10-14-2012, 10:20 | #2 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Hi, Post here Scan Phone logs, so we may see what DCC file it requires... BTW, DCC files are available here: C:\AdvanceBox Turbo Flasher\Nokia\DCC\Common BR |
10-15-2012, 08:14 | #3 (permalink) |
No Life Poster Join Date: Sep 2011 Location: Dubz
Member: 1651733 Status: Offline Thanks Meter: 21 | ================================================ Extended Phone Information ================================================ Product Serial Number: CUE933035 Product Code : 0595081 Module Code : 0204444 Basic Production Code: 0587862 Long Production SN : 0 PPM SW Version : V 09.85 04-11-10 RM-615 (c) Nokia MEH BT MCM Version : 1673-46038 MCU SW Version : V 09.85 04-11-10 RM-615 (c) Nokia HW Version : 0423 RFIC Version : |Vapaus_5.1 | ??? DSP Version : ICPR91_10w19 LCD Version : SEIKO Content Pack Version : Content: Vodacom ZA V 09.85 04-11-10 RM-615 (c) Nokia AHNE Version : 41 RETU Version : 40 TAHVO Version : 00 Bluetooth ID : 78:2E:EF:52:80:39 CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA II, WCDMA V ================================================ Simlock Information ================================================ CONFIG KEY : 0000000000000000 PROVIDER KEY : 2440700000000000 NETWORK NAME : Nokia Default;Finland LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10 SIMLOCK TABLE : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK STATE : Not Locked SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : 27435353 PHONE_MODE : TEST ================================================ Dynamic Camera Configuration ================================================ DCC ID : NI00IIIIRR0300000000 DCC Ver: XXXXXX ERROR: DCC File Mismatched! Required DCC File: NI00IIIIRR0300000000 Write the correct DCC to Fix the Problem |
10-15-2012, 16:46 | #4 (permalink) | |
Freak Poster Join Date: Dec 2010 Location: gujrat pakistan
Member: 1462894 Status: Offline Sonork: 100.1609879 Thanks Meter: 47 | this one is hardware problem Quote:
may be ic | |
