10-24-2013, 08:02 | #1 (permalink) |
No Life Poster Join Date: Mar 2011 Location: India,Chennai Super Kings..... Age: 33
Member: 1531954 Status: Offline Sonork: 100.1619337 Thanks Meter: 294 | Nokia 501 flashing problem Code: Number of Image Files: 2 Processing Image File : rm902_10.0.1_059R3C3_s2_310_01_215198.rofs.fpsx CMT Type : XG223 CMT Algorithm : XG223_V0 ALG Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 19 Entry Point: 0x00B5 Page Format : -1 MAX PAGE : 0x00080000 Processing Image File : rm902_10.0.1_059R3C3_s2_310_01_215198.image.fpsx CMT Type : XG223 CMT Algorithm : XG223_V0 ALG Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 84 Entry Point: 0x00B8 Page Format : -1 MAX PAGE : 0x00080000 AUTO SELECTED DEAD USB FLASHING... If Phone Booting does not Start in 5 Seconds, Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 READING BOOTROM BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 82 (0x52) bytes returned Number of Sub Blocks 5 (0x05) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000C20 ID DWORD 1 : 16100040 ID DWORD 2 : 498A2209 ID DWORD 3 : B28178EC ID DWORD 4 : B41D2100 2 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 95E8C8FE ID DWORD 1 : BAFBBF93 ID DWORD 2 : 498A2209 ID DWORD 3 : B28178EC ID DWORD 4 : B41D2100 3 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 4 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 12 5F C7 26 05 B5 C4 E4 8A 9E 02 25 08 4D 25 79 5 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 53588225 CRC 1 : 2F54C676 ADL_SERVER: PROCESSING rm902_10.0.2.mcusw.fpsx ADL_SERVER: INVALID BB5 IMAGE CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\XG223_v11_usb2nd.fg Secondary Loader Sent.... CMT Algorithm Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\XG223_v11_usbalg.fg Algorithm Loader Sent.... FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok PA PUBLIC KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: 7E4AA99553DB48A5F2DD39E02FA1B862ECB0EF5E Reading : ISA-USER... OK! ImagePath: C:\Program Files\Nokia\Phoenix\Products\RM-902\ ImageFilename: rm902_10.0.1_059R3C3_s2_310_01_215198.rofs.fpsx NO RESTORE CERTIFICATE BLOCK FOUND... StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 42700000-437FFFFF ERASE_REQUEST_BB5 : 5001120B00000042700000437FFFFF6F Successfully Erased... Total blocks to write : 19 >> CMT Rootkey Hash CERT : PPM ImagePath: C:\Program Files\Nokia\Phoenix\Products\RM-902\ ImageFilename: rm902_10.0.1_059R3C3_s2_310_01_215198.image.fpsx StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 43800000-47DFFFFF ERASE_REQUEST_BB5 : 5001120B0000004380000047DFFFFFFA Successfully Erased... Total blocks to write : 84 ContinueFlash_DCT5 Complete Continue Flash Complete : : No Error - 0 (0x00) Flashing Failed.... Booting/Flashing Failed... Please Try Again... |
10-24-2013, 08:11 | #2 (permalink) | |
Member: 1531954 Status: Offline Sonork: 100.1619337 Thanks Meter: 294 | Quote:
http://img46.imageshack.us/img46/7850/lsv3.png | |
10-24-2013, 12:32 | #5 (permalink) |
No Life Poster Join Date: Aug 2010 Location: kpk _PAK
Member: 1358184 Status: Offline Sonork: 100.1616912 Thanks Meter: 615 | your files version not match with each other plz check mcu ver-10.0.2 rofs and image ver is 10.01 |
The Following User Says Thank You to aliyousafzai For This Useful Post: |
10-24-2013, 12:51 | #7 (permalink) |
Member: 1358184 Status: Offline Sonork: 100.1616912 Thanks Meter: 615 | same product code files not have on server try these http://nds2.fds-fire.nokia.com/fds_f...0.2.mcusw.fpsx http://nds2.fds-fire.nokia.com/fds_f..._ea1.rofs.fpsx http://nds2.fds-fire.nokia.com/fds_f...ea1.image.fpsx and post the result also use full charge battery during flash |
10-24-2013, 13:50 | #8 (permalink) |
Member: 1531954 Status: Offline Sonork: 100.1619337 Thanks Meter: 294 | Mobile Ready Thx u so much atf team special thx to srinibas, fahad ali khan,aliyousafzai Code: Number of Image Files: 3 Processing Image File : rm902_10.0.14.mcusw.fpsx CMT Type : XG223 CMT Algorithm : XG223_V0 ALG Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 70 Entry Point: 0x2945 Page Format : -1 MAX PAGE : 0x00080000 Processing Image File : rm902_10.0.2_059R3B3_i1_239_02_236669.rofs.fpsx CMT Type : XG223 CMT Algorithm : XG223_V0 ALG Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 13 Entry Point: 0x00B5 Page Format : -1 MAX PAGE : 0x00080000 Processing Image File : rm902_10.0.2_059R3B3_i1_239_02_236669.image.fpsx CMT Type : XG223 CMT Algorithm : XG223_V0 ALG Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 58 Entry Point: 0x00B8 Page Format : -1 MAX PAGE : 0x00080000 AUTO SELECTED DEAD USB FLASHING... If Phone Booting does not Start in 5 Seconds, Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 READING BOOTROM BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 82 (0x52) bytes returned Number of Sub Blocks 5 (0x05) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000C20 ID DWORD 1 : 16100040 ID DWORD 2 : 498A2209 ID DWORD 3 : B28178EC ID DWORD 4 : B41D2100 2 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 95E8C8FE ID DWORD 1 : BAFBBF93 ID DWORD 2 : 498A2209 ID DWORD 3 : B28178EC ID DWORD 4 : B41D2100 3 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 4 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 12 5F C7 26 05 B5 C4 E4 8A 9E 02 25 08 4D 25 79 5 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 53588225 CRC 1 : 2F54C676 CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\XG223_v11_usb2nd.fg Secondary Loader Sent.... CMT Algorithm Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\XG223_v11_usbalg.fg Algorithm Loader Sent.... FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok PA PUBLIC KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: 7E4AA99553DB48A5F2DD39E02FA1B862ECB0EF5E Reading : ISA-USER... OK! PPM HASH : 66127904a0100a422c885350a9f513e52e3b181d PPM VERSION: 10.0.2 ====================================================== PHONE FIRMWARE VERSION: 10.0.2 ====================================================== ImagePath: C:\Program Files\Nokia\Phoenix\Products\RM-902\ ImageFilename: rm902_10.0.14.mcusw.fpsx Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) Certificate 1 Name : NPC ASIC Index : CMT 0 Certificate 2 Name : CCC ASIC Index : CMT 0 Certificate 3 Name : HWC ASIC Index : CMT 0 Certificate 4 Name : R&D ASIC Index : CMT 0 STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3 STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00) StartErase_DCT5... BlockLength : 0x2E (46) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x2B (43) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 40000000-4003FFFF 1 : 47E00000-47E3FFFF 2 : 40060000-426FFFFF 3 : 42700000-437FFFFF 4 : 47E40000-47F1FFFF ERASE_REQUEST_BB5 : 5005120B000000400000004003FFFF120B00000047E0000047E3FFFF120B00000040060000426FFFFF120B00000042700000437FFFFF120B00000047E4000047F1FFFFD1 Successfully Erased... Total blocks to write : 70 >> CMT Rootkey Hash CERT : ISSW >> CMT Rootkey Hash CERT : MEMSET >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : LOADER >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : PAPUBKEYS [7E4AA99553DB48A5F2DD39E02FA1B862ECB0EF5E] >> CMT Rootkey Hash CERT : UPDAPP >> CMT Rootkey Hash CERT : MCUSW ImagePath: C:\Program Files\Nokia\Phoenix\Products\RM-902\ ImageFilename: rm902_10.0.2_059R3B3_i1_239_02_236669.rofs.fpsx StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 42700000-437FFFFF ERASE_REQUEST_BB5 : 5001120B00000042700000437FFFFF6F Successfully Erased... Total blocks to write : 13 >> CMT Rootkey Hash CERT : PPM ImagePath: C:\Program Files\Nokia\Phoenix\Products\RM-902\ ImageFilename: rm902_10.0.2_059R3B3_i1_239_02_236669.image.fpsx StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 43800000-47DFFFFF ERASE_REQUEST_BB5 : 5001120B0000004380000047DFFFFFFA Successfully Erased... Total blocks to write : 58 ContinueFlash_DCT5 Complete Continue Flash Complete : : No Error - 0 (0x00) FlashInfo.RestartMode : Test Mode Flashing Done... Total Flashing Time (Erase + Flashing) : 00:00:38 (Booting time is NOT Included) Waiting for Phone to Start-Up..(Max 150 seconds) SW: V 10.0.14 04-07-13 RM-902 (c) Nokia IMEI: 357294058570605 CONFIG KEY : 0000000000000000 PROVIDER KEY : 2440700000000000 NETWORK NAME : Nokia Default;Finland LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10 SIMLOCK TABLE : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK STATE : Not Locked SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SUPER_DONGLE_TEST : PASSED ================================================ SL3 Phone detected ================================================ * Firmware Version Downgrade will KILL PHONE !!! * Manual Full Erase WILL KILL PHONE!!! * Simlocks are in PM 120 Only... * PM 308 is Write Protected... FACTORY SET TO : Full Factory Set OK FACTORY SET TO : User Data OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Service Center OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : Production Tune OK RESET LIFE TIMER TO : 0000:00 OK |
