12-25-2012, 09:23 | #1 (permalink) |
No Life Poster Join Date: Sep 2011 Location: Pakistan Chakwal
Member: 1652269 Status: Offline Sonork: 100.1638989 Thanks Meter: 54 | Nokia c5 only vibrater help me plzzzzzzzzzzzzz ================================================== ==== ================================================== ==== USB Phone BUSCheck Boot ================================================== ==== ================================================== ==== 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 READING BOOTROM BootFlashModeDCT5Ex Succeded After 0 Tries SYSTEM_ID_RESPONSE_BB5 (0xC0) - 96 (0x60) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000003 ID DWORD 1 : 00000226 ID DWORD 2 : 00010007 ID DWORD 3 : 600C1921 ID DWORD 4 : 02031104 2 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000C35 3 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000C30 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 13A0020E ID DWORD 1 : C5D80344 ID DWORD 2 : E6CAEAA1 ID DWORD 3 : 22CFF7A0 ID DWORD 4 : ED4B3A54 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 91 6F 75 21 7F 32 08 12 48 B1 5C 38 DF C8 E8 1B 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : E693EF0D CRC 1 : AC22615B CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv11_2nd.fg Secondary Loader Sent.... MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 06 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0020 -> Device ID : 0040 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0031 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 0020 -> Device ID : 0040 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0031 6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5 Block Length : 09 BB ASIC Index : CMT 00 Data : XSR 1.6 SearchForBootstrap_DCT5 : No Error - 0 (0x00) Flash Descriptor Manufacturer Code : 0020 Device ID : 0040 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 10000000 (256 MB) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 CMT Algorithm Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv11_XSR17_alg.fg Algorithm Loader Sent... FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok PA PUBLIC KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: D7D05CFC982BF1491F4BE3FE0F28D3016DA5E057 FlashInfo.RestartMode : Test Mode Process Done... |
12-25-2012, 10:11 | #5 (permalink) |
Member: 1652269 Status: Offline Sonork: 100.1638989 Thanks Meter: 54 | Number of Image Files: 6 Processing Image File : rm645_071.005_prd.core.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 453 Entry Point: 0x01F0 Page Format : -1 MAX PAGE : 0x00040000 Processing Image File : rm645_071.005_C00.01_DEFAULT_prd.rofs3.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 5 Entry Point: 0x012C Page Format : -1 MAX PAGE : 0x00000E00 Processing Image File : rm645_071.005_11.01_MEA_C_prd.rofs2.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 150 Entry Point: 0x012C Page Format : -1 MAX PAGE : 0x00040000 Processing Image File : rm645_071.005_U040.000_prd.uda.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 1 Entry Point: 0x012C Page Format : -1 MAX PAGE : 0x00030000 Processing Image File : RM645_ENO_10wk48v0.001.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 13 Entry Point: 0x012C Page Format : -1 MAX PAGE : 0x00040000 Processing Image File : rm645_071.005_prd.core.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 453 Entry Point: 0x01F0 Page Format : -1 MAX PAGE : 0x00040000 AUTO SELECTED DEAD USB FLASHING... If Phone Booting does not Start in 5 Seconds, Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 READING BOOTROM BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 96 (0x60) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000003 ID DWORD 1 : 00000226 ID DWORD 2 : 00010007 ID DWORD 3 : 600C1921 ID DWORD 4 : 02031104 2 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000C35 3 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000C30 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 13A0020E ID DWORD 1 : C5D80344 ID DWORD 2 : E6CAEAA1 ID DWORD 3 : 22CFF7A0 ID DWORD 4 : ED4B3A54 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 91 6F 75 21 7F 32 08 12 48 B1 5C 38 DF C8 E8 1B 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : E693EF0D CRC 1 : AC22615B CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv11_2nd.fg Secondary Loader Sent.... MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 06 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0020 -> Device ID : 0040 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0031 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 0020 -> Device ID : 0040 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0031 6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5 Block Length : 09 BB ASIC Index : CMT 00 Data : XSR 1.6 SearchForBootstrap_DCT5 : No Error - 0 (0x00) Flash Descriptor Manufacturer Code : 0020 Device ID : 0040 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 10000000 (256 MB) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 CMT Algorithm Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv11_XSR17_alg.fg Algorithm Loader Sent... FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok START READING RPL DATA IMEI: 357409046337442 Reading : NPC... OK! Reading : CCC... OK! Reading : HWC... OK! Reading : R&D... OK! NPC CERTIFICATE INFORMATION (CMT): IMEI : 357409046337442 PRODUCT CODE : 0593669 BLUETOOTH ID : 48C:FB:A2:53:85 PUBLIC_ID : 13A0020EC5D80344E6CAEAA122CFF7A0ED4B3A54 PAPUB_KEYS_HASH: D7D05CFC982BF1491F4BE3FE0F28D3016DA5E057 CCC CERTIFICATE INFORMATION (CMT): PRODUCT CODE : 0593669 HWC CERTIFICATE INFORMATION (CMT): PUBLIC_ID : 13A0020EC5D80344E6CAEAA122CFF7A0ED4B3A54 PRODUCT CODE : 0593669 RPL Backup was Successful... Plain RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\357409046337442\3574090463374 42_20641.rpl PA PUBLIC KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: D7D05CFC982BF1491F4BE3FE0F28D3016DA5E057 ImagePath: C:\Program Files\Nokia\Phoenix\Products\RM-645\ ImageFilename: rm645_071.005_prd.core.fpsx Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) Certificate 1 Name : NPC ASIC Index : CMT 0 Certificate 2 Name : CCC ASIC Index : CMT 0 Certificate 3 Name : HWC ASIC Index : CMT 0 Certificate 4 Name : R&D ASIC Index : CMT 0 STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3 STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Partition Version : 00020000 Spare : FFFFFFFF Num Partitions : 00000004 Partition 1 ID : 00000003 COPIEDOS Attribute : 00000002 RO Start Address : 000A0000 Size : 030A0000 Partition 2 ID : 00000004 DEMANDONOS Attribute : 00000002 RO Start Address : 03140000 Size : 07D00000 Partition 3 ID : 00000008 FILESYSTEM Attribute : 00000001 RW Start Address : 0AE40000 Size : 04800000 Partition 4 ID : 0000000A PMM Attribute : 00000001 RW Start Address : 0F640000 Size : 003C0000 PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000020000FFFFFFFF00000004000000030000 0002000A0000030A000000000004000000020314000007D000 0000000008000000010AE40000048000000000000A00000001 0F640000003C000036 PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) StartErase_DCT5... BlockLength : 0x4F (79) ERASE Blocks : 0x02 (2) 0 ERASE_AREA_BB5 0x12 Block Length : 0x1B (27) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 00020000-0003FFFF 1 : 00060000-004DFFFF 2 : 008E0000-0AE3FFFF 1 FORMAT_PARTITION_BB5 0x19 Block Length : 0x2F (47) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Format Info ID : 0x02000000 Format Info : 000000000000000A0000000000000002000000640000000B00 000002000000010000000000000000 ERASE_REQUEST_BB5 : 5003120B000300000200000003FFFF120B0003000006000000 4DFFFF120B000300008E00000AE3FFFFCF FORMAT_REQUEST_BB5 : 5001192F00030000000002000000000000000A000000000000 0002000000640000000B000000020000000100000000000000 0033 Successfully Erased... Total blocks to write : 453 >> CMT Rootkey Hash CERT : ADA >> CMT Rootkey Hash CERT : KEYS >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : RAP3NAND >> CMT Rootkey Hash CERT : SOS+PMML >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : PAPUBKEYS [D7D05CFC982BF1491F4BE3FE0F28D3016DA5E057] >> CMT Rootkey Hash CERT : GENIO_INIT >> CMT Rootkey Hash CERT : SOS*UPDAPP >> CMT Rootkey Hash CERT : SOS*DSP0 >> CMT Rootkey Hash CERT : LDSP >> CMT Rootkey Hash CERT : SOS*ISASW >> CMT Rootkey Hash CERT : SOS+CORE >> CMT Rootkey Hash CERT : SOS+ROFS1 ImagePath: C:\Program Files\Nokia\Phoenix\Products\RM-645\ ImageFilename: rm645_071.005_C00.01_DEFAULT_prd.rofs3.fpsx StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 0A040000-0AE3FFFF ERASE_REQUEST_BB5 : 5001120B0003000A0400000AE3FFFFE5 Successfully Erased... Total blocks to write : 5 >> CMT Rootkey Hash CERT : SOS+ROFS3 ImagePath: C:\Program Files\Nokia\Phoenix\Products\RM-645\ ImageFilename: rm645_071.005_11.01_MEA_C_prd.rofs2.fpsx StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 06D40000-0A03FFFF ERASE_REQUEST_BB5 : 5001120B00030006D400000A03FFFFF9 Successfully Erased... Total blocks to write : 150 >> CMT Rootkey Hash CERT : SOS+ROFS2 ImagePath: C:\Program Files\Nokia\Phoenix\Products\RM-645\ ImageFilename: rm645_071.005_U040.000_prd.uda.fpsx StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 0AE40000-0F63FFFF ERASE_REQUEST_BB5 : 5001120B0003000AE400000F63FFFF80 Successfully Erased... Total blocks to write : 1 ImagePath: C:\Program Files\Nokia\Phoenix\Products\RM-645\ ImageFilename: RM645_ENO_10wk48v0.001.fpsx StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 004E0000-008DFFFF ERASE_REQUEST_BB5 : 5001120B000300004E0000008DFFFF05 Successfully Erased... Total blocks to write : 13 >> CMT Rootkey Hash CERT : SOS*ENO ImagePath: C:\Program Files\Nokia\Phoenix\Products\RM-645\ ImageFilename: rm645_071.005_prd.core.fpsx StartErase_DCT5... BlockLength : 0x4F (79) ERASE Blocks : 0x02 (2) 0 ERASE_AREA_BB5 0x12 Block Length : 0x1B (27) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 00020000-0003FFFF 1 : 00060000-004DFFFF 2 : 008E0000-0AE3FFFF 1 FORMAT_PARTITION_BB5 0x19 Block Length : 0x2F (47) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Format Info ID : 0x02000000 Format Info : 000000000000000A0000000000000002000000640000000B00 000002000000010000000000000000 ERASE_REQUEST_BB5 : 5003120B000300000200000003FFFF120B0003000006000000 4DFFFF120B000300008E00000AE3FFFFCF FORMAT_REQUEST_BB5 : 5001192F00030000000002000000000000000A000000000000 0002000000640000000B000000020000000100000000000000 0033 Successfully Erased... Total blocks to write : 453 >> CMT Rootkey Hash CERT : ADA >> CMT Rootkey Hash CERT : KEYS >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : RAP3NAND >> CMT Rootkey Hash CERT : SOS+PMML >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : PAPUBKEYS [D7D05CFC982BF1491F4BE3FE0F28D3016DA5E057] >> CMT Rootkey Hash CERT : GENIO_INIT >> CMT Rootkey Hash CERT : SOS*UPDAPP >> CMT Rootkey Hash CERT : SOS*DSP0 >> CMT Rootkey Hash CERT : LDSP >> CMT Rootkey Hash CERT : SOS*ISASW >> CMT Rootkey Hash CERT : SOS+CORE >> CMT Rootkey Hash CERT : SOS+ROFS1 ContinueFlash_DCT5 Complete Continue Flash Complete : : No Error - 0 (0x00) STATUS_REQUEST_BB5... 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000000 Additional Bad : 00000000 Correctable ECC : 00000000 FlashInfo.RestartMode : 1 Flashing Done... Total Flashing Time (Erase + Flashing) : 00:03:58 (Booting time is NOT Included) Waiting for Phone to Start-Up..(Max 150 seconds) |
12-25-2012, 10:40 | #7 (permalink) |
No Life Poster Join Date: Oct 2009 Location: srilanka Age: 39
Member: 1133072 Status: Offline Thanks Meter: 505 | if not have rpl back up do this step. back up full flash dump (read flash) back up npc certificate.(only npc in dead mode) next do erase. and post result. |
