03-04-2015, 08:37 | #5 (permalink) |
Freak Poster Join Date: Dec 2002 Location: ...
Member: 18642 Status: Offline Thanks Meter: 44 | I removed PERM_WRITE_PROTECT but now device can not start and I can not flash. Current consumption is about 40mA. Before on LCD was the message "Unable to find bootable options". How to solve this problem? Log below. Code: 15:59:42 : 1. DO NOT USE THE PHONE"S BATTERY 15:59:42 : 2. Connect the Soldered TP Connections to ATF Box 15:59:42 : 3. Disconnect the USB Cable and Wait until the 15:59:42 : the ATF Software will tell you to Connect the USB. 15:59:42 : 15:59:42 : 15:59:42 : Interface Reset OK! 15:59:42 : eMMC Access Type: SECTOR MODE 15:59:42 : eMMC Supported Voltage Range: 15:59:42 : 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V 15:59:42 : 15:59:42 : CID : 1501004D3847325943009FFEBC5580D1 15:59:42 : CSD : D02701320F5903FFF6DBFFEF96404063 15:59:42 : 15:59:42 : eMMC Boot Information 15:59:42 : Revision 1.5 (for MMC v4.41) 15:59:42 : BOOT PARTITION : USER AREA 15:59:42 : PARTITION ACCESS : R/W USER PARTITION 15:59:42 : PERM_BOOT_CFG_PROT : DISABLED 15:59:42 : PWR_BOOT_CFG_PROT : DISABLED 15:59:42 : BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED 15:59:42 : RESET BUS WIDTH : ENABLED 15:59:42 : eMMC FirmW UPDATE : DISABLED 15:59:42 : EMMC CACHE SIZE : 0 KB 15:59:42 : SUPER PAGE SIZE : 3584 KB 15:59:42 : HC ERASE GROUP SIZE: 512 KB 15:59:42 : USER AREA SIZE : 7818182656 BYTES 15:59:42 : BOOT PARTITION SIZE: 4096 KB 15:59:42 : RPMB PARTITION SIZE: 512 KB 15:59:42 : 15:59:42 : 15:59:42 : eMMC Device Information 15:59:42 : Manufacturer ID: SAMSUNG 15:59:42 : Device Type : Embedded BGA 15:59:42 : Application ID : 00 15:59:42 : Product Name : M8G2YC 15:59:42 : Product Rev : 0.0 15:59:42 : Product SN : 9FFEBC55 15:59:42 : Manufactured : August 1997 15:59:42 : 15:59:42 : Card Specific Data 15:59:42 : CSD_STRUCTURE : Extended 15:59:42 : SPEC_VERS : Version 4.1/4.2/4.3 15:59:42 : TAAC : 13 ns 15:59:42 : TRAN_SPEED : 4000000 KHz 15:59:42 : READ_BL_LEN : 512 Bytes 15:59:42 : C_SIZE : HIGH CAPACITY 15:59:42 : WP_GRP_ENABLE : YES 15:59:42 : WRITE_BL_LEN : 512 Bytes 15:59:42 : CONTENT_PROT_APP : NO 15:59:42 : PERM_WRITE_PROTECT: NO 15:59:42 : TMP_WRITE_PROTECT : NO 15:59:42 : 15:59:42 : Extended CSD Saved: 15:59:42 : 1501004D3847325943009FFEBC5580D1.ext_csd 15:59:42 : Backup Directory: 15:59:42 : C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ 16:01:40 : ====================================================== 16:01:40 : Windows Phone 8/8.1 Lumia Flasher 16:01:40 : ====================================================== 16:01:40 : 16:01:40 : If the Phone is ALIVE 16:01:40 : 1. Power On the Phone and Connect it to the USB Port 16:01:40 : 16:01:40 : If the Phone is DEAD 16:01:40 : 1. Connect Phone to the USB Port 16:01:40 : 2. Press and Hold the VOLUME DOWN and POWER Buttons 16:01:40 : 3. Wait until the Phone Vibrates Shortly... 16:01:40 : 4. Stop Pressing the Buttons... 16:01:40 : 16:01:40 : If the Phone is DEAD BOOT 16:01:40 : 1. Connect Phone to the USB Port 16:01:40 : 2. Install Correct Drivers: 16:01:40 : "Nokia Emergency Connectivity" 16:01:40 : ====================================================== 16:01:40 : 16:01:40 : Recovery Handle Found! - (WinUSB) 16:01:42 : Sending Factory Loader... 16:01:43 : Loader Upload Done! 16:01:43 : Executing Loader... 16:01:43 : Start Loader Done! 16:01:43 : Waiting for USB Cycle... 16:01:44 : USB Cycle OK! 16:01:48 : Device Factory Mode OK! 16:01:49 : USB Reconfiguration Done... 16:01:49 : eMMC Detected OK... 16:01:49 : 16:01:49 : Extracting Partitions from FFU... 16:01:49 : Looking for SBL1... 16:01:53 : SBL1 OK 16:01:53 : Looking for SBL2... 16:01:58 : SBL2 OK 16:01:58 : Looking for SBL3... 16:02:03 : SBL3 OK 16:02:03 : Looking for UEFI... 16:02:08 : UEFI OK 16:02:08 : Looking for RPM... 16:02:12 : RPM OK 16:02:12 : Looking for TZ... 16:02:13 : TZ OK 16:02:13 : Looking for WINSECAPP... 16:02:14 : WINSECAPP OK 16:02:14 : Extracting Partitions Done! 16:02:14 : Start Writing eMMC Blocks at : 0x00000000 16:02:14 : Start Writing eMMC Blocks at : 0x01000000 16:02:14 : ERROR: eMMC WRITE Failed at 0x01000000 16:02:14 : Skipping This Partition... 16:02:14 : Start Writing eMMC Blocks at : 0x01200000 16:02:14 : ERROR: eMMC WRITE Failed at 0x01200000 16:02:14 : 7E0D07000000577269746520756E7375636365737366756CF05B7E 16:02:14 : ERROR: Flashing Failed! |
03-04-2015, 08:55 | #6 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @zaworek Write BOOT via eMMC Connection using .mmc files from here: http://forum.gsmhosting.com/vbb/10399850-post2.html |
03-04-2015, 09:30 | #7 (permalink) |
Member: 18642 Status: Offline Thanks Meter: 44 | Could not perform the operation on the second partition. I stopped it. Does this mean that the eMMC is faulty? Code: 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 1501004D3847325943009FFEBC5580D1 CSD : D02701320F5903FFF6DBFFEF96404063 eMMC Boot Information Revision 1.5 (for MMC v4.41) BOOT PARTITION : USER AREA PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3584 KB HC ERASE GROUP SIZE: 512 KB USER AREA SIZE : 7818182656 BYTES BOOT PARTITION SIZE: 4096 KB RPMB PARTITION SIZE: 512 KB eMMC Device Information Manufacturer ID: SAMSUNG Device Type : Embedded BGA Application ID : 00 Product Name : M8G2YC Product Rev : 0.0 Product SN : 9FFEBC55 Manufactured : August 1997 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 1501004D3847325943009FFEBC5580D1.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ ====================================================== Loading ATF MMC File... (Please Wait) ====================================================== MMC File Version: v11.30 MMC File Author: 963F2A3CB175EDB4B4358C42 Date Created: 05/07/2014 (dd/mm/yyyy) Description: Lumia 520 RM-914 BIG BOOT V2 [3056.40000.1408.0007] Current Partition: Partition 1 Start Writing Blocks... Writing Blocks Done! Current Partition: Partition 2 Start Writing Blocks... Operation Cancelled... EMMC Connect Error Operation Cancelled... Total Elapsed Time 00:09:41 ERROR: WRITE FAILED! |
