04-26-2013, 09:29 | #1 (permalink) |
Junior Member Join Date: Mar 2013
Member: 1901735 Status: Offline Thanks Meter: 1 | Nokia 6020 Dead It was working correctly before the flash. But after the flash it is not switching on.... Please help. I tried many different files but the same result. Flash completes every time but phone is not switching on…. |
04-26-2013, 14:19 | #2 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Quote:
Br - srinibas | |
The Following User Says Thank You to srinibas For This Useful Post: |
04-27-2013, 08:46 | #3 (permalink) |
Member: 1901735 Status: Offline Thanks Meter: 1 | Log of 6020 11:22:14 : ================================================ 11:22:14 : Advance Turbo Flasher Found 11:22:14 : ================================================ 11:22:14 : Driver Version : 00020416 11:22:14 : Library Version : 00030118 11:22:16 : Box Type : ATF Lightning 11:22:16 : Box Firmware : LogiCore 10.3.12 11:22:16 : Software Version : v8.90 11:22:16 : AdvanceBox SN : 83D68B81B905F85EE0AA19FE 11:22:16 : Box Status : ACTIVATED 11:22:16 : ================================================ 11:22:16 : Box Successfully Initialized 11:22:16 : ================================================ 11:22:16 : 11:22:16 : VBATT Powering Down <<<< 11:22:20 : VBATT Powering Up >>>> 11:22:20 : SET VCCIO Level Done 11:22:20 : SET BSI Load Done 11:22:20 : 11:22:20 : 11:22:20 : 11:22:20 : ///////// /// /// /////// /////// ///////// 11:22:20 : /// /// /// /// // /// /// /// /// 11:22:20 : /// /// /// /////// /////// /// /// 11:22:20 : /// /// /// /// /// /// /// /// /// 11:22:20 : /// ///// /// /// /////// ////// 11:22:20 : 11:22:20 : ======================================= 11:22:20 : /// /// /// ///////// /////// ////// 11:22:20 : ///// /// /// /// /// // /// /// 11:22:20 : /// ///// /// /// /////// /// /// 11:22:20 : /// //// /// /// /// /// /// /// 11:22:20 : /// /// /// /// /// /// ////// 11:22:20 : ======================================= 11:22:20 : 11:22:58 : Boot Check, Please wait... 11:23:05 : MCUID Response 11:23:05 : ------------------------------------- 11:23:05 : MessageID : 92 11:23:05 : msbUPP_ID : 21 11:23:05 : lsbUPP_ID : 42 11:23:05 : ------------------------------------- 11:23:05 : Boot OK 11:23:05 : 11:23:05 : Boot File: C:\Program Files\AdvanceBox Turbo Flasher\Nokia\DCT4_Loader\u_2nd.fia 11:23:05 : DataLen : 000009D8 11:23:06 : Secondary Loader Sent... 11:23:06 : Boot OK! 11:23:06 : MCU_CONFIGURATION_RESPONSE_DCT4_MUL3 11:23:06 : DCT4 Mess 9F MUL3 Mess 9F 11:23:06 : TransMode : 03 11:23:06 : NumFlash : 02 11:23:06 : DevAddr0 : 01 11:23:06 : ManuId0 : 0001 - SPANSION 11:23:06 : DevId0 : 2C7E - 72NS128N 11:23:06 : ExtId0 : 0035 11:23:06 : RevId0 : 7021 11:23:06 : SectorSize0: 11 11:23:06 : Reserved0 : 00 11:23:06 : DevAddr1 : 02 11:23:06 : ManuId1 : 0000 - Flash 11:23:06 : DevId1 : 0001 - not used 11:23:06 : ExtId1 : 0000 11:23:06 : RevId1 : 0000 11:23:06 : SectorSize1: 00 11:23:06 : Reserved1 : 00 11:23:06 : ExtBUSC : AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 11:23:06 : CheckSum : 4D 11:23:06 : ReceiveConfigurationResponse_DCT4 - FLS1_NO_ERROR 11:23:06 : SearchForBootstrap_DCT4 : No Error 11:23:06 : Algo Match File : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\DCT4_Loader\uh_amd.fia 11:23:09 : ALGO SENT.. 11:23:09 : Perform AUTHENTICATION.. 11:23:09 : MSID: 8441049AAD2EB55BBF6955D1FB 11:23:09 : DecodedMSID: 843E4EBAE9001E88CDAA000000 11:23:09 : EncodedFAID: 169C94D93A38A33A332D57A6 11:23:10 : Authentication : SUCCESSFULL 11:23:10 : BB_RESTART : 07 FF 11:23:10 : MCURestart : SUCCESS 11:23:10 : Done! 11:23:14 : 11:23:14 : MCU: V 04.90 09-05-06 RM-30 (c) Nokia. 11:23:15 : IMEI: 357937008537740 11:23:15 : Model : Nokia 6020 11:23:15 : Product Serial Number: MKI410112 11:23:15 : Product Code : 0521958 11:23:15 : Module Code : 0202357 11:23:15 : Basic Production Code: 0522363 11:23:15 : PPM SW Version : V 04.90 09-05-06 RM-30 (c) Nokia. R 11:23:15 : MCU SW Version : V 04.90 09-05-06 RM-30 (c) Nokia. 11:23:15 : HW Version : 5051 11:23:15 : UEM Version : 400 11:23:15 : UPP Version : 8514 11:23:16 : RFIC Version : 0205 11:23:16 : DSP Version : P05w06.v34 11:23:16 : LCD Version : AMAZON 11:23:16 : ********** SIMLOCK INFO ********** 11:23:16 : CONFIG_DATA : 0010100000000000 11:23:16 : PROFILE_BITS : 0000000000000002 11:23:16 : ASIC : 2 11:23:16 : PROVIDER : Default Test Operator 11:23:16 : 11:23:17 : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open 11:23:17 : Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open 11:23:17 : Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open 11:23:17 : Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open 11:23:17 : Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open 11:23:17 : Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open 11:23:17 : Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open 11:23:17 : ST_SIMLOCK_TEST : PASSED 11:23:17 : ST_LCD_TEST : PASSED 11:23:17 : SECURITY_CODE : 12345 11:23:17 : MASTER_CODE : 0317135664 11:23:18 : PHONE_MODE : LOCAL 11:23:18 : 11:23:18 : Quick RPL DATA1 Backup Saved to: 11:23:18 : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\Backup\357937008537740\3579370085377 40_BACKUP.RPL 11:23:18 : 11:24:27 : ImageFile:C:\Program Files\Nokia\Phoenix\Products\RM-30\rm30__05.220 11:24:27 : PhoneType : DCT4 11:24:27 : Algorithm : DCT4 ALGORITHM 11:24:27 : Supported Hardwares : 11:24:27 : > 1131 11:24:27 : > 1130 11:24:27 : > 2140 11:24:27 : > 2141 11:24:27 : > 2142 11:24:27 : > 2143 11:24:27 : > 3161 11:24:28 : > 3160 11:24:28 : Secondary Sending Speed : 100000Hz 11:24:28 : Algorithm Sending Speed : 6500000Hz 11:24:28 : Program Sending Speed : 6500000Hz 11:24:28 : Message Reading Speed : 51000Hz 11:24:28 : Number of Blocks : 535 11:24:28 : Entry Point: 0x00E4 11:24:28 : Is128k: True 11:24:28 : Boot Check, Please wait... 11:24:29 : MCUID Response 11:24:29 : ------------------------------------- 11:24:29 : MessageID : 92 11:24:29 : msbUPP_ID : 21 11:24:29 : lsbUPP_ID : 42 11:24:29 : ------------------------------------- 11:24:29 : Boot OK 11:24:29 : 11:24:29 : Boot File: C:\Program Files\AdvanceBox Turbo Flasher\Nokia\DCT4_Loader\u_2nd.fia 11:24:29 : DataLen : 000009D8 11:24:29 : Secondary Loader Sent... 11:24:29 : Boot OK! 11:24:29 : MCU_CONFIGURATION_RESPONSE_DCT4_MUL3 11:24:29 : DCT4 Mess 9F MUL3 Mess 9F 11:24:29 : TransMode : 03 11:24:29 : NumFlash : 02 11:24:29 : DevAddr0 : 01 11:24:29 : ManuId0 : 0001 - SPANSION 11:24:29 : DevId0 : 2C7E - 72NS128N 11:24:29 : ExtId0 : 0035 11:24:29 : RevId0 : 7021 11:24:29 : SectorSize0: 11 11:24:29 : Reserved0 : 00 11:24:29 : DevAddr1 : 02 11:24:29 : ManuId1 : 0000 - Flash 11:24:29 : DevId1 : 0001 - not used 11:24:29 : ExtId1 : 0000 11:24:29 : RevId1 : 0000 11:24:29 : SectorSize1: 00 11:24:29 : Reserved1 : 00 11:24:30 : ExtBUSC : AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 11:24:30 : CheckSum : 4D 11:24:30 : ReceiveConfigurationResponse_DCT4 - FLS1_NO_ERROR 11:24:30 : SearchForBootstrap_DCT4 : No Error 11:24:30 : Algo Match File : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\DCT4_Loader\uh_amd.fia 11:24:31 : ALGO SENT.. 11:24:31 : Perform AUTHENTICATION.. 11:24:31 : MSID: 84BE4126D78A0CEE60D32A9E16 11:24:31 : DecodedMSID: 8428C7BAE9001E88CDAA000000 11:24:31 : EncodedFAID: 2B3E1CC9731AD37C243154FA 11:24:32 : Authentication : SUCCESSFULL 11:24:32 : Erasing address: 11:24:32 : >> 01000000 : 0101FFFF 11:24:33 : BB_PROGRAMMING_STATUS_REQUEST : 04 FF 11:24:33 : ProgrammingStatus_DCT4 : No Error - 0 (0x00) 11:24:33 : 11:24:34 : >> 01020000 : 0185FFFF 11:25:27 : BB_PROGRAMMING_STATUS_REQUEST : 04 FF 11:25:27 : ProgrammingStatus_DCT4 : No Error - 0 (0x00) 11:25:27 : 11:25:27 : >> 01E60000 : 01FDFFFF 11:25:43 : BB_PROGRAMMING_STATUS_REQUEST : 04 FF 11:25:43 : ProgrammingStatus_DCT4 : No Error - 0 (0x00) 11:25:43 : 11:25:43 : Erasing Done 11:25:43 : Flashing ImageFile 11:26:47 : ContinueFlash_DCT4 Complete 11:26:47 : Write Time Elapse : 00:01:03 11:26:47 : FLASH Mode Set to : PHONEMODE_FLASHBUS 11:26:47 : ProgrammingStatus_DCT4 11:26:47 : BB_PROGRAMMING_STATUS_REQUEST : 04 FF -- Progamming status 11:26:47 : First Byte OK 11:26:47 : Second Byte OK 11:26:47 : BB_PERM_DATA_RESTORE_REQ : 18 FF 11:26:48 : BB_RESTART : 07 FF 11:26:48 : MCURestart : SUCCESS 11:26:48 : Making delay between files for 6000ms 11:26:54 : ImageFile:C:\Program Files\Nokia\Phoenix\Products\RM-30\rm30__05.22w 11:26:54 : PhoneType : DCT4 11:26:54 : Algorithm : DCT4 ALGORITHM 11:26:54 : Supported Hardwares : 11:26:54 : > 1131 11:26:54 : > 1130 11:26:54 : > 2140 11:26:54 : > 2141 11:26:54 : > 2142 11:26:54 : > 2143 11:26:54 : > 3161 11:26:54 : > 3160 11:26:54 : Secondary Sending Speed : 100000Hz 11:26:54 : Algorithm Sending Speed : 6500000Hz 11:26:54 : Program Sending Speed : 3250000Hz 11:26:54 : Message Reading Speed : 51000Hz 11:26:54 : Number of Blocks : 101 11:26:54 : Entry Point: 0x00D8 11:26:54 : Is128k: True 11:26:54 : Boot Check, Please wait... 11:26:55 : MCUID Response 11:26:55 : ------------------------------------- 11:26:55 : MessageID : 92 11:26:55 : msbUPP_ID : 21 11:26:55 : lsbUPP_ID : 42 11:26:55 : ------------------------------------- 11:26:55 : Boot OK 11:26:55 : 11:26:55 : Boot File: C:\Program Files\AdvanceBox Turbo Flasher\Nokia\DCT4_Loader\u_2nd.fia 11:26:55 : DataLen : 000009D8 11:26:56 : Secondary Loader Sent... 11:26:56 : Boot OK! 11:26:56 : MCU_CONFIGURATION_RESPONSE_DCT4_MUL3 11:26:56 : DCT4 Mess 9F MUL3 Mess 9F 11:26:56 : TransMode : 03 11:26:56 : NumFlash : 02 11:26:56 : DevAddr0 : 01 11:26:56 : ManuId0 : 0001 - SPANSION 11:26:56 : DevId0 : 2C7E - 72NS128N 11:26:56 : ExtId0 : 0035 11:26:56 : RevId0 : 7021 11:26:56 : SectorSize0: 11 11:26:56 : Reserved0 : 00 11:26:56 : DevAddr1 : 02 11:26:56 : ManuId1 : 0000 - Flash 11:26:56 : DevId1 : 0001 - not used 11:26:56 : ExtId1 : 0000 11:26:56 : RevId1 : 0000 11:26:56 : SectorSize1: 00 11:26:56 : Reserved1 : 00 11:26:56 : ExtBUSC : AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 11:26:56 : CheckSum : 4D 11:26:56 : ReceiveConfigurationResponse_DCT4 - FLS1_NO_ERROR 11:26:56 : SearchForBootstrap_DCT4 : No Error 11:26:56 : Algo Match File : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\DCT4_Loader\uh_amd.fia 11:26:58 : ALGO SENT.. 11:26:58 : Perform AUTHENTICATION.. 11:26:58 : MSID: 84C83F4D94AADBB85E8D8B4DBC 11:26:58 : DecodedMSID: 843E4EBAE9001E88CDA9000000 11:26:58 : EncodedFAID: EE738D626EE4787A4BE95A4E 11:26:59 : Authentication : SUCCESSFULL 11:26:59 : Erasing address: 11:26:59 : >> 01860000 : 01A5FFFF 11:27:12 : BB_PROGRAMMING_STATUS_REQUEST : 04 FF 11:27:12 : ProgrammingStatus_DCT4 : No Error - 0 (0x00) 11:27:12 : 11:27:12 : Erasing Done 11:27:12 : Flashing ImageFile 11:30:17 : FAILED.. 11:30:17 : Flashing FAILED... 11:30:17 : Flashing ERROR 11:30:25 : ImageFile:C:\Program Files\Nokia\Phoenix\Products\RM-30\rm30__05.22w 11:30:25 : PhoneType : DCT4 11:30:25 : Algorithm : DCT4 ALGORITHM 11:30:25 : Supported Hardwares : 11:30:25 : > 1131 11:30:25 : > 1130 11:30:25 : > 2140 11:30:25 : > 2141 11:30:25 : > 2142 11:30:25 : > 2143 11:30:25 : > 3161 11:30:25 : > 3160 11:30:25 : Secondary Sending Speed : 100000Hz 11:30:25 : Algorithm Sending Speed : 6500000Hz 11:30:25 : Program Sending Speed : 3250000Hz 11:30:25 : Message Reading Speed : 51000Hz 11:30:25 : Number of Blocks : 101 11:30:25 : Entry Point: 0x00D8 11:30:25 : Is128k: True 11:30:25 : Boot Check, Please wait... 11:30:33 : MCUID Response 11:30:33 : ------------------------------------- 11:30:33 : MessageID : 92 11:30:33 : msbUPP_ID : 21 11:30:33 : lsbUPP_ID : 42 11:30:34 : ------------------------------------- 11:30:34 : Boot OK 11:30:34 : 11:30:34 : Boot File: C:\Program Files\AdvanceBox Turbo Flasher\Nokia\DCT4_Loader\u_2nd.fia 11:30:34 : DataLen : 000009D8 11:30:34 : Secondary Loader Sent... 11:30:34 : Boot OK! 11:30:34 : MCU_CONFIGURATION_RESPONSE_DCT4_MUL3 11:30:34 : DCT4 Mess 9F MUL3 Mess 9F 11:30:34 : TransMode : 03 11:30:34 : NumFlash : 02 11:30:34 : DevAddr0 : 01 11:30:34 : ManuId0 : 0001 - SPANSION 11:30:34 : DevId0 : 2C7E - 72NS128N 11:30:34 : ExtId0 : 0035 11:30:34 : RevId0 : 7021 11:30:34 : SectorSize0: 11 11:30:34 : Reserved0 : 00 11:30:34 : DevAddr1 : 02 11:30:34 : ManuId1 : 0000 - Flash 11:30:34 : DevId1 : 0001 - not used 11:30:34 : ExtId1 : 0000 11:30:34 : RevId1 : 0000 11:30:34 : SectorSize1: 00 11:30:34 : Reserved1 : 00 11:30:34 : ExtBUSC : AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 11:30:34 : CheckSum : 4D 11:30:34 : ReceiveConfigurationResponse_DCT4 - FLS1_NO_ERROR 11:30:34 : SearchForBootstrap_DCT4 : No Error 11:30:34 : Algo Match File : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\DCT4_Loader\uh_amd.fia 11:30:36 : ALGO SENT.. 11:30:36 : Perform AUTHENTICATION.. 11:30:36 : MSID: 84C83F4D94AADBB85E8D8B4DBC 11:30:36 : DecodedMSID: 843E4EBAE9001E88CDA9000000 11:30:36 : EncodedFAID: EE738D626EE4787A4BE95A4E 11:30:37 : Authentication : SUCCESSFULL 11:30:37 : Erasing address: 11:30:37 : >> 01860000 : 01A5FFFF 11:30:51 : BB_PROGRAMMING_STATUS_REQUEST : 04 FF 11:30:51 : ProgrammingStatus_DCT4 : No Error - 0 (0x00) 11:30:51 : 11:30:51 : Erasing Done 11:30:51 : Flashing ImageFile 11:31:03 : ContinueFlash_DCT4 Complete 11:31:03 : Write Time Elapse : 00:00:11 11:31:03 : FLASH Mode Set to : PHONEMODE_FLASHBUS 11:31:03 : ProgrammingStatus_DCT4 11:31:03 : BB_PROGRAMMING_STATUS_REQUEST : 04 FF -- Progamming status 11:31:03 : First Byte OK 11:31:03 : Second Byte OK 11:31:03 : BB_PERM_DATA_RESTORE_REQ : 18 FF 11:31:04 : BB_RESTART : 07 FF 11:31:04 : MCURestart : SUCCESS 11:31:04 : Making delay between files for 6000ms 11:31:10 : Time Elapse : 00:00:45 11:31:14 : 11:31:14 : Waiting For Phone to go Online... 11:31:14 : 11:31:14 : 5, 11:31:15 : 4, 11:31:16 : 3, 11:31:17 : 2, 11:31:18 : 1... 11:31:19 : 11:31:19 : MCU: V 05.22 23-05-07 RM-30 (c) Nokia. 11:31:19 : IMEI: 357937008537740 11:31:19 : Model : Nokia 6020 11:31:19 : Product Serial Number: MKI410112 11:31:19 : Product Code : 0521958 11:31:19 : Module Code : 0202357 11:31:19 : Basic Production Code: 0522363 11:31:19 : PPM SW Version : V 05.22 23-05-07 RM-30 (c) Nokia. W 11:31:20 : MCU SW Version : V 05.22 23-05-07 RM-30 (c) Nokia. 11:31:20 : HW Version : 5051 11:31:20 : UEM Version : 400 11:31:20 : UPP Version : 8514 11:31:20 : RFIC Version : 0205 11:31:20 : DSP Version : P05w06.v40 11:31:20 : LCD Version : AMAZON 11:31:21 : ********** SIMLOCK INFO ********** 11:31:21 : CONFIG_DATA : 0010100000000000 11:31:21 : PROFILE_BITS : 0000000000000002 11:31:21 : ASIC : 2 11:31:21 : PROVIDER : Default Test Operator 11:31:21 : 11:31:22 : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open 11:31:22 : Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open 11:31:22 : Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open 11:31:22 : Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open 11:31:22 : Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open 11:31:22 : Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open 11:31:22 : Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open 11:31:22 : ST_SIMLOCK_TEST : PASSED 11:31:22 : ST_LCD_TEST : PASSED 11:31:22 : MASTER_CODE : 0317135664 11:31:22 : PHONE_MODE : TEST 11:31:22 : 11:31:22 : 11:31:22 : FACTORY SET TO : Full Factory Set 11:31:22 : OK 11:31:22 : FACTORY SET TO : User Data 11:31:23 : OK 11:31:23 : FACTORY SET TO : Leave Factory 11:31:23 : OK 11:31:23 : FACTORY SET TO : Service Center 11:31:23 : OK 11:31:23 : FACTORY SET TO : Software Upgrade 11:31:23 : OK 11:31:23 : FACTORY SET TO : Production Tune 11:31:23 : OK 11:31:30 : ImageFile:C:\Program Files\Nokia\Phoenix\Products\RM-30\rm30__05.22.image_india 11:31:30 : PhoneType : DCT4 11:31:30 : Algorithm : DCT4 ALGORITHM 11:31:30 : Supported Hardwares : 11:31:30 : > 1131 11:31:30 : > 1130 11:31:30 : > 2140 11:31:30 : > 2141 11:31:30 : > 2142 11:31:30 : > 2143 11:31:30 : > 3161 11:31:30 : > 3160 11:31:30 : Secondary Sending Speed : 100000Hz 11:31:30 : Algorithm Sending Speed : 6500000Hz 11:31:30 : Program Sending Speed : 6500000Hz 11:31:30 : Message Reading Speed : 51000Hz 11:31:30 : Number of Blocks : 120 11:31:30 : Entry Point: 0x00DF 11:31:30 : Is128k: False 11:31:30 : C:\Program Files\Nokia\Phoenix\Products\RM-30\rm30__05.22.image_india_128k 11:31:30 : PhoneType : DCT4 11:31:30 : Algorithm : DCT4 ALGORITHM 11:31:30 : Supported Hardwares : 11:31:30 : > 1131 11:31:30 : > 1130 11:31:30 : > 2140 11:31:30 : > 2141 11:31:30 : > 2142 11:31:30 : > 2143 11:31:30 : > 3161 11:31:30 : > 3160 11:31:30 : Secondary Sending Speed : 100000Hz 11:31:30 : Algorithm Sending Speed : 6500000Hz 11:31:30 : Program Sending Speed : 6500000Hz 11:31:30 : Message Reading Speed : 51000Hz 11:31:30 : Number of Blocks : 120 11:31:30 : Entry Point: 0x00DF 11:31:30 : Is128k: False 11:31:30 : Boot Check, Please wait... 11:31:31 : MCUID Response 11:31:31 : ------------------------------------- 11:31:31 : MessageID : 92 11:31:31 : msbUPP_ID : 21 11:31:31 : lsbUPP_ID : 42 11:31:31 : ------------------------------------- 11:31:31 : Boot OK 11:31:31 : 11:31:31 : Boot File: C:\Program Files\AdvanceBox Turbo Flasher\Nokia\DCT4_Loader\u_2nd.fia 11:31:31 : DataLen : 000009D8 11:31:32 : ERROR: Secondary Loader not accepted 07 11:31:32 : SearchForBootstrap_DCT4 : Error (Failed) 11:31:32 : Boot Check, Please wait... 11:31:39 : MCUID Response 11:31:39 : ------------------------------------- 11:31:39 : MessageID : 92 11:31:39 : msbUPP_ID : 21 11:31:39 : lsbUPP_ID : 42 11:31:39 : ------------------------------------- 11:31:39 : Boot OK 11:31:39 : 11:31:39 : Boot File: C:\Program Files\AdvanceBox Turbo Flasher\Nokia\DCT4_Loader\u_2nd.fia 11:31:39 : DataLen : 000009D8 11:31:39 : Secondary Loader Sent... 11:31:40 : Boot OK! 11:31:40 : MCU_CONFIGURATION_RESPONSE_DCT4_MUL3 11:31:40 : DCT4 Mess 9F MUL3 Mess 9F 11:31:40 : TransMode : 03 11:31:40 : NumFlash : 02 11:31:40 : DevAddr0 : 01 11:31:40 : ManuId0 : 0001 - SPANSION 11:31:40 : DevId0 : 2C7E - 72NS128N 11:31:40 : ExtId0 : 0035 11:31:40 : RevId0 : 7021 11:31:40 : SectorSize0: 11 11:31:40 : Reserved0 : 00 11:31:40 : DevAddr1 : 02 11:31:40 : ManuId1 : 0000 - Flash 11:31:40 : DevId1 : 0001 - not used 11:31:40 : ExtId1 : 0000 11:31:40 : RevId1 : 0000 11:31:40 : SectorSize1: 00 11:31:40 : Reserved1 : 00 11:31:40 : ExtBUSC : AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 11:31:40 : CheckSum : 4D 11:31:40 : ReceiveConfigurationResponse_DCT4 - FLS1_NO_ERROR 11:31:40 : SearchForBootstrap_DCT4 : No Error 11:31:40 : Algo Match File : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\DCT4_Loader\uh_amd.fia 11:31:41 : ALGO SENT.. 11:31:41 : Perform AUTHENTICATION.. 11:31:41 : MSID: 84F4C7B5336F17E1EA0105FF2C 11:31:41 : DecodedMSID: 841C15BAE3001E88CDAD0005BD 11:31:41 : EncodedFAID: 0CA661FC79EF109F601051F5 11:31:42 : Authentication : SUCCESSFULL 11:31:42 : Erasing address: 11:31:42 : >> 01A60000 : 01E5FFFF 11:32:10 : BB_PROGRAMMING_STATUS_REQUEST : 04 FF 11:32:10 : ProgrammingStatus_DCT4 : No Error - 0 (0x00) 11:32:10 : 11:32:10 : Erasing Done 11:32:10 : Flashing ImageFile 11:32:25 : ContinueFlash_DCT4 Complete 11:32:25 : Write Time Elapse : 00:00:15 11:32:25 : FLASH Mode Set to : PHONEMODE_FLASHBUS 11:32:25 : ProgrammingStatus_DCT4 11:32:25 : BB_PROGRAMMING_STATUS_REQUEST : 04 FF -- Progamming status 11:32:25 : First Byte OK 11:32:25 : Second Byte OK 11:32:26 : BB_PERM_DATA_RESTORE_REQ : 18 FF 11:32:27 : BB_RESTART : 07 FF 11:32:27 : MCURestart : SUCCESS 11:32:27 : Time Elapse : 00:00:57 11:32:30 : 11:32:31 : Waiting For Phone to go Online... 11:32:31 : 11:32:31 : 5, 11:32:32 : 4, 11:32:33 : 3, 11:32:34 : 2, 11:32:35 : 1... 11:32:36 : 11:33:01 : ERROR : PHONE READ INFO FAILED |
