07-15-2013, 16:12 | #1 (permalink) |
No Life Poster Join Date: May 2012 Location: PARADISE ON EARTH(KASHMIR)
Member: 1754881 Status: Offline Sonork: 100.1644926 Thanks Meter: 146 | Nokia 2690 security code not removing by atf through usb.......need help |
07-15-2013, 16:22 | #2 (permalink) |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Connect phone in ( power off ) Untick all file , Click on flash . . . Phone will go es to Local mode / Test mode Reset all If not goes to Local mode then flash the phone Br - srinibas |
07-15-2013, 16:34 | #3 (permalink) |
Junior Member Join Date: Jul 2013
Member: 1979486 Status: Offline Sonork: [email protected] Thanks Meter: 1 | Nokia 2690 security code not removing by atf today me also same |
07-15-2013, 16:43 | #4 (permalink) |
Freak Poster Join Date: Apr 2012 Location: forum.gsmhosting.com
Member: 1745022 Status: Offline Sonork: Save The Market Thanks Meter: 40 | if you use fbus cable, you can simply read security codes or reset them. If you want to reset code via usb then, Either you have to use modified usb cable or simply flash it And then Reset Full factory. |
07-15-2013, 16:53 | #5 (permalink) | |
Freak Poster Join Date: Mar 2007 Location: INDIA
Member: 466182 Status: Offline Sonork: 100.1604458 Thanks Meter: 88 | Quote:
Can you post pinout ? Thnx | |
07-15-2013, 17:21 | #6 (permalink) |
No Life Poster Join Date: Nov 2009 Location: pakistan Age: 35
Member: 1164608 Status: Offline Sonork: 100.1650273 Thanks Meter: 105 | so its so risk to flash a phone without knowing the phone is using which version and set can goes to contact service or so many faults plz adminstators do some thing give the solution to read the code with usb. |
07-16-2013, 06:22 | #8 (permalink) | |
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Quote:
Hello , there is Zero risk on ATF to flash a SL3 phone . Know it . Only I mean One & only ATF can detect the inside firmware even in a dead phone so no chances of downgrade Br - srinibas | |
09-05-2013, 14:15 | #13 (permalink) |
Major Poster Join Date: Jan 2012 Location: haldwani
Member: 1714579 Status: Offline Sonork: 601335 Thanks Meter: 14 | 2680s-2 network out after some time i flash with atf box i have flash with 6.17 ver. file after that come contact service than i flash again 6.17 ver but no now off after 10 secound plz help |
