06-20-2013, 10:38 | #1 (permalink) |
Freak Poster Join Date: Nov 2010 Location: Sri Lanka Age: 46
Member: 1455973 Status: Offline Thanks Meter: 6 | Nokia 808 Rm-807 security test fail - [SOLVED] Above phone successfully flashed with ATF all ok but phone boot up it says contact reseller start up fail then I check with ATf self test all ok but security check fail.I searched for .pm but not found also note phone came with drop damage.Pls tell me a solution to overcome the issue or if any one have .pm file Pls upload. |
06-20-2013, 11:34 | #2 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Quote:
Same time Scan the phone now & post the log Br - srinibas | |
06-20-2013, 15:36 | #5 (permalink) |
Member: 1455973 Status: Offline Thanks Meter: 6 | Pls find below ================================================ 12:10:47 : Advance Turbo Flasher Found 12:10:47 : ================================================ 12:10:47 : Driver Version : 00020422 12:10:47 : Library Version : 00030119 12:10:49 : Box Type : AdvanceBox Turbo 12:10:49 : Box Firmware : LogiCore 10.3.50 12:10:49 : Software Version : v9.90 12:10:49 : AdvanceBox SN : A8794 12:10:49 : Box Status : ACTIVATED 12:10:49 : ================================================ 12:10:49 : Box Successfully Initialized 12:10:49 : ================================================ 12:10:49 : 12:10:49 : VBATT Powering Down <<<< 12:10:53 : VBATT Powering Up >>>> 12:10:53 : SET VCCIO Level Done 12:10:53 : SET BSI Load Done 12:10:53 : 12:10:53 : 12:10:53 : 12:10:53 : ///////// /// /// /////// /////// ///////// 12:10:53 : /// /// /// /// // /// /// /// /// 12:10:53 : /// /// /// /////// /////// /// /// 12:10:53 : /// /// /// /// /// /// /// /// /// 12:10:53 : /// ///// /// /// /////// ////// 12:10:53 : 12:10:53 : ======================================= 12:10:53 : /// /// /// ///////// /////// ////// 12:10:53 : ///// /// /// /// /// // /// /// 12:10:53 : /// ///// /// /// /////// /// /// 12:10:53 : /// //// /// /// /// /// /// /// 12:10:53 : /// /// /// /// /// /// ////// 12:10:53 : ======================================= 12:10:53 : 12:11:13 : 12:11:13 : Make sure you have installed the 12:11:13 : COMPLETE Flash Package for this Phone... 12:11:13 : 12:11:13 : Goto "Settings" --> "Nokia Settings" and verify that 12:11:13 : the Folder where you installed your Flash Files are 12:11:13 : in the "PRODUCT PATH TO SCAN" List... 12:16:18 : 12:16:18 : ================================================== ==== 12:16:18 : Selected VPL File: 12:16:18 : RM807_059M9K4_113.010.1507_018.vpl 12:16:18 : ================================================== ==== 12:16:18 : Variant Details : ndt_seap_apac2_lk_black 12:16:18 : Software Version : 113.010.1507 12:16:18 : Product Type : RM-807 12:16:18 : Product Code : 059M9K4 12:16:18 : Variant Version : 018 12:16:18 : 12:16:28 : 12:16:28 : ================================================== ==== 12:16:28 : Flash File Checksum Verification 12:16:28 : ================================================== ==== 12:16:29 : RM-807_113.010.1507_79u_prd.core.fpsx: CHECKSUM PASSED 12:16:29 : RM-807_113.010.1507_C00.01_79u_prd.rofs3.fpsx: CHECKSUM PASSED 12:16:30 : RM-807_113.010.1507_14.01_APAC_2_79u_prd.rofs2.fpsx: CHECKSUM PASSED 12:16:34 : RM-807_113.010.1507_U01.01_79u.uda.fpsx: CHECKSUM PASSED 12:16:34 : ================================================== ==== 12:16:34 : Verification Done... 12:18:20 : 12:18:20 : FACTORY SET TO : Full Factory Set 12:18:20 : OK 12:18:20 : FACTORY SET TO : User Data 12:18:20 : OK 12:18:20 : FACTORY SET TO : Leave Factory 12:18:20 : OK 12:18:20 : FACTORY SET TO : Service Center 12:18:20 : OK 12:18:20 : FACTORY SET TO : Software Upgrade 12:18:20 : OK 12:18:20 : FACTORY SET TO : Production Tune 12:18:20 : OK 12:18:20 : 12:18:20 : 12:18:20 : RESET LIFE TIMER TO : 0000:00 12:18:20 : OK 12:18:30 : 12:18:30 : Scanning USB Ports... 12:18:30 : 12:18:30 : ================================================ 12:18:30 : Basic Phone Information 12:18:30 : ================================================ 12:18:30 : MCU Version: V 79u_sr2_12w20.9 19-09-12 RM-807 (c) Nokia 12:18:30 : IMEI Plain : 351********** 12:18:30 : IMEI Spare : A3519*** 12:18:30 : IMEI SV : 3351********* 12:18:30 : Phone Model: Nokia 808 PureView 12:18:30 : Category : Classic Phone 12:18:30 : Phone Type : RM-807 12:18:30 : 12:18:30 : 12:18:30 : Checking Available Drives... 12:18:30 : 12:18:30 : 12:18:35 : 12:18:35 : Scanning USB Ports... 12:18:35 : |
06-20-2013, 15:40 | #6 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | These are not Scan Phone logs neither Bus Check. You will find "Bus Check" button next to Backup RPL button on the top of right corner, lower it - you will see "Scan Phone" button. Click on these two buttons one by one and post the logs here. BR |
06-20-2013, 15:49 | #7 (permalink) |
Member: 1455973 Status: Offline Thanks Meter: 6 | Sorry, ================================================== ==== 20:15:11 : Selected VPL File: 20:15:11 : RM807_059M9K4_113.010.1507_018.vpl 20:15:11 : ================================================== ==== 20:15:11 : Variant Details : ndt_seap_apac2_lk_black 20:15:11 : Software Version : 113.010.1507 20:15:11 : Product Type : RM-807 20:15:11 : Product Code : 059M9K4 20:15:11 : Variant Version : 018 20:15:11 : 20:15:15 : Booting Phone via FBUS... 20:15:15 : 20:15:16 : VBATT Powering Down <<<< 20:15:20 : VBATT Powering Up >>>> 20:15:21 : SET VCCIO Level Done 20:15:21 : SET BSI Load Done 20:15:23 : VBATT Powering Down <<<< 20:15:28 : VBATT Powering Up >>>> 20:15:28 : SET VCCIO Level Done 20:15:28 : SET BSI Load Done 20:15:30 : VBATT Powering Down <<<< 20:15:31 : BootFlashModeDCT5Ex Failed 20:15:31 : ERROR: FBUS Boot FAILED 20:15:49 : Booting Phone via USB... 20:16:01 : 20:16:02 : 20:16:02 : Scanning USB Ports... 20:16:05 : 20:16:05 : ================================================ 20:16:05 : Basic Phone Information 20:16:05 : ================================================ 20:16:05 : MCU Version: V 79u_sr2_12w20.9 19-09-12 RM-807 (c) Nokia 20:16:05 : IMEI Plain : 35******** 20:16:05 : IMEI Spare : A351**** 20:16:05 : IMEI SV : 335*** 20:16:05 : Phone Model: Nokia 808 PureView 20:16:05 : Category : Classic Phone 20:16:05 : Phone Type : RM-807 20:16:05 : 20:16:05 : ================================================ 20:16:05 : Extended Phone Information 20:16:05 : ================================================ 20:16:05 : Product Serial Number: C7G80*** 20:16:05 : Product Code : 059M9K4 20:16:05 : Basic Production Code: 059K393 20:16:05 : Long Production SN : 0 20:16:05 : MCU SW Version : V 79u_sr2_12w20.9 19-09-12 RM-807 (c) Nokia 20:16:05 : HW Version : 4010 20:16:05 : RFIC Version : |Alli_4.b.1 20:16:05 : DSP Version : 79u_sr2_12w20_2 20:16:05 : APE BT Version : HCI Version 4 (rev. 0). LMP Version 4 (rev. 7455). Manufacturer 13. 20:16:05 : AHNE Version : 21 20:16:05 : APE SW Core Version : 113.010.1507 20:16:05 : Variant Version : 113.010.1507113.010.1507.14.01113.010.1507.C00.01 20:16:05 : APE Test Version : 0.044 20:16:05 : RETU Version : 35 20:16:05 : TAHVO Version : 00 20:16:05 : APE HW Version : 256 20:16:05 : APE ADSP SW Version : 256 20:16:05 : Wireless LAN ID : D0B:32:AC:9F:F7 20:16:05 : Bluetooth ID : D0B:32:A7:BD:F7 20:16:05 : CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA II, WCDMA IV, WCDMA V, WCDMA VIII 20:16:05 : 20:16:05 : ================================================ 20:16:05 : Simlock Information 20:16:05 : ================================================ 20:16:05 : CONFIG KEY : 0000000000000000 20:16:05 : PROVIDER KEY : 2440700000000000 20:16:05 : NETWORK NAME : Nokia Default;Finland 20:16:05 : LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10 20:16:05 : SIMLOCK TABLE : 20:16:05 : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open 20:16:05 : Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open 20:16:05 : Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open 20:16:05 : Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open 20:16:05 : Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open 20:16:05 : Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open 20:16:05 : Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open 20:16:05 : SIMLOCK STATE : Not Locked 20:16:05 : 20:16:05 : SIMLOCK_TYPE : PA_SL3 (15-digit NCK) 20:16:05 : SIMLOCK_TEST : PASSED 20:16:05 : SECURITY_TEST : FAILED 20:16:05 : > Try SX4 "PM AUTH" 20:16:05 : > Then Write PM 1 and 309 20:16:05 : SECURITY_CODE : ENCRYPTED 20:16:05 : PHONE_MODE : TEST 20:16:05 : DCC ID : NOT USED 20:16:05 : 20:16:06 : 20:16:06 : ================================================== ==== 20:16:06 : Selected VPL File: 20:16:06 : RM807_059M9K4_113.010.1507_018.vpl 20:16:06 : ================================================== ==== 20:16:06 : Variant Details : ndt_seap_apac2_lk_black 20:16:06 : Software Version : 113.010.1507 20:16:06 : Product Type : RM-807 20:16:06 : Product Code : 059M9K4 20:16:06 : Variant Version : 018 20:16:06 : |
06-20-2013, 17:47 | #10 (permalink) |
Member: 1455973 Status: Offline Thanks Meter: 6 | Pls find below sir, ================================================== ==== 22:13:33 : ================================================== ==== 22:13:33 : USB Phone BUSCheck Boot 22:13:33 : ================================================== ==== 22:13:33 : ================================================== ==== 22:13:33 : Then Perform Steps 1, 2, 3 and 4... 22:13:33 : 22:13:33 : 1. Remove USB and Battery... 22:13:33 : 2. Insert USB. 22:13:33 : 3. Insert Battery. (Some phones boot automatically) 22:13:33 : 4. Please Power on phone shortly... 22:13:33 : 22:13:39 : AdvanceFBox SendBootCodeEx 22:13:39 : InitialiseBootstrap_DCT5 DIR 22:13:39 : BootFlashMode_DCT5 22:13:39 : READING BOOTROM 22:13:39 : 22:13:39 : BootFlashModeDCT5Ex Succeded After 0 Tries 22:13:39 : SYSTEM_ID_RESPONSE_BB5 (0xC0) - 96 (0x60) bytes returned 22:13:39 : Number of Sub Blocks 7 (0x07) 22:13:39 : 1 SYSTEM_ASIC_ID 01 22:13:39 : Block Length : 21 (15) 22:13:39 : BB ASIC Index : 0 (00) CMT 22:13:39 : ID DWORD 0 : 00000003 22:13:39 : ID DWORD 1 : 00000226 22:13:39 : ID DWORD 2 : 00010007 22:13:39 : ID DWORD 3 : 400C1921 22:13:39 : ID DWORD 4 : 03032108 22:13:39 : 2 EM_ASIC_ID 02 22:13:39 : Block Length : 5 (05) 22:13:39 : BB ASIC Index : 0 (00) CMT 22:13:39 : ID DWORD 0 : 00000C35 22:13:39 : 3 EM_ASIC_ID 02 22:13:39 : Block Length : 5 (05) 22:13:39 : BB ASIC Index : 0 (00) CMT 22:13:39 : ID DWORD 0 : 00000C30 22:13:39 : 4 PUBLIC_ID 12 22:13:39 : Block Length : 21 (15) 22:13:39 : BB ASIC Index : 0 (00) CMT 22:13:39 : ID DWORD 0 : B07C0004 22:13:39 : ID DWORD 1 : FFFB7C40 22:13:39 : ID DWORD 2 : D590615E 22:13:39 : ID DWORD 3 : 01659661 22:13:39 : ID DWORD 4 : 3A23307B 22:13:39 : 5 ASIC_MODE_ID 13 22:13:39 : Block Length : 2 (02) 22:13:39 : BB ASIC Index : 0 (00) CMT 22:13:39 : Mode Id : 00 22:13:39 : 6 ROOT_KEY_HASH 14 22:13:39 : Block Length : 17 (11) 22:13:39 : BB ASIC Index : 0 (00) CMT 22:13:39 : Hash : 3A B5 DB 70 B4 5D 23 F1 AD EE BB 57 34 16 07 06 22:13:39 : 7 ROM_ID 15 22:13:39 : Block Length : 9 (09) 22:13:39 : BB ASIC Index : 0 (00) CMT 22:13:39 : CRC 0 : 2CAC45E2 22:13:39 : CRC 1 : 3BC33C8B 22:13:40 : CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv21_2nd.fg 22:13:40 : Secondary Loader Sent.... 22:13:40 : 22:13:40 : MCU_CONFIGURATION_RESPONSE_BB5: 22:13:40 : MessageID : C1 22:13:40 : SubBlocks : 06 22:13:40 : 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 22:13:40 : Block Length : 0B 22:13:40 : BB ASIC Index : CMT 00 22:13:40 : Device Type : RAM 05 22:13:40 : Device Index : 00 22:13:40 : Manufacturer Code : 0000 -> Flash 22:13:40 : Device ID : 0000 -> Type not in database 22:13:40 : Extended/Fixed ID : 0000 22:13:40 : Revision ID : 0000 22:13:40 : 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 22:13:40 : Block Length : 0B 22:13:40 : BB ASIC Index : CMT 00 22:13:40 : Device Type : MMC 04 22:13:40 : Device Index : 00 22:13:40 : Manufacturer Code : FFFF -> Flash 22:13:40 : Device ID : 0000 -> Type not in database 22:13:40 : Extended/Fixed ID : 0000 22:13:40 : Revision ID : 0000 22:13:40 : 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 22:13:40 : Block Length : 0B 22:13:40 : BB ASIC Index : CMT 00 22:13:40 : Device Type : NOR 00 22:13:40 : Device Index : 00 22:13:40 : Manufacturer Code : 0000 -> Flash 22:13:40 : Device ID : 0000 -> Type not in database 22:13:40 : Extended/Fixed ID : 0000 22:13:40 : Revision ID : 0000 22:13:40 : 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 22:13:40 : Block Length : 0B 22:13:40 : BB ASIC Index : CMT 00 22:13:40 : Device Type : NOR 00 22:13:40 : Device Index : 01 22:13:40 : Manufacturer Code : 0000 -> SPANSION 22:13:40 : Device ID : 0001 -> Type not in database 22:13:40 : Extended/Fixed ID : 0000 22:13:40 : Revision ID : 0000 22:13:40 : 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 22:13:40 : Block Length : 0B 22:13:40 : BB ASIC Index : CMT 00 22:13:40 : Device Type : MuxOneNAND 03 22:13:40 : Device Index : 00 22:13:40 : Manufacturer Code : 00EC -> 22:13:40 : Device ID : 0060 -> Type not in database 22:13:40 : Extended/Fixed ID : 0000 22:13:40 : Revision ID : 0032 22:13:40 : 6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5 22:13:40 : Block Length : 09 22:13:40 : BB ASIC Index : CMT 00 22:13:40 : Data : XSR 1.6 22:13:40 : 22:13:40 : SearchForBootstrap_DCT5 : No Error - 0 (0x00) 22:13:40 : Flash Descriptor 22:13:40 : Manufacturer Code : 00EC 22:13:40 : Device ID : 0060 22:13:40 : Extended/Fixed ID : 0000 22:13:40 : Revision ID : 0000 22:13:40 : Size : 40000000 (1024 MB) 22:13:40 : VPP Info : 0000 22:13:40 : Erase10s : 1E 22:13:40 : Block1s : 32 22:13:40 : BErase1s : 02 22:13:40 : Reserved0 : 00 22:13:40 : Reserved1 : 00 22:13:40 : Reserved2 : 00 22:13:40 : 22:13:40 : CMT Algorithm Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv21_XSR17_alg.fg 22:13:43 : Algorithm Loader Sent... 22:13:44 : 22:13:44 : FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) 22:13:44 : FUR control Ok 22:13:44 : PA PUBLIC KEY Request 22:13:44 : PhoneInfoRequest_BB5 (Asic Index 00 ) 22:13:44 : PHONE_INFO_RESPONSE_BB5 22:13:44 : PAPUB_KEYS_HASH_RESP_BB5 2A 22:13:44 : BB Asic Index : 00 22:13:44 : CMT PAPUBKEYS HASH: 22:13:44 : 17AC758130EC0A40BAB0A0E31B342A01D17B8EC0 22:13:44 : 22:13:44 : ================================================== ==== 22:13:44 : PHONE FIRMWARE VERSION: 22:13:44 : 113.010.1507 22:13:44 : ================================================== ==== 22:13:44 : 22:13:44 : 22:13:44 : FlashInfo.RestartMode : Test Mode 22:13:44 : 22:13:44 : Process Done... |
06-20-2013, 18:02 | #11 (permalink) |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Solution: 1. Authorize Phone via ATF Network tab 2. Write Generic PM using StandAlone SX4 Auth from PM/PP tab Generic PM can get from SX4 folder inside ATF dir. BR |
06-21-2013, 14:37 | #12 (permalink) |
Member: 1455973 Status: Offline Thanks Meter: 6 | @Angel Iam little confused when i goes Atf network tab it say not activated I can buy credits & activated but i need to know this one time activation or it will consume credits for each phone also note there is no RM-807 pm on MY sx4 folder is it in network?Pls inform |
06-21-2013, 14:47 | #13 (permalink) | |
Br - srinibas | |
