03-10-2014, 11:53 | #1 (permalink) | |
Freak Poster Join Date: Sep 2006 Location: Algeria
Member: 345732 Status: Offline Thanks Meter: 16 | Nokia C3 RM-614 dead after flash! Here's the log Quote:
Any suggetions? P.S: I have all the important files RPL and PM ect! | |
03-10-2014, 17:54 | #3 (permalink) |
Freak Poster Join Date: Aug 2012 Location: In your dreams
Member: 1802683 Status: Offline Sonork: 100.1655083 Thanks Meter: 29 | Brother first charge battery full then flash . If problem still then go to setting in atf soft and tick on 2nd type usb boot fix and try to flash |
The Following User Says Thank You to Hotline4all For This Useful Post: |
03-11-2014, 13:56 | #6 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | @habibtomb Where is flashing logs??? If phone cannot boot any more than follow the solution from ATF Software: TIPS: 1. Make Sure your Battery Power is Enough... 2. Make Sure Connectivity Drivers are installed... 3. DO NOT USE USB HUBS... 4. Use an ORIGINAL NOKIA CA-101D USB Cable... You can also try on other PC, might be your PC's drivers problem If phone still doesn't boot, then you should check phone's USB / Hardware. BR |
The Following User Says Thank You to ..::Angel::.. For This Useful Post: |
03-11-2014, 14:33 | #7 (permalink) | |
Member: 345732 Status: Offline Thanks Meter: 16 | I tried all the tips, another PC and i can flash another C3! This is the last log when last timephone booted Quote:
03-12-2014, 12:38 | #12 (permalink) |
Member: 345732 Status: Offline Thanks Meter: 16 | Just an update, i tested the phone's USB and it's OK, so it's not a problem of USB, i tried to rehot the Flash IC but same problem! Note: I flashed two C3-00 this morning without any problem! Do you have any other suggestions please?! |
03-12-2014, 18:59 | #13 (permalink) | |
No Life Poster Join Date: Mar 2014 Location: Kfe~Labs Co.- Age: 52
Member: 2140790 Status: Offline Sonork: 100.1679059 Thanks Meter: 212 | Quote:
Can you aAutorize a Phone in Network ATF and paste log here? maybe you are damage phone when was flashed cnt file (downgrade) Check if you can read RPL and NPC using Authorize Phone ciao automatico | |
