08-05-2013, 14:59 | #1 (permalink) |
Freak Poster Join Date: Dec 2010 Location: Uzbekistan/Jizzakh
Member: 1470188 Status: Offline Sonork: 100.1638921 Thanks Meter: 88 | nokia 701 security test failed ================================================ Basic Phone Information ================================================ MCU Version: V 79u_sr2_12w20.8 20-08-12 RM-774 (c) Nokia IMEI Plain : 358272047952828 IMEI Spare : A358272047952820 IMEI SV : 33582720479528230F Phone Model: Nokia 701 Category : Classic Phone Phone Type : RM-774 ================================================ Extended Phone Information ================================================ Product Serial Number: 0 Long Production SN : 0 MCU SW Version : V 79u_sr2_12w20.8 20-08-12 RM-774 (c) Nokia RFIC Version : |Alli_4.3.4 DSP Version : 79u_sr2_12w20_2 APE BT Version : HCI Version 12 (rev. 64). LMP Version 36 (rev. 64). Manufacturer 3616. AHNE Version : 21 APE SW Core Version : 113.010.1506 Variant Version : 113.010.1506113.010.1506.04.01113.010.1506.C00.01 RETU Version : 40 TAHVO Version : 00 APE HW Version : 256 APE ADSP SW Version : 256 Wireless LAN ID : B0:35:8D:EA6:56 Bluetooth ID : B0:35:8D:EA:976 CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA II, WCDMA IV, WCDMA V, WCDMA VIII ================================================ Simlock Information ================================================ CONFIG KEY : 0000000000000000 PROVIDER KEY : 2440700000000000 NETWORK NAME : Nokia Default;Finland LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10 SIMLOCK TABLE : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK STATE : Not Locked SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : FAILED > Try SX4 "PM AUTH" > Then Write PM 1 and 309 SECURITY_CODE : ENCRYPTED PHONE_MODE : LOCAL DCC ID : NOT USED log sx: ================================================ Basic Phone Information ================================================ MCU Version: V 79u_sr2_12w20.8 20-08-12 RM-774 (c) Nokia IMEI Plain : 358272047952828 IMEI Spare : A358272047952820 IMEI SV : 33582720479528230F Phone Model: Nokia 701 Category : Classic Phone Phone Type : RM-774 ================================================ SX4 Custom Keys Stand Alone Edition ================================================ >>> : SX4 Auth Successfull Selected PM File: D:\rm-774 1.309.pm Start Uploading PM... Field : 1 Sub : 0 Byte(s): 10 - Ok Field : 1 Sub : 1 Byte(s): 94 - Ok Field : 1 Sub : 2 Byte(s): 110 - Ok Field : 1 Sub : 4 Byte(s): 10 - Ok Field : 1 Sub : 6 Byte(s): 110 - Ok Field : 1 Sub : 7 Byte(s): 450 - Ok Field : 1 Sub : 8 Byte(s): 10 - Ok Field : 1 Sub : 13 Byte(s): 110 - Ok Field : 1 Sub : 15 Byte(s): 30 - Ok Field : 1 Sub : 16 Byte(s): 30 - Ok Field : 1 Sub : 17 Byte(s): 30 - Ok Field : 1 Sub : 18 Byte(s): 30 - Ok Field : 1 Sub : 19 Byte(s): 30 - Ok Field : 1 Sub : 22 Byte(s): 24 - Ok Field : 1 Sub : 26 Byte(s): 10 - Ok Field : 1 Sub : 27 Byte(s): 36 - Ok Field : 1 Sub : 28 Byte(s): 110 - Ok Field : 1 Sub : 29 Byte(s): 10 - Ok Field : 1 Sub : 30 Byte(s): 36 - Ok Field : 1 Sub : 31 Byte(s): 24 - Ok Field : 1 Sub : 32 Byte(s): 216 - Ok Field : 1 Sub : 33 Byte(s): 36 - Ok Field : 1 Sub : 35 Byte(s): 24 - Ok Field : 1 Sub : 36 Byte(s): 24 - Ok Field : 1 Sub : 38 Byte(s): 216 - Ok Field : 1 Sub : 39 Byte(s): 36 - [Requires SX4] Field : 1 Sub : 40 Byte(s): 24 - [Requires SX4] Field : 1 Sub : 41 Byte(s): 216 - [Requires SX4] Field : 1 Sub : 43 Byte(s): 36 - [Requires SX4] Field : 1 Sub : 44 Byte(s): 216 - [Requires SX4] Field : 1 Sub : 45 Byte(s): 216 - [Requires SX4] Field : 309 Sub : 0 Byte(s): 4 - [Requires SX4] Field : 309 Sub : 1 Byte(s): 2 - [Requires SX4] Field : 309 Sub : 2 Byte(s): 12 - [Requires SX4] Field : 309 Sub : 3 Byte(s): 36 - [Requires SX4] Field : 309 Sub : 4 Byte(s): 12 - [Requires SX4] Field : 309 Sub : 7 Byte(s): 12 - [Requires SX4] Field : 309 Sub : 17 Byte(s): 12 - [Requires SX4] PM Upload Done!... |
08-05-2013, 20:27 | #3 (permalink) | |
No Life Poster Join Date: Nov 2007 Location: Dubai.
Member: 625961 Status: Offline Sonork: 100.1590447 Thanks Meter: 1,285 | Quote:
authorize phone and try to write sx4 auth, wil b ok ! if not contact me via sonork i can give pm! | |
08-05-2013, 21:31 | #4 (permalink) |
Member: 1470188 Status: Offline Sonork: 100.1638921 Thanks Meter: 88 | PHONE FIRMWARE VERSION: Reading NPC IMEI... 358272047952828 Connecting to The ATF Network Network Connection Accepted Requesting Authorization Code Authorization Code Received Verifying Authorization Code Authorization Code is OK Saving RSA Modulus Saving Authorization Code File Saving Complete!!! ================================================== ==== Phone was Successfully Authorized ================================================== ==== Decrypt PM 120, Super Dongle Repair and Stand Alone SX-4 is NOW ENABLED for this Phone. ================================================== ==== Thank you for using The ATF Network Time Taken to Complete Tasks: 00:00:13 |
11-19-2013, 12:04 | #5 (permalink) |
Freak Poster Join Date: Nov 2006
Member: 385979 Status: Offline Thanks Meter: 16 | Connecting to The ATF Network ERROR: Server Response Invalid or Rerouted 0x01 DDR PROTOCOL ERROR: Phone did not Ack !!! 0x01 Time Taken to Complete Tasks: 00:00:27 help pm 1-309 |
