05-18-2013, 19:56 | #1 (permalink) |
Freak Poster Join Date: Aug 2011 Location: Uganda Age: 42
Member: 1640892 Status: Offline Sonork: 100.1651734 Thanks Meter: 25 | nokia asha 200 flashing problem j flashed it only it gives light on screen and key pads help please Processing Image File : rm761__11.56.mcusw Processing Image File : rm761__11.56.ppm_i2 Processing Image File : rm761__11.56.image_i2_059J5G3_003 []: Found 1 active devices. [Nokia Asha 200 USB Phonet]: Opening Connection [Nokia Asha 200 USB Phonet]: Port opened OK! SW: V 11.56 26-03-12 RM-761 (c) Nokia IMEI: 359348043781186 START FULL PM BACKUP Please Wait... Reading : PM 0~400... OK! FULL PM Backup Saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\359348043781186\USB_FULL_BACK UP_V 11.56 26-03-12 RM-761 (c) Nokia_359348043781186__43606.pm Rebooting Phone... AUTO SELECTED DEAD USB FLASHING... If Phone Booting does not Start in 5 Seconds, Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... Infineon USB Boot: F00A1FB300020303010100FF Sending PBL... PBL Successfully Sent... Sending SBL... SBL Successfully Sent... Setting Transmission Speed Done... Flash Chip Manufacturer: Intel Electronics Corp. Flash Boot Successful... Unique Data: A4468086AA116000 Original Product Code: 059J4K8 Reading : CCC... OK! Reading : HWC... OK! Reading : NPC... OK! RPL Backup was Successful... Plain RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\359348043781186\3593480437811 86_43616.rpl Data Sections : 04 Current File : rm761__11.56.mcusw Compile Name: rm761__11.56.mcusw_ebl_psi.fls Image Type : Main Firmware Data Size : 26480008 Bytes Sending Certificate Block FIRMWARE Certificate Block Sent Successfully... Processing Section 01 FIRMWARE Erase Block: 0x40000000~0x4001FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 131072 bytes Data Checksum: C1BC Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 02 FIRMWARE Erase Block: 0x40040000~0x4005FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 131072 bytes Data Checksum: 7A7A Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 03 FIRMWARE Erase Block: 0x40060000~0x4015FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 1048576 bytes Data Checksum: 1FA6 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 04 FIRMWARE Erase Block: 0x40280000~0x41A7FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 25165824 bytes Data Checksum: 63A6 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 05 FIRMWARE Erase Block: 0x43E20000~0x43E5FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Data Verification Successful... Data Sections : 01 Current File : rm761__11.56.ppm_i2 Compile Name: package_i2.ppm_ebl_psi.fls Image Type : PPM Image Data Size : 5954536 Bytes Sending Certificate Block PPM Certificate Block Sent Successfully... Processing Section 01 PPM Erase Block: 0x41A80000~0x421BFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 5951192 bytes Data Checksum: 7E3D Uploading Data Blocks to phone... Block Write Successful... PPM Data Blocks uploaded to phone... Data Verification Successful... Data Sections : 01 Current File : rm761__11.56.image_i2_059J5G3_003 Compile Name: package_i2_059J5G3.image.fls Image Type : CONTENT Package Data Size : 15469840 Bytes Sending Certificate Block CONTENT Certificate Block Sent Successfully... Processing Section 01 CONTENT Erase Block: 0x421C0000~0x43E1FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 15466496 bytes Data Checksum: 4601 Uploading Data Blocks to phone... Block Write Successful... CONTENT Data Blocks uploaded to phone... Processing Section 02 CONTENT Erase Block: 0x43E60000~0x43F3FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Data Verification Successful... Total Flashing Time (Erase + Flashing) : 00:05:10 (Booting time is NOT Included) Waiting for Phone to Start-Up..(Max 150 seconds) then the programme it says please wait starts counting the seconds it does not end br baruga |
05-18-2013, 21:07 | #2 (permalink) |
No Life Poster Join Date: May 2011 Location: Z3X ^ CM2 ^ MRT ^ OCTOPUS
Member: 1587480 Status: Offline Sonork: 100.1618317 Thanks Meter: 2,165 | You Flash With Old Version Dear Flash With Higher OR Latest Version v11.81 It's Latest Version Search On Google. BR. Arsalan gsm2000. |
