Number of Image Files: 3
Processing Image File :
RM766__05.92.mcusw
rm766__05.92.ppm_t
RM766__05.92.image_t_059L4C8
AUTO SELECTED DEAD USB FLASHING...
If Phone Booting does not Start in 5 Seconds,
Then Perform Steps 1, 2, 3 and 4...
1. Remove USB and Battery...
2. Insert USB.
3. Insert Battery. (Some phones boot automatically)
4. Please Power on phone shortly...
Infineon USB Boot: F00A1FB300020303010100FF
Sending PBL...
PBL Successfully Sent...
Sending SBL...
SBL Successfully Sent...
Setting Transmission Speed Done...
Flash Chip Manufacturer: Samsung Electronics Corp.
Flash Boot Successful...
Unique Data: 0220040D9C061834
Original Product Code: 059L0V1
Reading : CCC... OK!
Reading : HWC... OK!
Reading : NPC... OK!
RPL Backup was Successful...
Plain RPL saved to:
D:\PROGRAM FILES\AdvanceBox Turbo Flasher\Nokia\Backup\359059048595501\3590590485955 01_84912.rpl
Data Sections : 04
Current File : RM766__05.92.mcusw
Compile Name: rm766__05.92.mcusw_ebl_psi.fls
Image Type : Main Firmware
Data Size : 29117832 Bytes
Sending Certificate Block
FIRMWARE Certificate Block Sent Successfully...
Processing Section 01
FIRMWARE Erase Block: 0x40000000~0x4001FFFE
Start Erasing...
Erasing Please Wait...
Block Erase Done...
Preparing Data Blocks...
Data Size: 131072 bytes
Data Checksum: 1369
Uploading Data Blocks to phone...
Block Write Successful...
FIRMWARE Data Blocks uploaded to phone...
Processing Section 02
FIRMWARE Erase Block: 0x40040000~0x4005FFFE
Start Erasing...
Block Erase Done...
Data Checksum: 73CD
Processing Section 03
FIRMWARE Erase Block: 0x40060000~0x4011FFFE
Start Erasing...
Block Erase Done...
Data Size: 786432 bytes
Data Checksum: C572
Processing Section 04
FIRMWARE Erase Block: 0x40120000~0x41BFFFFE
Start Erasing...
Block Erase Done...
Data Size: 28065792 bytes
Data Checksum: 7F36
Processing Section 05
FIRMWARE Erase Block: 0x43EE0000~0x43EFFFFE
Start Erasing...
Block Erase Done...
Data Verification Successful...
Data Sections : 01
Current File : rm766__05.92.ppm_t
Compile Name: package_t.ppm_ebl_psi.fls
Image Type : PPM Image
Data Size : 7932648 Bytes
PPM Certificate Block Sent Successfully...
PPM Erase Block: 0x41C00000~0x423FFFFE
Start Erasing...
Block Erase Done...
Data Size: 7929304 bytes
Data Checksum: 4FBC
PPM Data Blocks uploaded to phone...
Data Sections : 01
Current File : RM766__05.92.image_t_059L4C8
Compile Name: package_t_059L4C8.image.fls
Image Type : CONTENT Package
Data Size : 13765904 Bytes
CONTENT Certificate Block Sent Successfully...
CONTENT Erase Block: 0x42400000~0x43EDFFFE
Start Erasing...
Block Erase Done...
Data Size: 13762560 bytes
Data Checksum: 35C4
CONTENT Data Blocks uploaded to phone...
CONTENT Erase Block: 0x43F00000~0x43F7FFFE
Start Erasing...
Block Erase Done...
Total Flashing Time (Erase + Flashing) : 00:03:28
(Booting time is NOT Included)
Waiting for Phone to Start-Up..(Max 150 seconds)
Scanning USB Ports...
Basic Phone Information
MCU Version: V 05.92 26-10-12 RM-766 (c) Nokia
IMEI Plain : 359059048595501
IMEI Spare : A359059048595500
IMEI SV : 33590590485955036F
IMEI (2nd) : 359059048595519
IMEI Spare : A359059048595510
IMEI SV : 33590590485955136F
Phone Model: Nokia 305
Category : Classic Phone
Phone Type : RM-766
Extended Phone Information
Product Serial Number: A15DFA4AH
Product Code : 059L0V1
Module Code : 0204884
Basic Production Code: 059F928
Long Production SN : 0
PPM SW Version : V 05.92 26-10-12 RM-766 (c) Nokia T
BT MCM Version : 19b5-22012
MCU SW Version : V 05.92 26-10-12 RM-766 (c) Nokia
HW Version : 1000
RFIC Version : Dummy RFIC version
LCD Version : TPO
Content Pack Version : Content: t_059L4C8 V 05.92 26-10-12 RM-766 (c) Nokia
AHNE Version : 11
Bluetooth ID : E8:CB:A1:C5:9E:6F
CS Type : GSM900, GSM1800
********** SIMLOCK INFO **********
CONFIG_DATA : 0010100000000000
PROFILE_BITS : 800000000003000B
ASIC : 11
PROVIDER : Default Test Operator
LOCK COUNTERS: KEYPRESS 0/3, FBUS 0/10
Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
SIMLOCK_TYPE : PA_SL3 (15-digit NCK)
SIMLOCK_TEST : PASSED
SECURITY_TEST : PASSED
SECURITY_CODE : 12345
PHONE_MODE : TEST
Dynamic Camera Configuration
DCC ID : 0A350160
DCC Ver: 006015
Status : OK
Make sure you have installed the
COMPLETE Flash Package for this Phone...
Goto "Settings" --> "Nokia Settings" and verify that
the Folder where you installed your Flash Files are
in the "PRODUCT PATH TO SCAN" List...
FACTORY SET TO : Full Factory Set
OK
FACTORY SET TO : User Data
OK
FACTORY SET TO : Leave Factory
OK
FACTORY SET TO : Service Center
OK
FACTORY SET TO : Software Upgrade
OK
FACTORY SET TO : Production Tune
OK
RESET LIFE TIMER TO : 0000:00
OK |
flash ok but not open pls help
Advance-Box team
