09-04-2014, 16:43 | #1 (permalink) |
No Life Poster Join Date: Aug 2010 Location: SearchinG ... Age: 39
Member: 1369772 Status: Offline Thanks Meter: 297 | Nokia 305 RM-766 flashing - ATF failed but successfully flash by MX-KEY! Here is log Number of Image Files: 4 (Mass Memory File Detected) Processing Image File : rm766__07.42.mcusw Processing Image File : rm766__07.42.ppm_ea1 Processing Image File : rm766__07.42.image_ea1_059L0G6 Processing Image File : rm766__07.42_sd_seap_nomap_ea1_2048.fpsimage AUTO SELECTED DEAD USB FLASHING... If Phone Booting does not Start in 5 Seconds, Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... Infineon USB Boot: F00A1FB300020303010100FF Sending PBL... PBL Successfully Sent... Sending SBL... SBL Successfully Sent... Setting Transmission Speed Done... Flash Chip Manufacturer: Samsung Electronics Corp. Flash Boot Successful... Unique Data: 1210080C96012810 Original Product Code: 059L0G6 Reading : CCC... OK! Reading : HWC... OK! Reading : NPC... OK! RPL Backup was Successful... Plain RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\354645058091848\3546450580918 48_91726.rpl Certificate Block Saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\354645058091848\3546450580918 48_CERTIFICATE_10CF49F9.bin PM Block Saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\354645058091848\3546450580918 48_PMM_PROT_0C563988.bin Security Code: 12345 Data Sections : 04 Current File : rm766__07.42.mcusw Compile Name: rm766__07.42.mcusw_ebl_psi.fls Image Type : Main Firmware Data Size : 29117832 Bytes Sending Certificate Block FIRMWARE Certificate Block Sent Successfully... Processing Section 01 FIRMWARE Erase Block: 0x40000000~0x4001FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 131072 bytes Data Checksum: 1369 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 02 FIRMWARE Erase Block: 0x40040000~0x4005FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 131072 bytes Data Checksum: 73CD Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 03 FIRMWARE Erase Block: 0x40060000~0x4011FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 786432 bytes Data Checksum: 3B38 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 04 FIRMWARE Erase Block: 0x40120000~0x41BFFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 28065792 bytes Data Checksum: 1302 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 05 FIRMWARE Erase Block: 0x43EE0000~0x43EFFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Data Verification Successful... Data Sections : 01 Current File : rm766__07.42.ppm_ea1 Compile Name: package_ea1.ppm_ebl_psi.fls Image Type : PPM Image Data Size : 7399624 Bytes Sending Certificate Block PPM Certificate Block Sent Successfully... Processing Section 01 PPM Erase Block: 0x41C00000~0x423FFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 7396280 bytes Data Checksum: 4253 Uploading Data Blocks to phone... Block Write Successful... PPM Data Blocks uploaded to phone... Data Verification Successful... Data Sections : 01 Current File : rm766__07.42.image_ea1_059L0G6 Compile Name: package_ea1_059L0G6.image.fls Image Type : CONTENT Package Data Size : 13634832 Bytes Sending Certificate Block CONTENT Certificate Block Sent Successfully... Processing Section 01 CONTENT Erase Block: 0x42400000~0x43EDFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 13631488 bytes Data Checksum: C939 Uploading Data Blocks to phone... Block Write Successful... CONTENT Data Blocks uploaded to phone... Processing Section 02 CONTENT Erase Block: 0x43F00000~0x43F7FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Data Verification Successful... Data Sections : 01 Current File : rm766__07.42_sd_seap_nomap_ea1_2048.fpsimage Compile Name: rm766__07.42_sd_seap_nomap_ea1_2048.fpsimage.fls Image Type : MASS Memory SD Card Size : Use 2 GB Cards Only Always use the CORRECT SD Card Size!!! Data Size : 225892 Bytes Sending Certificate Block ERROR: MASS MEMORY Certificate Block was not accepted !!! 1. Make Sure Micro SD Card is Inserted Properly. 2. Minimum Micro SD Card Size required is 2048 (2 GB). Here is MX-KEY success log MXKEY [FT SCR2000 0], SN: xxxxx Using device: USB ROM Connection status: UHCI:HUB::USB 1.10 (Full-speed) Driver: NMWCD, ver: 7.1.32.84 Module ver: 1.0.0.21724(14-05-2013), Library ver: 1.0.0.14397(09-05-2013) Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Device synchronized. CPU: XGOLD 213 Using embedded SBL from MCU. Sending EBL Loader...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.49 EBL version: Quantum_Bootloader_10.49_M1S1 Protocol version suggested by phone: 3 Set baud rate to: 6.50 Mbit/s Flash ID: 00EC 3012 - 23280002 [Samsung ] CFI information: Flash settings: 0/1024, size: 0x04000000 1 Block regions: 512 x 0x00020000 = 0x04000000 EBL ready ! Original IMEI: 35464505809184 RPL backup already exist (C:\mobileEx\3.5\data\backup\XGOLD_35464505809184_ back.RPL) Processing file: rm766__07.42.mcusw Downloading item CODE:rm766__07.42.mcusw_ebl_psi.fls, num block: 4, size: 27.77 MB Erasing area 0x40000000-0x4001FFFE ...OK Programming completed in 0.375 s Erasing area 0x40040000-0x4005FFFE ...OK Programming completed in 0.375 s Erasing area 0x40060000-0x4011FFFE ...OK Programming completed in 1.437 s Erasing area 0x40120000-0x41BE3FFE ...OK Programming completed in 42.500 s Checksum verified (0x9E48) Processing file: rm766__07.42.ppm_ea1 Downloading item CUSTackage_ea1.ppm_ebl_psi.fls, num block: 1, size: 7.06 MB Erasing area 0x41C00000-0x4230DBB6 ...OK Programming completed in 11.360 s Checksum verified (0x5342) Processing file: rm766__07.42.image_ea1_059L0G6 Downloading item CUSTackage_ea1_059L0G6.image.fls, num block: 1, size: 13 MB Erasing area 0x42400000-0x43EDFFFE ...OK Programming completed in 20.359 s Checksum verified (0x39C9) Total time for flashing process(boot+erase+write) was 4 min 11.093 s Waiting for USB device removal ...OK Waiting for USB device arrival ... Waiting for device boot up ... Device connected: nmwcdc\Nokia USB Phonet, PORT_ID: 354645058091848 Verifying communication to device OK. Phone type: RM-766 (Nokia 305) SW version: V 07.42 07-05-13 RM-766 (c) Nokia Imei plain: 35464505809184-8 Product code: 059L0G6 Language Pack: - not available. Imei net: 35464505809184 Version: SIMLOCK SERVER Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000003000B BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN FULL FACTORY... OK USER DATA... OK LEAVE FACTORY... OK SERVICE CENTER... OK SOFTWARE UPGRADE... OK PRODUCTION TUNING... OK Reset User Code (to default:12345) ... OK Completed in 0.109 s ATF team, please check the reeor |
