10-11-2012, 08:41 | #1 (permalink) |
No Life Poster Join Date: Oct 2009 Location: India [UNKNOWN]
Member: 1143809 Status: Offline Sonork: 100.1602432 Thanks Meter: 574 | nokia c2-03 local mode problem after flash imei 12345610654321? Code: Basic Phone Information ================================================ MCU Version: V 07.29 29-11-11 RM-702 (c) Nokia IMEI Plain : 12345610654321? IMEI Spare : A123456106543210 IMEI SV : 31234561065432109F Phone Model: Kv C2-03 Category : Phone Phone Type : RM-702 ================================================ Extended Phone Information ================================================ Product Serial Number: C54C5F6AI Product Code : 059D445 Module Code : 0204666 Basic Production Code: 059D008 Long Production SN : 0 PPM SW Version : V 07.29 29-11-11 RM-702 (c) Nokia MH1 BT MCM Version : 19b5-22012 MCU SW Version : V 07.29 29-11-11 RM-702 (c) Nokia HW Version : 2000 RFIC Version : Dummy RFIC version LCD Version : TPO FWID Version : kV 07.29 29-11-11 RM-702 (c) Nokia V 07.29 29-11-11 RM-702 (c) Nokia MH1 059D445 001 Content Pack Version : Content: ctv IN V 07.29 29-11-11 RM-702 (c) Nokia Bluetooth ID : 00:02:5B:00:A5:A5 CS Type : GSM900, GSM1800 ********** SIMLOCK INFO ********** CONFIG_DATA : 0000000000000000 PROFILE_BITS : 0000000000030000 ASIC : 11 PROVIDER : Unknown Provider Unable to read SP Data.. SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : FAILED > Try SX4 "PM AUTH" > Then Write PM 1 and 309 SECURITY_CODE : 12345 PHONE_MODE : TEST ================================================ Dynamic Camera Configuration ================================================ DCC ID : 06150123 DCC Ver: 007025 Status : OK Code: Number of Image Files: 3 Processing Image File : rm702__07.29.mcusw Processing Image File : rm702__07.29.ppm_mh1 Processing Image File : rm702__07.29_004.image_mh1_ctv_in_9k4z2 AUTO SELECTED DEAD USB FLASHING... If Phone Booting does not Start in 5 Seconds, Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... Infineon USB Boot: F00A1FB300020303010100FF Sending PBL... PBL Successfully Sent... Sending SBL... SBL Successfully Sent... Setting Transmission Speed Done... Flash Chip Manufacturer: Samsung Electronics Corp. Flash Boot Successful... Sections : 04 Current File : rm702__07.29.mcusw Compile Name: rm702__07.29.mcusw_ebl_psi.fls Image Type : Main Firmware Data Size : 29363592 Bytes Sending Certificate Block FIRMWARE Certificate Block Sent Successfully... Processing Section 01 of 04 FIRMWARE Erase Block: 0x40000000~0x4001FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 131072 bytes Data Checksum: EE63 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 02 of 04 FIRMWARE Erase Block: 0x40040000~0x4005FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 131072 bytes Data Checksum: 7AB2 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 03 of 04 FIRMWARE Erase Block: 0x40060000~0x4015FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 1048576 bytes Data Checksum: F0C6 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 04 of 04 FIRMWARE Erase Block: 0x40280000~0x41DBFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 28049408 bytes Data Checksum: 6841 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Data Verification Successful... Sections : 01 Current File : rm702__07.29.ppm_mh1 Compile Name: package_mh1.ppm_ebl_psi.fls Image Type : PPM Image Data Size : 5053612 Bytes Sending Certificate Block PPM Certificate Block Sent Successfully... Processing Section 01 of 01 PPM Erase Block: 0x41DC0000~0x424BFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 5050268 bytes Data Checksum: 3FC6 Uploading Data Blocks to phone... Block Write Successful... PPM Data Blocks uploaded to phone... Data Verification Successful... Sections : 01 Current File : rm702__07.29_004.image_mh1_ctv_in_9k4z2 Compile Name: package_mh1_ctv_in.image.fls Image Type : CONTENT Package Data Size : 14159120 Bytes Sending Certificate Block CONTENT Certificate Block Sent Successfully... Processing Section 01 of 01 CONTENT Erase Block: 0x424C0000~0x43E1FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 14155776 bytes Data Checksum: 57D5 Uploading Data Blocks to phone... Block Write Successful... CONTENT Data Blocks uploaded to phone... Data Verification Successful... Total Flashing Time (Erase + Flashing) : 00:03:24 (Booting time is NOT Included) |
04-14-2013, 13:16 | #3 (permalink) |
Junior Member Join Date: Jul 2009
Member: 1076390 Status: Offline Thanks Meter: 4 | just check c2-03 or c2-02 flashing rm-702 to rm-692 creat localmode problem flash with correct rm problem sloved |
The Following 2 Users Say Thank You to servicespot For This Useful Post: |
04-15-2013, 06:24 | #6 (permalink) |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | @ MOHIT_THAREJA What is the problem B4 flash ? Check the RM type , may be you mistake on it . if yes just flash with proper RM type phone will restore Br - srinibas |
02-04-2016, 11:13 | #8 (permalink) | |
No Life Poster Join Date: Nov 2014 Location: BADARPUR ASSAM (I N D I A) Age: 34
Member: 2298142 Status: Offline Thanks Meter: 240 | Quote:
some time costomer changed haddy body and creat this problem Last edited by khalidahmed; 02-04-2016 at 11:19. | |
