06-08-2014, 07:37 | #1 (permalink) |
No Life Poster Join Date: Aug 2010 Location: SearchinG ... Age: 39
Member: 1369772 Status: Offline Thanks Meter: 297 | Nokia 502 RM-921 wonderfull problem off but incoming call is ok. when incoming call light is on |
06-08-2014, 11:32 | #4 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Hi, you press this power + vol. down or only power? You know this: If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Connect Phone to the USB Port 2. Press and Hold the VOLUME DOWN and POWER Buttons 3. Wait until the Phone Vibrates Shortly... 4. Stop Pressing the Buttons... So i think that incoming call pressing Power On button have need to ceck setting from this phone, can be shortcut setted by user when press Power on button... try and post result PHONE MUST BE OFF TOTALLY Br allumts |
06-08-2014, 14:12 | #6 (permalink) | |
Member: 1369772 Status: Offline Thanks Meter: 297 | Quote:
When power ON the phone show only NOKIA logo then light off But when is an incoming call light is ON I connect the phone via USB, do factory reset, format the phone but same result I connect the phone my Laptop and transfer some data from Laptop to phone and goes to this position................... | |
06-08-2014, 18:47 | #8 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
BR | |
12-01-2014, 14:40 | #11 (permalink) |
Junior Member Join Date: Jan 2008
Member: 674739 Status: Offline Thanks Meter: 4 | i have nokia asha 502 rm-921... touch is not working in this cellphone,and the touch is also not broken from anywhere. so i flashed the handset with latest version ....but the problem did not solve. and i also changed several touch but touch still not working.. help me out from this problem. |
