02-04-2020, 18:59 | #1 (permalink) |
No Life Poster Join Date: Mar 2016 Location: MWA
Member: 2541648 Status: Offline Thanks Meter: 166 | Nokia 7310c Unlock Succes Just Want To Show You ATF Team that Am Still Using My Box Thanks Booting Phone via FBUS... VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done AdvanceBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ************************************************** **** TIME STARTS HERE ************************************************** **** BootFlashModeDCT5Ex Succeeded after 4 Attempts SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 030C1921 ID DWORD 4 : 01033000 2 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000295 3 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 1970010D ID DWORD 1 : 19D25850 ID DWORD 2 : 75DC6DD6 ID DWORD 3 : C5B1766C ID DWORD 4 : 2556AFE4 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 273F6D55 CRC 1 : DFAAF68F Checksum 82 SearchForBootstrap_DCT5.. C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg Boot File - Version 010.042.00 Boot File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : 03 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0089 -> Device ID : 8982 -> NU48F512 Extended/Fixed ID : 0000 Revision ID : 8A31 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 00000000000000000000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 51 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :0089 DevID :8982 ExtID :0000 RevID :8A31 Flash Descriptor Manufacturer Code : 0089 Device ID : 8982 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 04000000 (64 MB) VPP Info : 0009 Erase10s : 28 Block1s : 64 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPPInfo : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg Algorithm File - Version 010.040.00 Algorithm File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) ============================================ OLD Protocol Detected... Using Turbo Mode... ============================================ PAPUB_KEYS_HASH_REQ_BB5 PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: 1C4FF759B84A261249E1BBE6F8B6CED06F54373D =========================================== PHONE FIRMWARE VERSION: V 08.20 12-06-08 RM-379 (c) Nokia =========================================== Scanning Simlock Applet Type... OK ================================================= SL1/SL2 Applet detected ================================================= ================================================ Basic Phone Information ================================================ MCU Version: V 08.20 12-06-08 RM-379 (c) Nokia IMEI Plain : 354151023081931 IMEI Spare : A354151023081930 IMEI SV : 33541510230819350F Phone Model: Nokia 7310 Supernova Category : Lifestyle Phone Phone Type : RM-379 ================================================ Extended Phone Information ================================================ Product Serial Number: KMG864897 Product Code : 0568658 Module Code : 0203645 Basic Production Code: 0553924 Long Production SN : 0 PPM SW Version : V 08.20 12-06-08 RM-379 (c) Nokia C BT MCM Version : 2222-143 MCU SW Version : V 08.20 12-06-08 RM-379 (c) Nokia HW Version : 2001 RFIC Version : 064c0609 DSP Version : ICPR71_08w22 LCD Version : SEIKO Content Pack Version : Content: c_o2_ie V 08.20 12-06-08 RM-379 (c) Nokia AHNE Version : 30 RETU Version : 15 TAHVO Version : 22 Bluetooth ID : 00:21:08:82:21:B9 CS Type : GSM900, GSM1800, GSM1900 ================================================ Simlock Information ================================================ CONFIG KEY : 8000000000000000 PROVIDER KEY : 2720200000000000 NETWORK NAME : O2 Ireland;Ireland [GSM] LOCK COUNTERS : KEYPRESS 0/3, FBUS 1/10 SIMLOCK TABLE : Block [1] 1:Close SIMLOCK STATE : LOCKED SIMLOCK_TYPE : PA_SL2 SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED PHONE_MODE : TEST ================================================ Dynamic Camera Configuration ================================================ DCC ID : NIMMIIIIRRFF094B2F01 DCC Ver: 002009 Status : OK Make sure you have installed the COMPLETE Flash Package for this Phone... Goto "Settings" --> "Nokia Settings" and verify that the Folder where you installed your Flash Files are in the "PRODUCT PATH TO SCAN" List... ================================================ Basic Phone Information ================================================ MCU Version: V 08.20 12-06-08 RM-379 (c) Nokia IMEI Plain : 354151023081931 IMEI Spare : A354151023081930 IMEI SV : 33541510230819350F Phone Model: Nokia 7310 Supernova Category : Lifestyle Phone Phone Type : RM-379 Changing MODE : FLASH Booting Phone via FBUS... BOOTING BB5 Phone... ************************************************** **** TIME STARTS HERE ************************************************** **** CMT Hardware : 030C192101033000 CMT PUBLIC ID : 1970010D19D2585075DC6DD6C5B1766C2556AFE4 CMT ROOTHASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM_ID : 273F6D55DFAAF68F Send Loader... Custom Loader Running! Restarting phone, please wait .. . VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Forcing Test Mode via BUSCHECK... Booting Phone via FBUS... VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done AdvanceBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ************************************************** **** TIME STARTS HERE ************************************************** **** BootFlashModeDCT5Ex Succeeded after 4 Attempts SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 030C1921 ID DWORD 4 : 01033000 2 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000295 3 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 1970010D ID DWORD 1 : 19D25850 ID DWORD 2 : 75DC6DD6 ID DWORD 3 : C5B1766C ID DWORD 4 : 2556AFE4 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 273F6D55 CRC 1 : DFAAF68F Checksum 82 SearchForBootstrap_DCT5.. C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg Boot File - Version 010.042.00 Boot File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : 03 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0089 -> Device ID : 8982 -> NU48F512 Extended/Fixed ID : 0000 Revision ID : 8A31 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 00000000000000000000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 51 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :0089 DevID :8982 ExtID :0000 RevID :8A31 Flash Descriptor Manufacturer Code : 0089 Device ID : 8982 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 04000000 (64 MB) VPP Info : 0009 Erase10s : 28 Block1s : 64 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPPInfo : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg Algorithm File - Version 010.040.00 Algorithm File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) PAPUB_KEYS_HASH_REQ_BB5 PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: 1C4FF759B84A261249E1BBE6F8B6CED06F54373D =========================================== PHONE FIRMWARE VERSION: V 08.20 12-06-08 RM-379 (c) Nokia =========================================== Scanning Simlock Applet Type... OK ================================================= SL1/SL2 Applet detected ================================================= Waiting for Phone to Go Online... Elapsed Time: 1s Elapsed Time: 2s Elapsed Time: 3s Elapsed Time: 4s Elapsed Time: 5s Elapsed Time: 6s Elapsed Time: 7s Elapsed Time: 8s Elapsed Time: 9s Elapsed Time: 10s ================================================ Basic Phone Information ================================================ MCU Version: V 08.20 12-06-08 RM-379 (c) Nokia IMEI Plain : 354151023081931 IMEI Spare : A354151023081930 IMEI SV : 33541510230819350F Phone Model: Nokia 7310 Supernova Category : Lifestyle Phone Phone Type : RM-379 ================================================ Extended Phone Information ================================================ Product Serial Number: KMG864897 Product Code : 0568658 Module Code : 0203645 Basic Production Code: 0553924 Long Production SN : 0 PPM SW Version : V 08.20 12-06-08 RM-379 (c) Nokia C ================================================ Simlock Information ================================================ Unable to read SP Data.. Waiting for Phone to Go Online... Elapsed Time: 1s Elapsed Time: 2s Elapsed Time: 3s Elapsed Time: 4s Elapsed Time: 5s Elapsed Time: 6s Elapsed Time: 7s Elapsed Time: 8s Elapsed Time: 9s Elapsed Time: 10s ================================================ Basic Phone Information ================================================ MCU Version: V 08.20 12-06-08 RM-379 (c) Nokia IMEI Plain : 354151023081931 IMEI Spare : A354151023081930 IMEI SV : 33541510230819350F Phone Model: Nokia 7310 Supernova Category : Lifestyle Phone Phone Type : RM-379 ================================================ Extended Phone Information ================================================ Product Serial Number: KMG864897 Product Code : 0568658 Module Code : 0203645 Basic Production Code: 0553924 Long Production SN : 0 PPM SW Version : V 08.20 12-06-08 RM-379 (c) Nokia C BT MCM Version : 2222-143 MCU SW Version : V 08.20 12-06-08 RM-379 (c) Nokia HW Version : 2001 RFIC Version : 064c0609 DSP Version : ICPR71_08w22 LCD Version : SEIKO Content Pack Version : Content: c_o2_ie V 08.20 12-06-08 RM-379 (c) Nokia AHNE Version : 30 RETU Version : 15 TAHVO Version : 22 Bluetooth ID : 00:21:08:82:21:B9 CS Type : GSM900, GSM1800, GSM1900 ================================================ Simlock Information ================================================ CONFIG KEY : 8000000000000000 PROVIDER KEY : 2720200000000000 NETWORK NAME : O2 Ireland;Ireland [GSM] LOCK COUNTERS : KEYPRESS 0/3, FBUS 1/10 SIMLOCK TABLE : Block [1] 1:Close SIMLOCK STATE : LOCKED SIMLOCK_TYPE : PA_SL2 SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED PHONE_MODE : TEST ================================================ Dynamic Camera Configuration ================================================ DCC ID : NIMMIIIIRRFF094B2F01 DCC Ver: 002009 Status : OK ================================================ SL1/SL2 Simlock RPL Stand Alone Edition ================================================ Generating Simlock Data RPL... OK: Simlock RPL Accepted ================================================ Basic Phone Information ================================================ MCU Version: V 08.20 12-06-08 RM-379 (c) Nokia IMEI Plain : 354151023081931 IMEI Spare : A354151023081930 IMEI SV : 33541510230819350F Phone Model: Nokia 7310 Supernova Category : Lifestyle Phone Phone Type : RM-379 ================================================ Extended Phone Information ================================================ Product Serial Number: KMG864897 Product Code : 0568658 Module Code : 0203645 Basic Production Code: 0553924 Long Production SN : 0 PPM SW Version : V 08.20 12-06-08 RM-379 (c) Nokia C BT MCM Version : 2222-143 MCU SW Version : V 08.20 12-06-08 RM-379 (c) Nokia HW Version : 2001 RFIC Version : 064c0609 DSP Version : ICPR71_08w22 LCD Version : SEIKO Content Pack Version : Content: c_o2_ie V 08.20 12-06-08 RM-379 (c) Nokia AHNE Version : 30 RETU Version : 15 TAHVO Version : 22 Bluetooth ID : 00:21:08:82:21:B9 CS Type : GSM900, GSM1800, GSM1900 ================================================ Simlock Information ================================================ CONFIG KEY : 0000000000000000 PROVIDER KEY : 2440700000000000 NETWORK NAME : Nokia Default;Finland LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10 SIMLOCK TABLE : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK STATE : Not Locked SIMLOCK_TYPE : PA_SL2 SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED CMLA_KEY : PASSED SUPER_DONGLE_TEST : PASSED ================================================ SL1/SL2 Phone detected ================================================ PHONE_MODE : TEST ================================================ Dynamic Camera Configuration ================================================ DCC ID : NIMMIIIIRRFF094B2F01 DCC Ver: 002009 Status : OK Successfully done. |
