07-03-2013, 16:31 | #3 (permalink) | |
Freak Poster Join Date: Mar 2006 Location: Portugal
Member: 239543 Status: Offline Thanks Meter: 7 | Quote:
Booting Phone via USB... ================================================== ==== ================================================== ==== USB Phone Backup RPL Boot ================================================== ==== ================================================== ==== Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... Unable to detect "Nokia USB Flashing Generic" | |
07-03-2013, 17:12 | #4 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Quote:
Id dead then connect on dead mode . I think this should be done by a common man Br - srinibas | |
07-03-2013, 17:30 | #5 (permalink) | |
i have the pc suite on and the he connect to pc suite but no connect to atf box... I canīt read the phone. | |
07-03-2013, 20:24 | #7 (permalink) |
Member: 239543 Status: Offline Thanks Meter: 7 | I have the same problem.... Booting Phone via USB... ================================================== ==== ================================================== ==== USB Phone Backup RPL Boot ================================================== ==== ================================================== ==== Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... Unable to detect "Nokia USB Flashing Generic" But when i try scan phone appears: ================================================== ==== ERROR: Active Phone Handle was NOT DETECTED ================================================== ==== TIP: Make sure that Phone USB Connection Mode is OVI Suite Mode or PC Suite Mode ================================================== ==== Make sure you have installed the COMPLETE Flash Package for this Phone... Goto "Settings" --> "Nokia Settings" and verify that the Folder where you installed your Flash Files are in the "PRODUCT PATH TO SCAN" List... |
07-06-2013, 10:31 | #11 (permalink) |
Member: 239543 Status: Offline Thanks Meter: 7 | Hi. I can connect the phone to atf and backup RPL and FULL Flash. I erase flash but now when i try flash the phone i have one error. Number of Image Files: 2 Processing Image File : RM-609_025.007_79.92_prd.core.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 509 Entry Point: 0x0214 Page Format : -1 MAX PAGE : 0x00040000 Processing Image File : RM609_0588108_025.007_043.vpl CMT Type : CMT Algorithm : Secondary Sending Speed : 0Hz Algorithm Sending Speed : 0Hz Program Sending Speed : 0Hz Message Reading Speed : 0Hz Number of Blocks : 0 Entry Point: 0x0000 Page Format : -1 MAX PAGE : 0x00000000 Booting/Flashing Failed... Please Try Again... |
