Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 02-27-2011, 07:44   #1 (permalink)
gsmsumon's Avatar
Member: 1292009
Sonork: 100.1586379
nokia 2710 usb flash only 7 secound by atf
AUTO SELECTED DEAD USB FLASHING...
 If Flashing DOES NOT Start in 5 Seconds,
 Then Perform Steps 1, 2, 3 and 4...
1. Remove USB and Battery...
2. Insert USB.
3. Insert Battery. (Some phones boot automatically)
4. Please Power on phone shortly..
AdvanceFBox SendBootCodeEx
InitialiseBootstrap_DCT5 DIR
BootFlashMode_DCT5
 BootRom Verified!
BootFlashModeDCT5Ex Succeeded First Time
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0  (0x00) bytes returned
Number of Sub Blocks 6 (0x06)
  1  SYSTEM_ASIC_ID 01
     Block Length  : 17  (11)
     BB ASIC Index : 0  (00)  CMT
     ID DWORD    0 : 00000000
     ID DWORD    1 : 00000000
     ID DWORD    2 : 22000509
     ID DWORD    3 : 200C0000
  2  ROM_ID 15
     Block Length  : 5  (05)
     ID DWORD    0 : 00005331
  3  PUBLIC_ID 12
     Block Length  : 21  (15)
     ID DWORD    1 : 003B75E2
     ID DWORD    2 : 68773F47
     ID DWORD    3 : 6081F6D8
     ID DWORD    4 : 42D2A36C
  4  ASIC_MODE_ID 13
     Block Length  : 2  (02)
     Mode Id       : 00
  5  ROOT_KEY_HASH 14
     Hash          :  1B 0D 74 C5 32 CA 1C 61 33 94 0C 74 0E 8C 78 6E
  6  ROM_ID 15
     Block Length  : 9  (09)
     CRC         0 : DE56D582
     CRC         1 : BDDE7A3A
START FLASHING
RawLoaderExtract: Processing rm586__09.67.mcusw
CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\BCM21351_usb2nd.fg
Secondary Loader Sent...
MCU_CONFIGURATION_RESPONSE_BB5:
 MessageID  : C1
 SubBlocks  : 06
 1 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   BB ASIC Index     : CMT  00
   Device Type       : RAM  05
   Device Index      : 00
   Manufacturer Code : 0000 -> Flash
   Device ID         : 0000 -> not detected
   Extended/Fixed ID : 0000
   Revision ID       : 0000
 2 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Type       : MMC  04
   Device Index      : 00
   Manufacturer Code : FFFF -> Flash
   Device ID         : 0000 -> BAD FLASH TYPE
   Revision ID       : 0000
 3 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Type       : NOR  00
   Device Index      : 00
   Revision ID       : 0000
 4 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Index      : 01
   Manufacturer Code : 0010 ->
   Device ID         : 0011 -> Type not in database
   Revision ID       : 0000
 5 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Type       : MuxOneNAND  03
   Device Index      : 00
   Manufacturer Code : 00EC ->
   Device ID         : 0030 -> K5W1G13ACB
   Revision ID       : 0321
 6 Sub Block ID      : 35  NAND_DRIVER_VERSION_BB5
   Block Length      : 09
   Data              :
SearchForBootstrap_DCT5  : No Error - 0 (0x00)
Flash Descriptor
   Device ID         : 0030
   Revision ID       : 0000
   Size              : 08000000 (128 MB)
   VPP Info          : 0000
   Erase10s          : 1E
   Block1s           : 32
   BErase1s          : 02
   Reserved0         : 00
   Reserved1         : 00
   Reserved2         : 00
CMT Algorithm Loader:C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\BCM21351_XSR16_usbalg.fg
Algorithm Loader Sent...
FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
FUR control Ok
 START READING RPL DATA
NPC is Corrupted...
ERROR: NPC is Corrupted..., 3
 RPL Backup is Skipped
Pabub KEY Request
PhoneInfoRequest_BB5 (Asic Index 00 )
PHONE_INFO_RESPONSE_BB5
  PAPUB_KEYS_HASH_RESP_BB5 2A
    BB Asic Index   : 00
    PAPUB Keys Hash : 84CDC75F79F52BBAE46EA3A70C9240861412C480
ImagePath: C:\Program Files\Nokia\Phoenix\Products\RM-586\
ImadeFilename: rm586__09.67.mcusw
Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT  00 only)
Certificate 1
  ASIC Index  : CMT  0
Certificate 2
  ASIC Index  : CMT  0
Certificate 3
  ASIC Index  : CMT  0
Certificate 4
  ASIC Index  : CMT  0
Certificate 5
  ASIC Index  : CMT  0
STORE_CERTIFICATE_REQUEST_BB5 : 61 05 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 4E 44 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 B6
STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
ProcessPartitionInfo_DCT5...
Partition Info
    Partition Blocks :   1
     1   PARTITION_INFO_BB5
            BB ASIC Index     : 0x00 CMT
            Device Type       : 0x03 MuxOneNAND
            Device Index      : 0x00
            Partition Version : 00010000
            Spare             : FFFFFFFF
            Num Partitions    : 00000004
            Partition    1
              Attribute       : 00000002  RO
              Start Address   : 00020000
            Partition    2
              ID              : 00000008  FILESYSTEM
              Attribute       : 00000001  RW
              Start Address   : 02800000
            Partition    3
              Start Address   : 07540000
            Partition    4
              Start Address   : 07B40000
PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF000000040000000300000002000200000266000000000008000000010280000004D400000000000A0000000107540000006000000000000B0000000107B400000018000005
PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00)
ProcessPartitionInfo_DCT5 : No Error - 0 (0x00)
StartErase_DCT5...
BlockLength  :  0x80  (128)
ERASE Blocks :  0x03  (3)
     0   ERASE_AREA_BB5 0x12
            Block Length     : 0x1B (27)
            Device Index     : 0x00
               0             : 00000000-0001FFFF
               1             : 00020000-000203FF
               2             : 00060000-01FFFFFF
     1   FORMAT_PARTITION_BB5 0x19
            Block Length     : 0x2F (47)
            Device Index     : 0x00
            Format Info ID   : 0x02000000
            Format Info      : 000000000000000A0000000100000002000000640000000200000002000000010000000000000000
     2   FORMAT_PARTITION_BB5 0x19
            Device Index     : 0x00
            Format Info      : 000000000000000B0000000000000002000000640000000200000002000000010000000000000000
ERASE_REQUEST_BB5 : 5003120B000300000000000001FFFF120B00030000020000000203FF120B0003000006000001FFFFFF93
ERASE_REQUEST_BB5 : 5001192F00030000000002000000000000000A00000001000000020000006400000002000000020000000100000000000000003B
ERASE_REQUEST_BB5 : 5001192F00030000000002000000000000000B00000000000000020000006400000002000000020000000100000000000000003B
Successfully erased..
Total blocks to write : 466
>>  CMT Rootkey Hash CERT : KEYS
>>  CMT Rootkey Hash CERT : ADA
>>  CMT Rootkey Hash CERT : PRIMAPP
>>  CMT Rootkey Hash CERT : RAP3NAND
>>  CMT Rootkey Hash CERT : PASUBTOC
>>  CMT Rootkey Hash CERT : PAPUBKEYS
>>  CMT Rootkey Hash CERT : UPDAPP
>>  CMT Rootkey Hash CERT : MCUSW
>>  CMT Rootkey Hash CERT : GENIO_INIT
ImadeFilename: rm586__09.67.ppm_mk
StartErase_DCT5...
BlockLength  :  0x0E  (14)
ERASE Blocks :  0x01  (1)
            Block Length     : 0x0B (11)
            Device Index     : 0x00
               0             : 02000000-0267FFFF
ERASE_REQUEST_BB5 : 5001120B000300020000000267FFFF75
Total blocks to write : 109
ImadeFilename: rm586__09.67.image_mk_silv
StartErase_DCT5...
BlockLength  :  0x3F  (63)
ERASE Blocks :  0x02  (2)
            Device Index     : 0x00
               0             : 02800000-0753FFFF
            Device Index     : 0x00
            Format Info      : 00000000000000080000000000000002000000640000000200000002000000010000000000000000
ERASE_REQUEST_BB5 : 5001120B000300028000000753FFFF04
ERASE_REQUEST_BB5 : 5001192F00030000000002000000000000000800000000000000020000006400000002000000020000000100000000000000003E
Total blocks to write : 195
ContinueFlash_DCT5 Complete
Continue Flash Complete :  : No Error - 0 (0x00)
Status_BB5 STATUS_REQUEST_BB5..
1  Sub Block ID      : 15 STATUS_NAND_OK_BB5
          Block Length      :  0F
          BB ASIC Index     :  00
          Device Type       :  03
          Device Type       :  00
          Num Bad Blocks    :  00000002
          Additional Bad    :  00000002
          Correctable ECC   :  00000000
FlashInfo.RestartMode : 2
Flashing Done...
Total Flashing Time (Erase + Flashing) : 00:00:07
(Booting time is NOT Included)
Waiting for Phone to Start-Up..(Max 100 seconds
The Following 3 Users Say Thank You to gsmsumon For This Useful Post:
Old 02-27-2011, 07:58   #2 (permalink)
Member: 1015645
good info bro keep it up nice........................
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 73 05-15-2013 13:07
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
Page generated in 0.34093 seconds with 11 queries
