08-31-2017, 07:45 | #1 (permalink) |
No Life Poster Join Date: Jul 2013 Location: Nepal,kathmandu
Member: 1988630 Status: Offline Sonork: 100.1684003 Thanks Meter: 312 | Nokia 820.1 flashing help. Loading Flash Files Please Wait... [DEAD BOOT REPAIR via USB is SUPPORTED] ================================================== ==== Windows Phone 8/8.1/10 Lumia Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Connect Phone to the USB Port 2. Press and Hold the VOLUME DOWN and POWER Buttons 3. Wait until the Phone Vibrates Shortly... 4. Stop Pressing the Buttons... If the Phone is DEAD BOOT 1. Connect Phone to the USB Port 2. Install Correct Drivers: "Nokia Emergency Connectivity" Located at: C:\AdvanceBox Turbo Flasher\Driver\NOKIA_X2_USB_DRIVERS\ ================================================== ==== Recovery Handle Found! - (WinUSB) Sending Factory Loader... Loader Upload Done! Executing Loader... Start Loader Done! Waiting for USB Cycle... USB Cycle OK! Device Factory Mode OK! USB Reconfiguration Done... eMMC Detected OK... Extracting Partitions from FFU... Looking for SBL1... SBL1 OK Looking for SBL2... SBL2 OK Looking for SBL3... SBL3 OK Looking for UEFI... UEFI OK Looking for RPM... RPM OK Looking for TZ... TZ OK Looking for WINSECAPP... WINSECAPP OK Extracting Partitions Done! Start Writing eMMC Blocks at : 0x00000000 Start Writing eMMC Blocks at : 0x01000000 Start Writing eMMC Blocks at : 0x01200000 Start Writing eMMC Blocks at : 0x01400000 Start Writing eMMC Blocks at : 0x01600000 Start Writing eMMC Blocks at : 0x01A00000 Start Writing eMMC Blocks at : 0x01C00000 Start Writing eMMC Blocks at : 0x01E00000 eMMC Write OK! Closing Partition... Partition Close OK! BOOT WRITE DONE! Waiting for USB Cycle... USB Cycle OK! Rebooting Phone... ERROR: NON Windows 8/8.1 Phone detected! ERROR: Flashing Failed! |
08-31-2017, 08:47 | #2 (permalink) |
Member: 1988630 Status: Offline Sonork: 100.1684003 Thanks Meter: 312 | Problem Solve just unistall nokia emegency driver then detect care usb auto Windows Phone 8/8.1/10 Flashing Started Loading Flash Files Please Wait... [DEAD BOOT REPAIR via USB is SUPPORTED] ================================================== ==== Windows Phone 8/8.1/10 Lumia Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Connect Phone to the USB Port 2. Press and Hold the VOLUME DOWN and POWER Buttons 3. Wait until the Phone Vibrates Shortly... 4. Stop Pressing the Buttons... If the Phone is DEAD BOOT 1. Connect Phone to the USB Port 2. Install Correct Drivers: "Nokia Emergency Connectivity" Located at: C:\AdvanceBox Turbo Flasher\Driver\NOKIA_X2_USB_DRIVERS\ ================================================== ==== Recovery Handle Found! - (WinUSB) Sending Factory Loader... Loader Upload Done! Executing Loader... Start Loader Done! Waiting for USB Cycle... USB Cycle OK! Device Factory Mode OK! USB Reconfiguration Done... eMMC Detected OK... Extracting Partitions from FFU... Looking for SBL1... SBL1 OK Looking for SBL2... SBL2 OK Looking for SBL3... SBL3 OK Looking for UEFI... UEFI OK Looking for RPM... RPM OK Looking for TZ... TZ OK Looking for WINSECAPP... WINSECAPP OK Extracting Partitions Done! Start Writing eMMC Blocks at : 0x00000000 Start Writing eMMC Blocks at : 0x01000000 Start Writing eMMC Blocks at : 0x01200000 Start Writing eMMC Blocks at : 0x01400000 Start Writing eMMC Blocks at : 0x01600000 Start Writing eMMC Blocks at : 0x01A00000 Start Writing eMMC Blocks at : 0x01C00000 Start Writing eMMC Blocks at : 0x01E00000 eMMC Write OK! Closing Partition... Partition Close OK! BOOT WRITE DONE! Waiting for USB Cycle... USB Cycle OK! Rebooting Phone... Nokia Phone Info Mode Initiated... Please wait upto 15 Seconds for SW Reset IMEI: 354105052073920 Version: 1.1.1.3 Product Code: 059R0H7 Module Code: 0205162 Continuing Previous Boot... Please wait upto 30 Seconds for Boot Re-entry Boot Flash Mode Successful... Buffers Flushed OK... Phone Info Query Start... Blocks Returned: 0x07 Blocks Block ID 0x01 : 00241000 Block ID 0x02 : 00240000 Block ID 0x03 : 00ED0000 Block ID 0x05 : Nokia.MSM8960.P5174.3.2.1 Block ID 0x0D : 0001 Block ID 0x0F : 0301010100000101FF Block ID 0x10 : 01001F0000 Checking SD Card Size... Card Size: 0x00000000 Checking Platform Security Status... Platform Secure Boot Status: Active Secure FFU EFUSE Status: Active Debug Status: Active RDC Status: Not Active Authentication Status: Not Active UEFI Secure Boot Status: Active Checking Secure FFU Mode... Secure FFU Mode : Query Flash App Information... Flash App Information: 020112020200 UEFI App: FLASH APP Flash App Protocol Version: 1.18 Flash App Implementation Version: 2.2 Query ROOT KEY HASH... ROOT_KEY_HASH: DB73418E5840941CE7BD35949085B8F74628D511F19285A092 ED3B600A64CC29 Query PUBLIC ID... PUBLIC_ID: 617362951B49734945182FFCE746E8D4DBFED67D Query eMMC Info... EMMC Manufacture ID: TOSHIBA EMMC Product SN : 549B76D3 EMMC_SIZE: 8 Gigabytes Query Battery Charge Status... CHARGING_STATUS: Cannot Read in Flash Mode Sending Image Signatures... Image Signatures Accepted! Erasing Data Partition... Data Partition Erased Successfully Preparing Buffers for DATA LOOP... Allocating System RAM OK! Start Sending DATA BLOCKS... Finished Sending all DATA BLOCKS! Exiting FLASH Mode via REBOOT... Exit FLASH Mode Successful! Flashing Done! Total Flashing Time : 00:02:08 |
The Following 2 Users Say Thank You to adfd For This Useful Post: |
