Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 08-15-2013, 18:43   #1 (permalink)
ahmadge's Avatar
Member: 603971
Thanks Meter: 699
Thumbs down Nokia c5 hang nokia then off
i have nokia c5 rm-745 after write rpl hang nokia then power off
i also full erased flash old version butt prblem same
{Ahmadge}
Old 08-15-2013, 19:01   #2 (permalink)
ahmadge's Avatar
Member: 603971
Thanks Meter: 699
here rpl
rpl backup check may b its damage....
http://www.4shared.com/rar/7QwFhApP/backup_file.html
{Ahmadge}
Old 08-15-2013, 21:37   #3 (permalink)
Member: 808009
Thanks Meter: 16
rehot combo then flash again with latest version then wright bacup rpl. then post result.i wish it will be ok
Old 08-15-2013, 21:47   #4 (permalink)
ahmadge's Avatar
Member: 603971
Thanks Meter: 699
Thumbs down
sir if eraze rpl then phone work....
still wait.... may team reply
{Ahmadge}
Old 08-15-2013, 21:56   #5 (permalink)
Member: 808009
Thanks Meter: 16
{Ahmadge}
which box or software are you used? you can use Best dongle. I think best dongle is best in this case.
Old 08-15-2013, 23:52   #6 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Thanks Meter: 16,469
You need to update phone to latest version 102.xx after write rpl
Old 08-16-2013, 16:26   #7 (permalink)
ahmadge's Avatar
Member: 603971
Thanks Meter: 699
Thumbs down
same problem... phone also go local mode no problem. butt when power on then nokia and off...
any other solution.
{Ahmadge}
Old 08-16-2013, 16:35   #8 (permalink)
Member: 1789341
Sonork: 1627336
Thanks Meter: 14
it may be hardware problem.....check battery connecter for loose connection and also check bsi line.
Old 08-16-2013, 16:57   #9 (permalink)
tejas243404's Avatar
Member: 725038
Sonork: 100.1675584
Thanks Meter: 281
any other solution.
{Ahmadge}
halo bro use to other dongal and canect to my id bro
Old 08-16-2013, 17:03   #10 (permalink)
ahmadge's Avatar
Member: 603971
Thanks Meter: 699
Thumbs down Flashing logo
              TIME STARTS HERE
BootFlashModeDCT5Ex Succeeded after 3 Attempts
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0  (0x00) bytes returned
Number of Sub Blocks 7  (0x07)
  1  SYSTEM_ASIC_ID 01
     Block Length  : 21  (15)
     BB ASIC Index : 0  (00)  CMT
     ID DWORD    0 : 00000003
     ID DWORD    1 : 00000226
     ID DWORD    2 : 00010007
     ID DWORD    3 : 600C1921
     ID DWORD    4 : 02031104
  2  EM_ASIC_ID 02
     Block Length  : 5  (05)
     ID DWORD    0 : 00000C35
  3  EM_ASIC_ID 02
     ID DWORD    0 : 00000C30
  4  PUBLIC_ID 12
     ID DWORD    0 : 06300213
     ID DWORD    1 : A7DE0344
     ID DWORD    2 : 707DF8FB
     ID DWORD    3 : 1E9286C9
     ID DWORD    4 : F5F7F414
  5  ASIC_MODE_ID 13
     Block Length  : 2  (02)
     Mode Id       : 00
  6  ROOT_KEY_HASH 14
     Block Length  : 17  (11)
     Hash          :  91 6F 75 21 7F 32 08 12 48 B1 5C 38 DF C8 E8 1B
  7  ROM_ID 15
     Block Length  : 9  (09)
     CRC         0 : E693EF0D
     CRC         1 : AC22615B
Checksum           64
SearchForBootstrap_DCT5..
C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv11_2nd.fg
Boot File - Version  012.014.00
Boot File - Revision 0x0003 (3)
eBB5ProtocolType == New
PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0"
PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0"
SearchForBootstrap_DCT5  : No Error - 0 (0x00)
Secondary Loader Sent...
TransmissionTypeRequest_DCT5_NewProtocol
TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5
TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0
FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX
TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C
Transmission Type Request Sent...
ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000)..
MCU_CONFIGURATION_RESPONSE_BB5:
 MessageID  : 06
 SubBlocks  : 06
 1 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   BB ASIC Index     : CMT  00
   Device Type       : RAM  05
   Device Index      : 00
   Manufacturer Code : 0000 -> Flash
   Device ID         : 0000 -> not detected
   Extended/Fixed ID : 0000
   Revision ID       : 0000
 2 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Type       : MMC  04
   Device Index      : 00
   Manufacturer Code : FFFF -> Flash
   Device ID         : 0000 -> BAD FLASH TYPE
   Revision ID       : 0000
 3 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Type       : NOR  00
   Device Index      : 00
   Manufacturer Code : 0020 ->
   Device ID         : 0050 -> Type not in database
   Revision ID       : 0031
 4 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Index      : 01
   Manufacturer Code : 0000 -> SPANSION
   Device ID         : 0001 -> not used
   Revision ID       : 0000
 5 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Type       : MuxOneNAND  03
   Device Index      : 00
   Revision ID       : 0031
 6 Sub Block ID      : 35  NAND_DRIVER_VERSION_BB5
   Block Length      : 09
   Data              : XSR 1.6
 Checksum   : 34
FLS1SendAlgoCodeEx..
SendAlgoCode_DCT5..
SearchForAlgorithm_DCT5..
Looking for ALL Devices...
Searching Algorithm Files MuxOneNAND (03) ManID :0020 DevID :0050 ExtID :0000 RevID :0031
Flash Descriptor
   Device ID         : 0050
   Revision ID       : 0000
   Size              : 20000000 (512 MB)
   VPP Info          : 0000
   Erase10s          : 1E
   Block1s           : 32
   BErase1s          : 02
   Reserved0         : 00
   Reserved1         : 00
   Reserved2         : 00
C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv11_XSR17_alg.fg
Algorithm File - Version  012.014.00
Algorithm File - Revision 0x0003 (3)
Algo Loader Sent...
SendCodeStart_NewProtocol :
SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00)
SendAlgoCodeFile_DCT5 : No Error - 0 (0x00)
FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
FUR control Ok...
VPP Enabled by Software
Using Internal VPP
FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4
PAPUB_KEYS_HASH_REQ_BB5
PhoneInfoRequest_BB5 (Asic Index 00 )
PHONE_INFO_RESPONSE_BB5
   PAPUB_KEYS_HASH_RESP_BB5 2A
   BB Asic Index   : 00
CMT PAPUBKEYS HASH:
5F18D62F8F3D105EEFB6633F44614F8C6DCCA7E8
PHONE FIRMWARE VERSION:
102.002
Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT  00 only)
Certificate 1
  ASIC Index  : CMT  0
Certificate 2
  ASIC Index  : CMT  0
Certificate 3
  ASIC Index  : CMT  0
Certificate 4
  ASIC Index  : CMT  0
STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3
STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
ProcessPartitionInfo_DCT5...
Partition Info
    Partition Blocks :   1
     1   PARTITION_INFO_BB5
            BB ASIC Index     : 0x00 CMT
            Device Type       : 0x03 MuxOneNAND
            Device Index      : 0x00
            Partition Version : 00020000
            Spare             : FFFFFFFF
            Num Partitions    : 00000004
            Partition    1
              Attribute       : 00000002  RO
              Start Address   : 000A0000
            Partition    2
              ID              : 00000004  DEMANDONOS
              Start Address   : 03640000
            Partition    3
              ID              : 00000008  FILESYSTEM
              Attribute       : 00000001  RW
              Start Address   : 0D3C0000
            Partition    4
              Start Address   : 1F140000
PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000020000FFFFFFFF000000040000000300000002000A0000035A000000000004000000020364000009D8000000000008000000010D3C000011D800000000000A000000011F140000003C00000C
PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00)
ProcessPartitionInfo_DCT5 : No Error - 0 (0x00)
StartErase_DCT5...
BlockLength  :  0x4F  (79)
ERASE Blocks :  0x02  (2)
     0   ERASE_AREA_BB5 0x12
            Block Length     : 0x1B (27)
            Device Index     : 0x00
               0             : 00020000-0003FFFF
               1             : 00060000-004DFFFF
               2             : 008E0000-0D3BFFFF
     1   FORMAT_PARTITION_BB5 0x19
            Block Length     : 0x2F (47)
            Device Index     : 0x00
            Format Info ID   : 0x02000000
            Format Info      : 000000000000000A0000000000000002000000640000000B00000002000000010000000000000000
Erase_SendEraseBlock_BB5_NAND
Task in Progress... Please Wait...
Erase_SendFormatPartition_BB5_NAND
Successfully erased..
Time Taken to Erase : 00:00:03
Flashing Speed: 5.00 Mhz (AUTO)
Processing  : rm745_102.002_prd.core.fpsx
Total blocks to write : 427
>>  CMT Rootkey Hash CERT : ADA
>>  CMT Rootkey Hash CERT : KEYS
>>  CMT Rootkey Hash CERT : PRIMAPP
>>  CMT Rootkey Hash CERT : RAP3NAND
>>  CMT Rootkey Hash CERT : SOS+PMML
>>  CMT Rootkey Hash CERT : PASUBTOC
>>  CMT Rootkey Hash CERT : PAPUBKEYS [5F18D62F8F3D105EEFB6633F44614F8C6DCCA7E8]
>>  CMT Rootkey Hash CERT : GENIO_INIT
>>  CMT Rootkey Hash CERT : SOS*UPDAPP
>>  CMT Rootkey Hash CERT : SOS*DSP0
>>  CMT Rootkey Hash CERT : LDSP
>>  CMT Rootkey Hash CERT : SOS*ISASW
>>  CMT Rootkey Hash CERT : SOS+CORE
>>  CMT Rootkey Hash CERT : SOS+ROFS1
ContinueFlash_DCT5 Complete
Continue Flash Complete :  : No Error - 0 (0x00)
Time Taken to Flash  : 00:00:54
Processing Image File :
 C:\Program Files\Nokia\Phoenix\Products\RM-745\rm745_102.002_312.01_CV_CH_prd.rofs3.fpsx
CMT Type                   :  BB5
CMT Algorithm              :  XSR 1.6
Secondary Sending Speed    :  650000 Hz
Algorithm Sending Speed    :  6500000 Hz
Program Sending Speed      :  13000000 Hz
Message Reading Speed      :  98000 Hz
Number of Blocks           :  3
Entry Point                :  0x012C
Page Format                :  128K
Maximum Page Size          :  0x0000D200
StartErase_DCT5...
BlockLength  :  0x0E  (14)
ERASE Blocks :  0x01  (1)
            Block Length     : 0x0B (11)
            Device Index     : 0x00
               0             : 0BD40000-0D3BFFFF
Time Taken to Erase : 00:00:00
Processing  : rm745_102.002_312.01_CV_CH_prd.rofs3.fpsx
Total blocks to write : 3
>>  CMT Rootkey Hash CERT : SOS+ROFS3
Time Taken to Flash  : 00:00:00
 C:\Program Files\Nokia\Phoenix\Products\RM-745\rm745_102.002_01.01_Euro1_prd.rofs2.fpsx
CMT Type                   :  BB5
Number of Blocks           :  186
Page Format                :  128K
Maximum Page Size          :  0x00040000
StartErase_DCT5...
            Device Index     : 0x00
               0             : 07C40000-0BD3FFFF
Processing  : rm745_102.002_01.01_Euro1_prd.rofs2.fpsx
Total blocks to write : 186
>>  CMT Rootkey Hash CERT : SOS+ROFS2
Time Taken to Flash  : 00:00:25
 C:\Program Files\Nokia\Phoenix\Products\RM-745\rm745_102.002_U001.000_prd.uda.fpsx
CMT Type                   :  BB5
Number of Blocks           :  36
Page Format                :  128K
StartErase_DCT5...
            Device Index     : 0x00
               0             : 0D3C0000-1F13FFFF
Processing  : rm745_102.002_U001.000_prd.uda.fpsx
Total blocks to write : 36
Time Taken to Flash  : 00:00:10
 C:\Program Files\Nokia\Phoenix\Products\RM-745\rm745_ENO_APE_ONLY_11wk02_v0.003.fpsx
CMT Type                   :  BB5
Program Sending Speed      :  6500000 Hz
Number of Blocks           :  10
Page Format                :  128K
StartErase_DCT5...
            Device Index     : 0x00
               0             : 004E0000-008DFFFF
Processing  : rm745_ENO_APE_ONLY_11wk02_v0.003.fpsx
Total blocks to write : 10
>>  CMT Rootkey Hash CERT : SOS*ENO
Time Taken to Flash  : 00:00:01
Total Flash Write Time (Flashing Only) : 00:01:32
Total Flashing Time (Booting + Erase + Flashing) : 00:01:41
STATUS_REQUEST_BB5...
1  Sub Block ID      : 15 STATUS_NAND_OK_BB5
          Block Length      :  0F
          BB ASIC Index     :  00
          Device Type       :  03
          Device Type       :  00
          Num Bad Blocks    :  00000006
          Additional Bad    :  00000006
          Correctable ECC   :  00000000
Waiting for Phone to Go Online...
Elapsed Time: 1s
Elapsed Time: 2s
Elapsed Time: 3s
Elapsed Time: 4s
Elapsed Time: 5s
Elapsed Time: 6s
Elapsed Time: 7s
Elapsed Time: 8s
Elapsed Time: 9s
Elapsed Time: 10s
             Basic Phone Information
MCU Version: V ICPR82_11w16.3.14 16-11-12 RM-745 (c) Nokia
IMEI Plain : 351685052414649
IMEI Spare : A351685052414640
IMEI SV    : 33516850524146422F
Phone Model: Nokia C5-00
Category   : Classic Phone
Phone Type : RM-745
            Extended Phone Information
Product Serial Number: 0
Long Production SN   : 0
MCU SW Version       : V ICPR82_11w16.3.14 16-11-12 RM-745 (c) Nokia
RFIC Version         : |Vapaus_6.5 | Mikki_1.1
DSP Version          : 12w24
AHNE Version         : 11
APE SW Core Version  : 102.002
Variant Version      : 102.002102.002.01.01102.002.312.01
APE Test Version     : rm745_APE_ONLY_ENO_11wk02v0
RETU Version         : 35
TAHVO Version        : 00
APE HW Version       : 256
APE ADSP SW Version  : 256
Bluetooth ID         : 04:5A:95:65:A8:8F
CS Type              : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA VIII
               Simlock Information
CONFIG KEY    :  0000000000000000
PROVIDER KEY  :  2440700000000000
NETWORK NAME  :  Nokia Default;Finland
LOCK COUNTERS :  KEYPRESS 0/3,  FBUS 0/10
SIMLOCK TABLE :
   Block [1]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [2]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [3]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [4]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [5]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [6]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [7]  1:Open 2:Open 3:Open 4:Open 5:Open
SIMLOCK STATE :  Not Locked
SIMLOCK_TYPE             : PA_SL3 (15-digit NCK)
SIMLOCK_TEST             : PASSED
SECURITY_TEST     : FAILED
      >  Try SX4 "PM AUTH"
      >  Then Write PM 1 and 309
SECURITY_CODE          : ENCRYPTED
PHONE_MODE              : TEST
DCC ID                          : NOT USED
FACTORY SET TO : Full Factory Set
 OK
FACTORY SET TO : User Data
 OK
FACTORY SET TO : Leave Factory
 OK
FACTORY SET TO : Service Center
 OK
FACTORY SET TO : Software Upgrade
 OK
FACTORY SET TO : Production Tune
 OK
Life timer data is not yet used...
Life timer: ----:--
Old 08-16-2013, 17:05   #11 (permalink)
ahmadge's Avatar
Member: 603971
Thanks Meter: 699
added..... lets try.
{Ahmadge}
Page generated in 0.36035 seconds with 7 queries
