05-03-2013, 10:49 | #3 (permalink) | |
Freak Poster Join Date: Nov 2008
Member: 893550 Status: Offline Thanks Meter: 139 | Quote:
Will Write CCC/HWC keys now... Using : RM-774.rpl CCC Data found! HWC Data found! Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000030000022600010007400C192103032108 CPU ID : RAPU v21 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: 241F0000FFFF7C409C2637CAF392E0DDE88D499E ASIC MODE ID: 00 ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 ROM ID: 2CAC45E23BC33C8B Use RAPUv21_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 006000EC Req : XSR 1.6 Use RAPUv21_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : FEB3BB7481D3E5D0EAC907335A4402A071493D53 ADL: Preparing for write certificates... Erase CCC... Ok Writing CCC... Ok Erase HWC... Ok Writing HWC... Ok ADL: Writing Flash certs done! ADL: Close_Session Content: 000300000000500000000200000000 ADL: Reboot All done, disconneting... Done! Elapsed: 00:00:22 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Local SX4 procedure started... Check SD : Key is Ok Phone Imei: 358272041437933 Use custom key... Step 1... Step 2... Step 3... SX4 Auth - Ok Upload PM checked Uploading RF/Battery tune to phone... RM-774.pm not exist Select file, please Using : RM-774 Nokia 701.pm Operating mode is OK, no need change... Check ST_SECURITY now... Security status : ST_SECURITY => DAMAGED - > Try "Restore CCC/HWC" option, after SX4 again Done! Elapsed: 00:00:37 Upload done Checking StartUp data ... ----------------------- SDD Key status : SDData is Ok CMLA Key status : CMLA key Not exist SimLock status : SimLock is Ok Security status : Security Damaged!!!!! - > Do Local SX4 or Server SX4 , Upload Tune ( checkbox or manual ) ----------------------- PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 Done! Local SX4 procedure started... Check SD : Key is Ok Phone Imei: 358272041437933 Use custom key... Step 1... Step 2... Step 3... SX4 Auth - Ok Upload PM checked Uploading RF/Battery tune to phone... RM-774.pm not exist Select file, please Using : RM-774 Nokia 701.pm Operating mode is OK, no need change... Check ST_SECURITY now... Security status : ST_SECURITY => DAMAGED - > Try "Restore CCC/HWC" option, after SX4 again Done! Elapsed: 00:00:05 Upload done | |
05-03-2013, 11:06 | #4 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | @hajukhan You are in ATF section. So, if you have ATF Box then post logs from it... Otherwise, go to correct section. BR |
05-03-2013, 11:19 | #5 (permalink) | |
Scanning USB Ports... ================================================ Basic Phone Information ================================================ MCU Version: V 79u_sr2_12w20.8 20-08-12 RM-774 (c) Nokia IMEI Plain : 358272041437933 IMEI Spare : A358272041437930 IMEI SV : 33582720414379330F Phone Model: Nokia 701 Category : Classic Phone Phone Type : RM-774 ================================================ Extended Phone Information ================================================ Product Serial Number: MJN998313 Product Code : 059H036 Basic Production Code: 059G8T9 Long Production SN : 0 MCU SW Version : V 79u_sr2_12w20.8 20-08-12 RM-774 (c) Nokia HW Version : 2011 RFIC Version : |Alli_4.b.1 DSP Version : 79u_sr2_12w20_2 Content : 113.010.1506.U10.01 APE BT Version : HCI Version 4 (rev. 0). LMP Version 4 (rev. 7455). Manufacturer 13. AHNE Version : 21 APE SW Core Version : 113.010.1506 Variant Version : 113.010.1506113.010.1506.18.01113.010.1506.C00.01 APE Test Version : 0.037 RETU Version : 40 TAHVO Version : 00 APE HW Version : 256 APE ADSP SW Version : 256 Wireless LAN ID : 281:AF:9F:98:C1 Bluetooth ID : 281:AF:9F:69:E1 CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA II, WCDMA IV, WCDMA V, WCDMA VIII ================================================ Simlock Information ================================================ CONFIG KEY : 0000000000000000 PROVIDER KEY : 2440700000000000 NETWORK NAME : Nokia Default;Finland LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10 SIMLOCK TABLE : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK STATE : Not Locked SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : FAILED > Try SX4 "PM AUTH" > Then Write PM 1 and 309 SECURITY_CODE : ENCRYPTED PHONE_MODE : TEST ================================================== ==== Selected VPL File: RM774_059H218_113.010.1506_038.vpl ================================================== ==== Variant Details : _india_dark_steel Software Version : 113.010.1506 Product Type : RM-774 Product Code : 059H218 Variant Version : 038 | |
05-03-2013, 11:36 | #6 (permalink) |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Write this CCC/HWC from ATF Folder and let me know results: C:\AdvanceBox Turbo Flasher\Nokia\RPL_Wout_NPC\RM-774_without_NPC_DATA.rpl |
05-03-2013, 11:49 | #7 (permalink) |
Member: 893550 Status: Offline Thanks Meter: 139 | 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 READING BOOTROM BootFlashModeDCT5Ex Succeded After 0 Tries SYSTEM_ID_RESPONSE_BB5 (0xC0) - 96 (0x60) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000003 ID DWORD 1 : 00000226 ID DWORD 2 : 00010007 ID DWORD 3 : 400C1921 ID DWORD 4 : 03032108 2 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00001040 3 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00001030 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 241F0000 ID DWORD 1 : FFFF7C40 ID DWORD 2 : 9C2637CA ID DWORD 3 : F392E0DD ID DWORD 4 : E88D499E 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 3A B5 DB 70 B4 5D 23 F1 AD EE BB 57 34 16 07 06 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 2CAC45E2 CRC 1 : 3BC33C8B CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv21_2nd.fg Secondary Loader Sent.... MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 06 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 0060 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0032 6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5 Block Length : 09 BB ASIC Index : CMT 00 Data : XSR 1.6 SearchForBootstrap_DCT5 : No Error - 0 (0x00) Flash Descriptor Manufacturer Code : 00EC Device ID : 0060 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 40000000 (1024 MB) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 CMT Algorithm Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv21_XSR17_alg.fg Algorithm Loader Sent... FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok PA PUBLIC KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: FEB3BB7481D3E5D0EAC907335A4402A071493D53 StartErase_DCT5... BlockLength : 0x10 (16) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x13 Block Length : 0x0D (13) BB ASIC Index : 0x00 CMT ERASE_REQUEST_BB5 : 5001130D0043434300000000000000000015 Successfully Erased... Now Writing : CMT CCC Certificate 0x022C Bytes CCC Write Successful... StartErase_DCT5... BlockLength : 0x10 (16) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x13 Block Length : 0x0D (13) BB ASIC Index : 0x00 CMT ERASE_REQUEST_BB5 : 5001130D00485743000000000000000000FC Successfully Erased... Now Writing : CMT HWC Certificate 0x00D4 Bytes HWC Write Successful... Write Certificates OK! FlashInfo.RestartMode : Test Mode Process Done... RPL Upload Finished!!! Scanning USB Ports... ================================================ Basic Phone Information ================================================ MCU Version: V 79u_sr2_12w20.8 20-08-12 RM-774 (c) Nokia IMEI Plain : 358272041437933 IMEI Spare : A358272041437930 IMEI SV : 33582720414379330F Phone Model: Nokia 701 Category : Classic Phone Phone Type : RM-774 ================================================ Extended Phone Information ================================================ Product Serial Number: MJN998313 Product Code : 059H036 Basic Production Code: 059G8T9 Long Production SN : 0 MCU SW Version : V 79u_sr2_12w20.8 20-08-12 RM-774 (c) Nokia HW Version : 2011 RFIC Version : |Alli_4.b.1 DSP Version : 79u_sr2_12w20_2 Content : 113.010.1506.U10.01 APE BT Version : HCI Version 4 (rev. 0). LMP Version 4 (rev. 7455). Manufacturer 13. AHNE Version : 21 APE SW Core Version : 113.010.1506 Variant Version : 113.010.1506113.010.1506.18.01113.010.1506.C00.01 APE Test Version : 0.037 RETU Version : 40 TAHVO Version : 00 APE HW Version : 256 APE ADSP SW Version : 256 Wireless LAN ID : 281:AF:9F:98:C1 Bluetooth ID : 281:AF:9F:69:E1 CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA II, WCDMA IV, WCDMA V, WCDMA VIII ================================================ Simlock Information ================================================ CONFIG KEY : 0000000000000000 PROVIDER KEY : 2440700000000000 NETWORK NAME : Nokia Default;Finland LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10 SIMLOCK TABLE : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK STATE : Not Locked SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : FAILED > Try SX4 "PM AUTH" > Then Write PM 1 and 309 SECURITY_CODE : ENCRYPTED PHONE_MODE : TEST ================================================== ==== Selected VPL File: RM774_059H218_113.010.1506_038.vpl ================================================== ==== Variant Details : _india_dark_steel Software Version : 113.010.1506 Product Type : RM-774 Product Code : 059H218 Variant Version : 038 |
06-20-2014, 08:45 | #11 (permalink) |
Freak Poster Join Date: Aug 2007 Location: gsmservice city
Member: 567810 Status: Online Sonork: Xiaomi direct Thanks Meter: 30 | Have same problem. What i did: Erase Code: WARNING: SL3 Phone Detected !!! 12:07:47 : StartErase_DCT5... 12:07:47 : BlockLength : 0x0E (14) 12:07:47 : ERASE Blocks : 0x01 (1) 12:07:47 : 0 ERASE_AREA_BB5 0x12 12:07:47 : Block Length : 0x0B (11) 12:07:47 : BB ASIC Index : 0x00 CMT 12:07:47 : Device Type : 0x03 MuxOneNAND 12:07:47 : Device Index : 0x00 12:07:47 : 0 : 00000000-3FFFFFFF 12:07:47 : 12:07:47 : Erase_SendEraseBlock_BB5_NAND 12:07:47 : Task in Progress... Please Wait... 12:07:47 : 12:07:47 : Successfully erased.. 12:07:53 : Booting Phone via FBUS... Code: Flash File Checksum Verification 12:08:36 : ====================================================== 12:08:37 : RM-774_113.010.1506_79u_prd.core.fpsx: CHECKSUM PASSED 12:08:37 : RM-774_113.010.1506_C00.01_79u_prd.rofs3.fpsx: CHECKSUM PASSED 12:08:38 : RM-774_113.010.1506_04.01_Russian_79u_prd.rofs2.fpsx: CHECKSUM PASSED 12:08:40 : RM-774_113.010.1506_U01.01_79u.uda.fpsx: CHECKSUM PASSED 12:08:41 : ====================================================== 12:08:41 : Verification Done... 12:08:42 : ATF Software Version v11.30 12:08:42 : ATF Nitro FBUS Flash Started... 12:08:42 : 12:08:42 : Number of Image Files: 4 12:08:42 : 12:08:42 : Processing Image File : 12:08:42 : C:\Program Files (x86)\Nokia\Phoenix\Products\RM-774\RM-774_113.010.1506_79u_prd.core.fpsx 12:08:42 : CMT Type : BB5 12:08:42 : CMT Algorithm : XSR 1.6 12:08:42 : Secondary Sending Speed : 650000 Hz 12:08:42 : Algorithm Sending Speed : 6500000 Hz 12:08:42 : Program Sending Speed : 13000000 Hz 12:08:42 : Message Reading Speed : 98000 Hz 12:08:42 : Number of Blocks : 610 12:08:42 : Entry Point : 0x025A 12:08:42 : Page Format : 128K 12:08:42 : Maximum Page Size : 0x00040000 12:08:42 : 12:08:42 : Changing MODE : FLASH 12:08:42 : Booting Phone via FBUS... 12:08:42 : 12:08:44 : VBATT Powering Down <<<< 12:08:48 : VBATT Powering Up >>>> 12:08:48 : SET VCCIO Level Done 12:08:48 : SET BSI Load Done 12:08:48 : 12:08:48 : AdvanceBox SendBootCodeEx 12:08:48 : InitialiseBootstrap_DCT5 DIR 12:08:48 : BootFlashMode_DCT5 12:08:48 : 12:08:48 : ****************************************************** 12:08:48 : TIME STARTS HERE 12:08:48 : ****************************************************** 12:08:48 : 12:08:48 : BootFlashModeDCT5Ex Succeeded after 3 Attempts 12:08:48 : SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned 12:08:48 : Number of Sub Blocks 7 (0x07) 12:08:48 : 1 SYSTEM_ASIC_ID 01 12:08:48 : Block Length : 21 (15) 12:08:48 : BB ASIC Index : 0 (00) CMT 12:08:48 : ID DWORD 0 : 00000003 12:08:48 : ID DWORD 1 : 00000226 12:08:48 : ID DWORD 2 : 00010007 12:08:48 : ID DWORD 3 : 400C1921 12:08:48 : ID DWORD 4 : 03032108 12:08:48 : 2 EM_ASIC_ID 02 12:08:48 : Block Length : 5 (05) 12:08:48 : BB ASIC Index : 0 (00) CMT 12:08:48 : ID DWORD 0 : 00001040 12:08:48 : 3 EM_ASIC_ID 02 12:08:48 : Block Length : 5 (05) 12:08:48 : BB ASIC Index : 0 (00) CMT 12:08:48 : ID DWORD 0 : 00001030 12:08:48 : 4 PUBLIC_ID 12 12:08:48 : Block Length : 21 (15) 12:08:48 : BB ASIC Index : 0 (00) CMT 12:08:48 : ID DWORD 0 : 8C4A0000 12:08:48 : ID DWORD 1 : FFFB7C40 12:08:48 : ID DWORD 2 : 9684A507 12:08:48 : ID DWORD 3 : 7C279C0A 12:08:48 : ID DWORD 4 : 69F1BA89 12:08:48 : 5 ASIC_MODE_ID 13 12:08:48 : Block Length : 2 (02) 12:08:48 : BB ASIC Index : 0 (00) CMT 12:08:48 : Mode Id : 00 12:08:48 : 6 ROOT_KEY_HASH 14 12:08:48 : Block Length : 17 (11) 12:08:48 : BB ASIC Index : 0 (00) CMT 12:08:48 : Hash : 3A B5 DB 70 B4 5D 23 F1 AD EE BB 57 34 16 07 06 12:08:48 : 7 ROM_ID 15 12:08:48 : Block Length : 9 (09) 12:08:48 : BB ASIC Index : 0 (00) CMT 12:08:48 : CRC 0 : 2CAC45E2 12:08:48 : CRC 1 : 3BC33C8B 12:08:48 : Checksum 7E 12:08:48 : 12:08:48 : SearchForBootstrap_DCT5.. 12:08:49 : C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv21_2nd.fg 12:08:49 : Boot File - Version 012.014.00 12:08:49 : Boot File - Revision 0x0003 (3) 12:08:49 : eBB5ProtocolType == New 12:08:49 : PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" 12:08:49 : PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0" 12:08:49 : SearchForBootstrap_DCT5 : No Error - 0 (0x00) 12:08:49 : Secondary Loader Sent... 12:08:49 : TransmissionTypeRequest_DCT5_NewProtocol 12:08:49 : TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 12:08:49 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 12:08:49 : TransmissionTypeRequest_DCT5_NewProtocol 12:08:49 : FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX 12:08:49 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C 12:08:49 : Transmission Type Request Sent... 12:08:49 : ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. 12:08:49 : MCU_CONFIGURATION_RESPONSE_BB5: 12:08:49 : MessageID : 06 12:08:49 : SubBlocks : 06 12:08:49 : 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 12:08:49 : Block Length : 0B 12:08:49 : BB ASIC Index : CMT 00 12:08:49 : Device Type : RAM 05 12:08:49 : Device Index : 00 12:08:49 : Manufacturer Code : 0000 -> Flash 12:08:49 : Device ID : 0000 -> not detected 12:08:49 : Extended/Fixed ID : 0000 12:08:49 : Revision ID : 0000 12:08:49 : 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 12:08:49 : Block Length : 0B 12:08:49 : BB ASIC Index : CMT 00 12:08:49 : Device Type : MMC 04 12:08:49 : Device Index : 00 12:08:49 : Manufacturer Code : FFFF -> Flash 12:08:49 : Device ID : 0000 -> BAD FLASH TYPE 12:08:49 : Extended/Fixed ID : 0000 12:08:49 : Revision ID : 0000 12:08:49 : 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 12:08:49 : Block Length : 0B 12:08:49 : BB ASIC Index : CMT 00 12:08:49 : Device Type : NOR 00 12:08:49 : Device Index : 00 12:08:49 : Manufacturer Code : FFFF -> BAD FLASH VENDOR 12:08:49 : Device ID : FFFF -> Type not in database 12:08:49 : Extended/Fixed ID : 0000 12:08:49 : Revision ID : 0000 12:08:49 : 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 12:08:49 : Block Length : 0B 12:08:49 : BB ASIC Index : CMT 00 12:08:49 : Device Type : NOR 00 12:08:49 : Device Index : 01 12:08:49 : Manufacturer Code : 0000 -> SPANSION 12:08:49 : Device ID : 0001 -> not used 12:08:49 : Extended/Fixed ID : 0000 12:08:49 : Revision ID : 0000 12:08:49 : 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 12:08:49 : Block Length : 0B 12:08:49 : BB ASIC Index : CMT 00 12:08:49 : Device Type : MuxOneNAND 03 12:08:49 : Device Index : 00 12:08:49 : Manufacturer Code : 00EC -> 12:08:49 : Device ID : 0060 -> Type not in database 12:08:49 : Extended/Fixed ID : 0000 12:08:49 : Revision ID : 0032 12:08:49 : 6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5 12:08:49 : Block Length : 09 12:08:49 : BB ASIC Index : CMT 00 12:08:49 : Data : XSR 1.6 12:08:49 : Checksum : FC 12:08:49 : SearchForBootstrap_DCT5 : No Error - 0 (0x00) 12:08:49 : FLS1SendAlgoCodeEx.. 12:08:49 : SendAlgoCode_DCT5.. 12:08:49 : SearchForAlgorithm_DCT5.. 12:08:49 : Looking for ALL Devices... 12:08:49 : Searching Algorithm Files MuxOneNAND (03) ManID :00EC DevID :0060 ExtID :0000 RevID :0032 12:08:49 : Flash Descriptor 12:08:49 : Manufacturer Code : 00EC 12:08:49 : Device ID : 0060 12:08:49 : Extended/Fixed ID : 0000 12:08:49 : Revision ID : 0000 12:08:49 : Size : 40000000 (1024 MB) 12:08:49 : VPP Info : 0000 12:08:49 : Erase10s : 1E 12:08:49 : Block1s : 32 12:08:49 : BErase1s : 02 12:08:49 : Reserved0 : 00 12:08:49 : Reserved1 : 00 12:08:49 : Reserved2 : 00 12:08:49 : C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv21_XSR17_alg.fg 12:08:49 : Algorithm File - Version 012.014.00 12:08:49 : Algorithm File - Revision 0x0003 (3) 12:08:49 : eBB5ProtocolType == New 12:08:49 : Algo Loader Sent... 12:08:49 : SendCodeStart_NewProtocol : 12:08:51 : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) 12:08:51 : TransmissionTypeRequest_DCT5_NewProtocol 12:08:51 : TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 12:08:51 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 12:08:51 : TransmissionTypeRequest_DCT5_NewProtocol 12:08:51 : FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX 12:08:51 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C 12:08:51 : SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) 12:08:51 : FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) 12:08:51 : FUR control Ok... 12:08:51 : VPP Enabled by Software 12:08:51 : Using Internal VPP 12:08:51 : VPP Enabled by Software 12:08:51 : FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 12:08:51 : PAPUB_KEYS_HASH_REQ_BB5 12:08:52 : No PAPUBKeysHash Returned 12:08:52 : Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) 12:08:52 : Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) 12:08:52 : Certificate 1 12:08:52 : Name : NPC 12:08:52 : ASIC Index : CMT 0 12:08:52 : Certificate 2 12:08:52 : Name : CCC 12:08:52 : ASIC Index : CMT 0 12:08:52 : Certificate 3 12:08:52 : Name : HWC 12:08:52 : ASIC Index : CMT 0 12:08:52 : Certificate 4 12:08:52 : Name : R&D 12:08:52 : ASIC Index : CMT 0 12:08:52 : Certificate 5 12:08:52 : Name : PARTNERC 12:08:52 : ASIC Index : CMT 0 12:08:52 : STORE_CERTIFICATE_REQUEST_BB5 : 61 05 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 2B 0D 50 41 52 54 4E 45 52 43 00 00 00 00 00 3B 12:08:52 : STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00) 12:08:52 : ProcessPartitionInfo_DCT5... 12:08:52 : Partition Info 12:08:52 : Partition Blocks : 1 12:08:52 : 1 PARTITION_INFO_BB5 12:08:52 : BB ASIC Index : 0x00 CMT 12:08:52 : Device Type : 0x03 MuxOneNAND 12:08:52 : Device Index : 0x00 12:08:52 : Partition Version : 00020000 12:08:52 : Spare : FFFFFFFF 12:08:52 : Num Partitions : 00000004 12:08:52 : Partition 1 12:08:52 : ID : 00000003 COPIEDOS 12:08:52 : Attribute : 00000002 RO 12:08:52 : Start Address : 00140000 12:08:52 : Size : 02DC0000 12:08:52 : Partition 2 12:08:52 : ID : 00000004 DEMANDONOS 12:08:52 : Attribute : 00000002 RO 12:08:52 : Start Address : 02F00000 12:08:52 : Size : 14200000 12:08:52 : Partition 3 12:08:52 : ID : 00000008 FILESYSTEM 12:08:52 : Attribute : 00000001 RW 12:08:52 : Start Address : 17100000 12:08:52 : Size : 27500000 12:08:52 : Partition 4 12:08:52 : ID : 0000000A PMM 12:08:52 : Attribute : 00000001 RW 12:08:52 : Start Address : 3E600000 12:08:52 : Size : 00400000 12:08:52 : PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000020000FFFFFFFF0000000400000003000000020014000002DC0000000000040000000202F0000014200000000000080000000117100000275000000000000A000000013E60000000400000C8 12:08:53 : PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) 12:08:53 : ProcessPartitionInfo_DCT5 : No Error - 0 (0x00) 12:08:53 : StartErase_DCT5... 12:08:53 : BlockLength : 0x4F (79) 12:08:53 : ERASE Blocks : 0x02 (2) 12:08:53 : 0 ERASE_AREA_BB5 0x12 12:08:53 : Block Length : 0x1B (27) 12:08:53 : BB ASIC Index : 0x00 CMT 12:08:53 : Device Type : 0x03 MuxOneNAND 12:08:53 : Device Index : 0x00 12:08:53 : 0 : 00040000-0007FFFF 12:08:53 : 1 : 000C0000-008BFFFF 12:08:53 : 2 : 010C0000-170FFFFF 12:08:53 : 1 FORMAT_PARTITION_BB5 0x19 12:08:53 : Block Length : 0x2F (47) 12:08:53 : BB ASIC Index : 0x00 CMT 12:08:53 : Device Type : 0x03 MuxOneNAND 12:08:53 : Device Index : 0x00 12:08:53 : Format Info ID : 0x03000000 12:08:53 : Format Info : 000000000000000A0000000000000002000000640018000000000002000000010000000000000000 12:08:53 : 12:08:53 : Erase_SendEraseBlock_BB5_NAND 12:08:53 : Task in Progress... Please Wait... 12:08:53 : 12:08:53 : Erase_SendFormatPartition_BB5_NAND 12:08:53 : Task in Progress... Please Wait... 12:08:54 : 12:08:54 : Successfully erased.. 12:08:54 : Time Taken to Erase : 00:00:01 12:08:54 : Flashing Speed: 5.00 Mhz (AUTO) 12:08:54 : Processing : RM-774_113.010.1506_79u_prd.core.fpsx 12:08:54 : Total blocks to write : 610 12:08:54 : >> CMT Rootkey Hash CERT : ADA 12:08:54 : >> CMT Rootkey Hash CERT : KEYS 12:08:54 : >> CMT Rootkey Hash CERT : PRIMAPP 12:08:54 : >> CMT Rootkey Hash CERT : RAP3NAND 12:08:54 : >> CMT Rootkey Hash CERT : SOS+PMML 12:08:55 : >> CMT Rootkey Hash CERT : SOS+DECOMP 12:08:55 : >> CMT Rootkey Hash CERT : PASUBTOC 12:08:55 : >> CMT Rootkey Hash CERT : PAPUBKEYS [FEB3BB7481D3E5D0EAC907335A4402A071493D53] 12:08:55 : >> CMT Rootkey Hash CERT : GENIO_INIT 12:08:55 : >> CMT Rootkey Hash CERT : SOS+IVE3A 12:08:55 : >> CMT Rootkey Hash CERT : SOS*UPDAPP 12:08:56 : >> CMT Rootkey Hash CERT : SOS*DSP0 12:08:57 : >> CMT Rootkey Hash CERT : LDSP 12:08:57 : >> CMT Rootkey Hash CERT : SOS*ISASW 12:08:58 : >> CMT Rootkey Hash CERT : SOS+CORE 12:09:12 : >> CMT Rootkey Hash CERT : SOS+ROFS1 12:10:08 : ContinueFlash_DCT5 Complete 12:10:08 : Continue Flash Complete : : No Error - 0 (0x00) 12:10:08 : Time Taken to Flash : 00:01:14 12:10:08 : 12:10:08 : Processing Image File : 12:10:08 : C:\Program Files (x86)\Nokia\Phoenix\Products\RM-774\RM-774_113.010.1506_C00.01_79u_prd.rofs3.fpsx 12:10:08 : CMT Type : BB5 12:10:08 : CMT Algorithm : XSR 1.6 12:10:08 : Secondary Sending Speed : 650000 Hz 12:10:08 : Algorithm Sending Speed : 6500000 Hz 12:10:08 : Program Sending Speed : 13000000 Hz 12:10:08 : Message Reading Speed : 98000 Hz 12:10:09 : Number of Blocks : 10 12:10:09 : Entry Point : 0x0153 12:10:09 : Page Format : 128K 12:10:09 : Maximum Page Size : 0x00001C00 12:10:09 : 12:10:09 : StartErase_DCT5... 12:10:09 : BlockLength : 0x16 (22) 12:10:09 : ERASE Blocks : 0x01 (1) 12:10:09 : 0 ERASE_AREA_BB5 0x12 12:10:09 : Block Length : 0x13 (19) 12:10:09 : BB ASIC Index : 0x00 CMT 12:10:09 : Device Type : 0x03 MuxOneNAND 12:10:09 : Device Index : 0x00 12:10:09 : 0 : 01678000-0169FFFF 12:10:09 : 1 : 135C0000-170FFFFF 12:10:09 : 12:10:09 : Erase_SendEraseBlock_BB5_NAND 12:10:09 : Task in Progress... Please Wait... 12:10:09 : 12:10:09 : Successfully erased.. 12:10:09 : Time Taken to Erase : 00:00:00 12:10:09 : Flashing Speed: 5.00 Mhz (AUTO) 12:10:09 : Processing : RM-774_113.010.1506_C00.01_79u_prd.rofs3.fpsx 12:10:09 : Total blocks to write : 10 12:10:09 : >> CMT Rootkey Hash CERT : SOS+ROFS3 12:10:09 : >> CMT Rootkey Hash CERT : SOS+IVE3B 12:10:09 : ContinueFlash_DCT5 Complete 12:10:09 : Continue Flash Complete : : No Error - 0 (0x00) 12:10:09 : Time Taken to Flash : 00:00:00 12:10:09 : 12:10:09 : Processing Image File : 12:10:09 : C:\Program Files (x86)\Nokia\Phoenix\Products\RM-774\RM-774_113.010.1506_04.01_Russian_79u_prd.rofs2.fpsx 12:10:09 : CMT Type : BB5 12:10:09 : CMT Algorithm : XSR 1.6 12:10:09 : Secondary Sending Speed : 650000 Hz 12:10:09 : Algorithm Sending Speed : 6500000 Hz 12:10:09 : Program Sending Speed : 13000000 Hz 12:10:09 : Message Reading Speed : 98000 Hz 12:10:09 : Number of Blocks : 300 12:10:09 : Entry Point : 0x014B 12:10:09 : Page Format : 128K 12:10:09 : Maximum Page Size : 0x00040000 12:10:09 : 12:10:09 : StartErase_DCT5... 12:10:09 : BlockLength : 0x0E (14) 12:10:09 : ERASE Blocks : 0x01 (1) 12:10:09 : 0 ERASE_AREA_BB5 0x12 12:10:09 : Block Length : 0x0B (11) 12:10:09 : BB ASIC Index : 0x00 CMT 12:10:09 : Device Type : 0x03 MuxOneNAND 12:10:09 : Device Index : 0x00 12:10:09 : 0 : 0D1C0000-135BFFFF 12:10:09 : 12:10:09 : Erase_SendEraseBlock_BB5_NAND 12:10:09 : Task in Progress... Please Wait... 12:10:09 : 12:10:09 : Successfully erased.. 12:10:09 : Time Taken to Erase : 00:00:00 12:10:09 : Flashing Speed: 5.00 Mhz (AUTO) 12:10:09 : Processing : RM-774_113.010.1506_04.01_Russian_79u_prd.rofs2.fpsx 12:10:09 : Total blocks to write : 300 12:10:09 : >> CMT Rootkey Hash CERT : SOS+ROFS2 12:10:50 : ContinueFlash_DCT5 Complete 12:10:50 : Continue Flash Complete : : No Error - 0 (0x00) 12:10:50 : Time Taken to Flash : 00:00:41 12:10:50 : 12:10:50 : Processing Image File : 12:10:50 : C:\Program Files (x86)\Nokia\Phoenix\Products\RM-774\RM-774_113.010.1506_U01.01_79u.uda.fpsx 12:10:51 : CMT Type : BB5 12:10:51 : CMT Algorithm : XSR 1.6 12:10:51 : Secondary Sending Speed : 650000 Hz 12:10:51 : Algorithm Sending Speed : 6500000 Hz 12:10:51 : Program Sending Speed : 13000000 Hz 12:10:51 : Message Reading Speed : 98000 Hz 12:10:51 : Number of Blocks : 1097 12:10:51 : Entry Point : 0x014B 12:10:51 : Page Format : 128K 12:10:51 : Maximum Page Size : 0x00040000 12:10:51 : 12:10:51 : StartErase_DCT5... 12:10:51 : BlockLength : 0x0E (14) 12:10:51 : ERASE Blocks : 0x01 (1) 12:10:51 : 0 ERASE_AREA_BB5 0x12 12:10:51 : Block Length : 0x0B (11) 12:10:51 : BB ASIC Index : 0x00 CMT 12:10:51 : Device Type : 0x03 MuxOneNAND 12:10:51 : Device Index : 0x00 12:10:51 : 0 : 17100000-3E5FFFFF 12:10:51 : 12:10:51 : Erase_SendEraseBlock_BB5_NAND 12:10:51 : Task in Progress... Please Wait... 12:10:51 : 12:10:51 : Successfully erased.. 12:10:51 : Time Taken to Erase : 00:00:00 12:10:51 : Flashing Speed: 5.00 Mhz (AUTO) 12:10:51 : Processing : RM-774_113.010.1506_U01.01_79u.uda.fpsx 12:10:51 : Total blocks to write : 1097 12:13:28 : ContinueFlash_DCT5 Complete 12:13:28 : Continue Flash Complete : : No Error - 0 (0x00) 12:13:28 : Time Taken to Flash : 00:02:37 12:13:28 : 12:13:28 : Total Flash Write Time (Flashing Only) : 00:04:32 12:13:28 : Total Flashing Time (Booting + Erase + Flashing) : 00:04:36 12:13:28 : 12:13:28 : STATUS_REQUEST_BB5... 12:13:28 : 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 12:13:28 : Block Length : 0F 12:13:28 : BB ASIC Index : 00 12:13:28 : Device Type : 03 12:13:28 : Device Type : 00 12:13:28 : Num Bad Blocks : 00000000 12:13:28 : Additional Bad : 00000000 12:13:28 : Correctable ECC : 00000000 12:13:39 : 12:13:39 : Waiting for Phone to Go Online... 12:13:40 : Elapsed Time: 1s 12:13:41 : Elapsed Time: 2s 12:13:42 : Elapsed Time: 3s 12:13:43 : Elapsed Time: 4s 12:13:44 : Elapsed Time: 5s 12:13:45 : Elapsed Time: 6s 12:13:46 : Elapsed Time: 7s 12:13:47 : Elapsed Time: 8s 12:13:48 : Elapsed Time: 9s 12:13:49 : Elapsed Time: 10s 12:13:49 : 12:13:49 : ================================================ 12:13:49 : Basic Phone Information 12:13:49 : ================================================ 12:13:49 : MCU Version: V 79u_sr2_12w20.8 20-08-12 RM-774 (c) Nokia 12:13:49 : IMEI Plain : 12345610654321? 12:13:49 : IMEI Spare : A123456106543210 12:13:49 : IMEI SV : 31234561065432130F 12:13:49 : Phone Model: Nokia 701 12:13:49 : Category : Classic Phone 12:13:49 : Phone Type : RM-774 12:13:49 : 12:13:49 : ================================================ 12:13:49 : Extended Phone Information 12:13:49 : ================================================ 12:13:49 : Product Serial Number: 0 12:13:49 : Long Production SN : 0 12:13:50 : MCU SW Version : V 79u_sr2_12w20.8 20-08-12 RM-774 (c) Nokia 12:13:50 : RFIC Version : |Alli_4.3.4 12:13:50 : DSP Version : 79u_sr2_12w20_2 12:13:51 : APE BT Version : HCI Version 12 (rev. 64). LMP Version 36 (rev. 64). Manufacturer 2592. 12:13:51 : AHNE Version : 21 12:13:51 : APE SW Core Version : 113.010.1506 12:13:51 : Variant Version : 113.010.1506113.010.1506.04.01113.010.1506.C00.01 12:13:51 : RETU Version : 40 12:13:51 : TAHVO Version : 00 12:13:51 : APE HW Version : 256 12:13:51 : APE ADSP SW Version : 256 12:13:51 : Bluetooth ID : 00:02:5B:00:A5:A5 12:13:51 : CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA II, WCDMA IV, WCDMA V, WCDMA VIII 12:13:51 : 12:13:51 : ================================================ 12:13:51 : Simlock Information 12:13:51 : ================================================ 12:13:51 : Unable to read SP Data.. 12:13:55 : 12:13:55 : Waiting for Phone to Go Online... 12:13:56 : Elapsed Time: 1s 12:13:57 : Elapsed Time: 2s 12:13:58 : Elapsed Time: 3s 12:13:59 : Elapsed Time: 4s 12:14:00 : Elapsed Time: 5s 12:14:01 : Elapsed Time: 6s 12:14:02 : Elapsed Time: 7s 12:14:03 : Elapsed Time: 8s 12:14:04 : Elapsed Time: 9s 12:14:05 : Elapsed Time: 10s 12:14:05 : 12:14:05 : ================================================ 12:14:05 : Basic Phone Information 12:14:05 : ================================================ 12:14:05 : MCU Version: V 79u_sr2_12w20.8 20-08-12 RM-774 (c) Nokia 12:14:05 : IMEI Plain : 12345610654321? 12:14:05 : IMEI Spare : A123456106543210 12:14:05 : IMEI SV : 31234561065432130F 12:14:05 : Phone Model: Nokia 701 12:14:05 : Category : Classic Phone 12:14:05 : Phone Type : RM-774 12:14:05 : 12:14:05 : ================================================ 12:14:05 : Extended Phone Information 12:14:05 : ================================================ 12:14:05 : Product Serial Number: 0 12:14:06 : Long Production SN : 0 12:14:06 : MCU SW Version : V 79u_sr2_12w20.8 20-08-12 RM-774 (c) Nokia 12:14:06 : RFIC Version : |Alli_4.3.4 12:14:06 : DSP Version : 79u_sr2_12w20_2 12:14:07 : APE BT Version : HCI Version 12 (rev. 64). LMP Version 36 (rev. 64). Manufacturer 3488. 12:14:07 : AHNE Version : 21 12:14:07 : APE SW Core Version : 113.010.1506 12:14:07 : Variant Version : 113.010.1506113.010.1506.04.01113.010.1506.C00.01 12:14:07 : RETU Version : 40 12:14:07 : TAHVO Version : 00 12:14:07 : APE HW Version : 256 12:14:07 : APE ADSP SW Version : 256 12:14:07 : Bluetooth ID : 00:02:5B:00:A5:A5 12:14:07 : CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA II, WCDMA IV, WCDMA V, WCDMA VIII 12:14:08 : 12:14:08 : ================================================ 12:14:08 : Simlock Information 12:14:08 : ================================================ 12:14:08 : Unable to read SP Data.. 12:14:08 : SECURITY_TEST : PASSED 12:14:08 : PHONE_MODE : TEST 12:14:08 : DCC ID : NOT USED 12:14:08 : 12:14:08 : 12:14:08 : FACTORY SET TO : Full Factory Set 12:14:09 : FAILED 12:14:09 : FACTORY SET TO : User Data 12:14:09 : OK 12:14:09 : FACTORY SET TO : Leave Factory 12:14:10 : OK 12:14:10 : FACTORY SET TO : Service Center 12:14:10 : OK 12:14:10 : FACTORY SET TO : Software Upgrade 12:14:10 : OK 12:14:10 : FACTORY SET TO : Production Tune 12:14:10 : OK 12:14:10 : 12:14:10 : 12:14:10 : Life timer data is not yet used... 12:14:10 : Life timer: ----:-- Code: Basic Phone Information 12:14:44 : ================================================ 12:14:44 : MCU Version: V 79u_sr2_12w20.8 20-08-12 RM-774 (c) Nokia 12:14:44 : IMEI Plain : 12345610654321? 12:14:44 : IMEI Spare : A123456106543210 12:14:45 : IMEI SV : 31234561065432130F 12:14:45 : Phone Model: Nokia 701 12:14:45 : Category : Classic Phone 12:14:45 : Phone Type : RM-774 12:14:45 : 12:14:45 : ================================================ 12:14:45 : Extended Phone Information 12:14:45 : ================================================ 12:14:45 : Product Serial Number: 0 12:14:45 : Long Production SN : 0 12:14:46 : MCU SW Version : V 79u_sr2_12w20.8 20-08-12 RM-774 (c) Nokia 12:14:46 : RFIC Version : |Alli_4.3.4 12:14:46 : DSP Version : 79u_sr2_12w20_2 12:14:46 : APE BT Version : HCI Version 12 (rev. 64). LMP Version 36 (rev. 64). Manufacturer 2992. 12:14:46 : AHNE Version : 21 12:14:46 : APE SW Core Version : 113.010.1506 12:14:46 : Variant Version : 113.010.1506113.010.1506.04.01113.010.1506.C00.01 12:14:47 : RETU Version : 40 12:14:47 : TAHVO Version : 00 12:14:47 : APE HW Version : 256 12:14:47 : APE ADSP SW Version : 256 12:14:47 : Bluetooth ID : 00:02:5B:00:A5:A5 12:14:47 : CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA II, WCDMA IV, WCDMA V, WCDMA VIII 12:14:47 : 12:14:47 : ================================================ 12:14:47 : Simlock Information 12:14:47 : ================================================ 12:14:47 : Unable to read SP Data.. 12:14:47 : SECURITY_TEST : PASSED 12:14:48 : PHONE_MODE : TEST 12:14:48 : DCC ID : NOT USED 12:14:48 : 12:14:55 : 12:14:55 : ================================================ 12:14:55 : Basic Phone Information 12:14:55 : ================================================ 12:14:55 : MCU Version: V 79u_sr2_12w20.8 20-08-12 RM-774 (c) Nokia 12:14:55 : IMEI Plain : 12345610654321? 12:14:55 : IMEI Spare : A123456106543210 12:14:55 : IMEI SV : 31234561065432130F 12:14:55 : Phone Model: Nokia 701 12:14:55 : Category : Classic Phone 12:14:55 : Phone Type : RM-774 12:14:55 : 12:14:55 : 12:14:55 : Life timer data is not yet used... 12:14:55 : Life timer: ----:-- 12:15:01 : 12:15:01 : FACTORY SET TO : Full Factory Set 12:15:02 : FAILED 12:15:03 : 12:15:03 : FACTORY SET TO : Full Factory Set 12:15:04 : FAILED 12:15:04 : 12:15:04 : FACTORY SET TO : Full Factory Set 12:15:05 : FAILED 12:15:59 : Booting Phone via FBUS... 12:15:59 : 12:15:59 : 12:15:59 : AdvanceBox SendBootCodeEx 12:15:59 : InitialiseBootstrap_DCT5 DIR 12:15:59 : BootFlashMode_DCT5 12:15:59 : 12:15:59 : ****************************************************** 12:15:59 : TIME STARTS HERE 12:15:59 : ****************************************************** 12:15:59 : 12:15:59 : BootFlashModeDCT5Ex Succeeded First Time 12:15:59 : SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned 12:15:59 : Number of Sub Blocks 7 (0x07) 12:15:59 : 1 SYSTEM_ASIC_ID 01 12:15:59 : Block Length : 21 (15) 12:15:59 : BB ASIC Index : 0 (00) CMT 12:15:59 : ID DWORD 0 : 00000003 12:15:59 : ID DWORD 1 : 00000226 12:15:59 : ID DWORD 2 : 00010007 12:15:59 : ID DWORD 3 : 400C1921 12:15:59 : ID DWORD 4 : 03032108 12:15:59 : 2 EM_ASIC_ID 02 12:15:59 : Block Length : 5 (05) 12:15:59 : BB ASIC Index : 0 (00) CMT 12:15:59 : ID DWORD 0 : 00001040 12:15:59 : 3 EM_ASIC_ID 02 12:15:59 : Block Length : 5 (05) 12:15:59 : BB ASIC Index : 0 (00) CMT 12:15:59 : ID DWORD 0 : 00001030 12:15:59 : 4 PUBLIC_ID 12 12:15:59 : Block Length : 21 (15) 12:15:59 : BB ASIC Index : 0 (00) CMT 12:15:59 : ID DWORD 0 : 8C4A0000 12:15:59 : ID DWORD 1 : FFFB7C40 12:15:59 : ID DWORD 2 : 9684A507 12:15:59 : ID DWORD 3 : 7C279C0A 12:15:59 : ID DWORD 4 : 69F1BA89 12:15:59 : 5 ASIC_MODE_ID 13 12:15:59 : Block Length : 2 (02) 12:15:59 : BB ASIC Index : 0 (00) CMT 12:15:59 : Mode Id : 00 12:15:59 : 6 ROOT_KEY_HASH 14 12:15:59 : Block Length : 17 (11) 12:15:59 : BB ASIC Index : 0 (00) CMT 12:15:59 : Hash : 3A B5 DB 70 B4 5D 23 F1 AD EE BB 57 34 16 07 06 12:15:59 : 7 ROM_ID 15 12:15:59 : Block Length : 9 (09) 12:15:59 : BB ASIC Index : 0 (00) CMT 12:15:59 : CRC 0 : 2CAC45E2 12:15:59 : CRC 1 : 3BC33C8B 12:15:59 : Checksum 7E 12:15:59 : 12:15:59 : SearchForBootstrap_DCT5.. 12:15:59 : C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv21_2nd.fg 12:15:59 : Boot File - Version 012.014.00 12:15:59 : Boot File - Revision 0x0003 (3) 12:15:59 : eBB5ProtocolType == New 12:15:59 : PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" 12:15:59 : PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0" 12:15:59 : SearchForBootstrap_DCT5 : No Error - 0 (0x00) 12:15:59 : Secondary Loader Sent... 12:15:59 : TransmissionTypeRequest_DCT5_NewProtocol 12:15:59 : TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 12:15:59 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 12:15:59 : TransmissionTypeRequest_DCT5_NewProtocol 12:15:59 : FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX 12:15:59 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C 12:15:59 : Transmission Type Request Sent... 12:15:59 : ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. 12:15:59 : MCU_CONFIGURATION_RESPONSE_BB5: 12:15:59 : MessageID : 06 12:15:59 : SubBlocks : 06 12:15:59 : 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 12:15:59 : Block Length : 0B 12:15:59 : BB ASIC Index : CMT 00 12:15:59 : Device Type : RAM 05 12:15:59 : Device Index : 00 12:15:59 : Manufacturer Code : 0000 -> Flash 12:15:59 : Device ID : 0000 -> not detected 12:15:59 : Extended/Fixed ID : 0000 12:15:59 : Revision ID : 0000 12:15:59 : 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 12:15:59 : Block Length : 0B 12:15:59 : BB ASIC Index : CMT 00 12:15:59 : Device Type : MMC 04 12:15:59 : Device Index : 00 12:15:59 : Manufacturer Code : FFFF -> Flash 12:15:59 : Device ID : 0000 -> BAD FLASH TYPE 12:15:59 : Extended/Fixed ID : 0000 12:15:59 : Revision ID : 0000 12:15:59 : 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 12:15:59 : Block Length : 0B 12:15:59 : BB ASIC Index : CMT 00 12:15:59 : Device Type : NOR 00 12:15:59 : Device Index : 00 12:15:59 : Manufacturer Code : 0000 -> Flash 12:15:59 : Device ID : 0000 -> not detected 12:15:59 : Extended/Fixed ID : 0000 12:15:59 : Revision ID : 0000 12:15:59 : 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 12:15:59 : Block Length : 0B 12:15:59 : BB ASIC Index : CMT 00 12:15:59 : Device Type : NOR 00 12:15:59 : Device Index : 01 12:15:59 : Manufacturer Code : 0000 -> SPANSION 12:15:59 : Device ID : 0001 -> not used 12:15:59 : Extended/Fixed ID : 0000 12:15:59 : Revision ID : 0000 12:15:59 : 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 12:15:59 : Block Length : 0B 12:15:59 : BB ASIC Index : CMT 00 12:15:59 : Device Type : MuxOneNAND 03 12:15:59 : Device Index : 00 12:15:59 : Manufacturer Code : 00EC -> 12:15:59 : Device ID : 0060 -> Type not in database 12:15:59 : Extended/Fixed ID : 0000 12:15:59 : Revision ID : 0032 12:15:59 : 6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5 12:15:59 : Block Length : 09 12:15:59 : BB ASIC Index : CMT 00 12:15:59 : Data : XSR 1.6 12:15:59 : Checksum : F8 12:15:59 : SearchForBootstrap_DCT5 : No Error - 0 (0x00) 12:15:59 : FLS1SendAlgoCodeEx.. 12:15:59 : SendAlgoCode_DCT5.. 12:15:59 : SearchForAlgorithm_DCT5.. 12:15:59 : Looking for ALL Devices... 12:15:59 : Searching Algorithm Files MuxOneNAND (03) ManID :00EC DevID :0060 ExtID :0000 RevID :0032 12:15:59 : Flash Descriptor 12:15:59 : Manufacturer Code : 00EC 12:15:59 : Device ID : 0060 12:15:59 : Extended/Fixed ID : 0000 12:15:59 : Revision ID : 0000 12:15:59 : Size : 40000000 (1024 MB) 12:15:59 : VPP Info : 0000 12:15:59 : Erase10s : 1E 12:15:59 : Block1s : 32 12:15:59 : BErase1s : 02 12:15:59 : Reserved0 : 00 12:15:59 : Reserved1 : 00 12:15:59 : Reserved2 : 00 12:16:00 : C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv21_XSR17_alg.fg 12:16:00 : Algorithm File - Version 012.014.00 12:16:00 : Algorithm File - Revision 0x0003 (3) 12:16:00 : eBB5ProtocolType == New 12:16:00 : Algo Loader Sent... 12:16:00 : SendCodeStart_NewProtocol : 12:16:01 : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) 12:16:01 : TransmissionTypeRequest_DCT5_NewProtocol 12:16:01 : TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 12:16:01 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 12:16:02 : TransmissionTypeRequest_DCT5_NewProtocol 12:16:02 : FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX 12:16:02 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C 12:16:02 : SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) 12:16:02 : FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) 12:16:02 : FUR control Ok... 12:16:02 : VPP Enabled by Software 12:16:02 : Using Internal VPP 12:16:02 : VPP Enabled by Software 12:16:02 : FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 12:16:02 : PAPUB_KEYS_HASH_REQ_BB5 12:16:02 : PhoneInfoRequest_BB5 (Asic Index 00 ) 12:16:02 : PHONE_INFO_RESPONSE_BB5 12:16:02 : PAPUB_KEYS_HASH_RESP_BB5 2A 12:16:02 : BB Asic Index : 00 12:16:02 : CMT PAPUBKEYS HASH: 12:16:02 : FEB3BB7481D3E5D0EAC907335A4402A071493D53 12:16:02 : 12:16:04 : =========================================== 12:16:04 : PHONE FIRMWARE VERSION: 12:16:04 : 113.010.1506 12:16:04 : =========================================== 12:16:04 : 12:16:04 : VPP Enabled by Software 12:16:04 : Using Internal VPP 12:16:04 : VPP Enabled by Software 12:16:04 : FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 12:16:04 : StartErase_DCT5... 12:16:04 : BlockLength : 0x10 (16) 12:16:04 : ERASE Blocks : 0x01 (1) 12:16:04 : 0 ERASE_AREA_BB5 0x13 12:16:04 : Block Length : 0x0D (13) 12:16:04 : BB ASIC Index : 0x00 CMT 12:16:04 : 12:16:04 : Erase_SendEraseBlock_BB5_NAND 12:16:04 : Task in Progress... Please Wait... 12:16:04 : 12:16:04 : Successfully erased.. 12:16:05 : 12:16:05 : Now Writing : CMT NPC Certificate 0x0190 Bytes 12:16:05 : 12:16:05 : NPC Write Successful... 12:16:05 : 12:16:05 : StartErase_DCT5... 12:16:05 : BlockLength : 0x10 (16) 12:16:05 : ERASE Blocks : 0x01 (1) 12:16:05 : 0 ERASE_AREA_BB5 0x13 12:16:05 : Block Length : 0x0D (13) 12:16:05 : BB ASIC Index : 0x00 CMT 12:16:05 : 12:16:05 : Erase_SendEraseBlock_BB5_NAND 12:16:05 : Task in Progress... Please Wait... 12:16:05 : 12:16:05 : Successfully erased.. 12:16:05 : 12:16:05 : Now Writing : CMT CCC Certificate 0x022C Bytes 12:16:05 : 12:16:05 : CCC Write Successful... 12:16:05 : 12:16:05 : StartErase_DCT5... 12:16:05 : BlockLength : 0x10 (16) 12:16:05 : ERASE Blocks : 0x01 (1) 12:16:05 : 0 ERASE_AREA_BB5 0x13 12:16:05 : Block Length : 0x0D (13) 12:16:05 : BB ASIC Index : 0x00 CMT 12:16:05 : 12:16:05 : Erase_SendEraseBlock_BB5_NAND 12:16:05 : Task in Progress... Please Wait... 12:16:05 : 12:16:05 : Successfully erased.. 12:16:05 : 12:16:05 : Now Writing : CMT HWC Certificate 0x00D4 Bytes 12:16:05 : 12:16:05 : HWC Write Successful... 12:16:05 : 12:16:06 : 12:16:06 : Write Certificates OK! 12:16:06 : 12:16:16 : 12:16:16 : Waiting for Phone to Go Online... 12:16:17 : Elapsed Time: 1s 12:16:18 : Elapsed Time: 2s 12:16:19 : Elapsed Time: 3s 12:16:20 : Elapsed Time: 4s 12:16:21 : Elapsed Time: 5s 12:16:22 : Elapsed Time: 6s 12:16:23 : Elapsed Time: 7s 12:16:24 : Elapsed Time: 8s 12:16:25 : Elapsed Time: 9s 12:16:26 : Elapsed Time: 10s 12:16:26 : 12:16:26 : ================================================ 12:16:26 : Basic Phone Information 12:16:26 : ================================================ 12:16:26 : MCU Version: V 79u_sr2_12w20.8 20-08-12 RM-774 (c) Nokia 12:16:26 : IMEI Plain : 358272046918002 12:16:26 : IMEI Spare : A358272046918000 12:16:26 : IMEI SV : 33582720469180030F 12:16:26 : Phone Model: Nokia 701 12:16:26 : Category : Classic Phone 12:16:26 : Phone Type : RM-774 12:16:26 : 12:16:26 : 12:16:26 : Writing: SIMLOCK_DATA + SIMLOCK_KEY_DATA 12:16:27 : SUCCESSFUL !!! 12:16:27 : Writing: SUPERDONGLE_KEY_DATA 12:16:27 : SUCCESSFUL !!! 12:16:27 : Writing: CMLA_KEY_DATA 12:16:27 : SUCCESSFUL !!! 12:16:27 : Writing: WMDRM_PD_DATA 12:16:28 : SUCCESSFUL !!! 12:16:28 : 12:16:28 : RPL Upload Finished!!! Code: 12:04:32 : PHONE FIRMWARE VERSION: 12:04:32 : 113.010.1506 12:04:32 : =========================================== 12:04:32 : 12:04:34 : Reading NPC IMEI... 12:04:34 : 358272046918002 12:04:34 : Connecting to The ATF Network 12:04:36 : Network Connection Accepted 12:04:36 : Requesting Authorization Code 12:04:38 : Authorization Code Received 12:04:38 : Verifying Authorization Code 12:04:38 : Authorization Code is OK 12:04:38 : Saving RSA Modulus 12:04:38 : Saving Authorization Code 12:04:40 : File Saving Complete!!! 12:04:40 : 12:04:40 : 12:04:40 : ====================================================== 12:04:40 : Phone was Successfully Authorized 12:04:40 : ====================================================== 12:04:40 : Decrypt PM 120, Super Dongle Repair and 12:04:40 : Stand Alone SX-4 is NOW ENABLED for this Phone. 12:04:40 : ====================================================== 12:04:40 : 12:04:40 : Thank you for using The ATF Network Code: 12:05:09 : Basic Phone Information 12:05:09 : ================================================ 12:05:09 : MCU Version: V 79u_sr2_12w20.8 20-08-12 RM-774 (c) Nokia 12:05:09 : IMEI Plain : 358272046918002 12:05:09 : IMEI Spare : A358272046918000 12:05:09 : IMEI SV : 33582720469180030F 12:05:10 : Phone Model: Nokia 701 12:05:10 : Category : Classic Phone 12:05:10 : Phone Type : RM-774 12:05:10 : 12:05:10 : 12:05:10 : 12:05:10 : ================================================ 12:05:10 : SX4 Custom Keys Stand Alone Edition 12:05:10 : ================================================ 12:05:10 : 12:05:10 : >>> : SX4 Auth Successfull 12:05:10 : Selected PM File: C:\AdvanceBox Turbo Flasher\Nokia\PM Files\SX4\RM-774 .pm 12:05:10 : Start Uploading PM... 12:05:10 : Field : 1 Sub : 0 Byte(s): 10 - Ok 12:05:10 : Field : 1 Sub : 1 Byte(s): 94 - Ok 12:05:10 : Field : 1 Sub : 2 Byte(s): 110 - Ok 12:05:10 : Field : 1 Sub : 4 Byte(s): 10 - Ok 12:05:10 : Field : 1 Sub : 6 Byte(s): 110 - Ok 12:05:10 : Field : 1 Sub : 7 Byte(s): 450 - Ok 12:05:10 : Field : 1 Sub : 8 Byte(s): 10 - Ok 12:05:11 : Field : 1 Sub : 13 Byte(s): 110 - Ok 12:05:11 : Field : 1 Sub : 15 Byte(s): 30 - Ok 12:05:11 : Field : 1 Sub : 16 Byte(s): 30 - Ok 12:05:11 : Field : 1 Sub : 17 Byte(s): 30 - Ok 12:05:11 : Field : 1 Sub : 18 Byte(s): 30 - Ok 12:05:11 : Field : 1 Sub : 19 Byte(s): 30 - Ok 12:05:11 : Field : 1 Sub : 22 Byte(s): 24 - Ok 12:05:11 : Field : 1 Sub : 26 Byte(s): 10 - Ok 12:05:11 : Field : 1 Sub : 27 Byte(s): 36 - Ok 12:05:11 : Field : 1 Sub : 28 Byte(s): 110 - Ok 12:05:11 : Field : 1 Sub : 29 Byte(s): 10 - Ok 12:05:11 : Field : 1 Sub : 30 Byte(s): 36 - Ok 12:05:11 : Field : 1 Sub : 31 Byte(s): 24 - Ok 12:05:11 : Field : 1 Sub : 32 Byte(s): 216 - Ok 12:05:11 : Field : 1 Sub : 33 Byte(s): 36 - Ok 12:05:11 : Field : 1 Sub : 35 Byte(s): 24 - Ok 12:05:11 : Field : 1 Sub : 36 Byte(s): 24 - Ok 12:05:11 : Field : 1 Sub : 38 Byte(s): 216 - Ok 12:05:11 : Field : 1 Sub : 39 Byte(s): 36 - Ok 12:05:12 : Field : 1 Sub : 40 Byte(s): 24 - Ok 12:05:12 : Field : 1 Sub : 41 Byte(s): 216 - Ok 12:05:12 : Field : 1 Sub : 43 Byte(s): 36 - Ok 12:05:12 : Field : 1 Sub : 44 Byte(s): 216 - Ok 12:05:12 : Field : 1 Sub : 45 Byte(s): 216 - Ok 12:05:12 : Field : 309 Sub : 0 Byte(s): 4 - Ok 12:05:12 : Field : 309 Sub : 1 Byte(s): 2 - Ok 12:05:12 : Field : 309 Sub : 2 Byte(s): 12 - Ok 12:05:12 : Field : 309 Sub : 3 Byte(s): 36 - Ok 12:05:12 : Field : 309 Sub : 4 Byte(s): 12 - Ok 12:05:12 : Field : 309 Sub : 7 Byte(s): 12 - Ok 12:05:12 : Field : 309 Sub : 17 Byte(s): 12 - Ok 12:05:12 : PM Upload Done!... 12:05:16 : 12:05:17 : 12:05:17 : ================================================ 12:05:17 : Basic Phone Information 12:05:17 : ================================================ 12:05:17 : MCU Version: V 79u_sr2_12w20.8 20-08-12 RM-774 (c) Nokia 12:05:17 : IMEI Plain : 358272046918002 12:05:17 : IMEI Spare : A358272046918000 12:05:17 : IMEI SV : 33582720469180030F 12:05:17 : Phone Model: Nokia 701 12:05:17 : Category : Classic Phone 12:05:17 : Phone Type : RM-774 12:05:17 : 12:05:17 : ================================================ 12:05:17 : Extended Phone Information 12:05:17 : ================================================ 12:05:17 : Product Serial Number: 0 12:05:17 : Long Production SN : 0 12:05:18 : MCU SW Version : V 79u_sr2_12w20.8 20-08-12 RM-774 (c) Nokia 12:05:18 : RFIC Version : |Alli_4.3.4 12:05:18 : DSP Version : 79u_sr2_12w20_2 12:05:18 : APE BT Version : HCI Version 12 (rev. 64). LMP Version 36 (rev. 64). Manufacturer 2592. 12:05:18 : AHNE Version : 21 12:05:19 : APE SW Core Version : 113.010.1506 12:05:19 : Variant Version : 113.010.1506113.010.1506.04.01113.010.1506.C00.01 12:05:19 : RETU Version : 40 12:05:19 : TAHVO Version : 00 12:05:19 : APE HW Version : 256 12:05:19 : APE ADSP SW Version : 256 12:05:19 : Wireless LAN ID : 38:19:2F:53:FE:C0 12:05:19 : Bluetooth ID : 38:19:2F:53:C0:40 12:05:19 : CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA II, WCDMA IV, WCDMA V, WCDMA VIII 12:05:19 : 12:05:19 : ================================================ 12:05:19 : Simlock Information 12:05:19 : ================================================ 12:05:19 : CONFIG KEY : 0000000000000000 12:05:19 : PROVIDER KEY : 2440700000000000 12:05:19 : NETWORK NAME : Nokia Default;Finland 12:05:19 : LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10 12:05:19 : SIMLOCK TABLE : 12:05:19 : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open 12:05:19 : Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open 12:05:19 : Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open 12:05:19 : Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open 12:05:19 : Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open 12:05:19 : Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open 12:05:19 : Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open 12:05:19 : SIMLOCK STATE : Not Locked 12:05:19 : 12:05:19 : SIMLOCK_TYPE : PA_SL3 (15-digit NCK) 12:05:19 : SIMLOCK_TEST : PASSED 12:05:20 : SECURITY_TEST : FAILED 12:05:20 : > Try SX4 "PM AUTH" 12:05:20 : > Then Write PM 1 and 309 12:05:20 : SECURITY_CODE : ENCRYPTED 12:05:20 : PHONE_MODE : TEST 12:05:20 : DCC ID : NOT USED Code: PHONE FIRMWARE VERSION: 12:25:41 : 113.010.1506 12:25:41 : =========================================== 12:25:41 : 12:25:41 : VPP Enabled by Software 12:25:41 : Using Internal VPP 12:25:41 : VPP Enabled by Software 12:25:41 : FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 12:25:41 : StartErase_DCT5... 12:25:41 : BlockLength : 0x10 (16) 12:25:41 : ERASE Blocks : 0x01 (1) 12:25:41 : 0 ERASE_AREA_BB5 0x13 12:25:41 : Block Length : 0x0D (13) 12:25:41 : BB ASIC Index : 0x00 CMT 12:25:41 : 12:25:41 : Erase_SendEraseBlock_BB5_NAND 12:25:41 : Task in Progress... Please Wait... 12:25:41 : 12:25:41 : Successfully erased.. 12:25:42 : 12:25:42 : Now Writing : CMT CCC Certificate 0x022C Bytes 12:25:42 : 12:25:42 : CCC Write Successful... 12:25:42 : 12:25:42 : StartErase_DCT5... 12:25:42 : BlockLength : 0x10 (16) 12:25:42 : ERASE Blocks : 0x01 (1) 12:25:42 : 0 ERASE_AREA_BB5 0x13 12:25:42 : Block Length : 0x0D (13) 12:25:42 : BB ASIC Index : 0x00 CMT 12:25:42 : 12:25:42 : Erase_SendEraseBlock_BB5_NAND 12:25:42 : Task in Progress... Please Wait... 12:25:42 : 12:25:42 : Successfully erased.. 12:25:42 : 12:25:42 : Now Writing : CMT HWC Certificate 0x00D4 Bytes 12:25:42 : 12:25:42 : HWC Write Successful... 12:25:42 : 12:25:42 : 12:25:42 : Write Certificates OK! 12:25:42 : 12:25:42 : 12:25:42 : RPL Upload Finished!!! 12:25:46 : 12:25:52 : 12:25:52 : Waiting for Phone to Go Online... 12:25:53 : Elapsed Time: 1s 12:25:54 : Elapsed Time: 2s 12:25:55 : Elapsed Time: 3s 12:25:56 : Elapsed Time: 4s 12:25:57 : Elapsed Time: 5s 12:25:58 : Elapsed Time: 6s 12:25:59 : Elapsed Time: 7s 12:26:00 : Elapsed Time: 8s 12:26:01 : Elapsed Time: 9s 12:26:02 : Elapsed Time: 10s 12:26:03 : 12:26:03 : ================================================ 12:26:03 : Basic Phone Information 12:26:03 : ================================================ 12:26:03 : MCU Version: V 79u_sr2_12w20.8 20-08-12 RM-774 (c) Nokia 12:26:03 : IMEI Plain : 358272046918002 12:26:03 : IMEI Spare : A358272046918000 12:26:03 : IMEI SV : 33582720469180030F 12:26:03 : Phone Model: Nokia 701 12:26:03 : Category : Classic Phone 12:26:03 : Phone Type : RM-774 12:26:03 : 12:26:03 : ================================================ 12:26:03 : Extended Phone Information 12:26:03 : ================================================ 12:26:03 : Product Serial Number: 0 12:26:03 : Long Production SN : 0 12:26:04 : MCU SW Version : V 79u_sr2_12w20.8 20-08-12 RM-774 (c) Nokia 12:26:04 : RFIC Version : |Alli_4.3.4 12:26:04 : DSP Version : 79u_sr2_12w20_2 12:26:04 : APE BT Version : HCI Version 12 (rev. 64). LMP Version 36 (rev. 64). Manufacturer 2592. 12:26:04 : AHNE Version : 21 12:26:05 : APE SW Core Version : 113.010.1506 12:26:05 : Variant Version : 113.010.1506113.010.1506.04.01113.010.1506.C00.01 12:26:05 : RETU Version : 40 12:26:05 : TAHVO Version : 00 12:26:05 : APE HW Version : 256 12:26:05 : APE ADSP SW Version : 256 12:26:05 : Wireless LAN ID : 38:19:2F:53:FE:C0 12:26:05 : Bluetooth ID : 38:19:2F:53:C0:40 12:26:05 : CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA II, WCDMA IV, WCDMA V, WCDMA VIII 12:26:05 : 12:26:05 : ================================================ 12:26:05 : Simlock Information 12:26:05 : ================================================ 12:26:05 : CONFIG KEY : 0000000000000000 12:26:05 : PROVIDER KEY : 2440700000000000 12:26:05 : NETWORK NAME : Nokia Default;Finland 12:26:05 : LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10 12:26:05 : SIMLOCK TABLE : 12:26:05 : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open 12:26:05 : Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open 12:26:05 : Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open 12:26:05 : Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open 12:26:05 : Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open 12:26:05 : Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open 12:26:05 : Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open 12:26:05 : SIMLOCK STATE : Not Locked 12:26:05 : 12:26:05 : SIMLOCK_TYPE : PA_SL3 (15-digit NCK) 12:26:05 : SIMLOCK_TEST : PASSED 12:26:06 : SECURITY_TEST : FAILED 12:26:06 : > Try SX4 "PM AUTH" 12:26:06 : > Then Write PM 1 and 309 12:26:06 : SECURITY_CODE : ENCRYPTED 12:26:06 : PHONE_MODE : TEST 12:26:06 : DCC ID : NOT USED SECURITY_TEST : FAILED Server SX4 not working? Last edited by rifaaq; 06-20-2014 at 08:53. |
06-21-2014, 12:54 | #14 (permalink) | |
Member: 567810 Status: Online Sonork: Xiaomi direct Thanks Meter: 30 | Quote:
Code: Booting Phone via FBUS... AdvanceBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ****************************************************** TIME STARTS HERE ****************************************************** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000003 ID DWORD 1 : 00000226 ID DWORD 2 : 00010007 ID DWORD 3 : 400C1921 ID DWORD 4 : 03032108 2 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00001040 3 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00001030 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 8C4A0000 ID DWORD 1 : FFFB7C40 ID DWORD 2 : 9684A507 ID DWORD 3 : 7C279C0A ID DWORD 4 : 69F1BA89 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 3A B5 DB 70 B4 5D 23 F1 AD EE BB 57 34 16 07 06 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 2CAC45E2 CRC 1 : 3BC33C8B Checksum 7E SearchForBootstrap_DCT5.. C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv21_2nd.fg Boot File - Version 012.014.00 Boot File - Revision 0x0003 (3) eBB5ProtocolType == New PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0" SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C Transmission Type Request Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : 06 SubBlocks : 06 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> not used Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 0060 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0032 6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5 Block Length : 09 BB ASIC Index : CMT 00 Data : XSR 1.6 Checksum : F8 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files MuxOneNAND (03) ManID :00EC DevID :0060 ExtID :0000 RevID :0032 Flash Descriptor Manufacturer Code : 00EC Device ID : 0060 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 40000000 (1024 MB) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv21_XSR17_alg.fg Algorithm File - Version 012.014.00 Algorithm File - Revision 0x0003 (3) eBB5ProtocolType == New Algo Loader Sent... SendCodeStart_NewProtocol : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok... VPP Enabled by Software Using Internal VPP VPP Enabled by Software FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 PAPUB_KEYS_HASH_REQ_BB5 PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: FEB3BB7481D3E5D0EAC907335A4402A071493D53 =========================================== PHONE FIRMWARE VERSION: 113.010.1506 =========================================== VPP Enabled by Software Using Internal VPP VPP Enabled by Software FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 StartErase_DCT5... BlockLength : 0x10 (16) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x13 Block Length : 0x0D (13) BB ASIC Index : 0x00 CMT Erase_SendEraseBlock_BB5_NAND Task in Progress... Please Wait... Successfully erased.. Now Writing : CMT CCC Certificate 0x022C Bytes CCC Write Successful... StartErase_DCT5... BlockLength : 0x10 (16) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x13 Block Length : 0x0D (13) BB ASIC Index : 0x00 CMT Erase_SendEraseBlock_BB5_NAND Task in Progress... Please Wait... Successfully erased.. Now Writing : CMT HWC Certificate 0x00D4 Bytes HWC Write Successful... Write Certificates OK! RPL Upload Finished!!! Waiting for Phone to Go Online... Elapsed Time: 1s Elapsed Time: 2s Elapsed Time: 3s Elapsed Time: 4s Elapsed Time: 5s Elapsed Time: 6s Elapsed Time: 7s Elapsed Time: 8s Elapsed Time: 9s Elapsed Time: 10s ================================================ Basic Phone Information ================================================ MCU Version: V 79u_sr2_12w20.8 20-08-12 RM-774 (c) Nokia IMEI Plain : 358272046918002 IMEI Spare : A358272046918000 IMEI SV : 33582720469180030F Phone Model: Nokia 701 Category : Classic Phone Phone Type : RM-774 ================================================ Extended Phone Information ================================================ Product Serial Number: 0 Product Code : 059H222 Long Production SN : 0 MCU SW Version : V 79u_sr2_12w20.8 20-08-12 RM-774 (c) Nokia RFIC Version : |Alli_4.3.4 DSP Version : 79u_sr2_12w20_2 APE BT Version : HCI Version 12 (rev. 64). LMP Version 36 (rev. 64). Manufacturer 2592. AHNE Version : 21 APE SW Core Version : 113.010.1506 Variant Version : 113.010.1506113.010.1506.04.01113.010.1506.C00.01 RETU Version : 40 TAHVO Version : 00 APE HW Version : 256 APE ADSP SW Version : 256 Wireless LAN ID : 38:19:2F:53:FE:C0 Bluetooth ID : 38:19:2F:53:C0:40 CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA II, WCDMA IV, WCDMA V, WCDMA VIII ================================================ Simlock Information ================================================ CONFIG KEY : 0000000000000000 PROVIDER KEY : 2440700000000000 NETWORK NAME : Nokia Default;Finland LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10 SIMLOCK TABLE : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK STATE : Not Locked SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : FAILED > Try SX4 "PM AUTH" > Then Write PM 1 and 309 SECURITY_CODE : ENCRYPTED PHONE_MODE : TEST DCC ID : NOT USED ====================================================== Selected VPL File: RM774_059G9P9_113.010.1506_038.vpl ====================================================== Variant Details : _eu_russia_eeurope_l_silver Software Version : 113.010.1506 Product Type : RM-774 Product Code : 059G9P9 Variant Version : 038 PS: After erase and flashing phone working fine with IMEI 12345. I think need server SX4. | |
