04-11-2013, 20:14 | #1 (permalink) |
Junior Member Join Date: Jul 2005 Location: Ukraine
Member: 158841 Status: Offline Thanks Meter: 0 | Nokia 5800 still security_test failed <<< SOLVED >>> I try pm 1 and 309 with pm auth, repair simlock and repair sd but not solve problem. Then i use this method: "- backup rpl - full erase - flash eno - if model supports - full flash - write rpl - repair simlock - repair sd - use standalone sx4 auth and write pm 1, 309" 21:26:28 : Booting Phone via FBUS... 21:26:28 : 21:26:29 : 21:26:29 : AdvanceBox SendBootCodeEx 21:26:29 : InitialiseBootstrap_DCT5 DIR 21:26:29 : BootFlashMode_DCT5 21:26:29 : 21:26:29 : ************************************************** **** 21:26:29 : TIME STARTS HERE 21:26:29 : ************************************************** **** 21:26:29 : 21:26:29 : BootFlashModeDCT5Ex Succeeded First Time 21:26:29 : SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned 21:26:29 : Number of Sub Blocks 7 (0x07) 21:26:29 : 1 SYSTEM_ASIC_ID 01 21:26:29 : Block Length : 21 (15) 21:26:29 : BB ASIC Index : 0 (00) CMT 21:26:29 : ID DWORD 0 : 00000001 21:26:29 : ID DWORD 1 : 00000226 21:26:29 : ID DWORD 2 : 00010006 21:26:29 : ID DWORD 3 : 400C1921 21:26:29 : ID DWORD 4 : 01031103 21:26:29 : 2 EM_ASIC_ID 02 21:26:29 : Block Length : 5 (05) 21:26:29 : BB ASIC Index : 0 (00) CMT 21:26:29 : ID DWORD 0 : 00000296 21:26:29 : 3 EM_ASIC_ID 02 21:26:29 : Block Length : 5 (05) 21:26:29 : BB ASIC Index : 0 (00) CMT 21:26:29 : ID DWORD 0 : 00000B22 21:26:29 : 4 PUBLIC_ID 12 21:26:29 : Block Length : 21 (15) 21:26:29 : BB ASIC Index : 0 (00) CMT 21:26:29 : ID DWORD 0 : 0930010C 21:26:29 : ID DWORD 1 : 1AB70052 21:26:29 : ID DWORD 2 : 968F393B 21:26:29 : ID DWORD 3 : C5BD03C4 21:26:29 : ID DWORD 4 : 41F1CDD5 21:26:29 : 5 ASIC_MODE_ID 13 21:26:29 : Block Length : 2 (02) 21:26:29 : BB ASIC Index : 0 (00) CMT 21:26:29 : Mode Id : 00 21:26:29 : 6 ROOT_KEY_HASH 14 21:26:29 : Block Length : 17 (11) 21:26:29 : BB ASIC Index : 0 (00) CMT 21:26:29 : Hash : CA EE BB 65 D3 C4 8E 6D C7 3B 49 DC 50 63 A2 EE 21:26:29 : 7 ROM_ID 15 21:26:29 : Block Length : 9 (09) 21:26:29 : BB ASIC Index : 0 (00) CMT 21:26:29 : CRC 0 : 4B9B7510 21:26:29 : CRC 1 : 3E691FF8 21:26:29 : Checksum A6 21:26:29 : 21:26:29 : SearchForBootstrap_DCT5.. 21:26:30 : C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_2nd.fg 21:26:30 : Boot File - Version 012.08.00 21:26:30 : Boot File - Revision 0x0002 (2) 21:26:30 : eBB5ProtocolType == New 21:26:30 : PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" 21:26:30 : PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0" 21:26:30 : SearchForBootstrap_DCT5 : No Error - 0 (0x00) 21:26:30 : Secondary Loader Sent... 21:26:30 : TransmissionTypeRequest_DCT5_NewProtocol 21:26:30 : TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 21:26:30 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 21:26:30 : TransmissionTypeRequest_DCT5_NewProtocol 21:26:30 : FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX 21:26:30 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C 21:26:30 : Transmission Type Request Sent... 21:26:30 : ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. 21:26:30 : MCU_CONFIGURATION_RESPONSE_BB5: 21:26:30 : MessageID : 06 21:26:30 : SubBlocks : 06 21:26:30 : 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 21:26:30 : Block Length : 0B 21:26:30 : BB ASIC Index : CMT 00 21:26:30 : Device Type : RAM 05 21:26:30 : Device Index : 00 21:26:30 : Manufacturer Code : 0000 -> Flash 21:26:30 : Device ID : 0000 -> not detected 21:26:30 : Extended/Fixed ID : 0000 21:26:30 : Revision ID : 0000 21:26:30 : 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 21:26:30 : Block Length : 0B 21:26:30 : BB ASIC Index : CMT 00 21:26:30 : Device Type : MMC 04 21:26:30 : Device Index : 00 21:26:30 : Manufacturer Code : FFFF -> Flash 21:26:30 : Device ID : 0000 -> BAD FLASH TYPE 21:26:30 : Extended/Fixed ID : 0000 21:26:30 : Revision ID : 0000 21:26:30 : 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 21:26:30 : Block Length : 0B 21:26:30 : BB ASIC Index : CMT 00 21:26:30 : Device Type : NOR 00 21:26:30 : Device Index : 00 21:26:30 : Manufacturer Code : 0020 -> 21:26:30 : Device ID : 0040 -> Type not in database 21:26:30 : Extended/Fixed ID : 0000 21:26:30 : Revision ID : 0031 21:26:30 : 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 21:26:30 : Block Length : 0B 21:26:30 : BB ASIC Index : CMT 00 21:26:30 : Device Type : NOR 00 21:26:30 : Device Index : 01 21:26:30 : Manufacturer Code : 0000 -> SPANSION 21:26:30 : Device ID : 0001 -> not used 21:26:30 : Extended/Fixed ID : 0000 21:26:30 : Revision ID : 0000 21:26:30 : 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 21:26:30 : Block Length : 0B 21:26:30 : BB ASIC Index : CMT 00 21:26:30 : Device Type : MuxOneNAND 03 21:26:30 : Device Index : 00 21:26:30 : Manufacturer Code : 0020 -> 21:26:30 : Device ID : 0040 -> Type not in database 21:26:30 : Extended/Fixed ID : 0000 21:26:30 : Revision ID : 0031 21:26:30 : 6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5 21:26:30 : Block Length : 09 21:26:30 : BB ASIC Index : CMT 00 21:26:30 : Data : XSR 1.5 21:26:30 : Checksum : 55 21:26:30 : SearchForBootstrap_DCT5 : No Error - 0 (0x00) 21:26:30 : FLS1SendAlgoCodeEx.. 21:26:30 : SendAlgoCode_DCT5.. 21:26:30 : SearchForAlgorithm_DCT5.. 21:26:30 : Looking for ALL Devices... 21:26:30 : Searching Algorithm Files MuxOneNAND (03) ManID :0020 DevID :0040 ExtID :0000 RevID :0031 21:26:30 : Flash Descriptor 21:26:30 : Manufacturer Code : 0020 21:26:30 : Device ID : 0040 21:26:30 : Extended/Fixed ID : 0000 21:26:30 : Revision ID : 0000 21:26:30 : Size : 10000000 (256 MB) 21:26:30 : VPP Info : 0000 21:26:30 : Erase10s : 1E 21:26:30 : Block1s : 32 21:26:30 : BErase1s : 02 21:26:30 : Reserved0 : 00 21:26:30 : Reserved1 : 00 21:26:30 : Reserved2 : 00 21:26:30 : C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_XSR15_alg.f g 21:26:30 : Algorithm File - Version 012.08.00 21:26:30 : Algorithm File - Revision 0x0002 (2) 21:26:30 : eBB5ProtocolType == New 21:26:30 : Algo Loader Sent... 21:26:30 : SendCodeStart_NewProtocol : 21:26:32 : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) 21:26:32 : TransmissionTypeRequest_DCT5_NewProtocol 21:26:32 : TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 21:26:32 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 21:26:32 : TransmissionTypeRequest_DCT5_NewProtocol 21:26:32 : FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX 21:26:32 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C 21:26:32 : SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) 21:26:32 : FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) 21:26:32 : FUR control Ok... 21:26:32 : VPP Enabled by Software 21:26:32 : Using Internal VPP 21:26:32 : VPP Enabled by Software 21:26:32 : FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 21:26:32 : PAPUB_KEYS_HASH_REQ_BB5 21:26:32 : PhoneInfoRequest_BB5 (Asic Index 00 ) 21:26:32 : PHONE_INFO_RESPONSE_BB5 21:26:32 : PAPUB_KEYS_HASH_RESP_BB5 2A 21:26:32 : BB Asic Index : 00 21:26:32 : CMT PAPUBKEYS HASH: 21:26:32 : 76A20187051C30162EE91C77AE5E6011F5F1BA61 21:26:32 : 21:26:32 : START READING RPL DATA 21:26:32 : Reading : NPC (CMT) 21:26:33 : OK 21:26:33 : Reading : VARIANT (CMT) 21:26:33 : VARIANT : Empty 21:26:33 : Reading : CCC (CMT) 21:26:33 : OK 21:26:33 : Reading : HWC (CMT) 21:26:33 : OK 21:26:33 : Reading : R&D (CMT) 21:26:33 : OK 21:26:33 : Reading : PARTNERC (CMT) 21:26:34 : PARTNERC : Empty 21:26:34 : Reading : MDM_KEYS (CMT) 21:26:34 : MDM_KEYS : Empty 21:26:34 : 21:26:34 : NPC CERTIFICATE INFORMATION (CMT): 21:26:34 : IMEI : 353781043774452 21:26:34 : PRODUCT CODE : 0586361 21:26:34 : WLAN ID : E0:A6:70:379:FB 21:26:34 : BLUETOOTH ID : E0:A6:70:38:84:E4 21:26:34 : PUBLIC_ID : 0930010C1AB70052968F393BC5BD03C441F1CDD5 21:26:34 : PAPUB_KEYS_HASH: 76A20187051C30162EE91C77AE5E6011F5F1BA61 21:26:34 : CCC CERTIFICATE INFORMATION (CMT): 21:26:34 : PRODUCT CODE : yyyyyyy 21:26:34 : HWC CERTIFICATE INFORMATION (CMT): 21:26:34 : PUBLIC_ID : FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 21:26:34 : PRODUCT CODE : yyyyyyy 21:26:34 : 21:26:34 : WARNING: PRODUCT CODES MISMATCH 21:26:34 : This might cause SECURITY TEST FAILED 21:26:34 : in Phones which require them to match 21:26:34 : 21:26:34 : FINISHED READING RPL DATA 21:26:34 : RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\backup\353781043774452\3537810437744 52_212634.rpl 21:28:49 : Booting Phone via FBUS... 21:28:49 : 21:28:49 : 21:28:49 : AdvanceBox SendBootCodeEx 21:28:49 : InitialiseBootstrap_DCT5 DIR 21:28:49 : BootFlashMode_DCT5 21:28:49 : 21:28:49 : ************************************************** **** 21:28:49 : TIME STARTS HERE 21:28:49 : ************************************************** **** 21:28:49 : 21:28:49 : BootFlashModeDCT5Ex Succeeded First Time 21:28:49 : SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned 21:28:49 : Number of Sub Blocks 7 (0x07) 21:28:49 : 1 SYSTEM_ASIC_ID 01 21:28:49 : Block Length : 21 (15) 21:28:49 : BB ASIC Index : 0 (00) CMT 21:28:49 : ID DWORD 0 : 00000001 21:28:49 : ID DWORD 1 : 00000226 21:28:49 : ID DWORD 2 : 00010006 21:28:49 : ID DWORD 3 : 400C1921 21:28:49 : ID DWORD 4 : 01031103 21:28:49 : 2 EM_ASIC_ID 02 21:28:49 : Block Length : 5 (05) 21:28:49 : BB ASIC Index : 0 (00) CMT 21:28:49 : ID DWORD 0 : 00000296 21:28:49 : 3 EM_ASIC_ID 02 21:28:49 : Block Length : 5 (05) 21:28:49 : BB ASIC Index : 0 (00) CMT 21:28:49 : ID DWORD 0 : 00000B22 21:28:49 : 4 PUBLIC_ID 12 21:28:49 : Block Length : 21 (15) 21:28:49 : BB ASIC Index : 0 (00) CMT 21:28:49 : ID DWORD 0 : 0930010C 21:28:49 : ID DWORD 1 : 1AB70052 21:28:49 : ID DWORD 2 : 968F393B 21:28:49 : ID DWORD 3 : C5BD03C4 21:28:49 : ID DWORD 4 : 41F1CDD5 21:28:49 : 5 ASIC_MODE_ID 13 21:28:49 : Block Length : 2 (02) 21:28:49 : BB ASIC Index : 0 (00) CMT 21:28:49 : Mode Id : 00 21:28:49 : 6 ROOT_KEY_HASH 14 21:28:49 : Block Length : 17 (11) 21:28:49 : BB ASIC Index : 0 (00) CMT 21:28:49 : Hash : CA EE BB 65 D3 C4 8E 6D C7 3B 49 DC 50 63 A2 EE 21:28:49 : 7 ROM_ID 15 21:28:49 : Block Length : 9 (09) 21:28:49 : BB ASIC Index : 0 (00) CMT 21:28:49 : CRC 0 : 4B9B7510 21:28:49 : CRC 1 : 3E691FF8 21:28:49 : Checksum A6 21:28:49 : 21:28:49 : SearchForBootstrap_DCT5.. 21:28:49 : C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_2nd.fg 21:28:49 : Boot File - Version 012.08.00 21:28:49 : Boot File - Revision 0x0002 (2) 21:28:49 : eBB5ProtocolType == New 21:28:49 : PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" 21:28:49 : PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0" 21:28:49 : SearchForBootstrap_DCT5 : No Error - 0 (0x00) 21:28:50 : Secondary Loader Sent... 21:28:50 : TransmissionTypeRequest_DCT5_NewProtocol 21:28:50 : TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 21:28:50 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 21:28:51 : TransmissionTypeRequest_DCT5_NewProtocol 21:28:51 : FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX 21:28:51 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C 21:28:51 : Transmission Type Request Sent... 21:28:51 : ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. 21:28:51 : MCU_CONFIGURATION_RESPONSE_BB5: 21:28:51 : MessageID : 06 21:28:51 : SubBlocks : 06 21:28:51 : 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 21:28:51 : Block Length : 0B 21:28:51 : BB ASIC Index : CMT 00 21:28:51 : Device Type : RAM 05 21:28:51 : Device Index : 00 21:28:51 : Manufacturer Code : 0000 -> Flash 21:28:51 : Device ID : 0000 -> not detected 21:28:51 : Extended/Fixed ID : 0000 21:28:51 : Revision ID : 0000 21:28:51 : 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 21:28:51 : Block Length : 0B 21:28:51 : BB ASIC Index : CMT 00 21:28:51 : Device Type : MMC 04 21:28:51 : Device Index : 00 21:28:51 : Manufacturer Code : FFFF -> Flash 21:28:51 : Device ID : 0000 -> BAD FLASH TYPE 21:28:51 : Extended/Fixed ID : 0000 21:28:51 : Revision ID : 0000 21:28:51 : 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 21:28:51 : Block Length : 0B 21:28:51 : BB ASIC Index : CMT 00 21:28:51 : Device Type : NOR 00 21:28:51 : Device Index : 00 21:28:51 : Manufacturer Code : 0020 -> 21:28:51 : Device ID : 0040 -> Type not in database 21:28:51 : Extended/Fixed ID : 0000 21:28:51 : Revision ID : 0031 21:28:51 : 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 21:28:51 : Block Length : 0B 21:28:51 : BB ASIC Index : CMT 00 21:28:51 : Device Type : NOR 00 21:28:51 : Device Index : 01 21:28:51 : Manufacturer Code : 0000 -> SPANSION 21:28:51 : Device ID : 0001 -> not used 21:28:51 : Extended/Fixed ID : 0000 21:28:51 : Revision ID : 0000 21:28:51 : 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 21:28:51 : Block Length : 0B 21:28:51 : BB ASIC Index : CMT 00 21:28:51 : Device Type : MuxOneNAND 03 21:28:51 : Device Index : 00 21:28:51 : Manufacturer Code : 0020 -> 21:28:51 : Device ID : 0040 -> Type not in database 21:28:51 : Extended/Fixed ID : 0000 21:28:51 : Revision ID : 0031 21:28:51 : 6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5 21:28:51 : Block Length : 09 21:28:51 : BB ASIC Index : CMT 00 21:28:51 : Data : XSR 1.5 21:28:51 : Checksum : 55 21:28:51 : SearchForBootstrap_DCT5 : No Error - 0 (0x00) 21:28:51 : FLS1SendAlgoCodeEx.. 21:28:51 : SendAlgoCode_DCT5.. 21:28:51 : SearchForAlgorithm_DCT5.. 21:28:51 : Looking for ALL Devices... 21:28:51 : Searching Algorithm Files MuxOneNAND (03) ManID :0020 DevID :0040 ExtID :0000 RevID :0031 21:28:51 : Flash Descriptor 21:28:51 : Manufacturer Code : 0020 21:28:51 : Device ID : 0040 21:28:51 : Extended/Fixed ID : 0000 21:28:51 : Revision ID : 0000 21:28:51 : Size : 10000000 (256 MB) 21:28:51 : VPP Info : 0000 21:28:51 : Erase10s : 1E 21:28:51 : Block1s : 32 21:28:51 : BErase1s : 02 21:28:51 : Reserved0 : 00 21:28:51 : Reserved1 : 00 21:28:51 : Reserved2 : 00 21:28:51 : C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_XSR15_alg.f g 21:28:51 : Algorithm File - Version 012.08.00 21:28:51 : Algorithm File - Revision 0x0002 (2) 21:28:51 : eBB5ProtocolType == New 21:28:51 : Algo Loader Sent... 21:28:51 : SendCodeStart_NewProtocol : 21:28:53 : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) 21:28:53 : TransmissionTypeRequest_DCT5_NewProtocol 21:28:53 : TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 21:28:53 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 21:28:53 : TransmissionTypeRequest_DCT5_NewProtocol 21:28:53 : FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX 21:28:53 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C 21:28:54 : SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) 21:28:54 : FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) 21:28:54 : FUR control Ok... 21:28:54 : VPP Enabled by Software 21:28:54 : Using Internal VPP 21:28:54 : VPP Enabled by Software 21:28:54 : FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 21:28:54 : PAPUB_KEYS_HASH_REQ_BB5 21:28:54 : PhoneInfoRequest_BB5 (Asic Index 00 ) 21:28:54 : PHONE_INFO_RESPONSE_BB5 21:28:54 : PAPUB_KEYS_HASH_RESP_BB5 2A 21:28:54 : BB Asic Index : 00 21:28:54 : CMT PAPUBKEYS HASH: 21:28:54 : 76A20187051C30162EE91C77AE5E6011F5F1BA61 21:28:54 : 21:28:54 : 21:28:54 : Scanning Simlock Applet Type... 21:28:58 : OK 21:28:58 : 21:28:58 : ================================================= 21:28:58 : SL1/SL2 Applet detected 21:28:58 : ================================================= 21:28:58 : 21:28:58 : * If you want to unlock this phone, please use: 21:28:58 : Rebuild Simlocks via Simlock RPL 21:28:58 : 21:29:15 : Booting Phone via FBUS... 21:29:15 : 21:29:15 : 21:29:15 : AdvanceBox SendBootCodeEx 21:29:15 : InitialiseBootstrap_DCT5 DIR 21:29:15 : BootFlashMode_DCT5 21:29:15 : 21:29:15 : ************************************************** **** 21:29:15 : TIME STARTS HERE 21:29:15 : ************************************************** **** 21:29:15 : 21:29:15 : BootFlashModeDCT5Ex Succeeded First Time 21:29:15 : SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned 21:29:15 : Number of Sub Blocks 7 (0x07) 21:29:15 : 1 SYSTEM_ASIC_ID 01 21:29:15 : Block Length : 21 (15) 21:29:15 : BB ASIC Index : 0 (00) CMT 21:29:15 : ID DWORD 0 : 00000001 21:29:15 : ID DWORD 1 : 00000226 21:29:15 : ID DWORD 2 : 00010006 21:29:15 : ID DWORD 3 : 400C1921 21:29:15 : ID DWORD 4 : 01031103 21:29:15 : 2 EM_ASIC_ID 02 21:29:15 : Block Length : 5 (05) 21:29:15 : BB ASIC Index : 0 (00) CMT 21:29:15 : ID DWORD 0 : 00000296 21:29:15 : 3 EM_ASIC_ID 02 21:29:15 : Block Length : 5 (05) 21:29:15 : BB ASIC Index : 0 (00) CMT 21:29:15 : ID DWORD 0 : 00000B22 21:29:15 : 4 PUBLIC_ID 12 21:29:15 : Block Length : 21 (15) 21:29:15 : BB ASIC Index : 0 (00) CMT 21:29:15 : ID DWORD 0 : 0930010C 21:29:15 : ID DWORD 1 : 1AB70052 21:29:15 : ID DWORD 2 : 968F393B 21:29:15 : ID DWORD 3 : C5BD03C4 21:29:15 : ID DWORD 4 : 41F1CDD5 21:29:15 : 5 ASIC_MODE_ID 13 21:29:15 : Block Length : 2 (02) 21:29:15 : BB ASIC Index : 0 (00) CMT 21:29:15 : Mode Id : 00 21:29:15 : 6 ROOT_KEY_HASH 14 21:29:15 : Block Length : 17 (11) 21:29:15 : BB ASIC Index : 0 (00) CMT 21:29:15 : Hash : CA EE BB 65 D3 C4 8E 6D C7 3B 49 DC 50 63 A2 EE 21:29:15 : 7 ROM_ID 15 21:29:15 : Block Length : 9 (09) 21:29:15 : BB ASIC Index : 0 (00) CMT 21:29:15 : CRC 0 : 4B9B7510 21:29:15 : CRC 1 : 3E691FF8 21:29:15 : Checksum A6 21:29:15 : 21:29:15 : SearchForBootstrap_DCT5.. 21:29:15 : C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_2nd.fg 21:29:15 : Boot File - Version 012.08.00 21:29:15 : Boot File - Revision 0x0002 (2) 21:29:15 : eBB5ProtocolType == New 21:29:15 : PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" 21:29:15 : PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0" 21:29:15 : SearchForBootstrap_DCT5 : No Error - 0 (0x00) 21:29:16 : Secondary Loader Sent... 21:29:16 : TransmissionTypeRequest_DCT5_NewProtocol 21:29:16 : TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 21:29:16 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 21:29:16 : TransmissionTypeRequest_DCT5_NewProtocol 21:29:16 : FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX 21:29:16 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C 21:29:16 : Transmission Type Request Sent... 21:29:16 : ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. 21:29:16 : MCU_CONFIGURATION_RESPONSE_BB5: 21:29:16 : MessageID : 06 21:29:16 : SubBlocks : 06 21:29:16 : 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 21:29:16 : Block Length : 0B 21:29:16 : BB ASIC Index : CMT 00 21:29:16 : Device Type : RAM 05 21:29:16 : Device Index : 00 21:29:16 : Manufacturer Code : 0000 -> Flash 21:29:16 : Device ID : 0000 -> not detected 21:29:16 : Extended/Fixed ID : 0000 21:29:16 : Revision ID : 0000 21:29:16 : 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 21:29:16 : Block Length : 0B 21:29:16 : BB ASIC Index : CMT 00 21:29:16 : Device Type : MMC 04 21:29:16 : Device Index : 00 21:29:16 : Manufacturer Code : FFFF -> Flash 21:29:16 : Device ID : 0000 -> BAD FLASH TYPE 21:29:16 : Extended/Fixed ID : 0000 21:29:16 : Revision ID : 0000 21:29:16 : 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 21:29:16 : Block Length : 0B 21:29:16 : BB ASIC Index : CMT 00 21:29:16 : Device Type : NOR 00 21:29:16 : Device Index : 00 21:29:16 : Manufacturer Code : 0020 -> 21:29:16 : Device ID : 0040 -> Type not in database 21:29:16 : Extended/Fixed ID : 0000 21:29:16 : Revision ID : 0031 21:29:16 : 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 21:29:16 : Block Length : 0B 21:29:16 : BB ASIC Index : CMT 00 21:29:16 : Device Type : NOR 00 21:29:16 : Device Index : 01 21:29:16 : Manufacturer Code : 0000 -> SPANSION 21:29:16 : Device ID : 0001 -> not used 21:29:16 : Extended/Fixed ID : 0000 21:29:16 : Revision ID : 0000 21:29:16 : 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 21:29:16 : Block Length : 0B 21:29:16 : BB ASIC Index : CMT 00 21:29:16 : Device Type : MuxOneNAND 03 21:29:16 : Device Index : 00 21:29:16 : Manufacturer Code : 0020 -> 21:29:16 : Device ID : 0040 -> Type not in database 21:29:16 : Extended/Fixed ID : 0000 21:29:16 : Revision ID : 0031 21:29:16 : 6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5 21:29:16 : Block Length : 09 21:29:16 : BB ASIC Index : CMT 00 21:29:16 : Data : XSR 1.5 21:29:16 : Checksum : 55 21:29:16 : SearchForBootstrap_DCT5 : No Error - 0 (0x00) 21:29:16 : FLS1SendAlgoCodeEx.. 21:29:16 : SendAlgoCode_DCT5.. 21:29:16 : SearchForAlgorithm_DCT5.. 21:29:16 : Looking for ALL Devices... 21:29:16 : Searching Algorithm Files MuxOneNAND (03) ManID :0020 DevID :0040 ExtID :0000 RevID :0031 21:29:16 : Flash Descriptor 21:29:16 : Manufacturer Code : 0020 21:29:16 : Device ID : 0040 21:29:16 : Extended/Fixed ID : 0000 21:29:16 : Revision ID : 0000 21:29:16 : Size : 10000000 (256 MB) 21:29:16 : VPP Info : 0000 21:29:16 : Erase10s : 1E 21:29:16 : Block1s : 32 21:29:16 : BErase1s : 02 21:29:16 : Reserved0 : 00 21:29:16 : Reserved1 : 00 21:29:16 : Reserved2 : 00 21:29:16 : C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_XSR15_alg.f g 21:29:16 : Algorithm File - Version 012.08.00 21:29:16 : Algorithm File - Revision 0x0002 (2) 21:29:16 : eBB5ProtocolType == New 21:29:16 : Algo Loader Sent... 21:29:16 : SendCodeStart_NewProtocol : 21:29:18 : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) 21:29:18 : TransmissionTypeRequest_DCT5_NewProtocol 21:29:18 : TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 21:29:18 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 21:29:19 : TransmissionTypeRequest_DCT5_NewProtocol 21:29:19 : FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX 21:29:19 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C 21:29:19 : SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) 21:29:19 : FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) 21:29:19 : FUR control Ok... 21:29:19 : VPP Enabled by Software 21:29:19 : Using Internal VPP 21:29:19 : VPP Enabled by Software 21:29:19 : FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 21:29:19 : PAPUB_KEYS_HASH_REQ_BB5 21:29:19 : PhoneInfoRequest_BB5 (Asic Index 00 ) 21:29:19 : PHONE_INFO_RESPONSE_BB5 21:29:19 : PAPUB_KEYS_HASH_RESP_BB5 2A 21:29:19 : BB Asic Index : 00 21:29:19 : CMT PAPUBKEYS HASH: 21:29:19 : 76A20187051C30162EE91C77AE5E6011F5F1BA61 21:29:19 : 21:29:19 : 21:29:19 : Scanning Simlock Applet Type... 21:29:23 : OK 21:29:23 : 21:29:23 : ================================================= 21:29:23 : SL1/SL2 Applet detected 21:29:23 : ================================================= 21:29:23 : 21:29:23 : * If you want to unlock this phone, please use: 21:29:23 : Rebuild Simlocks via Simlock RPL 21:29:23 : 21:29:23 : StartErase_DCT5... 21:29:23 : BlockLength : 0x0E (14) 21:29:23 : ERASE Blocks : 0x01 (1) 21:29:23 : 0 ERASE_AREA_BB5 0x12 21:29:23 : Block Length : 0x0B (11) 21:29:23 : BB ASIC Index : 0x00 CMT 21:29:23 : Device Type : 0x03 MuxOneNAND 21:29:23 : Device Index : 0x00 21:29:23 : 0 : 00000000-0FFFFFFF 21:29:23 : 21:29:23 : Erase_SendEraseBlock_BB5_NAND 21:29:23 : Task in Progress... Please Wait... 21:29:23 : 21:29:23 : Successfully erased.. 21:31:25 : 21:31:25 : Only Phoenix.ini Flash Files are 21:31:25 : supported for Checksum Verification... 21:31:27 : ATF Software Version v9.70 21:31:27 : ATF Nitro FBUS Flash Started... 21:31:27 : 21:31:27 : Number of Image Files: 1 21:31:27 : 21:31:27 : Processing Image File : 21:31:27 : D:\Прошивки\UFS+HWK\NOKIA\RM-356\rm-356_ENO_x_2008wk42v0.033.fpsx 21:31:27 : CMT Type : BB5 21:31:27 : CMT Algorithm : XSR 1.5 21:31:27 : Secondary Sending Speed : 650000 Hz 21:31:27 : Algorithm Sending Speed : 6500000 Hz 21:31:27 : Program Sending Speed : 6500000 Hz 21:31:28 : Message Reading Speed : 98000 Hz 21:31:28 : Number of Blocks : 43 21:31:28 : Entry Point : 0x01FA 21:31:28 : Page Format : 128K 21:31:28 : Maximum Page Size : 0x00040000 21:31:28 : 21:31:28 : Changing MODE : FLASH 21:31:28 : Booting Phone via FBUS... 21:31:28 : 21:31:30 : VBATT Powering Down <<<< 21:31:35 : VBATT Powering Up >>>> 21:31:35 : SET VCCIO Level Done 21:31:35 : SET BSI Load Done 21:31:35 : 21:31:35 : AdvanceBox SendBootCodeEx 21:31:35 : InitialiseBootstrap_DCT5 DIR 21:31:35 : BootFlashMode_DCT5 21:31:35 : 21:31:36 : ************************************************** **** 21:31:36 : TIME STARTS HERE 21:31:36 : ************************************************** **** 21:31:36 : 21:31:36 : BootFlashModeDCT5Ex Succeeded after 3 Attempts 21:31:36 : SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned 21:31:36 : Number of Sub Blocks 7 (0x07) 21:31:36 : 1 SYSTEM_ASIC_ID 01 21:31:36 : Block Length : 21 (15) 21:31:36 : BB ASIC Index : 0 (00) CMT 21:31:36 : ID DWORD 0 : 00000001 21:31:36 : ID DWORD 1 : 00000226 21:31:36 : ID DWORD 2 : 00010006 21:31:36 : ID DWORD 3 : 400C1921 21:31:36 : ID DWORD 4 : 01031103 21:31:36 : 2 EM_ASIC_ID 02 21:31:36 : Block Length : 5 (05) 21:31:36 : BB ASIC Index : 0 (00) CMT 21:31:36 : ID DWORD 0 : 00000296 21:31:36 : 3 EM_ASIC_ID 02 21:31:36 : Block Length : 5 (05) 21:31:36 : BB ASIC Index : 0 (00) CMT 21:31:36 : ID DWORD 0 : 00000B22 21:31:36 : 4 PUBLIC_ID 12 21:31:36 : Block Length : 21 (15) 21:31:36 : BB ASIC Index : 0 (00) CMT 21:31:36 : ID DWORD 0 : 0930010C 21:31:36 : ID DWORD 1 : 1AB70052 21:31:36 : ID DWORD 2 : 968F393B 21:31:36 : ID DWORD 3 : C5BD03C4 21:31:36 : ID DWORD 4 : 41F1CDD5 21:31:36 : 5 ASIC_MODE_ID 13 21:31:36 : Block Length : 2 (02) 21:31:36 : BB ASIC Index : 0 (00) CMT 21:31:36 : Mode Id : 00 21:31:36 : 6 ROOT_KEY_HASH 14 21:31:36 : Block Length : 17 (11) 21:31:36 : BB ASIC Index : 0 (00) CMT 21:31:36 : Hash : CA EE BB 65 D3 C4 8E 6D C7 3B 49 DC 50 63 A2 EE 21:31:36 : 7 ROM_ID 15 21:31:36 : Block Length : 9 (09) 21:31:36 : BB ASIC Index : 0 (00) CMT 21:31:36 : CRC 0 : 4B9B7510 21:31:36 : CRC 1 : 3E691FF8 21:31:36 : Checksum A6 21:31:36 : 21:31:36 : SearchForBootstrap_DCT5.. 21:31:36 : C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_2nd.fg 21:31:36 : Boot File - Version 012.08.00 21:31:36 : Boot File - Revision 0x0002 (2) 21:31:36 : eBB5ProtocolType == New 21:31:36 : PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" 21:31:36 : PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0" 21:31:36 : SearchForBootstrap_DCT5 : No Error - 0 (0x00) 21:31:36 : Secondary Loader Sent... 21:31:36 : TransmissionTypeRequest_DCT5_NewProtocol 21:31:36 : TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 21:31:36 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 21:31:36 : TransmissionTypeRequest_DCT5_NewProtocol 21:31:36 : FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX 21:31:36 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C 21:31:36 : Transmission Type Request Sent... 21:31:36 : ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. 21:31:36 : MCU_CONFIGURATION_RESPONSE_BB5: 21:31:36 : MessageID : 06 21:31:36 : SubBlocks : 06 21:31:36 : 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 21:31:36 : Block Length : 0B 21:31:36 : BB ASIC Index : CMT 00 21:31:36 : Device Type : RAM 05 21:31:36 : Device Index : 00 21:31:36 : Manufacturer Code : 0000 -> Flash 21:31:36 : Device ID : 0000 -> not detected 21:31:36 : Extended/Fixed ID : 0000 21:31:36 : Revision ID : 0000 21:31:36 : 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 21:31:36 : Block Length : 0B 21:31:36 : BB ASIC Index : CMT 00 21:31:36 : Device Type : MMC 04 21:31:36 : Device Index : 00 21:31:36 : Manufacturer Code : FFFF -> Flash 21:31:36 : Device ID : 0000 -> BAD FLASH TYPE 21:31:36 : Extended/Fixed ID : 0000 21:31:36 : Revision ID : 0000 21:31:36 : 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 21:31:36 : Block Length : 0B 21:31:36 : BB ASIC Index : CMT 00 21:31:36 : Device Type : NOR 00 21:31:36 : Device Index : 00 21:31:36 : Manufacturer Code : 0020 -> 21:31:36 : Device ID : 0040 -> Type not in database 21:31:36 : Extended/Fixed ID : 0000 21:31:36 : Revision ID : 0031 21:31:36 : 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 21:31:36 : Block Length : 0B 21:31:36 : BB ASIC Index : CMT 00 21:31:36 : Device Type : NOR 00 21:31:36 : Device Index : 01 21:31:36 : Manufacturer Code : 0000 -> SPANSION 21:31:36 : Device ID : 0001 -> not used 21:31:36 : Extended/Fixed ID : 0000 21:31:36 : Revision ID : 0000 21:31:36 : 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 21:31:36 : Block Length : 0B 21:31:36 : BB ASIC Index : CMT 00 21:31:36 : Device Type : MuxOneNAND 03 21:31:36 : Device Index : 00 21:31:36 : Manufacturer Code : 0020 -> 21:31:36 : Device ID : 0040 -> Type not in database 21:31:36 : Extended/Fixed ID : 0000 21:31:36 : Revision ID : 0031 21:31:36 : 6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5 21:31:36 : Block Length : 09 21:31:36 : BB ASIC Index : CMT 00 21:31:36 : Data : XSR 1.5 21:31:36 : Checksum : 55 21:31:36 : SearchForBootstrap_DCT5 : No Error - 0 (0x00) 21:31:36 : FLS1SendAlgoCodeEx.. 21:31:36 : SendAlgoCode_DCT5.. 21:31:36 : SearchForAlgorithm_DCT5.. 21:31:36 : Looking for ALL Devices... 21:31:36 : Searching Algorithm Files MuxOneNAND (03) ManID :0020 DevID :0040 ExtID :0000 RevID :0031 21:31:36 : Flash Descriptor 21:31:36 : Manufacturer Code : 0020 21:31:36 : Device ID : 0040 21:31:36 : Extended/Fixed ID : 0000 21:31:36 : Revision ID : 0000 21:31:36 : Size : 10000000 (256 MB) 21:31:36 : VPP Info : 0000 21:31:36 : Erase10s : 1E 21:31:36 : Block1s : 32 21:31:36 : BErase1s : 02 21:31:37 : Reserved0 : 00 21:31:37 : Reserved1 : 00 21:31:37 : Reserved2 : 00 21:31:37 : C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_XSR15_alg.f g 21:31:37 : Algorithm File - Version 012.08.00 21:31:37 : Algorithm File - Revision 0x0002 (2) 21:31:37 : eBB5ProtocolType == New 21:31:37 : Algo Loader Sent... 21:31:37 : SendCodeStart_NewProtocol : 21:31:38 : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) 21:31:38 : TransmissionTypeRequest_DCT5_NewProtocol 21:31:38 : TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 21:31:38 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 21:31:38 : TransmissionTypeRequest_DCT5_NewProtocol 21:31:38 : FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX 21:31:38 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C 21:31:38 : SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) 21:31:38 : FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) 21:31:38 : FUR control Ok... 21:31:38 : VPP Enabled by Software 21:31:38 : Using Internal VPP 21:31:39 : VPP Enabled by Software 21:31:39 : FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 21:31:39 : PAPUB_KEYS_HASH_REQ_BB5 21:31:40 : No PAPUBKeysHash Returned 21:31:40 : Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) 21:31:40 : Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) 21:31:40 : Certificate 1 21:31:40 : Name : NPC 21:31:40 : ASIC Index : CMT 0 21:31:40 : Certificate 2 21:31:40 : Name : CCC 21:31:40 : ASIC Index : CMT 0 21:31:40 : Certificate 3 21:31:40 : Name : HWC 21:31:40 : ASIC Index : CMT 0 21:31:40 : Certificate 4 21:31:40 : Name : R&D 21:31:40 : ASIC Index : CMT 0 21:31:40 : STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3 21:31:40 : STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00) 21:31:40 : ProcessPartitionInfo_DCT5... 21:31:40 : Partition Info 21:31:40 : Partition Blocks : 1 21:31:40 : 1 PARTITION_INFO_BB5 21:31:40 : BB ASIC Index : 0x00 CMT 21:31:40 : Device Type : 0x03 MuxOneNAND 21:31:40 : Device Index : 0x00 21:31:40 : Partition Version : 00010000 21:31:40 : Spare : FFFFFFFF 21:31:40 : Num Partitions : 00000004 21:31:40 : Partition 1 21:31:40 : ID : 00000003 COPIEDOS 21:31:40 : Attribute : 00000002 RO 21:31:40 : Start Address : 00080000 21:31:40 : Size : 05AA0000 21:31:40 : Partition 2 21:31:40 : ID : 00000004 DEMANDONOS 21:31:40 : Attribute : 00000002 RO 21:31:40 : Start Address : 05B20000 21:31:40 : Size : 04D00000 21:31:40 : Partition 3 21:31:40 : ID : 00000008 FILESYSTEM 21:31:40 : Attribute : 00000001 RW 21:31:40 : Start Address : 0A820000 21:31:40 : Size : 04F00000 21:31:40 : Partition 4 21:31:40 : ID : 0000000A PMM 21:31:40 : Attribute : 00000001 RW 21:31:40 : Start Address : 0F8C0000 21:31:40 : Size : 00160000 21:31:40 : PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF00000004000000030000 00020008000005AA0000000000040000000205B2000004D000 0000000008000000010A82000004F000000000000A00000001 0F8C000000160000EA 21:31:40 : PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) 21:31:40 : ProcessPartitionInfo_DCT5 : No Error - 0 (0x00) 21:31:40 : StartErase_DCT5... 21:31:40 : BlockLength : 0x5F (95) 21:31:40 : ERASE Blocks : 0x02 (2) 21:31:40 : 0 ERASE_AREA_BB5 0x12 21:31:40 : Block Length : 0x2B (43) 21:31:40 : BB ASIC Index : 0x00 CMT 21:31:40 : Device Type : 0x03 MuxOneNAND 21:31:40 : Device Index : 0x00 21:31:40 : 0 : 00040000-00082FFF 21:31:40 : 1 : 00083400-003FFFFF 21:31:40 : 2 : 00400000-007FFFFF 21:31:40 : 3 : 00800000-00D5FFFF 21:31:40 : 4 : 00D60000-0A81FFFF 21:31:40 : 1 FORMAT_PARTITION_BB5 0x19 21:31:40 : Block Length : 0x2F (47) 21:31:40 : BB ASIC Index : 0x00 CMT 21:31:40 : Device Type : 0x03 MuxOneNAND 21:31:40 : Device Index : 0x00 21:31:40 : Format Info ID : 0x00000000 21:31:40 : Format Info : 000000000000000A0000000000000002000000640000000300 000001000000010000000000000000 21:31:40 : 21:31:40 : Erase_SendEraseBlock_BB5_NAND 21:31:40 : Task in Progress... Please Wait... 21:31:40 : 21:31:40 : Erase_SendFormatPartition_BB5_NAND 21:31:40 : Task in Progress... Please Wait... 21:31:41 : 21:31:41 : Successfully erased.. 21:31:41 : Time Taken to Erase : 00:00:01 21:31:41 : Flashing Speed: 5.00 Mhz (AUTO) 21:31:41 : Processing : rm-356_ENO_x_2008wk42v0.033.fpsx 21:31:41 : Total blocks to write : 43 21:31:41 : >> CMT Rootkey Hash CERT : ADA 21:31:41 : >> CMT Rootkey Hash CERT : KEYS 21:31:41 : >> CMT Rootkey Hash CERT : PRIMAPP 21:31:41 : >> CMT Rootkey Hash CERT : RAP3NAND 21:31:41 : >> CMT Rootkey Hash CERT : PASUBTOC 21:31:42 : >> CMT Rootkey Hash CERT : PAPUBKEYS [76A20187051C30162EE91C77AE5E6011F5F1BA61] 21:31:42 : >> CMT Rootkey Hash CERT : SOS*ENO 21:31:43 : >> CMT Rootkey Hash CERT : SOS*DSP0 21:31:44 : >> CMT Rootkey Hash CERT : SOS*ISASW 21:31:45 : ContinueFlash_DCT5 Complete 21:31:45 : Continue Flash Complete : : No Error - 0 (0x00) 21:31:45 : Time Taken to Flash : 00:00:04 21:31:45 : 21:31:45 : Total Flash Write Time (Flashing Only) : 00:00:04 21:31:45 : Total Flashing Time (Booting + Erase + Flashing) : 00:00:09 21:31:45 : 21:31:45 : STATUS_REQUEST_BB5... 21:31:46 : 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 21:31:46 : Block Length : 0F 21:31:46 : BB ASIC Index : 00 21:31:46 : Device Type : 03 21:31:46 : Device Type : 00 21:31:46 : Num Bad Blocks : 00000001 21:31:46 : Additional Bad : 00000001 21:31:46 : Correctable ECC : 00000000 21:31:50 : 21:31:50 : Waiting for Phone to Go Online... 21:31:51 : Elapsed Time: 1s 21:31:52 : Elapsed Time: 2s 21:31:53 : Elapsed Time: 3s 21:31:54 : Elapsed Time: 4s 21:31:55 : Elapsed Time: 5s 21:31:56 : Elapsed Time: 6s 21:31:57 : Elapsed Time: 7s 21:31:58 : Elapsed Time: 8s 21:31:59 : Elapsed Time: 9s 21:32:20 : 21:32:20 : Make sure you have installed the 21:32:20 : COMPLETE Flash Package for this Phone... 21:32:20 : 21:32:20 : Goto "Settings" --> "Nokia Settings" and verify that 21:32:20 : the Folder where you installed your Flash Files are 21:32:20 : in the "PRODUCT PATH TO SCAN" List... 21:32:50 : 21:32:50 : Only Phoenix.ini Flash Files are 21:32:50 : supported for Checksum Verification... 21:32:52 : ATF Software Version v9.70 21:32:52 : ATF Nitro FBUS Flash Started... 21:32:52 : 21:32:52 : Number of Image Files: 3 21:32:52 : 21:32:52 : Processing Image File : 21:32:52 : D:\Прошивки\UFS+HWK\NOKIA\RM-356\RM-356\RM-356_60.0.003_prd.core.C00 21:32:55 : CMT Type : BB5 21:32:55 : CMT Algorithm : XSR 1.5 21:32:55 : Secondary Sending Speed : 650000 Hz 21:32:55 : Algorithm Sending Speed : 13000000 Hz 21:32:55 : Program Sending Speed : 13000000 Hz 21:32:55 : Message Reading Speed : 98000 Hz 21:32:55 : Number of Blocks : 510 21:32:55 : Entry Point : 0x2CDFBF 21:32:56 : Page Format : 128K 21:32:56 : Maximum Page Size : 0x00040000 21:32:56 : 21:32:56 : Changing MODE : FLASH 21:32:56 : Booting Phone via FBUS... 21:32:56 : 21:32:56 : 21:32:56 : AdvanceBox SendBootCodeEx 21:32:56 : InitialiseBootstrap_DCT5 DIR 21:32:56 : BootFlashMode_DCT5 21:32:56 : 21:32:56 : ************************************************** **** 21:32:56 : TIME STARTS HERE 21:32:56 : ************************************************** **** 21:32:56 : 21:32:56 : BootFlashModeDCT5Ex Succeeded First Time 21:32:56 : SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned 21:32:56 : Number of Sub Blocks 7 (0x07) 21:32:56 : 1 SYSTEM_ASIC_ID 01 21:32:56 : Block Length : 21 (15) 21:32:56 : BB ASIC Index : 0 (00) CMT 21:32:56 : ID DWORD 0 : 00000001 21:32:56 : ID DWORD 1 : 00000226 21:32:56 : ID DWORD 2 : 00010006 21:32:56 : ID DWORD 3 : 400C1921 21:32:56 : ID DWORD 4 : 01031103 21:32:56 : 2 EM_ASIC_ID 02 21:32:56 : Block Length : 5 (05) 21:32:56 : BB ASIC Index : 0 (00) CMT 21:32:56 : ID DWORD 0 : 00000296 21:32:56 : 3 EM_ASIC_ID 02 21:32:56 : Block Length : 5 (05) 21:32:56 : BB ASIC Index : 0 (00) CMT 21:32:56 : ID DWORD 0 : 00000B22 21:32:56 : 4 PUBLIC_ID 12 21:32:56 : Block Length : 21 (15) 21:32:56 : BB ASIC Index : 0 (00) CMT 21:32:56 : ID DWORD 0 : 0930010C 21:32:56 : ID DWORD 1 : 1AB70052 21:32:56 : ID DWORD 2 : 968F393B 21:32:56 : ID DWORD 3 : C5BD03C4 21:32:56 : ID DWORD 4 : 41F1CDD5 21:32:56 : 5 ASIC_MODE_ID 13 21:32:56 : Block Length : 2 (02) 21:32:56 : BB ASIC Index : 0 (00) CMT 21:32:56 : Mode Id : 00 21:32:56 : 6 ROOT_KEY_HASH 14 21:32:56 : Block Length : 17 (11) 21:32:56 : BB ASIC Index : 0 (00) CMT 21:32:56 : Hash : CA EE BB 65 D3 C4 8E 6D C7 3B 49 DC 50 63 A2 EE 21:32:56 : 7 ROM_ID 15 21:32:56 : Block Length : 9 (09) 21:32:56 : BB ASIC Index : 0 (00) CMT 21:32:56 : CRC 0 : 4B9B7510 21:32:56 : CRC 1 : 3E691FF8 21:32:56 : Checksum A6 21:32:56 : 21:32:56 : SearchForBootstrap_DCT5.. 21:32:56 : C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_2nd.fg 21:32:56 : Boot File - Version 012.08.00 21:32:56 : Boot File - Revision 0x0002 (2) 21:32:56 : eBB5ProtocolType == New 21:32:56 : PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" 21:32:56 : PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0" 21:32:56 : SearchForBootstrap_DCT5 : No Error - 0 (0x00) 21:32:56 : Secondary Loader Sent... 21:32:56 : TransmissionTypeRequest_DCT5_NewProtocol 21:32:56 : TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 21:32:56 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 21:32:57 : TransmissionTypeRequest_DCT5_NewProtocol 21:32:57 : FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX 21:32:57 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C 21:32:57 : Transmission Type Request Sent... 21:32:57 : ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. 21:32:57 : MCU_CONFIGURATION_RESPONSE_BB5: 21:32:57 : MessageID : 06 21:32:57 : SubBlocks : 06 21:32:57 : 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 21:32:57 : Block Length : 0B 21:32:57 : BB ASIC Index : CMT 00 21:32:58 : Device Type : RAM 05 21:32:58 : Device Index : 00 21:32:58 : Manufacturer Code : 0000 -> Flash 21:32:58 : Device ID : 0000 -> not detected 21:32:58 : Extended/Fixed ID : 0000 21:32:58 : Revision ID : 0000 21:32:58 : 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 21:32:58 : Block Length : 0B 21:32:58 : BB ASIC Index : CMT 00 21:32:58 : Device Type : MMC 04 21:32:58 : Device Index : 00 21:32:58 : Manufacturer Code : FFFF -> Flash 21:32:58 : Device ID : 0000 -> BAD FLASH TYPE 21:32:58 : Extended/Fixed ID : 0000 21:32:58 : Revision ID : 0000 21:32:58 : 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 21:32:58 : Block Length : 0B 21:32:58 : BB ASIC Index : CMT 00 21:32:58 : Device Type : NOR 00 21:32:58 : Device Index : 00 21:32:58 : Manufacturer Code : 0020 -> 21:32:58 : Device ID : 0040 -> Type not in database 21:32:58 : Extended/Fixed ID : 0000 21:32:58 : Revision ID : 0031 21:32:58 : 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 21:32:58 : Block Length : 0B 21:32:58 : BB ASIC Index : CMT 00 21:32:58 : Device Type : NOR 00 21:32:58 : Device Index : 01 21:32:58 : Manufacturer Code : 0000 -> SPANSION 21:32:58 : Device ID : 0001 -> not used 21:32:58 : Extended/Fixed ID : 0000 21:32:58 : Revision ID : 0000 21:32:58 : 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 21:32:58 : Block Length : 0B 21:32:58 : BB ASIC Index : CMT 00 21:32:58 : Device Type : MuxOneNAND 03 21:32:58 : Device Index : 00 21:32:58 : Manufacturer Code : 0020 -> 21:32:58 : Device ID : 0040 -> Type not in database 21:32:58 : Extended/Fixed ID : 0000 21:32:58 : Revision ID : 0031 21:32:58 : 6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5 21:32:58 : Block Length : 09 21:32:58 : BB ASIC Index : CMT 00 21:32:58 : Data : XSR 1.5 21:32:58 : Checksum : 55 21:32:58 : SearchForBootstrap_DCT5 : No Error - 0 (0x00) 21:32:58 : FLS1SendAlgoCodeEx.. 21:32:58 : SendAlgoCode_DCT5.. 21:32:58 : SearchForAlgorithm_DCT5.. 21:32:58 : Looking for ALL Devices... 21:32:58 : Searching Algorithm Files MuxOneNAND (03) ManID :0020 DevID :0040 ExtID :0000 RevID :0031 21:32:58 : Flash Descriptor 21:32:58 : Manufacturer Code : 0020 21:32:58 : Device ID : 0040 21:32:58 : Extended/Fixed ID : 0000 21:32:58 : Revision ID : 0000 21:32:58 : Size : 10000000 (256 MB) 21:32:58 : VPP Info : 0000 21:32:58 : Erase10s : 1E 21:32:58 : Block1s : 32 21:32:58 : BErase1s : 02 21:32:58 : Reserved0 : 00 21:32:58 : Reserved1 : 00 21:32:58 : Reserved2 : 00 21:32:58 : C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_XSR15_alg.f g 21:32:58 : Algorithm File - Version 012.08.00 21:32:58 : Algorithm File - Revision 0x0002 (2) 21:32:58 : eBB5ProtocolType == New 21:32:58 : Algo Loader Sent... 21:32:58 : SendCodeStart_NewProtocol : 21:33:00 : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) 21:33:00 : TransmissionTypeRequest_DCT5_NewProtocol 21:33:00 : TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 21:33:00 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 21:33:00 : TransmissionTypeRequest_DCT5_NewProtocol 21:33:00 : FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX 21:33:00 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C 21:33:00 : SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) 21:33:00 : FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) 21:33:00 : FUR control Ok... 21:33:00 : VPP Enabled by Software 21:33:00 : Using Internal VPP 21:33:00 : VPP Enabled by Software 21:33:00 : FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 21:33:00 : PAPUB_KEYS_HASH_REQ_BB5 21:33:00 : PhoneInfoRequest_BB5 (Asic Index 00 ) 21:33:00 : PHONE_INFO_RESPONSE_BB5 21:33:00 : PAPUB_KEYS_HASH_RESP_BB5 2A 21:33:00 : BB Asic Index : 00 21:33:00 : CMT PAPUBKEYS HASH: 21:33:00 : 76A20187051C30162EE91C77AE5E6011F5F1BA61 21:33:00 : 21:33:00 : Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) 21:33:00 : Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) 21:33:00 : Certificate 1 21:33:00 : Name : NPC 21:33:00 : ASIC Index : CMT 0 21:33:00 : Certificate 2 21:33:00 : Name : CCC 21:33:00 : ASIC Index : CMT 0 21:33:00 : Certificate 3 21:33:00 : Name : HWC 21:33:00 : ASIC Index : CMT 0 21:33:00 : Certificate 4 21:33:00 : Name : R&D 21:33:00 : ASIC Index : CMT 0 21:33:00 : STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3 21:33:00 : STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00) 21:33:00 : ProcessPartitionInfo_DCT5... 21:33:00 : Partition Info 21:33:00 : Partition Blocks : 1 21:33:00 : 1 PARTITION_INFO_BB5 21:33:00 : BB ASIC Index : 0x00 CMT 21:33:00 : Device Type : 0x03 MuxOneNAND 21:33:00 : Device Index : 0x00 21:33:00 : Partition Version : 00010000 21:33:00 : Spare : FFFFFFFF 21:33:00 : Num Partitions : 00000004 21:33:00 : Partition 1 21:33:00 : ID : 00000003 COPIEDOS 21:33:00 : Attribute : 00000002 RO 21:33:00 : Start Address : 00080000 21:33:00 : Size : 029E0000 21:33:00 : Partition 2 21:33:00 : ID : 00000004 DEMANDONOS 21:33:00 : Attribute : 00000002 RO 21:33:00 : Start Address : 02A60000 21:33:00 : Size : 07400000 21:33:00 : Partition 3 21:33:00 : ID : 00000008 FILESYSTEM 21:33:00 : Attribute : 00000001 RW 21:33:00 : Start Address : 09E60000 21:33:00 : Size : 058C0000 21:33:00 : Partition 4 21:33:00 : ID : 0000000A PMM 21:33:00 : Attribute : 00000001 RW 21:33:00 : Start Address : 0F8C0000 21:33:00 : Size : 00160000 21:33:00 : PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF00000004000000030000 000200080000029E0000000000040000000202A60000074000 00000000080000000109E60000058C00000000000A00000001 0F8C00000016000095 21:33:00 : PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) 21:33:00 : ProcessPartitionInfo_DCT5 : No Error - 0 (0x00) 21:33:00 : StartErase_DCT5... 21:33:00 : BlockLength : 0x5F (95) 21:33:00 : ERASE Blocks : 0x02 (2) 21:33:00 : 0 ERASE_AREA_BB5 0x12 21:33:00 : Block Length : 0x2B (43) 21:33:00 : BB ASIC Index : 0x00 CMT 21:33:00 : Device Type : 0x03 MuxOneNAND 21:33:00 : Device Index : 0x00 21:33:00 : 0 : 00040000-00082FFF 21:33:00 : 1 : 00083400-003FFFFF 21:33:00 : 2 : 00400000-007FFFFF 21:33:00 : 3 : 00800000-00D5FFFF 21:33:00 : 4 : 00D60000-09E5FFFF 21:33:00 : 1 FORMAT_PARTITION_BB5 0x19 21:33:00 : Block Length : 0x2F (47) 21:33:00 : BB ASIC Index : 0x00 CMT 21:33:00 : Device Type : 0x03 MuxOneNAND 21:33:00 : Device Index : 0x00 21:33:00 : Format Info ID : 0x00000000 21:33:00 : Format Info : 000000000000000A0000000000000002000000640000000300 000001000000010000000000000000 21:33:00 : 21:33:00 : Erase_SendEraseBlock_BB5_NAND 21:33:00 : Task in Progress... Please Wait... 21:33:00 : 21:33:00 : Erase_SendFormatPartition_BB5_NAND 21:33:00 : Task in Progress... Please Wait... 21:33:01 : 21:33:01 : Successfully erased.. 21:33:01 : Time Taken to Erase : 00:00:01 21:33:01 : Flashing Speed: 5.00 Mhz (AUTO) 21:33:02 : Processing : RM-356_60.0.003_prd.core.C00 21:33:02 : Total blocks to write : 510 21:33:02 : >> CMT Rootkey Hash CERT : ADA 21:33:02 : >> CMT Rootkey Hash CERT : KEYS 21:33:02 : >> CMT Rootkey Hash CERT : PRIMAPP 21:33:02 : >> CMT Rootkey Hash CERT : RAP3NAND 21:33:02 : >> CMT Rootkey Hash CERT : PASUBTOC 21:33:02 : >> CMT Rootkey Hash CERT : PAPUBKEYS [76A20187051C30162EE91C77AE5E6011F5F1BA61] 21:33:02 : >> CMT Rootkey Hash CERT : SOS*UPDAPP 21:33:03 : >> CMT Rootkey Hash CERT : SOS*ENO 21:33:04 : >> CMT Rootkey Hash CERT : SOS*DSP0 21:33:05 : >> CMT Rootkey Hash CERT : SOS*ISASW 21:33:06 : >> CMT Rootkey Hash CERT : SOS+CORE 21:33:23 : >> CMT Rootkey Hash CERT : SOS+ROFS1 21:34:04 : ContinueFlash_DCT5 Complete 21:34:04 : Continue Flash Complete : : No Error - 0 (0x00) 21:34:04 : Time Taken to Flash : 00:01:03 21:34:04 : 21:34:04 : Processing Image File : 21:34:04 : D:\Прошивки\UFS+HWK\NOKIA\RM-356\RM-356\RM-356_60.0.003_prd.rofs2.V05 21:34:06 : CMT Type : BB5 21:34:06 : CMT Algorithm : XSR 1.5 21:34:06 : Secondary Sending Speed : 650000 Hz 21:34:06 : Algorithm Sending Speed : 13000000 Hz 21:34:06 : Program Sending Speed : 13000000 Hz 21:34:06 : Message Reading Speed : 98000 Hz 21:34:06 : Number of Blocks : 116 21:34:06 : Entry Point : 0x00FF 21:34:06 : Page Format : 128K 21:34:06 : Maximum Page Size : 0x00040000 21:34:06 : 21:34:06 : StartErase_DCT5... 21:34:06 : BlockLength : 0x0E (14) 21:34:06 : ERASE Blocks : 0x01 (1) 21:34:06 : 0 ERASE_AREA_BB5 0x12 21:34:06 : Block Length : 0x0B (11) 21:34:06 : BB ASIC Index : 0x00 CMT 21:34:06 : Device Type : 0x03 MuxOneNAND 21:34:06 : Device Index : 0x00 21:34:06 : 0 : 07180000-0915FFFF 21:34:06 : 21:34:06 : Erase_SendEraseBlock_BB5_NAND 21:34:06 : Task in Progress... Please Wait... 21:34:06 : 21:34:06 : Successfully erased.. 21:34:06 : Time Taken to Erase : 00:00:00 21:34:06 : Flashing Speed: 5.00 Mhz (AUTO) 21:34:07 : Processing : RM-356_60.0.003_prd.rofs2.V05 21:34:07 : Total blocks to write : 116 21:34:07 : >> CMT Rootkey Hash CERT : SOS+ROFS2 21:34:23 : ContinueFlash_DCT5 Complete 21:34:23 : Continue Flash Complete : : No Error - 0 (0x00) 21:34:23 : Time Taken to Flash : 00:00:16 21:34:23 : 21:34:23 : Processing Image File : 21:34:23 : D:\Прошивки\UFS+HWK\NOKIA\RM-356\RM-356\RM-356_60.0.001_026_000_U01.uda.fpsx 21:34:23 : CMT Type : BB5 21:34:23 : CMT Algorithm : XSR 1.5 21:34:23 : Secondary Sending Speed : 650000 Hz 21:34:23 : Algorithm Sending Speed : 13000000 Hz 21:34:23 : Program Sending Speed : 13000000 Hz 21:34:23 : Message Reading Speed : 98000 Hz 21:34:23 : Number of Blocks : 29 21:34:23 : Entry Point : 0x00F9 21:34:23 : Page Format : 128K 21:34:23 : Maximum Page Size : 0x00040000 21:34:23 : 21:34:23 : StartErase_DCT5... 21:34:23 : BlockLength : 0x0E (14) 21:34:23 : ERASE Blocks : 0x01 (1) 21:34:23 : 0 ERASE_AREA_BB5 0x12 21:34:23 : Block Length : 0x0B (11) 21:34:23 : BB ASIC Index : 0x00 CMT 21:34:23 : Device Type : 0x03 MuxOneNAND 21:34:23 : Device Index : 0x00 21:34:23 : 0 : 09E60000-0F71FFFF 21:34:23 : 21:34:23 : Erase_SendEraseBlock_BB5_NAND 21:34:23 : Task in Progress... Please Wait... 21:34:23 : 21:34:23 : Successfully erased.. 21:34:23 : Time Taken to Erase : 00:00:00 21:34:23 : Flashing Speed: 5.00 Mhz (AUTO) 21:34:24 : Processing : RM-356_60.0.001_026_000_U01.uda.fpsx 21:34:24 : Total blocks to write : 29 21:34:29 : ContinueFlash_DCT5 Complete 21:34:29 : Continue Flash Complete : : No Error - 0 (0x00) 21:34:29 : Time Taken to Flash : 00:00:05 21:34:29 : 21:34:29 : Total Flash Write Time (Flashing Only) : 00:01:24 21:34:29 : Total Flashing Time (Booting + Erase + Flashing) : 00:01:28 21:34:29 : 21:34:29 : STATUS_REQUEST_BB5... 21:34:29 : 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 21:34:29 : Block Length : 0F 21:34:29 : BB ASIC Index : 00 21:34:29 : Device Type : 03 21:34:29 : Device Type : 00 21:34:29 : Num Bad Blocks : 00000001 21:34:29 : Additional Bad : 00000001 21:34:29 : Correctable ECC : 00000000 21:34:33 : 21:34:33 : Waiting for Phone to Go Online... 21:34:34 : Elapsed Time: 1s 21:34:35 : Elapsed Time: 2s 21:34:36 : Elapsed Time: 3s 21:34:37 : Elapsed Time: 4s 21:34:38 : Elapsed Time: 5s 21:34:39 : Elapsed Time: 6s 21:34:40 : Elapsed Time: 7s 21:34:41 : Elapsed Time: 8s 21:34:42 : Elapsed Time: 9s 21:34:43 : Elapsed Time: 10s 21:34:43 : 21:34:43 : ================================================ 21:34:43 : Basic Phone Information 21:34:43 : ================================================ 21:34:43 : MCU Version: V ICPR72_10w29_tube1 24-05-11 RM-356 (c) Nokia 21:34:43 : IMEI Plain : 12345610654321? 21:34:43 : IMEI Spare : A123456106543210 21:34:43 : IMEI SV : 31234561065432174F 21:34:44 : Phone Model: Nokia 5800 XpressMusic 21:34:44 : Category : Classic Phone 21:34:44 : Phone Type : RM-356 21:34:44 : 21:34:44 : ================================================ 21:34:44 : Extended Phone Information 21:34:44 : ================================================ 21:34:44 : Product Serial Number: 0 21:34:44 : Long Production SN : 0 21:34:45 : MCU SW Version : V ICPR72_10w29_tube1 24-05-11 RM-356 (c) Nokia 21:34:45 : RFIC Version : 17141716 21:34:45 : DSP Version : ICPR72_10w26p1 21:34:46 : Content Pack Version : v 50.2010.06.1_001_000_U01 17-03-10 vanilla RM356 21:34:46 : AHNE Version : 11 21:34:46 : APE SW Core Version : V 60.0.003 21:34:46 : Variant Version : V 60.0.003V 60.0.003 21:34:46 : APE Test Version : eno_version 21:34:46 : RETU Version : 16 21:34:46 : TAHVO Version : 22 21:34:46 : APE HW Version : 256 21:34:46 : APE ADSP SW Version : 256 21:34:47 : Bluetooth ID : 00:02:5B:00:A5:A5 21:34:47 : CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA VIII 21:34:47 : 21:34:47 : ================================================ 21:34:47 : Simlock Information 21:34:47 : ================================================ 21:34:47 : Unable to read SP Data.. 21:34:51 : 21:34:51 : Waiting for Phone to Go Online... 21:34:52 : Elapsed Time: 1s 21:34:53 : Elapsed Time: 2s 21:34:54 : Elapsed Time: 3s 21:34:55 : Elapsed Time: 4s 21:34:56 : Elapsed Time: 5s 21:34:57 : Elapsed Time: 6s 21:34:58 : Elapsed Time: 7s 21:34:59 : Elapsed Time: 8s 21:35:00 : Elapsed Time: 9s 21:35:01 : Elapsed Time: 10s 21:35:01 : 21:35:01 : ================================================ 21:35:01 : Basic Phone Information 21:35:01 : ================================================ 21:35:01 : MCU Version: V ICPR72_10w29_tube1 24-05-11 RM-356 (c) Nokia 21:35:01 : IMEI Plain : 12345610654321? 21:35:01 : IMEI Spare : A123456106543210 21:35:01 : IMEI SV : 31234561065432174F 21:35:02 : Phone Model: Nokia 5800 XpressMusic 21:35:02 : Category : Classic Phone 21:35:02 : Phone Type : RM-356 21:35:02 : 21:35:02 : ================================================ 21:35:02 : Extended Phone Information 21:35:02 : ================================================ 21:35:02 : Product Serial Number: 0 21:35:02 : Long Production SN : 0 21:35:03 : MCU SW Version : V ICPR72_10w29_tube1 24-05-11 RM-356 (c) Nokia 21:35:03 : RFIC Version : 17141716 21:35:03 : DSP Version : ICPR72_10w26p1 21:35:04 : Content Pack Version : v 50.2010.06.1_001_000_U01 17-03-10 vanilla RM356 21:35:04 : AHNE Version : 11 21:35:04 : APE SW Core Version : V 60.0.003 21:35:04 : Variant Version : V 60.0.003V 60.0.003 21:35:04 : APE Test Version : eno_version 21:35:04 : RETU Version : 16 21:35:04 : TAHVO Version : 22 21:35:04 : APE HW Version : 256 21:35:05 : APE ADSP SW Version : 256 21:35:05 : Bluetooth ID : 00:02:5B:00:A5:A5 21:35:05 : CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA VIII 21:35:05 : 21:35:05 : ================================================ 21:35:05 : Simlock Information 21:35:05 : ================================================ 21:35:05 : Unable to read SP Data.. 21:35:05 : SECURITY_TEST : PASSED 21:35:06 : PHONE_MODE : TEST 21:35:06 : DCC ID : NOT USED 21:35:06 : 21:35:06 : 21:35:06 : FACTORY SET TO : Full Factory Set 21:35:12 : OK 21:35:12 : FACTORY SET TO : User Data 21:35:12 : OK 21:35:12 : FACTORY SET TO : Leave Factory 21:35:12 : OK 21:35:12 : FACTORY SET TO : Service Center 21:35:12 : OK 21:35:12 : FACTORY SET TO : Software Upgrade 21:35:12 : OK 21:35:12 : FACTORY SET TO : Production Tune 21:35:12 : OK 21:35:13 : 21:35:13 : 21:35:13 : Life timer data is not yet used... 21:35:13 : Life timer: ----:-- 21:36:50 : Booting Phone via FBUS... 21:36:50 : 21:36:50 : 21:36:50 : AdvanceBox SendBootCodeEx 21:36:50 : InitialiseBootstrap_DCT5 DIR 21:36:50 : BootFlashMode_DCT5 21:36:50 : 21:36:50 : ************************************************** **** 21:36:50 : TIME STARTS HERE 21:36:50 : ************************************************** **** 21:36:50 : 21:36:50 : BootFlashModeDCT5Ex Succeeded First Time 21:36:50 : SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned 21:36:50 : Number of Sub Blocks 7 (0x07) 21:36:50 : 1 SYSTEM_ASIC_ID 01 21:36:50 : Block Length : 21 (15) 21:36:50 : BB ASIC Index : 0 (00) CMT 21:36:50 : ID DWORD 0 : 00000001 21:36:50 : ID DWORD 1 : 00000226 21:36:50 : ID DWORD 2 : 00010006 21:36:50 : ID DWORD 3 : 400C1921 21:36:50 : ID DWORD 4 : 01031103 21:36:50 : 2 EM_ASIC_ID 02 21:36:50 : Block Length : 5 (05) 21:36:50 : BB ASIC Index : 0 (00) CMT 21:36:50 : ID DWORD 0 : 00000296 21:36:50 : 3 EM_ASIC_ID 02 21:36:50 : Block Length : 5 (05) 21:36:50 : BB ASIC Index : 0 (00) CMT 21:36:50 : ID DWORD 0 : 00000B22 21:36:50 : 4 PUBLIC_ID 12 21:36:50 : Block Length : 21 (15) 21:36:50 : BB ASIC Index : 0 (00) CMT 21:36:50 : ID DWORD 0 : 0930010C 21:36:50 : ID DWORD 1 : 1AB70052 21:36:50 : ID DWORD 2 : 968F393B 21:36:50 : ID DWORD 3 : C5BD03C4 21:36:50 : ID DWORD 4 : 41F1CDD5 21:36:50 : 5 ASIC_MODE_ID 13 21:36:50 : Block Length : 2 (02) 21:36:50 : BB ASIC Index : 0 (00) CMT 21:36:50 : Mode Id : 00 21:36:50 : 6 ROOT_KEY_HASH 14 21:36:50 : Block Length : 17 (11) 21:36:50 : BB ASIC Index : 0 (00) CMT 21:36:50 : Hash : CA EE BB 65 D3 C4 8E 6D C7 3B 49 DC 50 63 A2 EE 21:36:50 : 7 ROM_ID 15 21:36:50 : Block Length : 9 (09) 21:36:50 : BB ASIC Index : 0 (00) CMT 21:36:50 : CRC 0 : 4B9B7510 21:36:50 : CRC 1 : 3E691FF8 21:36:50 : Checksum A6 21:36:50 : 21:36:50 : SearchForBootstrap_DCT5.. |
04-11-2013, 20:17 | #2 (permalink) |
Member: 158841 Status: Offline Thanks Meter: 0 | 21:36:50 : SearchForBootstrap_DCT5.. 21:36:50 : C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_2nd.fg 21:36:50 : Boot File - Version 012.08.00 21:36:50 : Boot File - Revision 0x0002 (2) 21:36:50 : eBB5ProtocolType == New 21:36:50 : PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" 21:36:50 : PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0" 21:36:50 : SearchForBootstrap_DCT5 : No Error - 0 (0x00) 21:36:51 : Secondary Loader Sent... 21:36:51 : TransmissionTypeRequest_DCT5_NewProtocol 21:36:51 : TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 21:36:51 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 21:36:51 : TransmissionTypeRequest_DCT5_NewProtocol 21:36:51 : FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX 21:36:51 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C 21:36:51 : Transmission Type Request Sent... 21:36:51 : ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. 21:36:51 : MCU_CONFIGURATION_RESPONSE_BB5: 21:36:51 : MessageID : 06 21:36:51 : SubBlocks : 06 21:36:51 : 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 21:36:51 : Block Length : 0B 21:36:51 : BB ASIC Index : CMT 00 21:36:51 : Device Type : RAM 05 21:36:51 : Device Index : 00 21:36:51 : Manufacturer Code : 0000 -> Flash 21:36:51 : Device ID : 0000 -> not detected 21:36:51 : Extended/Fixed ID : 0000 21:36:51 : Revision ID : 0000 21:36:51 : 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 21:36:51 : Block Length : 0B 21:36:51 : BB ASIC Index : CMT 00 21:36:51 : Device Type : MMC 04 21:36:51 : Device Index : 00 21:36:51 : Manufacturer Code : FFFF -> Flash 21:36:51 : Device ID : 0000 -> BAD FLASH TYPE 21:36:51 : Extended/Fixed ID : 0000 21:36:51 : Revision ID : 0000 21:36:51 : 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 21:36:51 : Block Length : 0B 21:36:51 : BB ASIC Index : CMT 00 21:36:51 : Device Type : NOR 00 21:36:51 : Device Index : 00 21:36:51 : Manufacturer Code : 0020 -> 21:36:51 : Device ID : 0040 -> Type not in database 21:36:51 : Extended/Fixed ID : 0000 21:36:51 : Revision ID : 0031 21:36:51 : 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 21:36:51 : Block Length : 0B 21:36:51 : BB ASIC Index : CMT 00 21:36:51 : Device Type : NOR 00 21:36:51 : Device Index : 01 21:36:51 : Manufacturer Code : 0000 -> SPANSION 21:36:51 : Device ID : 0001 -> not used 21:36:51 : Extended/Fixed ID : 0000 21:36:51 : Revision ID : 0000 21:36:51 : 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 21:36:51 : Block Length : 0B 21:36:51 : BB ASIC Index : CMT 00 21:36:51 : Device Type : MuxOneNAND 03 21:36:51 : Device Index : 00 21:36:51 : Manufacturer Code : 0020 -> 21:36:51 : Device ID : 0040 -> Type not in database 21:36:51 : Extended/Fixed ID : 0000 21:36:51 : Revision ID : 0031 21:36:51 : 6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5 21:36:51 : Block Length : 09 21:36:51 : BB ASIC Index : CMT 00 21:36:51 : Data : XSR 1.5 21:36:51 : Checksum : 55 21:36:51 : SearchForBootstrap_DCT5 : No Error - 0 (0x00) 21:36:51 : FLS1SendAlgoCodeEx.. 21:36:51 : SendAlgoCode_DCT5.. 21:36:51 : SearchForAlgorithm_DCT5.. 21:36:51 : Looking for ALL Devices... 21:36:51 : Searching Algorithm Files MuxOneNAND (03) ManID :0020 DevID :0040 ExtID :0000 RevID :0031 21:36:51 : Flash Descriptor 21:36:51 : Manufacturer Code : 0020 21:36:51 : Device ID : 0040 21:36:51 : Extended/Fixed ID : 0000 21:36:51 : Revision ID : 0000 21:36:51 : Size : 10000000 (256 MB) 21:36:51 : VPP Info : 0000 21:36:51 : Erase10s : 1E 21:36:51 : Block1s : 32 21:36:51 : BErase1s : 02 21:36:51 : Reserved0 : 00 21:36:51 : Reserved1 : 00 21:36:51 : Reserved2 : 00 21:36:51 : C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_XSR15_alg.f g 21:36:51 : Algorithm File - Version 012.08.00 21:36:51 : Algorithm File - Revision 0x0002 (2) 21:36:51 : eBB5ProtocolType == New 21:36:51 : Algo Loader Sent... 21:36:51 : SendCodeStart_NewProtocol : 21:36:53 : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) 21:36:53 : TransmissionTypeRequest_DCT5_NewProtocol 21:36:53 : TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 21:36:53 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 21:36:53 : TransmissionTypeRequest_DCT5_NewProtocol 21:36:53 : FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX 21:36:53 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C 21:36:53 : SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) 21:36:53 : FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) 21:36:53 : FUR control Ok... 21:36:53 : VPP Enabled by Software 21:36:53 : Using Internal VPP 21:36:53 : VPP Enabled by Software 21:36:53 : FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 21:36:53 : PAPUB_KEYS_HASH_REQ_BB5 21:36:53 : PhoneInfoRequest_BB5 (Asic Index 00 ) 21:36:53 : PHONE_INFO_RESPONSE_BB5 21:36:53 : PAPUB_KEYS_HASH_RESP_BB5 2A 21:36:53 : BB Asic Index : 00 21:36:53 : CMT PAPUBKEYS HASH: 21:36:53 : 76A20187051C30162EE91C77AE5E6011F5F1BA61 21:36:53 : 21:36:53 : VPP Enabled by Software 21:36:53 : Using Internal VPP 21:36:53 : VPP Enabled by Software 21:36:53 : FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 21:36:53 : StartErase_DCT5... 21:36:53 : BlockLength : 0x10 (16) 21:36:53 : ERASE Blocks : 0x01 (1) 21:36:53 : 0 ERASE_AREA_BB5 0x13 21:36:53 : Block Length : 0x0D (13) 21:36:53 : BB ASIC Index : 0x00 CMT 21:36:53 : 21:36:53 : Erase_SendEraseBlock_BB5_NAND 21:36:53 : Task in Progress... Please Wait... 21:36:54 : 21:36:54 : Successfully erased.. 21:36:54 : 21:36:54 : Now Writing : CMT NPC Certificate 0x07F8 Bytes 21:36:54 : 21:36:54 : NPC Write Successful... 21:36:54 : 21:36:54 : StartErase_DCT5... 21:36:54 : BlockLength : 0x10 (16) 21:36:54 : ERASE Blocks : 0x01 (1) 21:36:54 : 0 ERASE_AREA_BB5 0x13 21:36:54 : Block Length : 0x0D (13) 21:36:54 : BB ASIC Index : 0x00 CMT 21:36:54 : 21:36:54 : Erase_SendEraseBlock_BB5_NAND 21:36:54 : Task in Progress... Please Wait... 21:36:54 : 21:36:54 : Successfully erased.. 21:36:54 : 21:36:54 : Now Writing : CMT CCC Certificate 0x03E8 Bytes 21:36:54 : 21:36:54 : CCC Write Successful... 21:36:54 : 21:36:55 : StartErase_DCT5... 21:36:55 : BlockLength : 0x10 (16) 21:36:55 : ERASE Blocks : 0x01 (1) 21:36:55 : 0 ERASE_AREA_BB5 0x13 21:36:55 : Block Length : 0x0D (13) 21:36:55 : BB ASIC Index : 0x00 CMT 21:36:55 : 21:36:55 : Erase_SendEraseBlock_BB5_NAND 21:36:55 : Task in Progress... Please Wait... 21:36:55 : 21:36:55 : Successfully erased.. 21:36:55 : 21:36:55 : Now Writing : CMT HWC Certificate 0x03E8 Bytes 21:36:55 : 21:36:55 : HWC Write Successful... 21:36:55 : 21:36:55 : StartErase_DCT5... 21:36:55 : BlockLength : 0x10 (16) 21:36:55 : ERASE Blocks : 0x01 (1) 21:36:55 : 0 ERASE_AREA_BB5 0x13 21:36:55 : Block Length : 0x0D (13) 21:36:55 : BB ASIC Index : 0x00 CMT 21:36:55 : 21:36:55 : Erase_SendEraseBlock_BB5_NAND 21:36:55 : Task in Progress... Please Wait... 21:36:55 : 21:36:55 : Successfully erased.. 21:36:56 : 21:36:56 : Now Writing : CMT R&D Certificate 0x03E8 Bytes 21:36:56 : 21:36:56 : R&D Write Successful... 21:36:56 : 21:36:56 : 21:36:56 : Write Certificates OK! 21:36:56 : 21:36:56 : 21:36:56 : RPL Upload Finished!!! 21:37:06 : 21:37:06 : ================================================ 21:37:06 : Basic Phone Information 21:37:06 : ================================================ 21:37:07 : MCU Version: V ICPR72_10w29_tube1 24-05-11 RM-356 (c) Nokia 21:37:07 : IMEI Plain : 353781043774452 21:37:07 : IMEI Spare : A353781043774450 21:37:07 : IMEI SV : 33537810437744574F 21:37:07 : Phone Model: Nokia 5800 XpressMusic 21:37:07 : Category : Classic Phone 21:37:07 : Phone Type : RM-356 21:37:07 : 21:37:07 : 21:37:07 : 21:37:07 : ================================================ 21:37:07 : SL1/SL2 Simlock RPL Stand Alone Edition 21:37:07 : ================================================ 21:37:07 : Generating Simlock Data RPL... 21:37:07 : OK: Simlock RPL Accepted 21:37:09 : 21:37:11 : 21:37:11 : Waiting for Phone to Go Online... 21:37:12 : Elapsed Time: 1s 21:37:13 : Elapsed Time: 2s 21:37:14 : Elapsed Time: 3s 21:37:15 : Elapsed Time: 4s 21:37:16 : Elapsed Time: 5s 21:37:17 : Elapsed Time: 6s 21:37:18 : Elapsed Time: 7s 21:37:19 : Elapsed Time: 8s 21:37:20 : Elapsed Time: 9s 21:37:21 : Elapsed Time: 10s 21:37:21 : 21:37:21 : ================================================ 21:37:21 : Basic Phone Information 21:37:21 : ================================================ 21:37:22 : MCU Version: V ICPR72_10w29_tube1 24-05-11 RM-356 (c) Nokia 21:37:22 : IMEI Plain : 353781043774452 21:37:22 : IMEI Spare : A353781043774450 21:37:22 : IMEI SV : 33537810437744574F 21:37:22 : Phone Model: Nokia 5800 XpressMusic 21:37:22 : Category : Classic Phone 21:37:22 : Phone Type : RM-356 21:37:22 : 21:37:22 : ================================================ 21:37:22 : Extended Phone Information 21:37:22 : ================================================ 21:37:22 : Product Serial Number: 0 21:37:22 : Long Production SN : 0 21:37:23 : MCU SW Version : V ICPR72_10w29_tube1 24-05-11 RM-356 (c) Nokia 21:37:23 : RFIC Version : 17141716 21:37:23 : DSP Version : ICPR72_10w26p1 21:37:24 : AHNE Version : 11 21:37:24 : APE SW Core Version : V 60.0.003 21:37:24 : Variant Version : V 60.0.003V 60.0.003 21:37:25 : APE Test Version : eno_version 21:37:25 : RETU Version : 16 21:37:25 : TAHVO Version : 22 21:37:25 : APE HW Version : 256 21:37:25 : APE ADSP SW Version : 256 21:37:25 : Wireless LAN ID : E0:A6:70:379:FB 21:37:25 : Bluetooth ID : E0:A6:70:38:84:E4 21:37:25 : CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA VIII 21:37:25 : 21:37:25 : ================================================ 21:37:25 : Simlock Information 21:37:25 : ================================================ 21:37:26 : CONFIG KEY : 0000000000000000 21:37:26 : PROVIDER KEY : 2440700000000000 21:37:26 : NETWORK NAME : Nokia Default;Finland 21:37:26 : LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10 21:37:26 : SIMLOCK TABLE : 21:37:26 : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open 21:37:26 : Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open 21:37:26 : Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open 21:37:26 : Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open 21:37:26 : Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open 21:37:26 : Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open 21:37:26 : Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open 21:37:26 : SIMLOCK STATE : Not Locked 21:37:26 : 21:37:26 : SIMLOCK_TYPE : PA_SL2 21:37:26 : SIMLOCK_TEST : PASSED 21:37:26 : SECURITY_TEST : FAILED 21:37:26 : > Try SX4 "PM AUTH" 21:37:26 : > Then Write PM 1 and 309 21:37:31 : CMLA_KEY : ABSENT 21:37:31 : SUPER_DONGLE_TEST : FAILED 21:37:31 : > Try "Repair Super Dongle" 21:37:31 : 21:37:31 : ================================================ 21:37:31 : SL1/SL2 Phone detected 21:37:31 : ================================================ 21:37:31 : 21:37:31 : PHONE_MODE : TEST 21:37:31 : DCC ID : NOT USED 21:37:31 : 21:37:31 : 21:37:31 : Successfully done. 21:37:43 : 21:37:43 : ================================================ 21:37:43 : Basic Phone Information 21:37:43 : ================================================ 21:37:44 : MCU Version: V ICPR72_10w29_tube1 24-05-11 RM-356 (c) Nokia 21:37:44 : IMEI Plain : 353781043774452 21:37:44 : IMEI Spare : A353781043774450 21:37:44 : IMEI SV : 33537810437744574F 21:37:44 : Phone Model: Nokia 5800 XpressMusic 21:37:44 : Category : Classic Phone 21:37:44 : Phone Type : RM-356 21:37:44 : 21:37:44 : 21:37:44 : 21:37:44 : ================================================ 21:37:44 : Super Dongle RPL Stand Alone Edition 21:37:44 : ================================================ 21:37:44 : Generating Super Dongle RPL... 21:37:44 : Sending Superdongle RPL... 21:37:44 : OK: Super Dongle RPL Accepted 21:37:46 : 21:37:46 : 21:37:46 : Successfully done. 21:38:08 : 21:38:08 : ================================================ 21:38:08 : Basic Phone Information 21:38:08 : ================================================ 21:38:08 : MCU Version: V ICPR72_10w29_tube1 24-05-11 RM-356 (c) Nokia 21:38:08 : IMEI Plain : 353781043774452 21:38:08 : IMEI Spare : A353781043774450 21:38:08 : IMEI SV : 33537810437744574F 21:38:08 : Phone Model: Nokia 5800 XpressMusic 21:38:08 : Category : Classic Phone 21:38:08 : Phone Type : RM-356 21:38:08 : 21:38:08 : 21:38:08 : 21:38:08 : ================================================ 21:38:08 : SX4 Custom Keys Stand Alone Edition 21:38:08 : ================================================ 21:38:08 : 21:38:08 : >>> : SX4 Auth Successfull 21:38:08 : Selected PM File: C:\AdvanceBox Turbo Flasher\Nokia\PM Files\SX4\RM-356.pm 21:38:08 : Start Uploading PM... 21:38:09 : Field : 1 Sub : 0 Byte(s): 114 - Ok 21:38:09 : Field : 1 Sub : 2 Byte(s): 98 - Ok 21:38:09 : Field : 1 Sub : 4 Byte(s): 110 - Ok 21:38:09 : Field : 1 Sub : 6 Byte(s): 98 - Ok 21:38:09 : Field : 1 Sub : 8 Byte(s): 110 - Ok 21:38:09 : Field : 1 Sub : 13 Byte(s): 98 - Ok 21:38:09 : Field : 1 Sub : 16 Byte(s): 98 - Ok 21:38:09 : Field : 1 Sub : 18 Byte(s): 98 - Ok 21:38:09 : Field : 1 Sub : 20 Byte(s): 98 - Ok 21:38:09 : Field : 1 Sub : 22 Byte(s): 16 - Ok 21:38:09 : Field : 1 Sub : 23 Byte(s): 4 - Ok 21:38:09 : Field : 1 Sub : 24 Byte(s): 84 - Ok 21:38:09 : Field : 1 Sub : 25 Byte(s): 4 - Ok 21:38:09 : Field : 1 Sub : 26 Byte(s): 110 - Ok 21:38:09 : Field : 1 Sub : 28 Byte(s): 98 - Ok 21:38:09 : Field : 1 Sub : 29 Byte(s): 10 - Ok 21:38:10 : Field : 1 Sub : 31 Byte(s): 98 - Ok 21:38:10 : Field : 1 Sub : 33 Byte(s): 36 - Ok 21:38:10 : Field : 1 Sub : 34 Byte(s): 80 - Ok 21:38:10 : Field : 1 Sub : 35 Byte(s): 16 - Ok 21:38:10 : Field : 1 Sub : 37 Byte(s): 4 - Ok 21:38:10 : Field : 1 Sub : 39 Byte(s): 36 - Ok 21:38:10 : Field : 1 Sub : 44 Byte(s): 182 - Ok 21:38:10 : Field : 1 Sub : 45 Byte(s): 182 - Ok 21:38:10 : Field : 309 Sub : 0 Byte(s): 4 - Ok 21:38:10 : Field : 309 Sub : 1 Byte(s): 2 - Ok 21:38:10 : Field : 309 Sub : 2 Byte(s): 12 - Ok 21:38:10 : Field : 309 Sub : 4 Byte(s): 12 - Ok 21:38:10 : Field : 309 Sub : 5 Byte(s): 12 - Ok 21:38:10 : Field : 309 Sub : 7 Byte(s): 12 - Ok 21:38:10 : Field : 309 Sub : 8 Byte(s): 12 - Ok 21:38:11 : Field : 309 Sub : 17 Byte(s): 12 - Ok 21:38:11 : PM Upload Done!... 21:38:15 : 21:38:16 : 21:38:16 : ================================================ 21:38:16 : Basic Phone Information 21:38:16 : ================================================ 21:38:16 : MCU Version: V ICPR72_10w29_tube1 24-05-11 RM-356 (c) Nokia 21:38:16 : IMEI Plain : 353781043774452 21:38:16 : IMEI Spare : A353781043774450 21:38:16 : IMEI SV : 33537810437744574F 21:38:16 : Phone Model: Nokia 5800 XpressMusic 21:38:16 : Category : Classic Phone 21:38:16 : Phone Type : RM-356 21:38:16 : 21:38:16 : ================================================ 21:38:16 : Extended Phone Information 21:38:16 : ================================================ 21:38:16 : Product Serial Number: 0 21:38:17 : Long Production SN : 0 21:38:17 : MCU SW Version : V ICPR72_10w29_tube1 24-05-11 RM-356 (c) Nokia 21:38:17 : RFIC Version : 17141716 21:38:17 : DSP Version : ICPR72_10w26p1 21:38:18 : AHNE Version : 11 21:38:19 : APE SW Core Version : V 60.0.003 21:38:19 : Variant Version : V 60.0.003V 60.0.003 21:38:19 : APE Test Version : eno_version 21:38:19 : RETU Version : 16 21:38:19 : TAHVO Version : 22 21:38:19 : APE HW Version : 256 21:38:19 : APE ADSP SW Version : 256 21:38:19 : Wireless LAN ID : E0:A6:70:379:FB 21:38:19 : Bluetooth ID : E0:A6:70:38:84:E4 21:38:20 : CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA VIII 21:38:20 : 21:38:20 : ================================================ 21:38:20 : Simlock Information 21:38:20 : ================================================ 21:38:20 : CONFIG KEY : 0000000000000000 21:38:20 : PROVIDER KEY : 2440700000000000 21:38:20 : NETWORK NAME : Nokia Default;Finland 21:38:20 : LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10 21:38:20 : SIMLOCK TABLE : 21:38:20 : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open 21:38:20 : Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open 21:38:20 : Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open 21:38:20 : Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open 21:38:20 : Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open 21:38:20 : Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open 21:38:20 : Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open 21:38:20 : SIMLOCK STATE : Not Locked 21:38:20 : 21:38:20 : SIMLOCK_TYPE : PA_SL2 21:38:20 : SIMLOCK_TEST : PASSED 21:38:20 : SECURITY_TEST : FAILED 21:38:20 : > Try SX4 "PM AUTH" 21:38:20 : > Then Write PM 1 and 309 21:38:21 : PHONE_MODE : TEST 21:38:21 : DCC ID : NOT USED I think that the problems with the PRODUCT CODE. How can i solve this problem? Help me, please! |
04-11-2013, 20:27 | #3 (permalink) |
No Life Poster Join Date: Jun 2009 Location: SouthAmericaUnlockers Age: 52
Member: 1057178 Status: Offline Sonork: Kfe~Labs Co.- Thanks Meter: 568 | You can write rpl without npcdata for this problem.- Check this (info) about 5800 xpress http://forum.gsmhosting.com/vbb/f609...g-sl2-1634312/ br polaco |
04-12-2013, 09:16 | #5 (permalink) |
Product Supporter Join Date: Sep 2006 Location: Kerala-India Age: 46
Member: 351924 Status: Offline Thanks Meter: 12,469 | moslty security test failed is 1&309(RF,BB Data) Missing or damage just write 1&309 pm via sx4 auth next is CCC&HWC data lost or damage just write this rpl file C:\AdvanceBox Turbo Flasher\Nokia\RPL_Wout_NPC post result |
04-12-2013, 11:13 | #6 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | @Sergunya Try to write RM-1.pm or Generic PM from SX4 folder using StandAlone SX4 AUTH. BR |
The Following User Says Thank You to ..::Angel::.. For This Useful Post: |
04-17-2013, 19:56 | #7 (permalink) |
Junior Member Join Date: Jul 2005 Location: Ukraine
Member: 158841 Status: Offline Thanks Meter: 0 | Thanks to all! I already tried to write RM-1.pm and Generic PM from SX4 folder using StandAlone SX4 AUTH - it doesn't helped me. After i wrote rpl file from C:\AdvanceBox Turbo Flasher\Nokia\RPL_Wout_NPC and finally SECURITY_TEST - PASSED 21:08:47 : BootFlashModeDCT5Ex Succeeded First Time 21:08:47 : SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned 21:08:47 : Number of Sub Blocks 7 (0x07) 21:08:47 : 1 SYSTEM_ASIC_ID 01 21:08:47 : Block Length : 21 (15) 21:08:47 : BB ASIC Index : 0 (00) CMT 21:08:47 : ID DWORD 0 : 00000001 21:08:47 : ID DWORD 1 : 00000226 21:08:47 : ID DWORD 2 : 00010006 21:08:47 : ID DWORD 3 : 400C1921 21:08:47 : ID DWORD 4 : 01031103 21:08:47 : 2 EM_ASIC_ID 02 21:08:47 : Block Length : 5 (05) 21:08:47 : BB ASIC Index : 0 (00) CMT 21:08:47 : ID DWORD 0 : 00000296 21:08:47 : 3 EM_ASIC_ID 02 21:08:47 : Block Length : 5 (05) 21:08:47 : BB ASIC Index : 0 (00) CMT 21:08:47 : ID DWORD 0 : 00000B22 21:08:47 : 4 PUBLIC_ID 12 21:08:47 : Block Length : 21 (15) 21:08:47 : BB ASIC Index : 0 (00) CMT 21:08:47 : ID DWORD 0 : 0930010C 21:08:47 : ID DWORD 1 : 1AB70052 21:08:47 : ID DWORD 2 : 968F393B 21:08:47 : ID DWORD 3 : C5BD03C4 21:08:47 : ID DWORD 4 : 41F1CDD5 21:08:47 : 5 ASIC_MODE_ID 13 21:08:47 : Block Length : 2 (02) 21:08:47 : BB ASIC Index : 0 (00) CMT 21:08:47 : Mode Id : 00 21:08:47 : 6 ROOT_KEY_HASH 14 21:08:47 : Block Length : 17 (11) 21:08:47 : BB ASIC Index : 0 (00) CMT 21:08:47 : Hash : CA EE BB 65 D3 C4 8E 6D C7 3B 49 DC 50 63 A2 EE 21:08:47 : 7 ROM_ID 15 21:08:47 : Block Length : 9 (09) 21:08:47 : BB ASIC Index : 0 (00) CMT 21:08:47 : CRC 0 : 4B9B7510 21:08:47 : CRC 1 : 3E691FF8 21:08:47 : Checksum A6 21:08:47 : 21:08:47 : SearchForBootstrap_DCT5.. 21:08:47 : C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_2nd.fg 21:08:47 : Boot File - Version 012.08.00 21:08:47 : Boot File - Revision 0x0002 (2) 21:08:47 : eBB5ProtocolType == New 21:08:47 : PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" 21:08:47 : PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0" 21:08:47 : SearchForBootstrap_DCT5 : No Error - 0 (0x00) 21:08:47 : Secondary Loader Sent... 21:08:47 : TransmissionTypeRequest_DCT5_NewProtocol 21:08:47 : TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 21:08:47 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 21:08:47 : TransmissionTypeRequest_DCT5_NewProtocol 21:08:47 : FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX 21:08:47 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C 21:08:47 : Transmission Type Request Sent... 21:08:47 : ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. 21:08:47 : MCU_CONFIGURATION_RESPONSE_BB5: 21:08:47 : MessageID : 06 21:08:47 : SubBlocks : 06 21:08:47 : 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 21:08:47 : Block Length : 0B 21:08:47 : BB ASIC Index : CMT 00 21:08:47 : Device Type : RAM 05 21:08:47 : Device Index : 00 21:08:47 : Manufacturer Code : 0000 -> Flash 21:08:47 : Device ID : 0000 -> not detected 21:08:47 : Extended/Fixed ID : 0000 21:08:47 : Revision ID : 0000 21:08:47 : 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 21:08:47 : Block Length : 0B 21:08:47 : BB ASIC Index : CMT 00 21:08:47 : Device Type : MMC 04 21:08:47 : Device Index : 00 21:08:47 : Manufacturer Code : FFFF -> Flash 21:08:47 : Device ID : 0000 -> BAD FLASH TYPE 21:08:47 : Extended/Fixed ID : 0000 21:08:47 : Revision ID : 0000 21:08:47 : 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 21:08:47 : Block Length : 0B 21:08:47 : BB ASIC Index : CMT 00 21:08:47 : Device Type : NOR 00 21:08:47 : Device Index : 00 21:08:47 : Manufacturer Code : 0020 -> 21:08:47 : Device ID : 0040 -> Type not in database 21:08:47 : Extended/Fixed ID : 0000 21:08:47 : Revision ID : 0031 21:08:47 : 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 21:08:47 : Block Length : 0B 21:08:47 : BB ASIC Index : CMT 00 21:08:47 : Device Type : NOR 00 21:08:47 : Device Index : 01 21:08:47 : Manufacturer Code : 0000 -> SPANSION 21:08:47 : Device ID : 0001 -> not used 21:08:47 : Extended/Fixed ID : 0000 21:08:47 : Revision ID : 0000 21:08:47 : 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 21:08:47 : Block Length : 0B 21:08:47 : BB ASIC Index : CMT 00 21:08:47 : Device Type : MuxOneNAND 03 21:08:47 : Device Index : 00 21:08:47 : Manufacturer Code : 0020 -> 21:08:47 : Device ID : 0040 -> Type not in database 21:08:47 : Extended/Fixed ID : 0000 21:08:47 : Revision ID : 0031 21:08:47 : 6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5 21:08:47 : Block Length : 09 21:08:47 : BB ASIC Index : CMT 00 21:08:47 : Data : XSR 1.5 21:08:47 : Checksum : 55 21:08:47 : SearchForBootstrap_DCT5 : No Error - 0 (0x00) 21:08:47 : FLS1SendAlgoCodeEx.. 21:08:47 : SendAlgoCode_DCT5.. 21:08:47 : SearchForAlgorithm_DCT5.. 21:08:47 : Looking for ALL Devices... 21:08:47 : Searching Algorithm Files MuxOneNAND (03) ManID :0020 DevID :0040 ExtID :0000 RevID :0031 21:08:47 : Flash Descriptor 21:08:47 : Manufacturer Code : 0020 21:08:47 : Device ID : 0040 21:08:47 : Extended/Fixed ID : 0000 21:08:47 : Revision ID : 0000 21:08:47 : Size : 10000000 (256 MB) 21:08:47 : VPP Info : 0000 21:08:47 : Erase10s : 1E 21:08:47 : Block1s : 32 21:08:47 : BErase1s : 02 21:08:47 : Reserved0 : 00 21:08:47 : Reserved1 : 00 21:08:47 : Reserved2 : 00 21:08:47 : C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_XSR15_alg.f g 21:08:47 : Algorithm File - Version 012.08.00 21:08:47 : Algorithm File - Revision 0x0002 (2) 21:08:47 : eBB5ProtocolType == New 21:08:48 : Algo Loader Sent... 21:08:48 : SendCodeStart_NewProtocol : 21:08:49 : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) 21:08:49 : TransmissionTypeRequest_DCT5_NewProtocol 21:08:49 : TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 21:08:49 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 21:08:50 : TransmissionTypeRequest_DCT5_NewProtocol 21:08:50 : FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX 21:08:50 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C 21:08:50 : SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) 21:08:50 : FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) 21:08:51 : FUR control Ok... 21:08:51 : VPP Enabled by Software 21:08:51 : Using Internal VPP 21:08:51 : VPP Enabled by Software 21:08:51 : FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 21:08:51 : PAPUB_KEYS_HASH_REQ_BB5 21:08:51 : PhoneInfoRequest_BB5 (Asic Index 00 ) 21:08:51 : PHONE_INFO_RESPONSE_BB5 21:08:51 : PAPUB_KEYS_HASH_RESP_BB5 2A 21:08:51 : BB Asic Index : 00 21:08:51 : CMT PAPUBKEYS HASH: 21:08:51 : 76A20187051C30162EE91C77A 21:08:51 : 21:08:51 : VPP Enabled by Software 21:08:51 : Using Internal VPP 21:08:51 : VPP Enabled by Software 21:08:51 : FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 21:08:51 : StartErase_DCT5... 21:08:51 : BlockLength : 0x10 (16) 21:08:51 : ERASE Blocks : 0x01 (1) 21:08:51 : 0 ERASE_AREA_BB5 0x13 21:08:51 : Block Length : 0x0D (13) 21:08:51 : BB ASIC Index : 0x00 CMT 21:08:51 : 21:08:51 : Erase_SendEraseBlock_BB5_NAND 21:08:51 : Task in Progress... Please Wait... 21:08:51 : 21:08:51 : Successfully erased.. 21:08:51 : 21:08:51 : Now Writing : CMT CCC Certificate 0x0208 Bytes 21:08:51 : 21:08:51 : CCC Write Successful... 21:08:51 : 21:08:51 : StartErase_DCT5... 21:08:51 : BlockLength : 0x10 (16) 21:08:51 : ERASE Blocks : 0x01 (1) 21:08:51 : 0 ERASE_AREA_BB5 0x13 21:08:51 : Block Length : 0x0D (13) 21:08:51 : BB ASIC Index : 0x00 CMT 21:08:51 : 21:08:51 : Erase_SendEraseBlock_BB5_NAND 21:08:52 : Task in Progress... Please Wait... 21:08:52 : 21:08:52 : Successfully erased.. 21:08:52 : 21:08:52 : Now Writing : CMT HWC Certificate 0x0118 Bytes 21:08:52 : 21:08:52 : HWC Write Successful... 21:08:52 : 21:08:52 : 21:08:52 : Write Certificates OK! 21:08:52 : 21:08:52 : 21:08:52 : RPL Upload Finished!!! 21:08:56 : 21:08:57 : 21:08:57 : ================================================ 21:08:57 : Basic Phone Information 21:08:57 : ================================================ 21:08:57 : MCU Version: V ICPR72_10w29_tube1 24-05-11 RM-356 (c) Nokia 21:08:57 : IMEI Plain : 3534452 21:08:57 : IMEI Spare : A35374450 21:08:57 : IMEI SV : 335337744574F 21:08:57 : Phone Model: Nokia 5800 XpressMusic 21:08:57 : Category : Classic Phone 21:08:57 : Phone Type : RM-356 21:08:57 : 21:08:57 : ================================================ 21:08:57 : Extended Phone Information 21:08:57 : ================================================ 21:08:57 : Product Serial Number: 0 21:08:58 : Product Code : 0586361 21:08:58 : Long Production SN : 0 21:08:58 : MCU SW Version : V ICPR72_10w29_tube1 24-05-11 RM-356 (c) Nokia 21:08:59 : RFIC Version : 17141716 21:08:59 : DSP Version : ICPR72_10w26p1 21:09:00 : AHNE Version : 11 21:09:00 : APE SW Core Version : V 60.0.003 21:09:00 : Variant Version : V 60.0.003V 60.0.003 21:09:00 : APE Test Version : eno_version 21:09:00 : RETU Version : 16 21:09:00 : TAHVO Version : 22 21:09:00 : APE HW Version : 256 21:09:00 : APE ADSP SW Version : 256 21:09:00 : Wireless LAN ID : E0:A6:B 21:09:00 : Bluetooth ID : E0:A684:E4 21:09:01 : CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA VIII 21:09:01 : 21:09:01 : ================================================ 21:09:01 : Simlock Information 21:09:01 : ================================================ 21:09:01 : CONFIG KEY : 0000000000000000 21:09:01 : PROVIDER KEY : 2440700000000000 21:09:01 : NETWORK NAME : Nokia Default;Finland 21:09:01 : LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10 21:09:01 : SIMLOCK TABLE : 21:09:01 : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open 21:09:01 : Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open 21:09:01 : Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open 21:09:01 : Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open 21:09:01 : Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open 21:09:01 : Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open 21:09:01 : Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open 21:09:01 : SIMLOCK STATE : Not Locked 21:09:01 : 21:09:01 : SIMLOCK_TYPE : PA_SL2 21:09:01 : SIMLOCK_TEST : PASSED 21:09:01 : SECURITY_TEST : PASSED 21:09:02 : PHONE_MODE : TEST 21:09:02 : DCC ID : NOT USED |
