07-13-2013, 13:30 | #1 (permalink) |
No Life Poster Join Date: Sep 2008 Location: Chittagong, Bangladesh Age: 40
Member: 866650 Status: Offline Sonork: mdsalimkhan_05 Thanks Meter: 147 | Nokia 5800 rm-427 SECURITY_TEST FAILED Atfer flash phone is dead I backup Rpl and simlock before flash simlock is sl2 I erase phone and flash and writhe rpl after write rpl I write simlock as pm then show SECURITY_TEST FAILED How to solve this problem Please help me Remember that there are no pm file (rm-427) at ATF pm folder here log Product Serial Number: 0 Long Production SN : 0 MCU SW Version : V ICPR72_09w20.5.2 07-09-09 RM-427 (c) Nokia RFIC Version : 17141715 DSP Version : ICPR72_09w19_1 AHNE Version : 11 APE SW Core Version : V 30.0.011.1 Variant Version : V 30.0.011.1V 30.0.011 V 30.0.011 APE Test Version : rm427_ENO_x_09wk17v0.030_hi RETU Version : 16 TAHVO Version : 22 APE HW Version : 256 APE ADSP SW Version : 256 Bluetooth ID : 00:25:48:5E:23:F6 CS Type : GSM850, GSM900, GSM1800, GSM1900 ================================================ Simlock Information ================================================ CONFIG KEY : 0000000000000000 PROVIDER KEY : 2440700000000000 NETWORK NAME : Nokia Default;Finland LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10 SIMLOCK TABLE : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK STATE : Not Locked SIMLOCK_TYPE : PA_SL2 SIMLOCK_TEST : PASSED SECURITY_TEST : FAILED > Try SX4 "PM AUTH" > Then Write PM 1 and 309 PHONE_MODE : TEST DCC ID : NOT USED |
07-13-2013, 13:51 | #2 (permalink) |
No Life Poster Join Date: May 2004 Location: India
Member: 65074 Status: Offline Sonork: 100.1611263 Thanks Meter: 214 | > Try SX4 "PM AUTH" > Then Write PM 1 and 309 (you may try generic Pm having 1 & 309 field) BR Last edited by Shubhanshu~; 07-13-2013 at 13:57. |
07-13-2013, 14:44 | #6 (permalink) |
Member: 65074 Status: Offline Sonork: 100.1611263 Thanks Meter: 214 | X:\AdvanceBox Turbo Flasher\Nokia\PM Files\SX4\GENERIC_1_309.pm Try this one.. BR |
The Following User Says Thank You to Shubhanshu~ For This Useful Post: |
07-14-2013, 06:05 | #8 (permalink) |
Member: 866650 Status: Offline Sonork: mdsalimkhan_05 Thanks Meter: 147 | After sd repaire no network found but only one operator network working I Need RM-427 Pm file Pleas help any body |
07-14-2013, 06:25 | #9 (permalink) |
No Life Poster Join Date: Oct 2009 Location: GSMFORUM Age: 37
Member: 1133716 Status: Offline Thanks Meter: 282 | for safe pls. back u simlock first then go to atf network press login to your atf account then click authorize bb5 wait until all done back to nokia service go to pm/pp tab click the arow down then select stanalone sx4 click sx4 pm authorization selecttion popup then select generic_1_309 wait until pim writing done. now go to tuning and maintinance tab then post the screen shot from self test.. good luck.. |
07-14-2013, 07:16 | #10 (permalink) | |
Member: 866650 Status: Offline Sonork: mdsalimkhan_05 Thanks Meter: 147 | Good Working Quote:
Good working........... Always I create a backup before any operation | |
