Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 07-08-2013, 15:11   #1 (permalink)
Member: 1515121
nokia asha 501 rm-902 need help
As its title can nokia asha 501 trees received rm-902 with security code, and I have used ATF phone with usb connection and check ok ==> phone has to'' test mode'' but not'' full '' factory was set up by his brother post support. I thank you all.
Old 07-08-2013, 15:20   #2 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Thanks Meter: 16,483
Hi, there is a check on PPM / ROFS. If you will flash with other Product Code files than the phone has - in this case, it will NOT power up. It will be like you have downgraded the phone. However, if MCU is same or higher. Anyway, solution is to FULL FLASH phone again via ATF Box using SAME PRODUCT CODE FILES
BTW, this is not right place for ATF Box Support. We got official section here in this forum: Advance-Box - GSM-Forum
You can post any problem RELATED to ATF Box in official section.
The Following User Says Thank You to ..::Angel::.. For This Useful Post:
Old 07-08-2013, 15:55   #3 (permalink)
Member: 1515121
I first thank you for tam.Minh also trying to flash file but no file associated with it qua.Anh then ask yourself okay. I thank
Old 07-09-2013, 12:54   #4 (permalink)
Member: 643472
Sonork: 100.96901
Hi, what are you talking about? You did not find a file or ???
Old 07-09-2013, 14:35   #5 (permalink)
Member: 1515121
I felt he ah.anh can not find flash file link for you would offline. thank you
Old 07-09-2013, 14:56   #6 (permalink)
Member: 643472
Sonork: 100.96901
Hi, what's your phone's Product Code ?
Old 07-09-2013, 15:16   #7 (permalink)
Member: 1515121
Nokia Asha 501 RM-902 AH YOU THANK YOU
Old 07-09-2013, 15:23   #8 (permalink)
Member: 643472
Sonork: 100.96901
Product Code starts from 059xxxx. You can see it on back under battery at it's lable. Check and post here!
Old 07-09-2013, 18:50   #9 (permalink)
Member: 1515121
sorry to take your time code is: 059s9z6. expecting him to help
Old 07-10-2013, 09:46   #10 (permalink)
Member: 643472
Sonork: 100.96901
Hi, files are available on Nokia ProductSupportTool for Store.
You have to follow this thread:
...:: Download official Nokia firmware without Navifirm+ ::..
Install software, write your phone's Product Code and Download files.
Old 10-10-2013, 10:50   #11 (permalink)
Member: 459869
Thanks Meter: 46
Exclamation
ATF Team,
I have facing this problem also, i want to change  language with different product code. my asha 501  RM902 original product code is (059T1N5).
after i download other product code (059R6V6) and  flash it, my phone become no power on  I s there anyway to solve this problem?
Please help & advice.
Old 10-11-2013, 13:42   #12 (permalink)
.:KRISHNA:..:MOBILE:.'s Avatar
Member: 304012
Thanks Meter: 297
NOKIA 501
http://www.mediafire.com/download/y4...+V+10.0.14.rar
Old 11-05-2013, 23:20   #13 (permalink)
Member: 1570177
i need flash ..... my product code 059t1n0
Old 12-21-2013, 09:27   #14 (permalink)
Member: 839673
Sonork: pastorshaggy
Thanks Meter: 29
help needed nokia 501 rm 902 product code 059r2t4 after flash with atf security code still on
Old 01-11-2014, 10:02   #15 (permalink)
Member: 1387604
501 firmware
Need nokia 501 firmware v11.1.1
product code 059t1n4
Page generated in 0.35329 seconds with 7 queries
