12-02-2014, 15:45 | #1 (permalink) |
Junior Member Join Date: Mar 2014 Location: Narang Mandi
Member: 2158071 Status: Offline Thanks Meter: 0 | Nokia Asha 302 Simlock & ImeI Damged ATF |
12-03-2014, 11:24 | #4 (permalink) | |
Member: 2158071 Status: Offline Thanks Meter: 0 | Quote:
Please Borther help me how to wirte rpl file with atf? | |
12-03-2014, 11:38 | #5 (permalink) | |
No Life Poster Join Date: Feb 2008 Location: Instant Mobile Age: 45
Member: 694652 Status: Offline Sonork: 100.1669706 Thanks Meter: 1,005 | Quote:
[IMG]http://1.bp.********.com/_8JZhVVmpICU/S_ayuzV8PxI/AAAAAAAAAaM/a2an5PT5s-8/s1600/how+to+backup+rpl.jpg[/IMG] | |
12-08-2014, 19:03 | #9 (permalink) | |
SUPER_DONGLE_TEST : FAILED Flashing Log: File Log: Please Read and give me Sulation Number of Image Files: 4 (Mass Memory File Detected) Processing Image File : rm813__14.26.mcusw CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 300 Entry Point: 0x02BB Page Format : -1 MAX PAGE : 0x00020000 Processing Image File : rm813__14.26.ppm_ma3 CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 44 Entry Point: 0x0151 Page Format : -1 MAX PAGE : 0x00020000 Processing Image File : rm813__14.26.image_ma3_059L164_059N7S8_579_01 CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 223 Entry Point: 0x0182 Page Format : -1 MAX PAGE : 0x00020000 Processing Image File : rm813__14.26_sd_empty_2048.fpsimage CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 3 Entry Point: 0x0167 Page Format : -1 MAX PAGE : 0x00020000 AUTO SELECTED DEAD USB FLASHING... If Phone Booting does not Start in 5 Seconds, Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 READING BOOTROM BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 96 (0x60) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000003 ID DWORD 1 : 00000226 ID DWORD 2 : 00010007 ID DWORD 3 : 400C1921 ID DWORD 4 : 03032108 2 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00001051 3 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00001060 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 8E010004 ID DWORD 1 : FFFB3C40 ID DWORD 2 : 46C7D52D ID DWORD 3 : 4CA03420 ID DWORD 4 : 8793A9C3 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 3A B5 DB 70 B4 5D 23 F1 AD EE BB 57 34 16 07 06 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 2CAC45E2 CRC 1 : 3BC33C8B CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv21_2nd.fg Secondary Loader Sent.... MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 06 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 0040 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0241 6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5 Block Length : 09 BB ASIC Index : CMT 00 Data : XSR 1.6 SearchForBootstrap_DCT5 : No Error - 0 (0x00) Flash Descriptor Manufacturer Code : 00EC Device ID : 0040 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 10000000 (256 MB) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 CMT Algorithm Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv21_XSR17_alg.fg Algorithm Loader Sent... FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok START READING RPL DATA NPC is Corrupted... ERROR: NPC is Corrupted..., 3 RPL Backup is Skipped PA PUBLIC KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: 05BDE0ECC36CDEAA016A0565CB6BAE0B1585232E Reading : ISA-USER... OK! ================================================== ==== PHONE FIRMWARE VERSION: V 14.92 09-11-12 RM-813 (c) Nokia ================================================== ==== ImagePath: C:\Program Files\Nokia\Phoenix\Products\RM-813\ ImageFilename: rm813__14.26.mcusw Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) Certificate 1 Name : NPC ASIC Index : CMT 0 Certificate 2 Name : CCC ASIC Index : CMT 0 Certificate 3 Name : HWC ASIC Index : CMT 0 Certificate 4 Name : R&D ASIC Index : CMT 0 STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3 STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Partition Version : 00010000 Spare : FFFFFFFF Num Partitions : 00000004 Partition 1 ID : 00000003 COPIEDOS Attribute : 00000002 RO Start Address : 00140000 Size : 030C0000 Partition 2 ID : 00000008 FILESYSTEM Attribute : 00000001 RW Start Address : 03880000 Size : 0B800000 Partition 3 ID : 0000000A PMM Attribute : 00000001 RW Start Address : 0F080000 Size : 00600000 Partition 4 ID : 0000000B Attribute : 00000001 RW Start Address : 0F680000 Size : 00300000 PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF00000004000000030000 000200140000030C00000000000800000001038800000B8000 000000000A000000010F080000006000000000000B00000001 0F6800000030000000 PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) StartErase_DCT5... BlockLength : 0xE9 (233) ERASE Blocks : 0x04 (4) 0 ERASE_AREA_BB5 0x12 Block Length : 0x53 (83) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 00040000-000403FF 1 : 000C0000-0013FFFF 2 : 00140000-004BFFFF 3 : 004C0000-0073FFFF 4 : 00740000-0147FFFF 5 : 00160000-0017FFFF 6 : 03200000-0387FFFF 7 : 0F080000-0F67FFFF 8 : 01480000-0243FFFF 9 : 02440000-025BFFFF 1 FORMAT_PARTITION_BB5 0x19 Block Length : 0x2F (47) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Format Info ID : 0x02000000 Format Info : 00000000000000080000000000000002000000640000000200 000002000000010000000000000000 2 FORMAT_PARTITION_BB5 0x19 Block Length : 0x2F (47) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Format Info ID : 0x02000000 Format Info : 000000000000000A0000000100000002000000640000000200 000002000000010000000000000000 3 FORMAT_PARTITION_BB5 0x19 Block Length : 0x2F (47) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Format Info ID : 0x02000000 Format Info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uccessfully Erased... Total blocks to write : 300 >> CMT Rootkey Hash CERT : KEYS >> CMT Rootkey Hash CERT : PAPUBKEYS [05BDE0ECC36CDEAA016A0565CB6BAE0B1585232E] >> CMT Rootkey Hash CERT : DSP0 >> CMT Rootkey Hash CERT : MCUSW >> CMT Rootkey Hash CERT : MCUSW1 >> CMT Rootkey Hash CERT : GENIO_INIT >> CMT Rootkey Hash CERT : ISA+DYNSW >> CMT Rootkey Hash CERT : ADA >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : RAP3NAND >> CMT Rootkey Hash CERT : UPDAPP >> CMT Rootkey Hash CERT : ISA+EXTDRV ImagePath: C:\Program Files\Nokia\Phoenix\Products\RM-813\ ImageFilename: rm813__14.26.ppm_ma3 StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 025C0000-031FFFFF ERASE_REQUEST_BB5 : 5001120B000300025C0000031FFFFF60 Successfully Erased... Total blocks to write : 44 ImagePath: C:\Program Files\Nokia\Phoenix\Products\RM-813\ ImageFilename: rm813__14.26.image_ma3_059L164_059N7S8_579_01 StartErase_DCT5... BlockLength : 0x3F (63) ERASE Blocks : 0x02 (2) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 03880000-0F07FFFF 1 FORMAT_PARTITION_BB5 0x19 Block Length : 0x2F (47) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Format Info ID : 0x02000000 Format Info : 00000000000000080000000000000002000000640000000200 000002000000010000000000000000 ERASE_REQUEST_BB5 : 5001120B000300038800000F07FFFF3F FORMAT_REQUEST_BB5 : 5001192F000300000000020000000000000008000000000000 00020000006400000002000000020000000100000000000000 003E Successfully Erased... Total blocks to write : 223 ImagePath: C:\Program Files\Nokia\Phoenix\Products\RM-813\ ImageFilename: rm813__14.26_sd_empty_2048.fpsimage ALG_CONF_REQUEST_BB5 : No Error - 0 (0x00) Total blocks to write : 3 ContinueFlash_DCT5 Complete Continue Flash Complete : : No Error - 0 (0x00) STATUS_REQUEST_BB5... 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000005 Additional Bad : 00000005 Correctable ECC : 00000000 FlashInfo.RestartMode : 1 Flashing Done... Total Flashing Time (Erase + Flashing) : 00:00:14 (Booting time is NOT Included) Waiting for Phone to Start-Up..(Max 150 seconds) SW: V 14.26 23-01-12 RM-813 (c) Nokia IMEI: 12345610654321? SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SUPER_DONGLE_TEST : FAILED > REPAIR USING FBUS CABLE > Try "Customized SX4 with SD Repair" > Then Write PM 1 and 309 SECURITY_CODE : 12345 ================================================ SL3 Phone detected ================================================ * Firmware Version Downgrade will KILL PHONE !!! * Manual Full Erase WILL KILL PHONE!!! * Simlocks are in PM 120 Only... * PM 308 is Write Protected... FACTORY SET TO : Full Factory Set FAILED FACTORY SET TO : User Data FAILED FACTORY SET TO : Leave Factory FAILED FACTORY SET TO : Service Center FAILED FACTORY SET TO : Software Upgrade FAILED FACTORY SET TO : Production Tune FAILED Life timer data is not yet used... Life timer: ----:-- | |
12-15-2014, 11:54 | #10 (permalink) |
No Life Poster Join Date: May 2011 Location: Z3X ^ CM2 ^ MRT ^ OCTOPUS
Member: 1587480 Status: Offline Sonork: 100.1618317 Thanks Meter: 2,165 | narang_mandi Auth ATF Network This Phone After Write Modified PM C:\AdvanceBox Turbo Flasher\Nokia\PM Files\SX4. WBR. Arsalan gsm2000. |
