06-21-2015, 16:13 | #3 (permalink) |
No Life Poster Join Date: Oct 2014 Location: Bangladesh
Member: 2274875 Status: Offline Sonork: ? Thanks Meter: 298 | You Found USB Driver .. Local Disk C:/AdvanceBox Turbo Flasher/Driver Open Your Advancebox.exe/Nokia Service/Go to Windows Phones Tab & Select Your Lumia 630/ Wirte Flash Section / Click Mcu & Select your .FFU Flash File / Then Prosec Flash Botton |
06-21-2015, 16:19 | #4 (permalink) |
Junior Member Join Date: Oct 2014 Location: Indonesia
Member: 2267744 Status: Offline Thanks Meter: 5 | install driver nokia emergecy, then turn off phone. press vol - with plug in usb cable. wait untill instalation driver succes. input file only on mcu. good luck |
06-22-2015, 17:19 | #5 (permalink) |
No Life Poster Join Date: Jul 2007 Location: Onilne Mobile Technology
Member: 548479 Status: Offline Thanks Meter: 138 | Windows Phone 8/8.1 Flashing Started Loading Flash Files Please Wait... [DEAD BOOT REPAIR via USB is SUPPORTED] ================================================== ==== Windows Phone 8/8.1/10 Lumia Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Connect Phone to the USB Port 2. Press and Hold the VOLUME DOWN and POWER Buttons 3. Wait until the Phone Vibrates Shortly... 4. Stop Pressing the Buttons... If the Phone is DEAD BOOT 1. Connect Phone to the USB Port 2. Install Correct Drivers: "Nokia Emergency Connectivity" ================================================== ==== ================================================== ==== ERROR: Active Phone Handle was NOT DETECTED ================================================== ==== ================================================== ==== ERROR: Flashing Failed! dear supporter not flashing the phone? winusb device[null] how to problem solved?please aurjent solution need?my pc win xp? |
