08-05-2012, 05:41 | #1 (permalink) |
No Life Poster Join Date: Jun 2008 Location: Bahawal Nagar
Member: 793565 Status: Offline Sonork: 100.1611436 Thanks Meter: 356 | NOKIA 2690 "sec test faild" first erase the phone 2-Flashed with high flash file (10.65) 3-then writed RPL 4-then write simloks (saved) 5-then SD 6-THEN write pm file (modified) but result still "sec test faild" 7-finally write RPL without NPC But still "sec test faild" what do i do? |
08-05-2012, 10:43 | #3 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Quote:
Br - srinibas | |
08-05-2012, 12:27 | #4 (permalink) |
Member: 793565 Status: Offline Sonork: 100.1611436 Thanks Meter: 356 | here is full info sir Basic Phone Information ================================================ MCU Version: V 10.65 09-12-10 RM-635 (c) Nokia IMEI Plain : 353409044080972 IMEI Spare : A353409044080970 IMEI SV : 33534090440809761F Phone Model: Nokia 2690 Category : Classic Phone Phone Type : RM-635 ================================================ Extended Phone Information ================================================ Product Serial Number: 0 Long Production SN : 0 PPM SW Version : V 10.65 09-12-10 RM-635 (c) Nokia T BT MCM Version : 2.31-SP2.26 MCU SW Version : V 10.65 09-12-10 RM-635 (c) Nokia RFIC Version : 06560601 DSP Version : ICPR72_10w06 LCD Version : SUEZ Content Pack Version : Content: t_silver_au V 10.65 09-12-10 RM-635 (c) Nokia AHNE Version : 30 RETU Version : 16 TAHVO Version : 22 Bluetooth ID : 206:07:06:3A:21 CS Type : GSM850, GSM900, GSM1800, GSM1900 ================================================ Simlock Information ================================================ CONFIG KEY : 0000000000000000 PROVIDER KEY : 2440700000000000 NETWORK NAME : Nokia Default;Finland LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10 SIMLOCK TABLE : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK STATE : Not Locked SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : FAILED > Try SX4 "PM AUTH" > Then Write PM 1 and 309 SECURITY_CODE : ENCRYPTED PHONE_MODE : TEST ================================================ Dynamic Camera Configuration ================================================ DCC ID : NI00IIIIRR030C213402 DCC Ver: 003002 Status : OK ================================================== ==== Selected VPL File: RM635_0592485_10.65_036.vpl ================================================== ==== Variant Details : RM-635 SEAP T SILVER LATIN AUSTRALIA Software Version : 10.65 Product Type : RM-635 Product Code : 0592485 Variant Version : 036 |
08-05-2012, 15:53 | #5 (permalink) |
No Life Poster Join Date: Jun 2010 Location: Russia Age: 44
Member: 1331464 Status: Offline Thanks Meter: 206 | Bro make sx4 auth and write this pm DepositFiles This pm is full with 1 and 309 block but without 120 and 308 block. It will not damage simlock but repair security test failed |
08-05-2012, 18:25 | #6 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | @gulzarjan Write PM by zorgy_1979, if it doesn't resolve security test failed, then try to find CCC and HWC mataching to phone original product code. |
08-06-2012, 06:01 | #7 (permalink) |
Member: 793565 Status: Offline Sonork: 100.1611436 Thanks Meter: 356 | tell me where am wrong 1:again erased the phone 2:flashed with 10.65 after flash it asks for .dcc file mismatch and auto a window appear where the .dcc file located i seleted it wrote and all factory reset option ok. 3: write the saved RPL 4:repair SD 5:write saved simlocks with the help of full pm tab 6:now write pm file given by zorgy_1979 with sx4 auth at all still hang sec test fail why? tell me the steps and how to fine this >>>"o find CCC and HWC mataching to phone original product code"??? |
08-06-2012, 13:35 | #9 (permalink) |
Member: 793565 Status: Offline Sonork: 100.1611436 Thanks Meter: 356 | zorgay i hv add u in sonorok bro add u in sonorok why not get my tv id and solve the fallowing problem in ATF ,what u say ,let me clear you i hv write rpl wiyhout npc before u advice. |
08-07-2012, 07:48 | #10 (permalink) |
Member: 1331464 Status: Offline Thanks Meter: 206 | Tryed this phone buy team viewer. Very strange but i cant write 309 block of pm from atf and my file. Write failed. When i edit atf pm and made pm file with only 309 block it was written ok. After i could write atf pm without problem. But pm from rpl server uo5oq.com was written with error in 309 block. Also tryed atf rpl without npc. Problem was not solved. Tryed this all after erase and flash only mcu also. In all this security test was failed. As i think its some atf bugs or hardware problem. Also saw self test. All was good. Wait for TS report about writing pm buy another solution |
08-07-2012, 08:56 | #13 (permalink) | |
No Life Poster Join Date: Oct 2009 Location: srilanka Age: 39
Member: 1133072 Status: Offline Thanks Meter: 505 | Quote:
i also check with tv but not slove with all method, i also think this is bug of standalone sx4 auth. | |
08-07-2012, 15:27 | #14 (permalink) | |
Member: 793565 Status: Offline Sonork: 100.1611436 Thanks Meter: 356 | ok sir srinibas i have add u in sonorok Quote: BR | |
