12-03-2013, 07:51 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Auckland
Member: 160928 Status: Offline Thanks Meter: 338 | Nokia 520 after big boot file flash still dead? try to flash with ATF but can not connect what to do? |
12-03-2013, 08:49 | #2 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @MUTUAL You need to use newer BIG BOOT FILE Boot in case firmware inside the Phone is the latest version. You can download here: LUMIA_520_RM-914_BIG_BOOT - Download - 4shared This is newest BOOT from 520 RM-914 uploaded 3 days ago. B.R. |
The Following 2 Users Say Thank You to Advance-Box For This Useful Post: |
12-03-2013, 12:26 | #4 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @FARIN1 You can use ATF Software eMMC TP - No activation required Pinout Heres: C:\AdvanceBox Turbo Flasher\Nokia\Lumia\TP_PIX\ or You can use ATF JTAG Software JTAG Connection - 39 U$D Activation Required Activate Now The difference is only ATF JTAG can write BIG BOOT Files. You need BIG BOOT Files if after BOOT Repair, you cannot flash phone. B.R. Last edited by Advance-Box; 12-03-2013 at 12:37. |
The Following User Says Thank You to Advance-Box For This Useful Post: |
12-04-2013, 07:18 | #5 (permalink) | |
Member: 160928 Status: Offline Thanks Meter: 338 | Quote:
can not even connect with usb now what to do? | |
12-04-2013, 07:35 | #6 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @MUTUAL Charge Battery. Even if you physically remove eMMC chip with hot air from the PCB, the phone will still be detected as: HS-USB QD loader 9008 ... SO your phone not being detected by your PC now is not related to what files you write via ATF JTAG. CHeck PCB area, make sure nothing is shorted. |
12-04-2013, 07:45 | #7 (permalink) | |
when i put again test point phone can detect with ATG JTAg here is the log Code: Default language ID 0x0409 JTAG Interface Connected, S/N 0xC89B1FE6 Resetting and Exploring JTAG chain...2 Device(s) Device #1 ID 0x4BA00477 IR4 Device #2 ID 0x207D00E1 IR11 Loading AFP (Please Wait)...OK AFP revision 4, compiled 12/2/2013 10:27:00 AM ========================================================== Phone Type : Lumia 520 RM-914 CPU Type : Qualcomm MSM8227 Storage TYpe: eMMC 8GB Boot Package: 3046.0000.1329.2009 (BIG BOOT) ========================================================== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect USB Cable to Phone 4. Connect RJ-45 JTAG Cable to ATF Box 5. Select the Correct Phone Type RM-XXX 6. Use RESET JTAG button to check the JTAG Connection 7. Click RESTORE BOOT button to Start Boot Repairs ---------------------------------------------------------- Resetting and Exploring JTAG chain...2 Device(s) Device #1 ID 0x4F1F0F0F IR4 Device #2 ID 0x207D00E1 IR11 | |
12-04-2013, 07:58 | #9 (permalink) | |
Code: Default language ID 0x0409 JTAG Interface Connected, S/N 0xC89B1FE6 Resetting and Exploring JTAG chain...2 Device(s) Device #1 ID 0x4BA00477 IR4 Device #2 ID 0x207D00E1 IR11 Loading AFP (Please Wait)...OK AFP revision 4, compiled 12/2/2013 10:27:00 AM ========================================================== Phone Type : Lumia 520 RM-914 CPU Type : Qualcomm MSM8227 Storage TYpe: eMMC 8GB Boot Package: 3046.0000.1329.2009 (BIG BOOT) ========================================================== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect USB Cable to Phone 4. Connect RJ-45 JTAG Cable to ATF Box 5. Select the Correct Phone Type RM-XXX 6. Use RESET JTAG button to check the JTAG Connection 7. Click RESTORE BOOT button to Start Boot Repairs ---------------------------------------------------------- Resetting and Exploring JTAG chain...2 Device(s) Device #1 ID 0x4F1F0F0F IR4 Device #2 ID 0x207D00E1 IR11 Restore Boot... Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting EMMC #1 ID...Samsung M8G2YC, 7.28 GiB Testing Device Memory...OK Sending Flash Loader...OK Restoring Partition #1...OK Restoring Partition #2...OK Restoring Partition #3...OK Restoring Partition #4...OK Restoring Partition #5...OK Restoring Partition #6...OK Restoring Partition #7...OK Restoring Partition #8...OK Restoring Partition #9...OK Restoring Partition #10...OK Restoring Partition #11...OK Restoring Partition #12...OK Boot Restore Done! ============================================================= Assemble Phone and Start Normally If Phone cannot Start, perform USB Firmware Update Procedure | |
12-04-2013, 09:52 | #10 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @MUTUAL Your Battery is probably EMPTY or you are doing something Wrong. If battery is dead or not connected, phone will not be detected as anything on USB port (Especially if Boot Inside Phone is 100% Fixed already) See My Tests with same BIG BOOT FILE: LUMIA_520_RM-914_BIG_BOOT - Download - 4shared JTAG BOOT REPAIR using BIG BOOT FILE: Flashing the phone after Boot Repair: My Wired Up 520 Test Phone: Our Boot Repair Files are 100% Tested. Maybe you are using wrong RM-XXX for your phone. Maybe your battery is DEAD. Check everything again. B.R. |
12-05-2013, 08:05 | #11 (permalink) |
Insane Poster Join Date: Jun 2012 Location: KAZAKHSTAN-ASTANA
Member: 1772768 Status: Offline Sonork: 123456 Thanks Meter: 4 | Advance-Box Hi !!! What of them sing on charge of the telephone? It is Correct has done or no? Beside me telephone is defined how do I his(its) now sew !!! Last edited by FARIN1; 12-05-2013 at 08:14. |
12-05-2013, 09:33 | #15 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @FARIN1 Are you 100% Sure Your Phone is RM-914? If So, then use latest AFP for RM-914 LUMIA_520_RM-914_BIG_BOOT - Download - 4shared If it is showing "QDloader 9008", then it means your BOOT is still damaged. SO Do jtag again with CORRECT RM-XXX |
