05-31-2015, 17:25 | #1 (permalink) |
Freak Poster Join Date: Dec 2004 Location: albania Age: 45
Member: 95440 Status: Offline Thanks Meter: 25 | nokia 510 unlock error - (SOLVED) JTAG Interface Connected, S/N 0xEE835CF1 Resetting and Exploring JTAG chain...No Devices found in Chain! Loading AFP (Please Wait)...OK AFP revision 4, compiled 11/26/2013 10:47:00 AM ================================================== ======== Phone Type : Lumia 510 RM-889 - Supported : Lumia 510 RM-898 - Supported Unlock Type : Read PIN and PUK Unlock Codes Other Notes : Disconnect USB Cable before Reading Codes ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect RJ-45 JTAG Cable to ATF Box 4. Disconnect USB Cable from the Phone 5. DO NOT click RESET JTAG button 6. Click READ CODES button to Start Reading Unlock Codes ---------------------------------------------------------- Disconnect USB Cable from Phone (If Connected) Re-Connect USB Cable to Phone... Connect USB Cable to Phone...OK USB Connected! Waiting for First Event...OK Disconnect USB Cable Now...OK Re-Connect USB Cable to Phone... Waiting for Device Connection 10 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Retrieving Unlock Codes...USB I/O Error, Code 0x00000004 Disconnect USB Cable from Phone (If Connected) Re-Connect USB Cable to Phone... Connect USB Cable to Phone...OK USB Connected! Waiting for First Event...OK Disconnect USB Cable Now...OK Re-Connect USB Cable to Phone... Set TCK Error Shift IR Error(s)USB I/O Error, Code 0x00000004 |
06-01-2015, 10:22 | #2 (permalink) |
Member: 95440 Status: Offline Thanks Meter: 25 | Default language ID 0x0409, LR 14 JTAG Interface Connected, S/N 0xEE835CF1 Resetting and Exploring JTAG chain...No Devices found in Chain! Loading AFP (Please Wait)...OK AFP revision 4, compiled 11/26/2013 10:47:00 AM ================================================== ======== Phone Type : Lumia 510 RM-889 - Supported : Lumia 510 RM-898 - Supported Unlock Type : Read PIN and PUK Unlock Codes Other Notes : Disconnect USB Cable before Reading Codes ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect RJ-45 JTAG Cable to ATF Box 4. Disconnect USB Cable from the Phone 5. DO NOT click RESET JTAG button 6. Click READ CODES button to Start Reading Unlock Codes ---------------------------------------------------------- Disconnect USB Cable from Phone (If Connected) Re-Connect USB Cable to Phone... Connect USB Cable to Phone...OK USB Connected! Waiting for First Event...OK Disconnect USB Cable Now...OK Re-Connect USB Cable to Phone... Waiting for Device Connection 10 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Retrieving Unlock Codes...USB Read Error, Received 0x00002A58 of 0x00002C56 Resetting and Exploring JTAG chain...Shift IR Error(s) Disconnect USB Cable from Phone (If Connected) Re-Connect USB Cable to Phone... Connect USB Cable to Phone...OK USB Connected! Waiting for First Event...OK Disconnect USB Cable Now...OK Re-Connect USB Cable to Phone... Waiting for Device Connection 10 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Turbo JTAG Frequency 15.00 MHz! Retrieving Unlock Codes...USB I/O Error, Code 0x00000004 Resetting and Exploring JTAG chain...Shift IR Error(s) Disconnect USB Cable from Phone (If Connected) Re-Connect USB Cable to Phone... Connect USB Cable to Phone...OK USB Connected! Waiting for First Event...OK Disconnect USB Cable Now...OK Re-Connect USB Cable to Phone... Waiting for Device Connection 10 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...Shift IR Error(s)USB I/O Error, Code 0x00000004 Disconnect USB Cable from Phone (If Connected) Re-Connect USB Cable to Phone... Connect USB Cable to Phone...OK USB Connected! Waiting for First Event...OK Disconnect USB Cable Now...OK Re-Connect USB Cable to Phone... Waiting for Device Connection 10 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...Shift IR Error(s)USB I/O Error, Code 0x00000004 JTAG Interface Disconnected! JTAG Interface Connected, S/N 0xEE835CF1 Resetting and Exploring JTAG chain...No Devices found in Chain! Disconnect USB Cable from Phone (If Connected) Re-Connect USB Cable to Phone... Connect USB Cable to Phone...OK USB Connected! Waiting for First Event...OK Disconnect USB Cable Now...OK Re-Connect USB Cable to Phone... Waiting for Device Connection 10 second(s)...Timeout During Operation!USB I/O Error, Code 0x00000004 Disconnect USB Cable from Phone (If Connected) Re-Connect USB Cable to Phone... Connect USB Cable to Phone...OK USB Connected! Waiting for First Event...OK Disconnect USB Cable Now...OK Re-Connect USB Cable to Phone... Waiting for Device Connection 10 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Retrieving Unlock Codes...USB I/O Error, Code 0x00000004 Loading AFP (Please Wait)...OK AFP revision 4, compiled 11/26/2013 10:47:00 AM ================================================== ======== Phone Type : Lumia 510 RM-889 - Supported : Lumia 510 RM-898 - Supported Unlock Type : Read PIN and PUK Unlock Codes Other Notes : Disconnect USB Cable before Reading Codes ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect RJ-45 JTAG Cable to ATF Box 4. Disconnect USB Cable from the Phone 5. DO NOT click RESET JTAG button 6. Click READ CODES button to Start Reading Unlock Codes ---------------------------------------------------------- JTAG Interface Disconnected! JTAG Interface Connected, S/N 0xEE835CF1 Resetting and Exploring JTAG chain...No Devices found in Chain! Resetting and Exploring JTAG chain...No Devices found in Chain! Loading AFP (Please Wait)...OK AFP revision 4, compiled 11/26/2013 10:47:00 AM ================================================== ======== Phone Type : Lumia 510 RM-889 - Supported : Lumia 510 RM-898 - Supported Unlock Type : Read PIN and PUK Unlock Codes Other Notes : Disconnect USB Cable before Reading Codes ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect RJ-45 JTAG Cable to ATF Box 4. Disconnect USB Cable from the Phone 5. DO NOT click RESET JTAG button 6. Click READ CODES button to Start Reading Unlock Codes ---------------------------------------------------------- Disconnect USB Cable from Phone (If Connected) Re-Connect USB Cable to Phone... Connect USB Cable to Phone...OK USB Connected! Waiting for First Event...OK Disconnect USB Cable Now...OK Re-Connect USB Cable to Phone... Waiting for Device Connection 10 second(s)...Timeout During Operation!USB I/O Error, Code 0x00000004 Resetting and Exploring JTAG chain...No Devices found in Chain! Disconnect USB Cable from Phone (If Connected) Re-Connect USB Cable to Phone... Connect USB Cable to Phone...OK USB Connected! Waiting for First Event...OK Disconnect USB Cable Now...OK Re-Connect USB Cable to Phone... Waiting for Device Connection 10 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Retrieving Unlock Codes...USB I/O Error, Code 0x00000004 |
06-01-2015, 16:09 | #4 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | First try to use this exe ATF Offcial Support Area > ATF JTAG Installer Then use unlock V3, inside folder UNLOCK |
The Following User Says Thank You to Advance-Box For This Useful Post: |
06-01-2015, 16:45 | #5 (permalink) | |
Member: 95440 Status: Offline Thanks Meter: 25 | done thank you Quote:
JTAG Interface Connected, S/N 0xEE835CF1 Resetting and Exploring JTAG chain...No Devices found in Chain! Loading AFP (Please Wait)...OK AFP revision 4, compiled 7/8/2014 10:52:00 PM ================================================== ======== Phone Type : Lumia 610 RM-835 - Supported : Lumia 610 RM-849 - Supported : Lumia 610C RM-836 - Supported : Lumia 510 RM-889 - Supported : Lumia 510 RM-898 - Supported : Lumia 505 RM-923 - Supported Unlock Type : Read PIN and PUK Unlock Codes Other Notes : Power On Phone before Reading Codes ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. DO NOT Connect a USB Cable to the phone 3. Connect RJ-45 JTAG Cable to ATF Box 4. Connect Phone BATTERY and POWER ON the Phone 5. Wait until WP7 OS is FULLY LOADED showing Main Menu 6. Check that Phone IMEI is valid via *#06# 7. If IMEI is valid, Click READ CODES button then wait... ---------------------------------------------------------- Initializing Connection Connected 1 device(s)! Halting Core... Halted Device 0x106210E1 Searching for PIN/PUK Unlock Codes... Please wait for a while... Codes Found! ========================= PIN LEVEL 1: 00890234 - LOCKED PUK LEVEL 1: 29571509 - LOCKED PIN LEVEL 2: 56850543 PUK LEVEL 2: 26854801 PIN LEVEL 3: 37853311 - LOCKED PUK LEVEL 3: 34628664 - LOCKED PIN LEVEL 4: 71072461 PUK LEVEL 4: 21740459 PIN LEVEL 5: 76295978 PUK LEVEL 5: 94001370 ========================= | |
