field : 390 Sub : 458 Byte(s): 256 - Ok Field : 390 Sub : 459 Byte(s): 256 - Ok Field : 390 Sub : 460 Byte(s): 256 - Ok Field : 390 Sub : 461 Byte(s): 256 - Ok Field : 390 Sub : 462 Byte(s): 256 - Ok Field : 390 Sub : 463 Byte(s): 256 - Ok Field : 390 Sub : 464 Byte(s): 256 - Ok Field : 390 Sub : 465 Byte(s): 256 - Ok Field : 390 Sub : 466 Byte(s): 256 - Ok Field : 390 Sub : 467 Byte(s): 256 - Ok Field : 390 Sub : 468 Byte(s): 256 - Ok Field : 390 Sub : 469 Byte(s): 256 - Ok Field : 390 Sub : 470 Byte(s): 256 - Ok Field : 390 Sub : 471 Byte(s): 256 - Ok Field : 390 Sub : 472 Byte(s): 256 - Ok Field : 390 Sub : 473 Byte(s): 256 - Ok Field : 390 Sub : 474 Byte(s): 256 - Ok Field : 390 Sub : 475 Byte(s): 256 - Ok Field : 390 Sub : 476 Byte(s): 256 - Ok Field : 390 Sub : 477 Byte(s): 256 - Ok Field : 390 Sub : 478 Byte(s): 256 - Ok Field : 390 Sub : 479 Byte(s): 256 - Ok Field : 390 Sub : 480 Byte(s): 256 - Ok Field : 390 Sub : 481 Byte(s): 256 - Ok Field : 390 Sub : 482 Byte(s): 256 - Ok Field : 390 Sub : 483 Byte(s): 256 - Ok Field : 390 Sub : 484 Byte(s): 256 - Ok Field : 390 Sub : 485 Byte(s): 256 - Ok Field : 390 Sub : 486 Byte(s): 256 - Ok Field : 390 Sub : 487 Byte(s): 256 - Ok Field : 390 Sub : 488 Byte(s): 256 - Ok Field : 390 Sub : 489 Byte(s): 256 - Ok Field : 390 Sub : 490 Byte(s): 256 - Ok Field : 390 Sub : 491 Byte(s): 256 - Ok Field : 390 Sub : 492 Byte(s): 256 - Ok Field : 390 Sub : 493 Byte(s): 256 - Ok Field : 390 Sub : 494 Byte(s): 256 - Ok Field : 390 Sub : 495 Byte(s): 256 - Ok Field : 390 Sub : 496 Byte(s): 256 - Ok Field : 390 Sub : 497 Byte(s): 256 - Ok Field : 390 Sub : 498 Byte(s): 256 - Ok Field : 390 Sub : 499 Byte(s): 256 - Ok Field : 390 Sub : 500 Byte(s): 256 - Ok Field : 390 Sub : 501 Byte(s): 256 - Ok Field : 390 Sub : 502 Byte(s): 256 - Ok Field : 390 Sub : 503 Byte(s): 256 - Ok Field : 390 Sub : 504 Byte(s): 256 - Ok Field : 390 Sub : 505 Byte(s): 256 - Ok Field : 390 Sub : 506 Byte(s): 256 - Ok Field : 390 Sub : 507 Byte(s): 256 - Ok Field : 390 Sub : 508 Byte(s): 256 - Ok Field : 390 Sub : 509 Byte(s): 256 - Ok Field : 390 Sub : 510 Byte(s): 256 - Ok Field : 391 Sub : 0 Byte(s): 256 - Ok Field : 391 Sub : 2 Byte(s): 256 - Ok Field : 391 Sub : 3 Byte(s): 256 - Ok Field : 391 Sub : 4 Byte(s): 256 - Ok Field : 391 Sub : 5 Byte(s): 256 - Ok Field : 391 Sub : 6 Byte(s): 256 - Ok Field : 391 Sub : 7 Byte(s): 256 - Ok Field : 391 Sub : 8 Byte(s): 256 - Ok Field : 391 Sub : 9 Byte(s): 256 - Ok Field : 391 Sub : 10 Byte(s): 256 - Ok Field : 391 Sub : 11 Byte(s): 256 - Ok Field : 391 Sub : 12 Byte(s): 256 - Ok Field : 391 Sub : 13 Byte(s): 256 - Ok Field : 391 Sub : 14 Byte(s): 256 - Ok Field : 391 Sub : 15 Byte(s): 256 - Ok Field : 391 Sub : 16 Byte(s): 256 - Ok Field : 391 Sub : 17 Byte(s): 256 - Ok Field : 391 Sub : 18 Byte(s): 256 - Ok Field : 391 Sub : 19 Byte(s): 256 - Ok Field : 391 Sub : 20 Byte(s): 256 - Ok Field : 391 Sub : 21 Byte(s): 256 - Ok Field : 391 Sub : 22 Byte(s): 256 - Ok Field : 391 Sub : 23 Byte(s): 256 - Ok Field : 391 Sub : 24 Byte(s): 256 - Ok Field : 391 Sub : 25 Byte(s): 256 - Ok Field : 391 Sub : 26 Byte(s): 256 - Ok Field : 391 Sub : 27 Byte(s): 256 - Ok Field : 391 Sub : 28 Byte(s): 256 - Ok Field : 391 Sub : 29 Byte(s): 256 - Ok Field : 391 Sub : 30 Byte(s): 256 - Ok Field : 391 Sub : 31 Byte(s): 256 - Ok Field : 391 Sub : 32 Byte(s): 256 - Ok Field : 391 Sub : 33 Byte(s): 256 - Ok Field : 391 Sub : 34 Byte(s): 256 - Ok Field : 391 Sub : 35 Byte(s): 256 - Ok Field : 391 Sub : 36 Byte(s): 256 - Ok Field : 391 Sub : 37 Byte(s): 256 - Ok Field : 391 Sub : 38 Byte(s): 256 - Ok Field : 391 Sub : 39 Byte(s): 256 - Ok Field : 391 Sub : 40 Byte(s): 256 - Ok Field : 391 Sub : 41 Byte(s): 256 - Ok Field : 391 Sub : 42 Byte(s): 256 - Ok Field : 391 Sub : 43 Byte(s): 256 - Ok Field : 391 Sub : 44 Byte(s): 256 - Ok Field : 391 Sub : 45 Byte(s): 256 - Ok Field : 391 Sub : 46 Byte(s): 256 - Ok Field : 391 Sub : 47 Byte(s): 256 - Ok Field : 391 Sub : 48 Byte(s): 256 - Ok Field : 391 Sub : 49 Byte(s): 256 - Ok Field : 391 Sub : 50 Byte(s): 256 - Ok Field : 391 Sub : 51 Byte(s): 256 - Ok Field : 391 Sub : 52 Byte(s): 256 - Ok Field : 391 Sub : 53 Byte(s): 256 - Ok Field : 391 Sub : 54 Byte(s): 256 - Ok Field : 391 Sub : 55 Byte(s): 256 - Ok Field : 391 Sub : 56 Byte(s): 256 - Ok Field : 391 Sub : 57 Byte(s): 256 - Ok Field : 391 Sub : 58 Byte(s): 256 - Ok Field : 391 Sub : 59 Byte(s): 256 - Ok Field : 391 Sub : 60 Byte(s): 256 - Ok Field : 391 Sub : 61 Byte(s): 256 - Ok Field : 391 Sub : 62 Byte(s): 256 - Ok Field : 391 Sub : 63 Byte(s): 256 - Ok Field : 391 Sub : 64 Byte(s): 256 - Ok Field : 391 Sub : 65 Byte(s): 256 - Ok Field : 391 Sub : 66 Byte(s): 256 - Ok Field : 391 Sub : 67 Byte(s): 256 - Ok Field : 391 Sub : 68 Byte(s): 256 - Ok Field : 391 Sub : 69 Byte(s): 256 - Ok Field : 391 Sub : 70 Byte(s): 256 - Ok Field : 391 Sub : 71 Byte(s): 256 - Ok Field : 391 Sub : 72 Byte(s): 256 - Ok Field : 391 Sub : 73 Byte(s): 256 - Ok Field : 391 Sub : 74 Byte(s): 256 - Ok Field : 391 Sub : 75 Byte(s): 256 - Ok Field : 391 Sub : 76 Byte(s): 256 - Ok Field : 391 Sub : 77 Byte(s): 256 - Ok Field : 391 Sub : 78 Byte(s): 256 - Ok Field : 391 Sub : 79 Byte(s): 256 - Ok Field : 391 Sub : 80 Byte(s): 256 - Ok Field : 391 Sub : 81 Byte(s): 256 - Ok Field : 391 Sub : 82 Byte(s): 256 - Ok Field : 391 Sub : 83 Byte(s): 256 - Ok Field : 391 Sub : 84 Byte(s): 256 - Ok Field : 391 Sub : 85 Byte(s): 256 - Ok Field : 391 Sub : 86 Byte(s): 256 - Ok Field : 391 Sub : 87 Byte(s): 256 - Ok Field : 391 Sub : 88 Byte(s): 256 - Ok Field : 391 Sub : 89 Byte(s): 256 - Ok Field : 391 Sub : 90 Byte(s): 256 - Ok Field : 391 Sub : 91 Byte(s): 256 - Ok Field : 391 Sub : 92 Byte(s): 256 - Ok Field : 391 Sub : 93 Byte(s): 256 - Ok Field : 391 Sub : 94 Byte(s): 256 - Ok Field : 391 Sub : 95 Byte(s): 256 - Ok Field : 391 Sub : 96 Byte(s): 256 - Ok Field : 391 Sub : 97 Byte(s): 256 - Ok Field : 391 Sub : 98 Byte(s): 256 - Ok Field : 391 Sub : 99 Byte(s): 256 - Ok Field : 391 Sub : 100 Byte(s): 256 - Ok Field : 391 Sub : 101 Byte(s): 256 - Ok Field : 391 Sub : 102 Byte(s): 256 - Ok Field : 391 Sub : 103 Byte(s): 256 - Ok Field : 391 Sub : 104 Byte(s): 256 - Ok Field : 391 Sub : 105 Byte(s): 256 - Ok Field : 391 Sub : 106 Byte(s): 256 - Ok Field : 391 Sub : 107 Byte(s): 256 - Ok Field : 391 Sub : 108 Byte(s): 256 - Ok Field : 391 Sub : 109 Byte(s): 256 - Ok Field : 391 Sub : 110 Byte(s): 256 - Ok Field : 391 Sub : 111 Byte(s): 256 - Ok Field : 391 Sub : 112 Byte(s): 256 - Ok Field : 391 Sub : 113 Byte(s): 256 - Ok Field : 391 Sub : 114 Byte(s): 256 - Ok Field : 391 Sub : 115 Byte(s): 256 - Ok Field : 391 Sub : 116 Byte(s): 256 - Ok Field : 391 Sub : 117 Byte(s): 256 - Ok Field : 391 Sub : 118 Byte(s): 256 - Ok Field : 391 Sub : 119 Byte(s): 256 - Ok Field : 391 Sub : 120 Byte(s): 256 - Ok Field : 391 Sub : 121 Byte(s): 256 - Ok Field : 391 Sub : 122 Byte(s): 256 - Ok Field : 391 Sub : 123 Byte(s): 256 - Ok Field : 391 Sub : 124 Byte(s): 256 - Ok Field : 391 Sub : 125 Byte(s): 256 - Ok Field : 391 Sub : 126 Byte(s): 256 - Ok Field : 391 Sub : 127 Byte(s): 256 - Ok Field : 391 Sub : 128 Byte(s): 256 - Ok Field : 391 Sub : 129 Byte(s): 256 - Ok Field : 391 Sub : 130 Byte(s): 256 - Ok Field : 391 Sub : 131 Byte(s): 256 - Ok Field : 391 Sub : 132 Byte(s): 256 - Ok Field : 391 Sub : 133 Byte(s): 256 - Ok Field : 391 Sub : 134 Byte(s): 256 - Ok Field : 391 Sub : 135 Byte(s): 256 - Ok Field : 391 Sub : 136 Byte(s): 256 - Ok Field : 391 Sub : 137 Byte(s): 256 - Ok Field : 391 Sub : 138 Byte(s): 256 - Ok Field : 391 Sub : 139 Byte(s): 256 - Ok Field : 391 Sub : 140 Byte(s): 256 - Ok Field : 391 Sub : 141 Byte(s): 256 - Ok Field : 391 Sub : 142 Byte(s): 256 - Ok Field : 391 Sub : 143 Byte(s): 256 - Ok Field : 391 Sub : 144 Byte(s): 256 - Ok Field : 391 Sub : 145 Byte(s): 256 - Ok Field : 391 Sub : 146 Byte(s): 256 - Ok Field : 391 Sub : 147 Byte(s): 256 - Ok Field : 391 Sub : 148 Byte(s): 256 - Ok Field : 391 Sub : 149 Byte(s): 256 - Ok Field : 391 Sub : 150 Byte(s): 256 - Ok Field : 391 Sub : 151 Byte(s): 256 - Ok Field : 391 Sub : 152 Byte(s): 256 - Ok Field : 391 Sub : 153 Byte(s): 256 - Ok Field : 391 Sub : 154 Byte(s): 256 - Ok Field : 391 Sub : 155 Byte(s): 256 - Ok Field : 391 Sub : 156 Byte(s): 256 - Ok Field : 391 Sub : 157 Byte(s): 256 - Ok Field : 391 Sub : 158 Byte(s): 256 - Ok Field : 391 Sub : 159 Byte(s): 256 - Ok Field : 391 Sub : 160 Byte(s): 256 - Ok Field : 391 Sub : 161 Byte(s): 256 - Ok Field : 391 Sub : 162 Byte(s): 256 - Ok Field : 391 Sub : 163 Byte(s): 256 - Ok Field : 391 Sub : 164 Byte(s): 256 - Ok Field : 391 Sub : 165 Byte(s): 256 - Ok Field : 391 Sub : 166 Byte(s): 256 - Ok Field : 391 Sub : 167 Byte(s): 256 - Ok Field : 391 Sub : 168 Byte(s): 256 - Ok Field : 391 Sub : 169 Byte(s): 256 - Ok Field : 391 Sub : 170 Byte(s): 256 - Ok Field : 391 Sub : 171 Byte(s): 256 - Ok Field : 391 Sub : 172 Byte(s): 256 - Ok Field : 391 Sub : 173 Byte(s): 256 - Ok Field : 391 Sub : 174 Byte(s): 256 - Ok Field : 391 Sub : 175 Byte(s): 256 - Ok Field : 391 Sub : 176 Byte(s): 256 - Ok Field : 391 Sub : 177 Byte(s): 256 - Ok Field : 391 Sub : 178 Byte(s): 256 - Ok Field : 391 Sub : 179 Byte(s): 256 - Ok Field : 391 Sub : 180 Byte(s): 256 - Ok Field : 391 Sub : 181 Byte(s): 256 - Ok Field : 391 Sub : 182 Byte(s): 256 - Ok Field : 391 Sub : 183 Byte(s): 256 - Ok Field : 391 Sub : 184 Byte(s): 256 - Ok Field : 391 Sub : 185 Byte(s): 256 - Ok Field : 391 Sub : 186 Byte(s): 256 - Ok Field : 391 Sub : 187 Byte(s): 256 - Ok Field : 398 Sub : 0 Byte(s): 56 - Ok PM Upload Done!... FACTORY SET TO : Full Factory Set OK FACTORY SET TO : User Data OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Service Center OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : Production Tune OK Scanning USB Ports... ================================================ Basic Phone Information ================================================ MCU Version: V 04.52 30-06-13 RM-872 (c) Nokia IMEI Plain : 359999056326929 IMEI Spare : A359999056326920 IMEI SV : 33599990563269211F IMEI (2nd) : 359999056326937 IMEI Spare : A359999056326930 IMEI SV : 33599990563269311F Phone Model: K` 206 Category : Entry Phone Type : RM-872 ================================================ Extended Phone Information ================================================ Product Serial Number: 10463DEBH Product Code : 059S8K5 Module Code : 0205283 Basic Production Code: 059P6H2 Long Production SN : 0 PPM SW Version : V 04.52 30-06-13 RM-872 (c) Nokia M2 BT MCM Version : 19b5-22012 MCU SW Version : V 04.52 30-06-13 RM-872 (c) Nokia HW Version : 1601 RFIC Version : 68 LCD Version : TPO Content Pack Version : Content: m2_059Q4J7 V 04.52 30-06-13 RM-872 (c) Nokia Bluetooth ID : C0:64:C6:6FD:E4 CS Type : GSM900, GSM1800 ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 800000000004000B ASIC : 11 PROVIDER : Default Test Operator LOCK COUNTERS: KEYPRESS 0/3, FBUS 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : FAILED > Try SX4 "PM AUTH" > Then Write PM 1 and 309 SECURITY_CODE : 12345 PHONE_MODE : TEST ================================================ Dynamic Camera Configuration ================================================ DCC ID : 01029704 DCC Ver: 008013 Status : OK ================================================== ==== Selected VPL File: RM872_059S8K5_04.52_014.vpl ================================================== ==== Variant Details : RM-872 VAR MEA-M2 PK CV BLACK Software Version : 04.52 Product Type : RM-872 Product Code : 059S8K5 Variant Version : 014 |
