12-07-2013, 10:47 | #1 (permalink) |
Freak Poster Join Date: Apr 2009
Member: 1004987 Status: Offline Thanks Meter: 9 | Nokia 501 Flashing Failed (Mass Memory File Detected) Processing Image File : rm902_11.1.1.mcusw.fpsx CMT Type : XG223 CMT Algorithm : XG223_V0 ALG Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 80 Entry Point: 0x293D Page Format : -1 MAX PAGE : 0x00080000 Processing Image File : rm902_11.1.1_059R306_s1.rofs.fpsx CMT Type : XG223 CMT Algorithm : XG223_V0 ALG Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 24 Entry Point: 0x00B5 Page Format : -1 MAX PAGE : 0x00080000 Processing Image File : rm902_11.1.1_059R306_s1.image.fpsx CMT Type : XG223 CMT Algorithm : XG223_V0 ALG Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 56 Entry Point: 0x00B8 Page Format : -1 MAX PAGE : 0x00080000 Processing Image File : rm902_11.1.1_059R306_s1_SD_4GB.fpsimage.fpsx CMT Type : XG223 CMT Algorithm : XG223_V0 ALG Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 35 Entry Point: 0x00BA Page Format : -1 MAX PAGE : 0x00080000 AUTO SELECTED DEAD USB FLASHING... If Phone Booting does not Start in 5 Seconds, Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 READING BOOTROM BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 82 (0x52) bytes returned Number of Sub Blocks 5 (0x05) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000C20 ID DWORD 1 : 16100040 ID DWORD 2 : 498A2C09 ID DWORD 3 : 8A52B4C2 ID DWORD 4 : 02E3A100 2 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 4B2FE923 ID DWORD 1 : 12964672 ID DWORD 2 : 498A2C09 ID DWORD 3 : 8A52B4C2 ID DWORD 4 : 02E3A100 3 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 4 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 12 5F C7 26 05 B5 C4 E4 8A 9E 02 25 08 4D 25 79 5 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 53588225 CRC 1 : 2F54C676 CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\XG223_v11_usb2nd.fg Secondary Loader Sent.... CMT Algorithm Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\XG223_v11_usbalg.fg ERROR: Algorithm Loader Failed! Flashing Failed.... Booting/Flashing Failed... Please Try Again... |
12-07-2013, 12:24 | #2 (permalink) |
Member: 1004987 Status: Offline Thanks Meter: 9 | ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00020422 Library Version : 00030119 Box Type : ATF Lightning Box Firmware : LogiCore 10.3.80 Software Version : v10.50 AdvanceBox SN : XXXXXXXXXXXXXXXXXXXXXXXXX Box Status : ACTIVATED ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
