11-15-2014, 08:42 | #4 (permalink) |
No Life Poster Join Date: Mar 2014 Location: Indonesia
Member: 2155369 Status: Offline Thanks Meter: 706 | After write with 3.35 (3.30 is BAD) Now Done with 6.15 Number of Image Files: 3 Processing Image File : rm607__06.15.mcusw Processing Image File : rm607__06.15.ppm_x Processing Image File : rm607__06.15.image_x_0595594 AUTO SELECTED DEAD USB FLASHING... If Phone Booting does not Start in 5 Seconds, Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... Infineon USB Boot: F00A1FB300020303010100FF Sending PBL... PBL Successfully Sent... Sending SBL... SBL Successfully Sent... Setting Transmission Speed Done... Flash Chip Manufacturer: Intel Electronics Corp. Flash Boot Successful... Unique Data: 12302001A4041825 Original Product Code: 059D3N9 Reading : CCC... OK! Reading : HWC... OK! Reading : NPC... OK! RPL Backup was Successful... Plain RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\352429058556460\3524290585564 60_142847.rpl Certificate Block Saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\352429058556460\3524290585564 60_CERTIFICATE_46E570D6.bin PM Block Saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\352429058556460\3524290585564 60_PMM_PROT_CD5A1586.bin Security Code: 12345 Data Sections : 05 Current File : rm607__06.15.mcusw Compile Name: rm607__06.15.mcusw_ebl_psi.fls Image Type : Main Firmware Data Size : 26217904 Bytes Sending Certificate Block FIRMWARE Certificate Block Sent Successfully... Processing Section 01 FIRMWARE Erase Block: 0x40000000~0x4001FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 131072 bytes Data Checksum: 9899 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 02 FIRMWARE Erase Block: 0x40040000~0x4007FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 262144 bytes Data Checksum: 0000 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 03 FIRMWARE Erase Block: 0x40080000~0x4009FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 131072 bytes Data Checksum: 865C Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 04 FIRMWARE Erase Block: 0x400A0000~0x4019FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 1048576 bytes Data Checksum: ACD1 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 05 FIRMWARE Erase Block: 0x40400000~0x41BFFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 24641536 bytes Data Checksum: 105D Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Data Sections : 01 Current File : rm607__06.15.ppm_x Compile Name: package_x.ppm_ebl_psi.fls Image Type : PPM Image Data Size : 4305304 Bytes Sending Certificate Block PPM Certificate Block Sent Successfully... Processing Section 01 PPM Erase Block: 0x41C00000~0x421FFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 4301960 bytes Data Checksum: AEB7 Uploading Data Blocks to phone... Block Write Successful... PPM Data Blocks uploaded to phone... Data Verification Successful... Data Sections : 01 Current File : rm607__06.15.image_x_0595594 Compile Name: package_x_0595594.image.fls Image Type : CONTENT Package Data Size : 14421264 Bytes Sending Certificate Block CONTENT Certificate Block Sent Successfully... Processing Section 01 CONTENT Erase Block: 0x42200000~0x43E5FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 14417920 bytes Data Checksum: 9AB8 Uploading Data Blocks to phone... Block Write Successful... CONTENT Data Blocks uploaded to phone... Processing Section 02 CONTENT Erase Block: 0x43E60000~0x43F3FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Data Verification Successful... Total Flashing Time (Erase + Flashing) : 00:07:15 (Booting time is NOT Included) Waiting for Phone to Start-Up..(Max 150 seconds) Scanning USB Ports... ================================================ Basic Phone Information ================================================ MCU Version: V 06.15 25-11-11 RM-607 (c) Nokia IMEI Plain : 352429058556460 IMEI Spare : A352429058556460 IMEI SV : 33524290585564622F Phone Model: J C1-01 Category : Entry Phone Phone Type : RM-607 ================================================ Extended Phone Information ================================================ Product Serial Number: 8A89485AH Product Code : 059D3N9 Module Code : 0204430 Basic Production Code: 0585582 Long Production SN : 0 PPM SW Version : V 06.15 25-11-11 RM-607 (c) Nokia X BT MCM Version : 19b5-22012 MCU SW Version : V 06.15 25-11-11 RM-607 (c) Nokia HW Version : 3000 RFIC Version : 96 LCD Version : TPO Content Pack Version : Content: x_0595594 V 06.15 25-11-11 RM-607 (c) Nokia Bluetooth ID : A0:F4:19:CA:EF:E0 CS Type : GSM900, GSM1800 ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 800000000003000B ASIC : 11 PROVIDER : Default Test Operator LOCK COUNTERS: KEYPRESS 0/3, FBUS 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : TEST ================================================ Dynamic Camera Configuration ================================================ DCC ID : NI00CS00000401022E05 DCC Ver: 001004 Status : OK ================================================== ==== Selected VPL File: RM607_0595594_06.15_055.vpl ================================================== ==== Variant Details : RM-607 SEAP_X_DGRAY_STROK_INDONESIA Software Version : 06.15 Product Type : RM-607 Product Code : 0595594 Variant Version : 055 FACTORY SET TO : Full Factory Set OK FACTORY SET TO : User Data OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Service Center OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : Production Tune OK RESET LIFE TIMER TO : 0000:00 OK |
