MOHIT_THAREJA | 10-11-2012 08:41 | nokia c2-03 local mode problem nokia c2-03 local mode problem
after flash imei 12345610654321? Code:
Basic Phone Information
MCU Version: V 07.29 29-11-11 RM-702 (c) Nokia
IMEI Plain : 12345610654321?
IMEI Spare : A123456106543210
IMEI SV : 31234561065432109F
Phone Model: Kv C2-03
Category : Phone
Phone Type : RM-702
Extended Phone Information
Product Serial Number: C54C5F6AI
Product Code : 059D445
Module Code : 0204666
Basic Production Code: 059D008
Long Production SN : 0
PPM SW Version : V 07.29 29-11-11 RM-702 (c) Nokia MH1
BT MCM Version : 19b5-22012
MCU SW Version : V 07.29 29-11-11 RM-702 (c) Nokia
HW Version : 2000
RFIC Version : Dummy RFIC version
LCD Version : TPO
FWID Version : kV 07.29 29-11-11 RM-702 (c) Nokia V 07.29 29-11-11 RM-702 (c) Nokia MH1 059D445 001
Content Pack Version : Content: ctv IN V 07.29 29-11-11 RM-702 (c) Nokia
Bluetooth ID : 00:02:5B:00:A5:A5
CS Type : GSM900, GSM1800
********** SIMLOCK INFO **********
CONFIG_DATA : 0000000000000000
PROFILE_BITS : 0000000000030000
ASIC : 11
PROVIDER : Unknown Provider
Unable to read SP Data..
SIMLOCK_TYPE : PA_SL3 (15-digit NCK)
SIMLOCK_TEST : PASSED
SECURITY_TEST : FAILED
> Try SX4 "PM AUTH"
> Then Write PM 1 and 309
SECURITY_CODE : 12345
PHONE_MODE : TEST
Dynamic Camera Configuration
DCC ID : 06150123
DCC Ver: 007025
Status : OK Code:
Number of Image Files: 3
Processing Image File :
rm702__07.29.mcusw
rm702__07.29.ppm_mh1
rm702__07.29_004.image_mh1_ctv_in_9k4z2
AUTO SELECTED DEAD USB FLASHING...
If Phone Booting does not Start in 5 Seconds,
Then Perform Steps 1, 2, 3 and 4...
1. Remove USB and Battery...
2. Insert USB.
3. Insert Battery. (Some phones boot automatically)
4. Please Power on phone shortly...
Infineon USB Boot: F00A1FB300020303010100FF
Sending PBL...
PBL Successfully Sent...
Sending SBL...
SBL Successfully Sent...
Setting Transmission Speed Done...
Flash Chip Manufacturer: Samsung Electronics Corp.
Flash Boot Successful...
Sections : 04
Current File : rm702__07.29.mcusw
Compile Name: rm702__07.29.mcusw_ebl_psi.fls
Image Type : Main Firmware
Data Size : 29363592 Bytes
Sending Certificate Block
FIRMWARE Certificate Block Sent Successfully...
Processing Section 01 of 04
FIRMWARE Erase Block: 0x40000000~0x4001FFFE
Start Erasing...
Erasing Please Wait...
Block Erase Done...
Preparing Data Blocks...
Data Size: 131072 bytes
Data Checksum: EE63
Uploading Data Blocks to phone...
Block Write Successful...
FIRMWARE Data Blocks uploaded to phone...
Processing Section 02 of 04
FIRMWARE Erase Block: 0x40040000~0x4005FFFE
Start Erasing...
Block Erase Done...
Data Checksum: 7AB2
Processing Section 03 of 04
FIRMWARE Erase Block: 0x40060000~0x4015FFFE
Start Erasing...
Block Erase Done...
Data Size: 1048576 bytes
Data Checksum: F0C6
Processing Section 04 of 04
FIRMWARE Erase Block: 0x40280000~0x41DBFFFE
Start Erasing...
Block Erase Done...
Data Size: 28049408 bytes
Data Checksum: 6841
Data Verification Successful...
Sections : 01
Current File : rm702__07.29.ppm_mh1
Compile Name: package_mh1.ppm_ebl_psi.fls
Image Type : PPM Image
Data Size : 5053612 Bytes
PPM Certificate Block Sent Successfully...
Processing Section 01 of 01
PPM Erase Block: 0x41DC0000~0x424BFFFE
Start Erasing...
Block Erase Done...
Data Size: 5050268 bytes
Data Checksum: 3FC6
PPM Data Blocks uploaded to phone...
Sections : 01
Current File : rm702__07.29_004.image_mh1_ctv_in_9k4z2
Compile Name: package_mh1_ctv_in.image.fls
Image Type : CONTENT Package
Data Size : 14159120 Bytes
CONTENT Certificate Block Sent Successfully...
CONTENT Erase Block: 0x424C0000~0x43E1FFFE
Start Erasing...
Block Erase Done...
Data Size: 14155776 bytes
Data Checksum: 57D5
CONTENT Data Blocks uploaded to phone...
Total Flashing Time (Erase + Flashing) : 00:03:24
(Booting time is NOT Included) |
