04-07-2011, 09:44 | #1 (permalink) |
No Life Poster Join Date: Feb 2006 Location: iraq
Member: 234567 Status: Offline Thanks Meter: 45 | c1 error: pbl not found i try flashing many times c1 rm-607 with atf but cant flashing it show me this error : pbl not found so i setup pc suite for nokia but same problem |
04-07-2011, 09:49 | #2 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Quote:
Do this: 1. power off phone 2. select flash files 3. press flash button 4. insert cable to phone do this few times, and it will be OK BR | |
05-03-2011, 14:36 | #3 (permalink) |
Junior Member Join Date: Jul 2008
Member: 817702 Status: Offline Thanks Meter: 7 | NokiaC1-00 RM-689 (2 sim) flash error Problem - Please HELP !!! VBATT OFF... VBATT ON Setting VBATT Done!... Booting Phone... CPU ID Response: A200341100 CPU Type: XG110 2.1B Phone Booted at after First attempt... ************************************************** **** TIME STARTS HERE ************************************************** **** Sending PBL 37888 bytes... PBL Successfully Sent... Sending SBL 65024 bytes... SBL Successfully Sent... Flash Chip Manufacturer: Samsung Electronics Corp. Flash Chip Type: K8S6415ETC 64 Mbit (4Mb x 16) NOR Extended Information: Multiple Bank / Burst / 1.8v Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-689\rm689_003.000 FIRMWARE Image Found... Number of Sections: 03 FIRMWARE Certificate Block Sent Successfully... Processing Section 01 of 03 FIRMWARE Erase Block: 0x00800000~0x00A0FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 2162688 bytes Data Checksum: C237 Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Processing Section 02 of 03 FIRMWARE Erase Block: 0x00C60000~0x00EAFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 2140288 bytes Data Checksum: AD73 Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Processing Section 03 of 03 FIRMWARE Erase Block: 0x00FFC000~0x00FFFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 64 bytes Data Checksum: 0000 Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-689\rm689_003.00mc PPM Image Found... Number of Sections: 01 PPM Certificate Block Sent Successfully... Processing Section 01 of 01 PPM Erase Block: 0x00210000~0x003E9E7E Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 1941120 bytes Data Checksum: BDA3 Uploading Data Blocks to phone... PPM Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-689\rm6890_nai03.00mc CONTENT Image Found... Number of Sections: 01 CONTENT Certificate Block Sent Successfully... Processing Section 01 of 01 CONTENT Erase Block: 0x00EB0000~0x00F01AFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 334592 bytes Data Checksum: 9D98 Uploading Data Blocks to phone... CONTENT Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Exit Flash Mode Done... Time Elapse : 00:02:33 ************************************************** **** You must Factory Reset the phone to enable the ringtones and other customized settings to work ************************************************** **** Waiting For Phone to go Online... 5, 4, 3, 2, 1... ERROR : PHONE READ INFO FAILED |
12-01-2011, 07:05 | #4 (permalink) |
No Life Poster Join Date: Oct 2006 Location: Jammu & Kashmir (India)
Member: 367928 Status: Offline Thanks Meter: 178 | Here is another , 1202 fleshing error here i info VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Booting Phone... CPU ID Response: 830011 CPU Type: XG101/XG102 Phone Booted at after First attempt... ************************************************** **** START INFINEON BUS CHECK ************************************************** **** Sending PBL 12288 bytes... PBL Successfully Sent... Sending SBL 39624 bytes... SBL Successfully Sent... Flash Chip Manufacturer: Intel Electronics Corp. Flash Chip Type: 2000W0YTQE 64 Mbit (4Mb x 16) NOR Extended Information: Customized Device / 1.8v ************************************************** **** INFINEON BUS CHECK DONE ************************************************** **** MCU: V 5.00 08-02-10 RH-111 (c) NMP IMEI: 352004044005839 Product Serial Number: 2670EACAI Product Code : 0574736 Module Code : 0203772 Basic Production Code: 0574271 PPM SW Version : V 5.00 08-02-10 RH-111 (c) NMP MG ADSP Version : p V 5.00\n08-02-10\nRH-111\n(c) NMP\nmg MCU SW Version : V 5.00 08-02-10 RH-111 (c) NMP HW Version : 1506 UEM Version : 1328 UPP Version : 8850 LCD Version : adapter_bw ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 0000000000030002 ASIC : 11 PROVIDER : Default Test Operator Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open and when try to flesh, VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Booting Phone... CPU ID Response: 830011 CPU Type: XG101/XG102 Phone Booted at after First attempt... ************************************************** **** TIME STARTS HERE ************************************************** **** ERROR: PBL NOT FOUND !!! Flashing ERROR i try many times, phone is in blinking (when power on blink on nokia thenturn off) |
12-01-2011, 07:44 | #5 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @ALL PBL not found means your flash files are not correct as they may have been downloaded from another team's Support Site which they edit the flash files so that it will only work with their software. Solution is simple, just download the Flash Files again using ATF Support or Navifirm (if available) B.R. |
12-02-2011, 15:07 | #7 (permalink) |
Member: 367928 Status: Offline Thanks Meter: 178 | N73 power off after 10/15/20/25/30 menit when i chk sd test was fail i repare sd repare still power off after 10/15/20/25/30 ment ( i call about 25 menit with that fone, but when i cut call after 2/3 menit i power off Basic Phone Information ================================================ MCU Version: V 05wk47v62 05-12-08 RM-133 (c) Nokia. IMEI Plain : 353548024371016 IMEI Spare : A353548024371010 IMEI SV : 33535480243710181F Phone Model: Nokia N73 Category : Imaging Phone Phone Type : RM-133 ================================================ Extended Phone Information ================================================ Product Serial Number: CCH535439 Product Code : 0543843 Module Code : 0202855 Basic Production Code: 0537044 MCU SW Version : V 05wk47v62 05-12-08 RM-133 (c) Nokia. HW Version : 7201 RFIC Version : 17211721 DSP Version : scarfe_mc.05wk46v50p2 APE BT Version : HCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10. AHNE Version : 30 APE SW Core Version : V 4.0850.43.0.1 12-12-2008 RM-133 Variant Version : V 4.0850.43.0.1-12 12-12-2008 RM-133 RETU Version : 15 TAHVO Version : 22 APE HW Version : 1 APE ADSP SW Version : 256 Bluetooth ID : 00:21:08:5A:E5:55 CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I ================================================ Simlock Information ================================================ CONFIG KEY : 0000000000000000 PROVIDER KEY : 2440700000000000 NETWORK NAME : Nokia Default;Finland LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10 SIMLOCK TABLE : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK STATE : Not Locked SIMLOCK_TYPE : PA_SL1 SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : 12345 SUPER_DONGLE_TEST : PASSED ================================================ SL1/SL2 Phone detected ================================================ PHONE_MODE : LOCAL DCC ID : NOT USED Last edited by zargar322; 12-02-2011 at 15:11. Reason: add log |
The Following User Says Thank You to zargar322 For This Useful Post: |
12-03-2011, 20:09 | #10 (permalink) |
Member: 367928 Status: Offline Thanks Meter: 178 | APE PAPUBKEYS HASH: 5E8D0D504A0902E261268C14FCD8A2C9093523BC( CMT and APE PAPUBKEYS HASH are Identical ) START READING RPL DATA Reading : NPC (CMT) OK Reading : VARIANT (CMT) OK Reading : CCC (CMT) CCC : Empty Reading : HWC (CMT) HWC : Empty Reading : R&D (CMT) OK Reading : PARTNERC (CMT) PARTNERC : Empty Reading : MDM_KEYS (CMT) MDM_KEYS : Empty Reading : NPC (APE) NPC : Empty Reading : VARIANT (APE) VARIANT : Empty Reading : CCC (APE) CCC : Empty Reading : HWC (APE) HWC : Empty Reading : R&D (APE) OK Reading : PARTNERC (APE) PARTNERC : Empty Reading : MDM_KEYS (APE) MDM_KEYS : Empty FINISHED READING RPL DATA RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\backup\353548024371016\3535480243710 16_125816.rplFlashInfo.RestartMode : 2 Last edited by zargar322; 12-03-2011 at 20:19. |
12-05-2011, 08:19 | #13 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @zargar322 Because it is empty and this is not a problem. Did ATF Software tell you there was a problem? No, because there is no Problem and this is perfectly normal for N73 phones. |
12-05-2011, 08:53 | #14 (permalink) |
Member: 367928 Status: Offline Thanks Meter: 178 | then why it shut down after 5/10/15/20/25 menit, is it HW or bad rpl pllllzzzz i erase ape, can i erase cmt also, or ........................ |
12-05-2011, 10:20 | #15 (permalink) | |
Yes, erase both CMT and APE, after erase, full flash phone Write RPL backup and Repair SIMLOCK, SUPER DONGLE data and SX4 Auth... If problem remain same, chk phone's hardware. BR | |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
hope it is not too comercial | aleksj | Wanted Products | 0 | 06-12-2000 13:22 |
Nokia 5110 - "SIMcard not accepted". | Kond | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 03-02-2000 22:46 |
winlock wintesla m2bus do not work | Bigbrothers2000 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 01-26-2000 14:31 |
