11-24-2013, 06:19 | #1 (permalink) |
Insane Poster Join Date: Mar 2012
Member: 1735906 Status: Offline Thanks Meter: 12 | NOKIA ASHA 200 connect Server show in Disply help needed PROFILE_BITS : 0000000000040000 ASIC : 11 PROVIDER : Unknown Provider Unable to read SP Data.. SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : FAILED SECURITY_TEST : PASSED SECURITY_CODE : ENCRYPTED PHONE_MODE : TEST ================================================ Dynamic Camera Configuration ================================================ DCC ID : 06150123 DCC Ver: XXXXXX ERROR: DCC File Mismatched! Required DCC File: 06150123 Write the correct DCC to Fix the Problem |
11-24-2013, 06:22 | #2 (permalink) |
No Life Poster Join Date: Dec 2005 Location: Punjab Pakistan
Member: 209582 Status: Offline Sonork: 100.1607015 Thanks Meter: 149 | SIMLOCK_TEST : FAILED auth fone write good pm and check if your cell phone have good nck then all will ok if not then you need RPL |
The Following User Says Thank You to gsmkiller173 For This Useful Post: |
11-25-2013, 06:09 | #11 (permalink) |
No Life Poster Join Date: Jun 2009 Location: SouthAmericaUnlockers Age: 52
Member: 1057178 Status: Offline Sonork: Kfe~Labs Co.- Thanks Meter: 568 | What For is This File? The Problem is Damage SimLock (field120) and not present in this Files.- No way, only full Rpl. ATF AutoSave pm 120 and 308 before Flash the set.- What happen with this Phone? Tell us Phone History, maybe Supporter can Help you.- Br P0Lac0 |
11-25-2013, 12:17 | #12 (permalink) |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | May other section will match in PM of different phone but sec 120 will not so once 120 damaged , cant managed by other same phone PM Br - srinibas |
