01-20-2011, 08:14 | #1 (permalink) |
No Life Poster Join Date: May 2005 Location: GULMI Age: 49
Member: 143007 Status: Offline Thanks Meter: 141 | Booting/Flashing Failed...Please Try Again... usb hub ok box reset,uninstorl instorl and tik skip, skip erase, skip ape,skip h/wid chk but coming same error pls chk log, e5, c5, c7,x3,x6, x2, to maney more models comming error this is dead fone, Number of Image Files: 4 Processing Image File : rm632_042.010_prd.core.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 466 Entry Point: 0x01E2 Page Format : -1 MAX PAGE : 0x00040000 Processing Image File : rm632_042.010_C00.01_DEFAULT_prd.rofs3.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 35 Entry Point: 0x00E7 Page Format : -1 MAX PAGE : 0x00040000 Processing Image File : rm632_042.010_24.01_Hebrew_QW_prd.rofs2.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 244 Entry Point: 0x00E7 Page Format : -1 MAX PAGE : 0x00040000 Processing Image File : rm632_042.010_U001.000_prd.uda.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 87 Entry Point: 0x00E7 Page Format : -1 MAX PAGE : 0x00040000 AUTO SELECTED DEAD USB FLASHING... If Flashing DOES NOT Start in 5 Seconds, Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly.. AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 Cant verify BootRom! AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 BootRom Verified! BootFlashModeDCT5Ex Succeded After 2 Tries SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000003 ID DWORD 1 : 00000226 ID DWORD 2 : 00010007 ID DWORD 3 : 600C1921 ID DWORD 4 : 02031104 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000C35 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000C30 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 0300020D ID DWORD 1 : B7A40344 ID DWORD 2 : ACB7D56E ID DWORD 3 : 0A0AFE11 ID DWORD 4 : 16629FCA 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 91 6F 75 21 7F 32 08 12 48 B1 5C 38 DF C8 E8 1B 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : E693EF0D CRC 1 : AC22615B START FLASHING RawLoaderExtract: Processing rm632_042.010_prd.core.fpsx Match LOADER : C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\RAPUv11_2n d.fg Loader Uploaded..... MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 06 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> not used Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 0050 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0031 6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5 Block Length : 09 BB ASIC Index : CMT 00 Data : SearchForBootstrap_DCT5 : No Error - 0 (0x00) Flash Descriptor Manufacturer Code : 00EC Device ID : 0050 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 20000000 (512 MB) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 ROOTHASH : 916F75217F32081248B15C38DFC8E81B Match File.....C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\RAPUv11_XS R17_alg.fg Done! FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) Booting/Flashing Failed... Please Try Again... |
The Following User Says Thank You to gsm st For This Useful Post: |
01-26-2011, 20:32 | #5 (permalink) |
No Life Poster Join Date: Jan 2000 Location: GSM Forum
Member: 871 Status: Offline Thanks Meter: 602 | First make sure you have installed the latest Nokia Connectivity Drivers... http://174.120.45.27/tmp/Nokia_Conne...r_7_1_36_0.msi If you cannot flash any phone in USB,, then your PC have setup problems. There is nothing wrong with ATF USB Flashing especially on RAPUYAMA PHONES. We have ALL RAPUYAMA PHONES in our office and we have tested ALL of them. |
01-27-2011, 08:00 | #6 (permalink) | |
Member: 143007 Status: Offline Thanks Meter: 141 | Quote:
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
