03-14-2015, 13:29 | #1 (permalink) |
No Life Poster Join Date: Mar 2005 Age: 43
Member: 129486 Status: Offline Thanks Meter: 66 | Nokia 520 unable to find bootable option Code: ====================================================== ====================================================== eMMC Test Point Connection Module ====================================================== ====================================================== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 1501004D384732594300721764C36059 CSD : D02701320F5903FFF6DBFFEF96404063 eMMC Boot Information Revision 1.5 (for MMC v4.41) BOOT PARTITION : USER AREA PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3584 KB HC ERASE GROUP SIZE: 512 KB USER AREA SIZE : 7818182656 BYTES BOOT PARTITION SIZE: 4096 KB RPMB PARTITION SIZE: 512 KB eMMC Device Information Manufacturer ID: SAMSUNG Device Type : Embedded BGA Application ID : 00 Product Name : M8G2YC Product Rev : 0.0 Product SN : 721764C3 Manufactured : June 1997 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 1501004D384732594300721764C36059.ext_csd Backup Directory: L:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ ERROR: PERM_WP BIT is NOT SET... You do not have to Perform this Operation... Code: ====================================================== Loading ATF MMC File... (Please Wait) ====================================================== MMC File Version: v11.30 MMC File Author: 963F2A3CB175EDB4B4358C42 Date Created: 05/07/2014 (dd/mm/yyyy) Description: Lumia 520 RM-914 BIG BOOT V2 [3056.40000.1408.0007] Current Partition: Partition 1 Start Writing Blocks... R1b Timeout Error! R1b Timeout Error!EMMC Connect Error Operation Cancelled... Total Elapsed Time 00:01:27 ERROR: WRITE FAILED! |
03-14-2015, 17:22 | #2 (permalink) |
Freak Poster Join Date: May 2011 Location: Himachal Pradesh,Kangra,India
Member: 1587904 Status: Offline Thanks Meter: 56 | Same problem with my Lumia 520 also tried to boot repair but not done I think this emmc boot file work with Lumia 520 8.0 windows version and my phone is updated to 8.1 version possibly there may be bug. Also product manager look inside this thread as here is same problem like mine please provide the 100% working solution still Lumia 520 is in my hands Sent from my Lumia520 |
03-14-2015, 19:25 | #3 (permalink) | |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,117 | Quote:
This bug is from windows 8.1 update, most times when done via OTA. Thread starter and you have exactly the same eMMC brand/model/version. I will check it on you PC tomorrow. Look at your own thread for details about appointment. | |
