Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 04-09-2011, 11:18   #1 (permalink)
kabul's Avatar
Member: 433097
Sonork: 100.1661890
Thanks Meter: 8,001
nokia c1.01 after flash dead
Number of Image Files: 3
Processing Image File :
rm607__03.35.mcusw
rm607__03.35.ppm_m_c
rm607__03.35.image_m_c_059B107
AUTO SELECTED DEAD USB FLASHING...
If Flashing DOES NOT Start in 5 Seconds,
Then Perform Steps 1, 2, 3 and 4...
1. Remove USB and Battery...
2. Insert USB.
3. Insert Battery. (Some phones boot automatically)
4. Please Power on phone shortly..
Infineon USB Boot: F00A1FB300020303010100FF
Sending PBL...
PBL Successfully Sent...
Sending SBL...
SBL Successfully Sent...
Setting Transmission Speed Done...
Flash Chip Manufacturer: Intel Electronics Corp.
Flash Boot Successful...
Current File : rm607__03.35.mcusw
Image Type : Main Firmware
Sections : 05
Compile Name: rm607__03.35.mcusw_ebl_psi.fls
Data Size : 26217904 Bytes
Sending Certificate Block
FIRMWARE Certificate Block Sent Successfully...
Processing Section 01 of 05
FIRMWARE Erase Block: 0x40000000~0x4001FFFE
Start Erasing...
Erasing Please Wait...
Block Erase Done...
Preparing Data Blocks...
Data Size: 131072 bytes
Data Checksum: A830
Uploading Data Blocks to phone...
Block Write Successful...
FIRMWARE Data Blocks uploaded to phone...
Processing Section 02 of 05
FIRMWARE Erase Block: 0x40040000~0x4007FFFE
Start Erasing...
Block Erase Done...
Data Size: 262144 bytes
Data Checksum: 0000
Processing Section 03 of 05
FIRMWARE Erase Block: 0x40080000~0x4009FFFE
Start Erasing...
Block Erase Done...
Data Checksum: 865C
Processing Section 04 of 05
FIRMWARE Erase Block: 0x400A0000~0x4019FFFE
Start Erasing...
Block Erase Done...
Data Size: 1048576 bytes
Data Checksum: 097B
Processing Section 05 of 05
FIRMWARE Erase Block: 0x40400000~0x41BFFFFE
Start Erasing...
Block Erase Done...
Data Size: 24641536 bytes
Data Checksum: C5EE
Data Verification Successful...
Current File : rm607__03.35.ppm_m_c
Image Type : PPM Image
Sections : 01
Compile Name: package_m_c.ppm_ebl_psi.fls
Data Size : 3254104 Bytes
PPM Certificate Block Sent Successfully...
Processing Section 01 of 01
PPM Erase Block: 0x41C00000~0x421FFFFE
Start Erasing...
Block Erase Done...
Data Size: 3250760 bytes
Data Checksum: 932D
PPM Data Blocks uploaded to phone...
Current File : rm607__03.35.image_m_c_059B107
Image Type : CONTENT Package
Sections : 01
Compile Name: package_m_c_059B107.image.fls
Data Size : 11799824 Bytes
CONTENT Certificate Block Sent Successfully...
CONTENT Erase Block: 0x42200000~0x43E5FFFE
Start Erasing...
Block Erase Done...
Data Size: 11796480 bytes
Data Checksum: 50AE
CONTENT Data Blocks uploaded to phone...
Total Flashing Time (Erase + Flashing) : 00:07:34
(Booting time is NOT Included)
Waiting for Phone to Start-Up..(Max 100 seconds)
If Windows is Installing Drivers...
Phone Polling MIGHT Exit Automatically.
Elapsed Time: 5 Seconds...
Elapsed Time: 10 Seconds...
Elapsed Time: 15 Seconds...
Elapsed Time: 20 Seconds...
Elapsed Time: 25 Seconds...
Elapsed Time: 30 Seconds...
Elapsed Time: 35 Seconds...
Elapsed Time: 40 Seconds...
Elapsed Time: 45 Seconds...
Elapsed Time: 50 Seconds...
Elapsed Time: 55 Seconds...
Elapsed Time: 60 Seconds...
Elapsed Time: 65 Seconds...
Elapsed Time: 70 Seconds...
Elapsed Time: 75 Seconds...
Elapsed Time: 80 Seconds...
Elapsed Time: 85 Seconds...
Elapsed Time: 90 Seconds...
Elapsed Time: 95 Seconds...
Elapsed Time: 100 Seconds...
WARNING: Phone is not in the Required Mode...
Disconnect the Phone and Power it Up Manually.
Old 04-09-2011, 11:24   #2 (permalink)
Advance-Box's Avatar
Member: 651945
Thanks Meter: 20,045
@kabul
Maybe phone was already dead before you flashed it...
Check Battery, Check Everything...
C1-01 flashing dont have bugs in ATF Software.
B.R.
Old 04-09-2011, 11:34   #3 (permalink)
kabul's Avatar
Member: 433097
Sonork: 100.1661890
Thanks Meter: 8,001
Originally Posted by Advance-Box View Post
@kabul
B.R.
phone already on only chang language flash dead
Old 04-09-2011, 13:07   #4 (permalink)
Member: 651945
@kabul
Check this guy,, he also flashed same firmware version as you... But his phone is OK.
c1-01 flash ok
B.R>
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 52 12-30-2016 07:17
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 30 02-24-2016 09:21
Page generated in 0.25848 seconds with 8 queries
