05-26-2014, 16:28 | #1 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Romania, Bistrita Age: 70
Member: 85467 Status: Offline Thanks Meter: 104 | Nokia 710 driver? how install driver for nokia 210, run all driver from support, also manual update driver but "cannot install this hardware" 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... Infineon USB Boot: F00A1FB300020303010100FF Sending PBL... PBL Successfully Sent... Sending SBL... SBL Successfully Sent... Setting Transmission Speed Done... Flash Chip Manufacturer: Intel Electronics Corp. Flash Boot Successful... Unique Data: 1220100225122829 Reading : HWC... OK! Reading : NPC... OK! RPL Backup was Successful... Plain RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\356326050109130\3563260501091 30_62047.rpl Certificate Block Saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\356326050109130\3563260501091 30_CERTIFICATE_0FE357D3.bin Infineon USB Buscheck Done Phone Restart Mode: TEST MODE Process Done... Scanning USB Ports... ================================================== ==== ERROR: Active Phone Handle was NOT DETECTED ================================================== ==== TIP: Make sure that Phone USB Connection Mode is OVI Suite Mode or PC Suite Mode ================================================== ==== ERROR: Read Phone Failed! thx |
05-26-2014, 17:37 | #2 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Give this path: "C:\AdvanceBox Turbo Flasher\Drivers\Lumia and asha phones drivers |
The Following User Says Thank You to ..::Angel::.. For This Useful Post: |
05-27-2014, 10:24 | #5 (permalink) |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | 1. C:\AdvanceBox Turbo Flasher\Driver\Nokia_Connectivity_Cable_Driver_7.1 .182.0.msi 2. C:\AdvanceBox Turbo Flasher\Driver\WinUSB\ 3. If still ask drivers, then this path: C:\AdvanceBox Turbo Flasher\Driver\Lumia and Asha Phone Drivers BR |
