03-08-2014, 19:15 | #1 (permalink) |
Insane Poster Join Date: Jun 2007
Member: 523149 Status: Offline Thanks Meter: 4 | nokia e63-1 Unable to read SP Data.. ================================================ Basic Phone Information ================================================ MCU Version: V ICPR71_09w47.11 14-02-11 RM-437 (c) Nokia IMEI Plain : 354329047234302 IMEI Spare : A354329047234300 IMEI SV : 33543290472343017F Phone Model: Nokia E63 Category : Smartphone Phone Type : RM-437 first it dead i backup rpl and erase it and then flash next write rpl now it say sim Unable to read SP Data.. when i try repair super dongle then its show You need to use The ATF Network and Authorize this Phone to enable Super Dongle Repair, Stand-Alone SX4 and Decrypt SL3 PM 120 HASHES Visit The ATF Store for more Information now what can i do please reply any expert |
The Following User Says Thank You to rana das For This Useful Post: |
03-09-2014, 19:02 | #3 (permalink) | |
No Life Poster Join Date: May 2011 Location: Z3X ^ CM2 ^ MRT ^ OCTOPUS
Member: 1587480 Status: Offline Sonork: 100.1618317 Thanks Meter: 2,165 | Quote:
WBR. Arsalan gsm2000. | |
The Following User Says Thank You to .::MASTER ALONE::. For This Useful Post: |
03-11-2014, 13:56 | #8 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | For dead phones, you should use SIMLock Recovery from IMEI and Locks tab and Backup RPL, than you can Full Erase and Flash phones, else it will end-up SIMlock damaged / Contact Retailer and only Nokia RPL will solve this for SL3 based phones. Post here Bus Check log, to check if your phone is SL2 or SL3 based. BR |
The Following User Says Thank You to ..::Angel::.. For This Useful Post: |
03-11-2014, 18:50 | #9 (permalink) | |
Member: 523149 Status: Offline Thanks Meter: 4 | nokia e63-01unable to read sp data... Quote:
thanks brother but now i return phone in my customer | |
06-24-2014, 15:59 | #10 (permalink) |
Registered User Join Date: Jan 2007 Location: South Africa/Pakistan
Member: 437195 Status: Offline Thanks Meter: 1,734 | Have same problem after manual erase Code: Booting Phone via FBUS... AdvanceBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ****************************************************** TIME STARTS HERE ****************************************************** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 400C1921 ID DWORD 4 : 01051103 2 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000296 3 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 18000202 ID DWORD 1 : 7AA50052 ID DWORD 2 : D30DDBE1 ID DWORD 3 : 51534189 ID DWORD 4 : 30BC7293 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : C7 0C B0 73 24 05 6B C6 6A 82 43 47 F4 0D B2 D5 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 4B9B7510 CRC 1 : 3E691FF8 Checksum C1 SearchForBootstrap_DCT5.. C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_2nd.fg Boot File - Version 012.08.00 Boot File - Revision 0x0002 (2) eBB5ProtocolType == New PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0" SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C Transmission Type Request Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : 06 SubBlocks : 06 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0020 -> Device ID : 0040 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0031 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> not used Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 0020 -> Device ID : 0040 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0031 6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5 Block Length : 09 BB ASIC Index : CMT 00 Data : XSR 1.5 Checksum : 55 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files MuxOneNAND (03) ManID :0020 DevID :0040 ExtID :0000 RevID :0031 Flash Descriptor Manufacturer Code : 0020 Device ID : 0040 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 10000000 (256 MB) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_XSR15_alg.fg Algorithm File - Version 012.08.00 Algorithm File - Revision 0x0002 (2) eBB5ProtocolType == New Algo Loader Sent... SendCodeStart_NewProtocol : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok... VPP Enabled by Software Using Internal VPP VPP Enabled by Software FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 PAPUB_KEYS_HASH_REQ_BB5 PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: D9C25399C696B8549EDCDB1497A950B3A20DDFB6 Scanning Simlock Applet Type... OK ================================================= PA_SL3 Applet detected ================================================= * Firmware Version Downgrade will KILL PHONE !!! * Manual Full Erase WILL KILL PHONE!!! * Simlocks are in PM 120 Only... * PM 308 is Write Protected... ================================================ Basic Phone Information ================================================ MCU Version: V ICPR71_09w47.11 14-02-11 RM-437 (c) Nokia IMEI Plain : 354329049288025 IMEI Spare : A354329049288020 IMEI SV : 33543290492880217F Phone Model: Nokia E63 Category : Smartphone Phone Type : RM-437 ================================================ Extended Phone Information ================================================ Product Serial Number: 0 Long Production SN : 0 MCU SW Version : V ICPR71_09w47.11 14-02-11 RM-437 (c) Nokia RFIC Version : 17141716 DSP Version : sofie.ICPR71_09w40 AHNE Version : 11 APE SW Core Version : 510.21.010 Variant Version : 510.21.010510.21.010_v42 APE Test Version : v0.a018 RETU Version : 16 TAHVO Version : 22 APE HW Version : 256 APE ADSP SW Version : 256 Wireless LAN ID : C8:DF:7C:98:F4:A2 Bluetooth ID : C8:DF:7C:98:B6:22 CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA VIII ================================================ Simlock Information ================================================ Unable to read SP Data.. ================================================ Basic Phone Information ================================================ MCU Version: V ICPR71_09w47.11 14-02-11 RM-437 (c) Nokia IMEI Plain : 354329049288025 IMEI Spare : A354329049288020 IMEI SV : 33543290492880217F Phone Model: Nokia E63 Category : Smartphone Phone Type : RM-437 ================================================ Extended Phone Information ================================================ Product Serial Number: 0 Long Production SN : 0 MCU SW Version : V ICPR71_09w47.11 14-02-11 RM-437 (c) Nokia RFIC Version : 17141716 DSP Version : sofie.ICPR71_09w40 AHNE Version : 11 APE SW Core Version : 510.21.010 Variant Version : 510.21.010510.21.010_v42 APE Test Version : v0.a018 RETU Version : 16 TAHVO Version : 22 APE HW Version : 256 APE ADSP SW Version : 256 Wireless LAN ID : C8:DF:7C:98:F4:A2 Bluetooth ID : C8:DF:7C:98:B6:22 CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA VIII ================================================ Simlock Information ================================================ Unable to read SP Data.. SECURITY_TEST : PASSED PHONE_MODE : TEST ====================================================== Selected VPL File: RM437_0584630_510.21.010_001.vpl ====================================================== Variant Details : RM-437 CTR MEA-F1 South-Afr. Midnight Black Software Version : 510.21.010 Product Type : RM-437 Product Code : 0584630 Variant Version : 001 Br. |
