nokia asha 501 rm-902 need help As its title can nokia asha 501 trees received rm-902 with security code, and I have used ATF phone with usb connection and check ok ==> phone has to'' test mode'' but not'' full '' factory was set up by his brother post support. I thank you all. |
Hi, there is a check on PPM / ROFS. If you will flash with other Product Code files than the phone has - in this case, it will NOT power up. It will be like you have downgraded the phone. However, if MCU is same or higher. Anyway, solution is to FULL FLASH phone again via ATF Box using SAME PRODUCT CODE FILES BTW, this is not right place for ATF Box Support. We got official section here in this forum: Advance-Box - GSM-Forum You can post any problem RELATED to ATF Box in official section. BR |
I first thank you for tam.Minh also trying to flash file but no file associated with it qua.Anh then ask yourself okay. I thank |
Hi, what are you talking about? You did not find a file or ??? BR |
I felt he ah.anh can not find flash file link for you would offline. thank you |
Hi, what's your phone's Product Code ? BR |
Nokia Asha 501 RM-902 AH YOU THANK YOU |
Product Code starts from 059xxxx. You can see it on back under battery at it's lable. Check and post here! |
sorry to take your time code is: 059s9z6. expecting him to help |
Hi, files are available on Nokia ProductSupportTool for Store. You have to follow this thread: http://forum.gsmhosting.com/vbb/f609...ifirm-1656869/ Install software, write your phone's Product Code and Download files. BR |
ATF Team, I have facing this problem also, i want to change language with different product code. my asha 501 RM902 original product code is (059T1N5). after i download other product code (059R6V6) and flash it, my phone become no power on:confused: I s there anyway to solve this problem? Please help & advice. |
i need flash ..... my product code 059t1n0 |
help needed nokia 501 rm 902 product code 059r2t4 after flash with atf security code still on |
501 firmware Need nokia 501 firmware v11.1.1 product code 059t1n4 |
