05-11-2015, 11:24 | #1 (permalink) |
Freak Poster Join Date: Nov 2012 Location: I Don't Know
Member: 1836857 Status: Offline Sonork: Not In use. Thanks Meter: 73 | Nokia 710 can't repair boot need help. so i try with TP but got error. Connection all Ok. when i try to detect in emmc tool ots work perfect.but o don't know how to repair boot via direct emmc. |
05-14-2015, 06:47 | #4 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | What error occurs while repairing boot loader? Or you just don't know how to repair? If this is the case then read F.A.Q thread from Sticky. |
05-14-2015, 08:38 | #5 (permalink) | |
Member: 1836857 Status: Offline Sonork: Not In use. Thanks Meter: 73 | Can you able to see attached Image ? Quote:
05-22-2015, 17:23 | #9 (permalink) | |
Member: 1836857 Status: Offline Sonork: Not In use. Thanks Meter: 73 | @allumts Don't Answer Like A nursery school child . I Want To Reapir Boot But Got Error . Quote:
I also Follow Thread. http://forum.gsmhosting.com/vbb/f609...olved-1668949/ http://forum.gsmhosting.com/vbb/f609...epair-1673102/ BR Last edited by Rk mobile lab; 05-22-2015 at 17:30. | |
05-22-2015, 17:36 | #10 (permalink) |
Member: 1836857 Status: Offline Sonork: Not In use. Thanks Meter: 73 | If You Can See Attechment Then good. I Post Both Screen Shot From Tp Repair Error and Emmc Tab While I Detect Emmc. 1.I do Scan Emmc Emmc Show Ok. I can Read Dump (user Area) From Emmc.That Means Emmc Working. But I |
05-22-2015, 20:27 | #11 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Not is Complicate Search in Sticky thread F.A.Q. what read other thread that not are for you case? Here, directly in you handles: http://forum.gsmhosting.com/vbb/f609...tions-1127479/ Now not post here in which page is you solution, read and find Why you have this problem.... P.d. Quote:
BR allumts | |
05-23-2015, 05:13 | #12 (permalink) | |
Member: 1836857 Status: Offline Sonork: Not In use. Thanks Meter: 73 | @ATF Team Why This Men Is Missguiding Me ? I want to Know Why This Error Come and How To Solve Quote:
you really spam in my thread. Error: EMMC_SEND_TXT_CSD (CMD8) 0X03 Search In Forum If you found This error Solution link here. Otherwise plz leave thread. i will wait untill team give some time Last edited by Rk mobile lab; 05-23-2015 at 05:19. | |
05-23-2015, 10:50 | #13 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | @RK_mobile_lab, Remember that i never Misguide anybody. From now you will remain w/o answer becouse own Good P.Supporter, @Angel have just answer to you, here: Quote:
So, isn't more one my problem, solve by yourself all you issue. Remember that in the life when you are receiving HELP thanked and learns to be more humble with all, Good lucky | |
05-23-2015, 11:29 | #14 (permalink) | ||
Member: 1836857 Status: Offline Sonork: Not In use. Thanks Meter: 73 | @i again reply you. Quote:
Ans. error I already Posted With Logs And Screen Shot. Check Post #1 and #5. Or you just don't know how to repair? I know how to repair boot and also repair boot Many nokia lumia 710 successfully Via TP. If this is the case then read F.A.Q thread from Sticky. I read all them but no Solution Posted Yet For This Problem. Quote:
ATF Supporter and Team When Have time ,then they Check My Problem.I Not Force Any One. | ||
03-18-2016, 15:05 | #15 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 33
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Nokia Lumia 710 Boot repair problem ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 90014A48594E4958205D086E7DC84F8D CSD : D04F01320F5903FFFFFFFFEF8A400061 eMMC Boot Information Revision 1.5 (for MMC v4.41) BOOT PARTITION : USER AREA PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3584 KB HC ERASE GROUP SIZE: 8192 KB USER AREA SIZE : 7759462400 BYTES BOOT PARTITION SIZE: 2048 KB RPMB PARTITION SIZE: 2048 KB Lumia 710 Detected eMMC Device Information Manufacturer ID: HYNIX Device Type : Embedded BGA Application ID : 4A Product Name : HYNIX Product Rev : 5.13 Product SN : 086E7DC8 Manufactured : January 2012 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 300 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 90014A48594E4958205D086E7DC84F8D.ext_csd Backup Directory: D:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ Writing MBR... Write Success! Writing DBL... ERROR: Block Write Failed at 0x00000002 Check your Test Point Soldering! ERROR: WRITE FAILED! Total Elapsed Time 00:00:01 Which tp connection actually problem? |
