05-21-2012, 07:36 | #31 (permalink) |
Junior Member Join Date: May 2008 Location: iraq
Member: 776526 Status: Offline Sonork: 1590976 Thanks Meter: 7 | i did like your post all the day several times but same proplem ok >> now i want to flash back the phone with the highest ver. i want the phone back to live flashed with 111.... ver symbian belle now it gives like my log above all log info is normal CONFIG KEY : 0000000000000000 PROVIDER KEY : 2440700000000000 NETWORK NAME : Nokia Default;Finland LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10 SIMLOCK TABLE : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK STATE : Not Locked SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : ENCRYPTED CMLA_KEY : ABSENT SUPER_DONGLE_TEST : PASSED but the phone stuck on boot logo nokia with ..... i try eno 100 times do you think its hadware now??? |
06-05-2012, 05:24 | #37 (permalink) |
No Life Poster Join Date: Feb 2011 Location: ( United States Of Islam ) Age: 35
Member: 1519396 Status: Offline Sonork: 100.1612702 Thanks Meter: 1,951 | Thnx a lot Angel very very usefull post....... plzzz add me ( [email protected] ) |
06-06-2012, 14:37 | #41 (permalink) |
Freak Poster Join Date: Nov 2009 Location: Romania Age: 53
Member: 1169376 Status: Offline Sonork: 100.1618134 Thanks Meter: 8 | Downgrading (C7-00) from Belle to Anna it happening to me with stuck on Nokia logo...but..I try with some many boxes but same result...but I found a solution with Phoenix. So..first erase phone then with Phoenix 2010 write on C7 firmware of N8 version 25.007 and then flash again with Phoenix 2010 (not 2011 or 2012) version 11.005 or lowest of N8, don't worry about RM-xxx. Then uninstall Phoenix 2010 and instal 2011 or 2012 and flash with lowest firmware of C7 and then flash again with final firmware that you want. SO simple procedure: all stuff u need... 1.Phoenix Service Software 2010 2.Phoenix Service Software 2011 3.RM-596[N8] version 25.007 4.RM-596[N8] version 11.005 5.lowest version of your phone's firmware 6.Anna firmware for ur phone[or any firmware that u want to use] step by step[in this case it is C7] 1.Flashing ur C7 with RM-596 version 25.007(N8 firmware)[use Phoenix Service Software 2010] 2.Flashng ur C7 with RM-596 version 11.005(N8 firmware)[use Phoenix Service Software 2010] 3.Flashing ur C7 with the lowest version of ur C7 phone firmware(C7 firmware)[usePhoenix Service Software 2011] 4.Flashing ur C7 with firmware version u want(C7 firmware)[use Phoenix Service Software 2011] or read this toping forum.dailymobile.se FOR ANY phones with Symbian ^ 3: NOKIA E6, C7, C6 01 ... ETC |
06-11-2012, 07:44 | #42 (permalink) |
Freak Poster Join Date: Mar 2012 Location: Bihar
Member: 1741396 Status: Offline Sonork: 100.1640320 Thanks Meter: 16 | nokia 2730c1 flashing problem Number of Image Files: 3 Processing Image File : rm578__10.47.mcusw CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 1395 Entry Point: 0x457E Page Format : -1 MAX PAGE : 0x00004000 Processing Image File : rm578__10.47.ppm_m_h CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 360 Entry Point: 0x00B6 Page Format : -1 MAX PAGE : 0x00004000 Processing Image File : rm578__10.47.image_m_h_black CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 816 Entry Point: 0x00C8 Page Format : -1 MAX PAGE : 0x00004000 AUTO SELECTED DEAD USB FLASHING... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 READING BOOTROM BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 030C1921 ID DWORD 4 : 01023000 2 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000296 3 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 1900020B ID DWORD 1 : 0A828E56 ID DWORD 2 : 120740A4 ID DWORD 3 : B876E249 ID DWORD 4 : 88E28386 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 273F6D55 CRC 1 : DFAAF68F [NO COMPATIBLE BOOT FILE FOUND] Now Switching to ADL Booting ADL_SERVER: PROCESSING rm578__10.47.mcusw ADL_SERVER: ROOT_KEY_HASH MATCH FOUND ADL_SERVER: PROCESSING rm578__10.47.mcusw ADL_SERVER: CMT CERTIFICATE BLOCK FOUND ADL_SERVER: CMT DATA BLOCKS FOUND ADL_SERVER: CONSOLIDATING CMT BLOCKS ADL_SERVER: PASUBTOC BLOCK FOUND BB5 ADL Loader Start Up... (Please Wait...) Unable to detect "Nokia BB5 ADL Loader USB Generic" Booting/Flashing Failed... Please Try Again... |
07-02-2012, 04:46 | #45 (permalink) | |
Freak Poster Join Date: Apr 2002
Member: 11441 Status: Offline Thanks Meter: 7 | Quote:
Hi to All! Same the problem with Nokia 700! But no have is ENO, not found it. I have USB cable only. What is the resolve? | |
