Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 06-08-2012, 11:17   #1 (permalink)
Member: 392149
Sonork: 100.1597220
Thumbs up Nokia 5800 after flash just vibrat
Hi all nokia 5800 flash ok but after flash just vibrat phone mode change ok
local mode when am set to normal phone it is on and working not power
on on battery or supply new update have bugs????????????
Old 06-08-2012, 11:20   #2 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
@shh_903
Post here flashing logs... Always flash phone with SAME Product Code
file.
Old 06-08-2012, 11:26   #3 (permalink)
tauheed9's Avatar
Member: 1761678
Sonork: 100.1615439
use latest version firmware 60version 5800
Old 06-08-2012, 11:32   #4 (permalink)
...:::::NP™:::::...'s Avatar
Member: 1162626
Sonork: 100.1591727
Post Here Scan Short & Where You Can Understand New Update is Bug.
Must Be Use Same Products Code & latest Version Firmware With Flash.
Then Result Post Here
Old 06-08-2012, 11:38   #5 (permalink)
fazal subhan's Avatar
Member: 235459
dear flash with latest version..........
Old 06-08-2012, 11:45   #6 (permalink)
Member: 392149
Sonork: 100.1597220
Originally Posted by ..::Angel::.. View Post
@shh_903
file.
Bro here is flashing logs
Free Cloud Storage - MediaFire
Old 06-08-2012, 11:46   #7 (permalink)
Member: 392149
Sonork: 100.1597220
Bro am also use latest version for flashing u may chek in logs
Old 06-08-2012, 11:50   #8 (permalink)
Member: 392149
Sonork: 100.1597220
@angel
Bro one more thing is am also make backup rpl and simlock and now
rpl write on it ok but simlock not write what the h e l l is this why simlock
not write on it 8.80 not make perfect backup u can chek in logs and screen shot
Old 06-08-2012, 11:55   #9 (permalink)
Member: 643472
Sonork: 100.96901
@angel
Hi,
Post logs in forum with CODE tag, please.
Backup RPL is perfect and Okay...
RPL backup in .rpl format and
SIMLock backup in .pm format.. both you can read, write easily.
Old 06-08-2012, 12:04   #10 (permalink)
Member: 392149
Sonork: 100.1597220
Hi,
Here is simlock write logs
21:23:24 : SX4 Custom Keys Stand Alone Edition
21:23:24 : ================================================
21:23:24 :
21:23:25 : >>> : SX4 Auth Successfull
21:23:25 : Selected PM File: C:\AdvanceBox Turbo Flasher\Nokia\Backup\356039030147290\SL2_certifica te_V ICPR72_10w29_tube1 24-05-11 RM-356 (c) Nokia_356039030147290__90623.pm
21:23:25 : Start Uploading PM...
21:23:25 : Field : 120 Sub : 0 Byte(s): 944 - Ok
21:23:25 : Field : 120 Sub : 1 Byte(s): 80 - Ok
21:23:25 : Field : 120 Sub : 2 Byte(s): 20 - Ok
21:23:25 : Field : 120 Sub : 3 Byte(s): 112 - Ok
21:23:25 : Field : 308 Sub : 0 Byte(s): 4 - Failed
21:23:27 : Field : 308 Sub : 1 Byte(s): 8192 - Failed
21:23:27 : Field : 308 Sub : 3 Byte(s): 4 - Failed
21:23:27 : Field : 308 Sub : 4 Byte(s): 4 - Failed
21:23:27 : Field : 308 Sub : 6 Byte(s): 4 - Failed
21:23:27 : Field : 308 Sub : 7 Byte(s): 4 - Failed
21:23:27 : Field : 308 Sub : 9 Byte(s): 40 - Failed
21:23:27 : PM Upload Done!...
Old 06-08-2012, 12:09   #11 (permalink)
Member: 392149
Sonork: 100.1597220
Hi,
I didnt know how to Post logs in forum with CODE tag a ll send u on sonork
Old 06-08-2012, 12:17   #12 (permalink)
Member: 643472
Sonork: 100.96901
21:23:24 :
Its impossible that ATF make wrong backup.
PM120 sub field 1 and 2 are not correct. Before backup simlock
you have already WRITTEN any PM on this phone.. so it got damaged
and AFTER You backup simlock with ATF, so it will backup DAMAGED
data which was INSIDE phone...
Old 06-08-2012, 12:22   #13 (permalink)
Member: 392149
Sonork: 100.1597220
Here is logs
21:28:10 : ************************************************** ****
21:28:10 : TIME STARTS HERE
21:28:10 :
21:28:10 : BootFlashModeDCT5Ex Succeeded after 3 Attempts
21:28:10 : SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned
21:28:10 : Number of Sub Blocks 7 (0x07)
21:28:10 : 1 SYSTEM_ASIC_ID 01
21:28:10 : Block Length : 21 (15)
21:28:10 : BB ASIC Index : 0 (00) CMT
21:28:10 : ID DWORD 0 : 00000001
21:28:10 : ID DWORD 1 : 00000226
21:28:10 : ID DWORD 2 : 00010006
21:28:10 : ID DWORD 3 : 400C1921
21:28:10 : ID DWORD 4 : 01031103
21:28:10 : 2 EM_ASIC_ID 02
21:28:10 : Block Length : 5 (05)
21:28:10 : ID DWORD 0 : 00000295
21:28:10 : 3 EM_ASIC_ID 02
21:28:10 : ID DWORD 0 : 00000B22
21:28:10 : 4 PUBLIC_ID 12
21:28:10 : ID DWORD 0 : 02800116
21:28:10 : ID DWORD 1 : 3B7B0052
21:28:10 : ID DWORD 2 : 8142012F
21:28:10 : ID DWORD 3 : 76C35652
21:28:10 : ID DWORD 4 : 92DB3C37
21:28:10 : 5 ASIC_MODE_ID 13
21:28:10 : Block Length : 2 (02)
21:28:11 : Mode Id : 00
21:28:11 : 6 ROOT_KEY_HASH 14
21:28:11 : Block Length : 17 (11)
21:28:11 : BB ASIC Index : 0 (00) CMT
21:28:11 : Hash : CA EE BB 65 D3 C4 8E 6D C7 3B 49 DC 50 63 A2 EE
21:28:11 : 7 ROM_ID 15
21:28:11 : Block Length : 9 (09)
21:28:11 : CRC 0 : 4B9B7510
21:28:11 : CRC 1 : 3E691FF8
21:28:11 : Checksum 71
21:28:11 :
21:28:11 : SearchForBootstrap_DCT5..
21:28:11 : C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_2nd.fg
21:28:11 : Boot File - Version 011.034.00
21:28:11 : Boot File - Revision 0x0002 (2)
21:28:11 : eBB5ProtocolType == New
21:28:11 : PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0"
21:28:11 : PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0"
21:28:11 : SearchForBootstrap_DCT5 : No Error - 0 (0x00)
21:28:11 : Secondary Loader Sent...
21:28:11 : TransmissionTypeRequest_DCT5_NewProtocol
21:28:11 : TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5
21:28:11 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0
21:28:11 : FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX
21:28:11 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C
21:28:11 : Transmission Type Request Sent...
21:28:11 : ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000)..
21:28:11 : MCU_CONFIGURATION_RESPONSE_BB5:
21:28:11 : MessageID : 06
21:28:11 : SubBlocks : 06
21:28:11 : 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
21:28:11 : Block Length : 0B
21:28:11 : BB ASIC Index : CMT 00
21:28:11 : Device Type : RAM 05
21:28:11 : Device Index : 00
21:28:11 : Manufacturer Code : 0000 -> Flash
21:28:11 : Device ID : 0000 -> not detected
21:28:11 : Extended/Fixed ID : 0000
21:28:11 : Revision ID : 0000
21:28:11 : 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
21:28:11 : Device Type : MMC 04
21:28:11 : Manufacturer Code : FFFF -> Flash
21:28:11 : Device ID : 0000 -> BAD FLASH TYPE
21:28:11 : 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
21:28:11 : Device Type : NOR 00
21:28:11 : Manufacturer Code : 0400 -> Flash
21:28:11 : Device ID : 0000 -> Type not in database
21:28:11 : 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
21:28:11 : Device Index : 01
21:28:11 : Manufacturer Code : 0000 -> SPANSION
21:28:11 : Device ID : 0001 -> not used
21:28:11 : 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
21:28:11 : Device Type : MuxOneNAND 03
21:28:11 : Manufacturer Code : 00EC ->
21:28:11 : Device ID : 0040 -> KAT00F00RA
21:28:11 : Revision ID : 0121
21:28:11 : 6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5
21:28:11 : Block Length : 09
21:28:12 : BB ASIC Index : CMT 00
21:28:12 : Data : XSR 1.5
21:28:12 : Checksum : 25
21:28:12 : SearchForBootstrap_DCT5 : No Error - 0 (0x00)
21:28:12 : FLS1SendAlgoCodeEx..
21:28:12 : SendAlgoCode_DCT5..
21:28:12 : SearchForAlgorithm_DCT5..
21:28:12 : Looking for ALL Devices...
21:28:12 : Searching Algorithm Files MuxOneNAND (03) ManID :00EC DevID :0040 ExtID :0000 RevID :0121
21:28:12 : Flash Descriptor
21:28:12 : Manufacturer Code : 00EC
21:28:12 : Device ID : 0040
21:28:12 : Extended/Fixed ID : 0000
21:28:12 : Revision ID : 0000
21:28:12 : Size : 10000000 (256 MB)
21:28:12 : VPP Info : 0000
21:28:12 : Erase10s : 1E
21:28:12 : Block1s : 32
21:28:12 : BErase1s : 02
21:28:12 : Reserved0 : 00
21:28:12 : Reserved1 : 00
21:28:12 : Reserved2 : 00
21:28:12 : C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_XSR15_alg.f g
21:28:12 : Algorithm File - Version 011.034.00
21:28:12 : Algorithm File - Revision 0x0002 (2)
21:28:12 : eBB5ProtocolType == New
21:28:12 : Algo Loader Sent...
21:28:12 : SendCodeStart_NewProtocol :
21:28:15 : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00)
21:28:15 : TransmissionTypeRequest_DCT5_NewProtocol
21:28:15 : TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5
21:28:15 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0
21:28:15 : FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX
21:28:15 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C
21:28:15 : SendAlgoCodeFile_DCT5 : No Error - 0 (0x00)
21:28:15 : FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
21:28:15 : FUR control Ok...
21:28:15 : VPP Enabled by Software
21:28:15 : Using Internal VPP
21:28:15 : FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4
21:28:15 : Pabub KEY Request
21:28:15 : PhoneInfoRequest_BB5 (Asic Index 00 )
21:28:15 : PHONE_INFO_RESPONSE_BB5
21:28:15 : PAPUB_KEYS_HASH_RESP_BB5 2A
21:28:15 : BB Asic Index : 00
21:28:15 : CMT PAPUBKEYS HASH:
21:28:15 : 76A20187051C30162EE91C77AE5E6011F5F1BA61
21:28:15 :
21:28:16 : StartErase_DCT5...
21:28:16 : BlockLength : 0x10 (16)
21:28:16 : ERASE Blocks : 0x01 (1)
21:28:16 : 0 ERASE_AREA_BB5 0x13
21:28:16 : Block Length : 0x0D (13)
21:28:16 : BB ASIC Index : 0x00 CMT
21:28:16 :
21:28:16 : Erase_SendEraseBlock_BB5_NAND
21:28:16 : Task in Progress... Please Wait...
21:28:16 :
21:28:16 : Successfully erased..
21:28:16 :
21:28:16 : Now Writing : CMT NPC Certificate 0x0200 Bytes
21:28:16 :
21:28:16 : NPC Write Successful...
21:28:16 :
21:28:16 :
21:28:16 :
21:28:17 :
21:28:17 : Now Writing : CMT CCC Certificate 0x0200 Bytes
21:28:17 :
21:28:17 : CCC Write Successful...
21:28:17 :
21:28:17 : StartErase_DCT5...
21:28:17 : BlockLength : 0x10 (16)
21:28:17 : ERASE Blocks : 0x01 (1)
21:28:17 : 0 ERASE_AREA_BB5 0x13
21:28:17 : Block Length : 0x0D (13)
21:28:17 : BB ASIC Index : 0x00 CMT
21:28:17 :
21:28:17 : Erase_SendEraseBlock_BB5_NAND
21:28:17 : Task in Progress... Please Wait...
21:28:17 :
21:28:17 : Successfully erased..
21:28:17 :
21:28:17 : Now Writing : CMT HWC Certificate 0x0200 Bytes
21:28:17 :
21:28:17 : HWC Write Successful...
21:28:17 :
21:28:17 :
21:28:17 :
21:28:18 :
21:28:18 : Now Writing : CMT R&D Certificate 0x0200 Bytes
21:28:18 :
21:28:18 : R&D Write Successful...
21:28:18 :
21:28:18 :
21:28:18 : Write Certificates OK!
21:28:18 :
21:28:18 :
21:28:18 : RPL Upload Finished!!!
21:28:50 :
21:28:50 : ================================================
21:28:50 : Basic Phone Information
21:28:50 : MCU Version: V ICPR72_10w25.3 11-10-10 RM-356 (c) Nokia
21:28:50 : IMEI Plain : 356039030147290
21:28:50 : IMEI Spare : A356039030147290
21:28:50 : IMEI SV : 33560390301472970F
21:28:50 : Phone Model: Nokia 5800 XpressMusic
21:28:50 : Category : Classic Phone
21:28:50 : Phone Type : RM-356
21:28:50 :
21:28:50 :
21:28:50 :
21:28:50 : SX4 Custom Keys Stand Alone Edition
21:28:50 :
21:28:51 : >>> : SX4 Auth Successfull
21:28:51 : Selected PM File: C:\AdvanceBox Turbo Flasher\Nokia\Backup\356039030147290\SL2_certifica te_V ICPR72_10w29_tube1 24-05-11 RM-356 (c) Nokia_356039030147290__90623.pm
21:28:51 : Start Uploading PM...
21:28:51 : Field : 120 Sub : 0 Byte(s): 944 - Ok
21:28:51 : Field : 120 Sub : 1 Byte(s): 80 - Ok
21:28:51 : Field : 120 Sub : 2 Byte(s): 20 - Ok
21:28:51 : Field : 120 Sub : 3 Byte(s): 112 - Ok
21:28:51 : Field : 308 Sub : 0 Byte(s): 4 - Failed
21:28:53 : Field : 308 Sub : 1 Byte(s): 8192 - Failed
21:28:53 : Field : 308 Sub : 3 Byte(s): 4 - Failed
21:28:53 : Field : 308 Sub : 4 Byte(s): 4 - Failed
21:28:53 : Field : 308 Sub : 6 Byte(s): 4 - Failed
21:28:53 : Field : 308 Sub : 7 Byte(s): 4 - Failed
21:28:53 : Field : 308 Sub : 9 Byte(s): 40 - Failed
21:28:53 : PM Upload Done!...
21:29:04 :
21:29:04 : ================================================
21:29:04 : Basic Phone Information
21:29:04 : MCU Version: V ICPR72_10w25.3 11-10-10 RM-356 (c) Nokia
21:29:04 : IMEI Plain : 356039030147290
21:29:04 : IMEI Spare : A356039030147290
21:29:04 : IMEI SV : 33560390301472970F
21:29:04 : Phone Model: Nokia 5800 XpressMusic
21:29:04 : Category : Classic Phone
21:29:04 : Phone Type : RM-356
21:29:04 :
21:29:04 :
21:29:04 :
21:29:04 : SX4 Custom Keys Stand Alone Edition
21:29:04 :
21:29:04 : >>> : SX4 Auth Successfull
21:29:04 : Selected PM File: C:\AdvanceBox Turbo Flasher\Nokia\Backup\356039030147290\SL2_certifica te_V ICPR72_09w02.3 26-01-09 RM-356 (c) Nokia_356039030147290_Not Locked_82908.pm
21:29:04 : Start Uploading PM...
21:29:05 : Field : 120 Sub : 0 Byte(s): 944 - Ok
21:29:05 : Field : 120 Sub : 1 Byte(s): 80 - Ok
21:29:05 : Field : 120 Sub : 2 Byte(s): 20 - Ok
21:29:05 : Field : 120 Sub : 3 Byte(s): 112 - Ok
21:29:05 : Field : 308 Sub : 0 Byte(s): 4 - Failed
21:29:07 : Field : 308 Sub : 1 Byte(s): 8192 - Failed
21:29:07 : Field : 308 Sub : 3 Byte(s): 4 - Failed
21:29:07 : Field : 308 Sub : 4 Byte(s): 4 - Failed
21:29:07 : Field : 308 Sub : 6 Byte(s): 4 - Failed
21:29:07 : Field : 308 Sub : 7 Byte(s): 4 - Failed
21:29:07 : Field : 308 Sub : 9 Byte(s): 40 - Failed
21:29:07 : PM Upload Done!...
21:29:12 :
21:29:12 : FACTORY SET TO : Full Factory Set
21:29:13 : OK
21:29:13 : FACTORY SET TO : User Data
21:29:13 : OK
21:29:13 : FACTORY SET TO : Leave Factory
21:29:13 : OK
21:29:13 : FACTORY SET TO : Service Center
21:29:13 : OK
21:29:13 : FACTORY SET TO : Software Upgrade
21:29:13 : OK
21:29:13 : FACTORY SET TO : Production Tune
21:29:13 : OK
21:29:15 :
21:29:15 :
21:29:15 : ================================================
21:29:15 : Basic Phone Information
21:29:15 : MCU Version: V ICPR72_10w25.3 11-10-10 RM-356 (c) Nokia
21:29:15 : IMEI Plain : 356039030147290
21:29:15 : IMEI Spare : A356039030147290
21:29:15 : IMEI SV : 33560390301472970F
21:29:16 : Phone Model: Nokia 5800 XpressMusic
21:29:16 : Category : Classic Phone
21:29:16 : Phone Type : RM-356
21:29:16 :
21:29:16 : ================================================
21:29:16 : Extended Phone Information
21:29:16 : Product Serial Number: 0
21:29:16 : Long Production SN : 0
21:29:17 : MCU SW Version : V ICPR72_10w25.3 11-10-10 RM-356 (c) Nokia
21:29:17 : RFIC Version : 17141715
21:29:17 : DSP Version : ICPR72_10w16
21:29:18 : AHNE Version : 11
21:29:18 : APE SW Core Version : V 52.0.007
21:29:18 : Variant Version : V 52.0.007V 52.0.007 V 52.0.007
21:29:18 : APE Test Version : eno_version
21:29:18 : RETU Version : 15
21:29:18 : TAHVO Version : 22
21:29:18 : APE HW Version : 256
21:29:18 : APE ADSP SW Version : 256
21:29:18 : Wireless LAN ID : 00:250E3:E7
21:29:18 : Bluetooth ID : 00:250E:85:C7
21:29:19 : CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA VIII
21:29:19 :
21:29:19 : ================================================
21:29:19 : Simlock Information
21:29:19 : Unable to read SP Data..
21:29:22 :
21:29:22 : ================================================
21:29:22 : Basic Phone Information
21:29:23 : MCU Version: V ICPR72_10w25.3 11-10-10 RM-356 (c) Nokia
21:29:23 : IMEI Plain : 356039030147290
21:29:23 : IMEI Spare : A356039030147290
21:29:23 : IMEI SV : 33560390301472970F
21:29:23 : Phone Model: Nokia 5800 XpressMusic
21:29:23 : Category : Classic Phone
21:29:23 : Phone Type : RM-356
and i give u all logs u may check them ur self
Old 06-08-2012, 12:24   #14 (permalink)
Member: 643472
Sonork: 100.96901
@shh_903
Repair SIMLocks from IMEI and LOCKS tab...
You have ALREADY corrupted backup. so, it can't be written.
but we can repair simlock data, since its SL2 phone...
Old 06-08-2012, 12:32   #15 (permalink)
Member: 392149
Sonork: 100.1597220
@shh_903
Bro and another thing is that on this box 4 to 5 other cells have been dead which
i recovered on other tools
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 73 05-15-2013 13:07
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
Page generated in 0.41928 seconds with 11 queries
