![]() | #3 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,119 | 1. Select BB5 in drop-down list 2. Select USB Connection 3. Click BusCheck button 4. Wait until USB drivers are installed for your phone 5. Click Scan phone, it will show Sec Code Asha 308, 309, 3080 and 3090 are XG223 phones, but ATF Software will treat it as a BB5 phone. Make sure you are using the latest ATF exe. |
The Following User Says Thank You to Advance-Box For This Useful Post: |
![]() | #4 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2009 Location: SouthAmericaUnlockers Age: 52
Member: 1057178 Status: Offline Sonork: Kfe~Labs Co.- Thanks Meter: 570 | Quote:
If the Step for Advance-Box fail for some reason, you can do that.... Select any flash packet for flash (6131 u other flash pack) Untick file from pack (mcu-ppm-cnt) tick save rpl (more Important) Tick Factory default... Press Flash Never fail, the user code will be 12345 All under USB Br Polaco | |
![]() | #5 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Quote:
No, it will NOT work, it was DISABLED before in ATF Software... WITHOUT files, it will say to select flash files first... He MUST do what Advance-Box said in his previous post, it will work for sure... BR | |
![]() | #6 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2005 Location: Pakistan
Member: 192810 Status: Offline Sonork: Some people NEED change Thanks Meter: 860 | Quote:
No sir this Method is not clear the Security code Still issue. Br, | |
![]() | #7 (permalink) | |
Untick file pack press flash w/o Tick Files (tick factory default) Work and tested 100% test by me many time! Polaco | |
![]() | #8 (permalink) | |
Yeah, that's right. PG disabled it before, looks like he have now re-enabled... So certainly it will be working also... ![]() BR | |
![]() | #10 (permalink) | |
I dont Know when you talk seriously, or teases me. I've tried this solution without problems. - I show you in the NExt time.. I do not want to confuse users Best Regard Angel..... Polaco Last edited by el-polaco; 11-21-2012 at 01:00. | |
