Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 11-21-2013, 09:06   #1 (permalink)
Member: 973227
Sonork: 100.1583121
Thanks Meter: 270
nokia 808 rm-807 local mode issue
hi sir
nokia 808 came to me for logo restart issue
i have flashed with latest firmware file 113.010.1508
but still it was restarting
so i have fully backup phone
erased and flashed
phone now turned on
issue is i can restore rpl backup only but not the security units
because phone not entering the LOCAL MODE , not works with special local mode cable
i read on forum it need ENO file
but ENO file is not available for this model
anybody can guide me for this?
how can i restore sp data?
thank you
Old 11-21-2013, 09:51   #2 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Thanks Meter: 10,300
Originally Posted by sureshshetty View Post
hi sir
erased and flashed
phone now turned on
thank you
Attach your PM backup here
Br - srinibas
The Following User Says Thank You to srinibas For This Useful Post:
Old 11-22-2013, 06:02   #3 (permalink)
Member: 973227
Sonork: 100.1583121
Thanks Meter: 270
hi
sir here is pm backup
351965050333805_RM-807_0-400_34914 - Download - 4shared - suresh shetty
thank you sir for reply
Old 11-22-2013, 11:07   #4 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Thanks Meter: 16,531
Hi, you can use my old method to repair this phone which does not requires ENO
Here is the link: Nokia E7-00, X7-00, E6-00 Downgrade to Anna Firmware:
BTW, You can also repair CMLA KEY with ONLY ATF Box
The Following User Says Thank You to ..::Angel::.. For This Useful Post:
Old 11-22-2013, 11:57   #5 (permalink)
Member: 973227
Sonork: 100.1583121
Thanks Meter: 270
nice..
sir your link helped me
with selected OVI SUITE
i could upload pm and now phone is normal working fine
16:49:37 : TIP: Make sure that Phone USB Connection Mode is
16:49:37 : OVI Suite Mode
16:49:37 : or
16:49:37 : PC Suite Mode
16:49:37 :
16:49:37 : ======================================================
16:54:10 : Selected PM File: C:\AdvanceBox Turbo Flasher\Nokia\Backup\351965050333805\351965050333805_RM-807_0-400_34914.pm
16:54:10 : Start Uploading PM...
16:54:10 :
16:54:10 : Scanning USB Ports...
16:54:10 :
16:54:10 : ================================================
16:54:10 :             Basic Phone Information
16:54:10 : MCU Version: V 79u_sr2_12w20.10 12-10-12 RM-807 (c) Nokia
16:54:10 : IMEI Plain : 12345610654321?
16:54:10 : IMEI Spare : A123456106543210
16:54:10 : IMEI SV    : 31234561065432132F
16:54:10 : Phone Model: Nokia 808 PureView
16:54:10 : Category   : Classic Phone
16:54:10 : Phone Type : RM-807
16:54:10 :
16:54:10 :
16:54:10 : Field : 1 Sub : 0 Byte(s): 12  - Ok
16:54:10 : Field : 1 Sub : 1 Byte(s): 96  - Ok
16:54:10 : Field : 1 Sub : 2 Byte(s): 112  - Ok
16:54:10 : Field : 1 Sub : 4 Byte(s): 12  - Ok
16:54:10 : Field : 1 Sub : 6 Byte(s): 112  - Ok
16:54:10 : Field : 1 Sub : 7 Byte(s): 452  - Ok
16:54:11 : Field : 1 Sub : 8 Byte(s): 12  - Ok
16:54:11 : Field : 1 Sub : 13 Byte(s): 112  - Ok
16:54:11 : Field : 1 Sub : 15 Byte(s): 32  - Ok
16:54:11 : Field : 1 Sub : 16 Byte(s): 32  - Ok
16:54:11 : Field : 1 Sub : 17 Byte(s): 32  - Ok
16:54:11 : Field : 1 Sub : 18 Byte(s): 32  - Ok
16:54:11 : Field : 1 Sub : 19 Byte(s): 32  - Ok
16:54:11 : Field : 1 Sub : 22 Byte(s): 24  - Ok
16:54:11 : Field : 1 Sub : 26 Byte(s): 12  - Ok
16:54:11 : Field : 1 Sub : 27 Byte(s): 36  - Ok
16:54:11 : Field : 1 Sub : 28 Byte(s): 112  - Ok
16:54:11 : Field : 1 Sub : 29 Byte(s): 12  - Ok
16:54:11 : Field : 1 Sub : 30 Byte(s): 36  - Ok
16:54:11 : Field : 1 Sub : 31 Byte(s): 24  - Ok
16:54:11 : Field : 1 Sub : 32 Byte(s): 216  - Ok
16:54:11 : Field : 1 Sub : 33 Byte(s): 36  - Ok
16:54:11 : Field : 1 Sub : 35 Byte(s): 24  - Ok
16:54:11 : Field : 1 Sub : 36 Byte(s): 24  - Ok
16:54:11 : Field : 1 Sub : 38 Byte(s): 216  - Ok
16:54:11 : Field : 1 Sub : 39 Byte(s): 36  - Ok
16:54:11 : Field : 1 Sub : 40 Byte(s): 24  - Ok
16:54:11 : Field : 1 Sub : 41 Byte(s): 216  - Ok
16:54:11 : Field : 1 Sub : 43 Byte(s): 36  - Ok
16:54:11 : Field : 1 Sub : 44 Byte(s): 216  - Ok
16:54:11 : Field : 1 Sub : 45 Byte(s): 216  - Ok
16:54:11 : Field : 2 Sub : 0 Byte(s): 2808  - Ok
16:54:11 : Field : 4 Sub : 1 Byte(s): 200  - Ok
16:54:11 : Field : 4 Sub : 3 Byte(s): 12  - Ok
16:54:11 : Field : 4 Sub : 4 Byte(s): 8  - Ok
16:54:11 : Field : 4 Sub : 5 Byte(s): 8  - Ok
16:54:11 : Field : 4 Sub : 9 Byte(s): 8  - Ok
16:54:11 : Field : 4 Sub : 28 Byte(s): 4  - Ok
16:54:11 : Field : 8 Sub : 0 Byte(s): 4  - Ok
16:54:11 : Field : 8 Sub : 3 Byte(s): 128  - Ok
16:54:11 : Field : 8 Sub : 4 Byte(s): 128  - Ok
16:54:11 : Field : 8 Sub : 8 Byte(s): 8  - Ok
16:54:11 : Field : 11 Sub : 0 Byte(s): 4  - Ok
16:54:11 : Field : 11 Sub : 1 Byte(s): 4  - Ok
16:54:11 : Field : 11 Sub : 2 Byte(s): 4  - Ok
16:54:11 : Field : 11 Sub : 3 Byte(s): 4  - Ok
16:54:11 : Field : 11 Sub : 4 Byte(s): 1064  - Ok
16:54:11 : Field : 12 Sub : 0 Byte(s): 8  - Ok
16:54:11 : Field : 31 Sub : 4 Byte(s): 20  - Ok
16:54:11 : Field : 44 Sub : 0 Byte(s): 4  - Ok
16:54:11 : Field : 50 Sub : 0 Byte(s): 4  - Ok
16:54:11 : Field : 50 Sub : 1 Byte(s): 4  - Ok
16:54:11 : Field : 54 Sub : 0 Byte(s): 4  - Ok
16:54:11 : Field : 54 Sub : 2 Byte(s): 24  - Ok
16:54:11 : Field : 96 Sub : 0 Byte(s): 4  - Ok
16:54:11 : Field : 96 Sub : 1 Byte(s): 20  - Ok
16:54:11 : Field : 107 Sub : 26 Byte(s): 12  - Ok
16:54:11 : Field : 120 Sub : 0 Byte(s): 944  - Ok
16:54:12 : Field : 120 Sub : 1 Byte(s): 160  - Ok
16:54:12 : Field : 120 Sub : 2 Byte(s): 132  - Ok
16:54:12 : Field : 120 Sub : 3 Byte(s): 112  - Ok
16:54:12 : Field : 122 Sub : 0 Byte(s): 4  - Ok
16:54:12 : Field : 193 Sub : 2 Byte(s): 8  - Ok
16:54:12 : Field : 193 Sub : 3 Byte(s): 32  - Ok
16:54:12 : Field : 193 Sub : 4 Byte(s): 32  - Ok
16:54:12 : Field : 193 Sub : 9 Byte(s): 64  - Ok
16:54:12 : Field : 217 Sub : 0 Byte(s): 32  - Ok
16:54:12 : Field : 239 Sub : 0 Byte(s): 4  - Ok
16:54:12 : Field : 239 Sub : 1 Byte(s): 6268  - Ok
16:54:12 : Field : 239 Sub : 2 Byte(s): 6268  - Ok
16:54:12 : Field : 239 Sub : 3 Byte(s): 6268  - Ok
16:54:12 : Field : 239 Sub : 4 Byte(s): 6268  - Ok
16:54:12 : Field : 239 Sub : 5 Byte(s): 6268  - Ok
16:54:12 : Field : 239 Sub : 6 Byte(s): 228  - Ok
16:54:12 : Field : 296 Sub : 0 Byte(s): 4  - Ok
16:54:12 : Field : 296 Sub : 1 Byte(s): 4  - Ok
16:54:12 : Field : 296 Sub : 2 Byte(s): 24  - Ok
16:54:12 : Field : 296 Sub : 3 Byte(s): 8  - Ok
16:54:12 : Phone Not Authorized, PM 308 Skipped...
16:54:12 : Field : 309 Sub : 0 Byte(s): 4  - Ok
16:54:12 : Field : 309 Sub : 1 Byte(s): 4  - Ok
16:54:12 : Field : 309 Sub : 2 Byte(s): 12  - Ok
16:54:12 : Field : 309 Sub : 3 Byte(s): 36  - Ok
16:54:12 : Field : 309 Sub : 4 Byte(s): 12  - Ok
16:54:12 : Field : 309 Sub : 7 Byte(s): 12  - Ok
16:54:12 : Field : 309 Sub : 17 Byte(s): 12  - Ok
16:54:12 : Field : 313 Sub : 0 Byte(s): 800  - Ok
16:54:12 : Field : 322 Sub : 0 Byte(s): 4  - Ok
16:54:12 : Field : 334 Sub : 0 Byte(s): 4  - Ok
16:54:12 : Field : 341 Sub : 0 Byte(s): 4  - Ok
16:54:12 : Field : 341 Sub : 3 Byte(s): 4  - Ok
16:54:12 : Field : 341 Sub : 4 Byte(s): 4528  - Ok
16:54:12 : Field : 341 Sub : 12 Byte(s): 328  - Ok
16:54:12 : Field : 341 Sub : 15 Byte(s): 940  - Ok
16:54:12 : Field : 354 Sub : 0 Byte(s): 16  - Ok
16:54:12 : Field : 356 Sub : 0 Byte(s): 4  - Ok
16:54:12 : Field : 360 Sub : 0 Byte(s): 4  - Ok
16:54:12 : Field : 360 Sub : 1 Byte(s): 4  - Ok
16:54:12 : Field : 369 Sub : 0 Byte(s): 40  - Ok
16:54:13 : Field : 382 Sub : 0 Byte(s): 64  - Ok
16:54:13 : Field : 382 Sub : 1 Byte(s): 4  - Ok
16:54:13 : Field : 388 Sub : 0 Byte(s): 4  - Ok
16:54:13 : Field : 389 Sub : 0 Byte(s): 4  - Ok
16:54:13 : Field : 389 Sub : 1 Byte(s): 4  - Ok
16:54:13 : Field : 389 Sub : 2 Byte(s): 8  - Ok
16:54:13 : Field : 389 Sub : 3 Byte(s): 4  - Ok
16:54:13 : Field : 389 Sub : 4 Byte(s): 12  - Ok
16:54:13 : Field : 389 Sub : 5 Byte(s): 8  - Ok
16:54:13 : Field : 389 Sub : 7 Byte(s): 4  - Ok
16:54:13 : Field : 389 Sub : 8 Byte(s): 4  - Ok
16:54:13 : Field : 389 Sub : 21 Byte(s): 80  - Ok
16:54:13 : Field : 395 Sub : 0 Byte(s): 16  - Ok
16:54:13 : PM  Upload Done!...
thank you so much
sir Angel
Page generated in 0.26266 seconds with 7 queries
