Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 10-11-2012, 08:41   #1 (permalink)
MOHIT_THAREJA's Avatar
Member: 1143809
Sonork: 100.1602432
Thanks Meter: 574
nokia c2-03 local mode problem
after flash imei 12345610654321?
Basic Phone Information
MCU Version: V 07.29 29-11-11 RM-702 (c) Nokia
IMEI Plain : 12345610654321?
IMEI Spare : A123456106543210
IMEI SV    : 31234561065432109F
Phone Model: Kv       C2-03
Category   : Phone
Phone Type : RM-702
            Extended Phone Information
Product Serial Number: C54C5F6AI
Product Code         : 059D445
Module Code          : 0204666
Basic Production Code: 059D008
Long Production SN   : 0
PPM SW Version       : V 07.29 29-11-11 RM-702 (c) Nokia             MH1
BT MCM Version       : 19b5-22012
MCU SW Version       : V 07.29 29-11-11 RM-702 (c) Nokia
HW Version           : 2000
RFIC Version         : Dummy RFIC version
LCD Version          : TPO
FWID Version         : kV 07.29 29-11-11 RM-702 (c) Nokia            V 07.29 29-11-11 RM-702 (c) Nokia             MH1 059D445 001
Content Pack Version : Content: ctv IN V 07.29 29-11-11 RM-702 (c) Nokia
Bluetooth ID         : 00:02:5B:00:A5:A5
CS Type              : GSM900, GSM1800
  ********** SIMLOCK INFO  **********
CONFIG_DATA  : 0000000000000000
PROFILE_BITS : 0000000000030000
ASIC         : 11
PROVIDER     : Unknown Provider
Unable to read SP Data..
SIMLOCK_TYPE             : PA_SL3 (15-digit NCK)
SIMLOCK_TEST             : PASSED
SECURITY_TEST     : FAILED
      >  Try SX4 "PM AUTH"
      >  Then Write PM 1 and 309
SECURITY_CODE          : 12345
PHONE_MODE              : TEST
          Dynamic Camera Configuration
DCC ID  : 06150123
DCC Ver: 007025
Status   : OK
Number of Image Files: 3
Processing Image File :
 rm702__07.29.mcusw
 rm702__07.29.ppm_mh1
 rm702__07.29_004.image_mh1_ctv_in_9k4z2
AUTO SELECTED DEAD USB FLASHING...
If Phone Booting does not Start in 5 Seconds,
Then Perform Steps 1, 2, 3 and 4...
1. Remove USB and Battery...
2. Insert USB.
3. Insert Battery. (Some phones boot automatically)
4. Please Power on phone shortly...
Infineon USB Boot: F00A1FB300020303010100FF
Sending PBL...
PBL Successfully Sent...
Sending SBL...
SBL Successfully Sent...
Setting Transmission Speed Done...
Flash Chip Manufacturer: Samsung Electronics Corp.
Flash Boot Successful...
Sections         : 04
Current File    : rm702__07.29.mcusw
Compile Name: rm702__07.29.mcusw_ebl_psi.fls
Image Type   : Main Firmware
Data Size       : 29363592 Bytes
Sending Certificate Block
FIRMWARE Certificate Block Sent Successfully...
 Processing Section 01 of 04
FIRMWARE Erase Block: 0x40000000~0x4001FFFE
Start Erasing...
Erasing Please Wait...
Block Erase Done...
Preparing Data Blocks...
Data Size: 131072 bytes
Data Checksum: EE63
Uploading Data Blocks to phone...
Block Write Successful...
FIRMWARE Data Blocks uploaded to phone...
 Processing Section 02 of 04
FIRMWARE Erase Block: 0x40040000~0x4005FFFE
Start Erasing...
Block Erase Done...
Data Checksum: 7AB2
 Processing Section 03 of 04
FIRMWARE Erase Block: 0x40060000~0x4015FFFE
Start Erasing...
Block Erase Done...
Data Size: 1048576 bytes
Data Checksum: F0C6
 Processing Section 04 of 04
FIRMWARE Erase Block: 0x40280000~0x41DBFFFE
Start Erasing...
Block Erase Done...
Data Size: 28049408 bytes
Data Checksum: 6841
Data Verification Successful...
Sections         : 01
Current File    : rm702__07.29.ppm_mh1
Compile Name: package_mh1.ppm_ebl_psi.fls
Image Type   : PPM Image
Data Size       : 5053612 Bytes
PPM Certificate Block Sent Successfully...
 Processing Section 01 of 01
PPM Erase Block: 0x41DC0000~0x424BFFFE
Start Erasing...
Block Erase Done...
Data Size: 5050268 bytes
Data Checksum: 3FC6
PPM Data Blocks uploaded to phone...
Sections         : 01
Current File    : rm702__07.29_004.image_mh1_ctv_in_9k4z2
Compile Name: package_mh1_ctv_in.image.fls
Image Type   : CONTENT Package
Data Size       : 14159120 Bytes
CONTENT Certificate Block Sent Successfully...
CONTENT Erase Block: 0x424C0000~0x43E1FFFE
Start Erasing...
Block Erase Done...
Data Size: 14155776 bytes
Data Checksum: 57D5
CONTENT Data Blocks uploaded to phone...
Total Flashing Time (Erase + Flashing) : 00:03:24
(Booting time is NOT Included)
Old 10-11-2012, 09:09   #2 (permalink)
Member: 47716
Thanks Meter: 13
pls cheq its c2-03 or c2-02
Old 04-14-2013, 13:16   #3 (permalink)
Member: 1076390
Thanks Meter: 4
just check c2-03 or c2-02 flashing rm-702 to rm-692 creat localmode problem flash with correct rm problem sloved
The Following 2 Users Say Thank You to servicespot For This Useful Post:
Old 04-14-2013, 13:31   #4 (permalink)
mahesh2121's Avatar
Member: 1263646
Sonork: 1625091
Thanks Meter: 17
rong flash file selection , just flash it with c2-02 rm -692 i solve same problem
Old 04-14-2013, 13:45   #5 (permalink)
Member: 1209576
Thanks Meter: 28
NO YOU NEED JUSTE AN rpl
Old 04-15-2013, 06:24   #6 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Thanks Meter: 10,214
@ MOHIT_THAREJA
What is the problem B4 flash ?
Check the RM type , may be you mistake on it . if yes just flash with proper RM type phone will restore
Br - srinibas
Old 04-19-2014, 06:06   #7 (permalink)
Member: 388272
Thanks Meter: 18
c2-03 local mode any solution pls help me
Old 02-04-2016, 10:13   #8 (permalink)
khalidahmed's Avatar
Member: 2298142
Thanks Meter: 202
Than.......Q 100% solved, just flash rm -692 i solve same problem
some time costomer changed haddy body and creat this problem
Page generated in 0.40067 seconds with 7 queries
