05-03-2012, 12:36 | #1 (permalink) |
No Life Poster Join Date: Nov 2010 Location: DHAKA BANGLADESH Age: 37
Member: 1441250 Status: Offline Sonork: 100:1602230 Thanks Meter: 199 | nokia e63 black lcd help ATF Box FBUS Flash Started... Number of Image Files: 5 Processing Image File : C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-437\rm437_501.21.001_prd.c00 CMT Type : BB5 CMT Algorithm : XSR 1.5 Secondary Sending Speed : 650000 Hz Algorithm Sending Speed : 6500000 Hz Program Sending Speed : 6500000 Hz Message Reading Speed : 98000 Hz Number of Blocks : 532 Entry Point : 0x1E20B3 Page Format : 128K Maximum Page Size : 0x00020000 Changing MODE : FLASH Booting Phone via FBUS... AdvanceBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ************************************************** **** TIME STARTS HERE ************************************************** **** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 400C1921 ID DWORD 4 : 01051103 2 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000296 3 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 0B300113 ID DWORD 1 : 46A70052 ID DWORD 2 : B6141240 ID DWORD 3 : CEFC88DB ID DWORD 4 : 416A1030 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : C7 0C B0 73 24 05 6B C6 6A 82 43 47 F4 0D B2 D5 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 4B9B7510 CRC 1 : 3E691FF8 Checksum 87 SearchForBootstrap_DCT5.. C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_2nd.fg Boot File - Version 011.016.00 Boot File - Revision 0x0002 (2) eBB5ProtocolType == New PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0" SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C Transmission Type Request Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : 06 SubBlocks : 06 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0020 -> Device ID : 0040 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0031 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> not used Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 0020 -> Device ID : 0040 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0031 6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5 Block Length : 09 BB ASIC Index : CMT 00 Data : XSR 1.5 Checksum : 55 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files MuxOneNAND (03) ManID :0020 DevID :0040 ExtID :0000 RevID :0031 Flash Descriptor Manufacturer Code : 0020 Device ID : 0040 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 10000000 (256 MB) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_XSR15_alg.f g Algorithm File - Version 011.016.00 Algorithm File - Revision 0x0002 (2) eBB5ProtocolType == New Algo Loader Sent... SendCodeStart_NewProtocol : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok... VPP Enabled by Software Using Internal VPP VPP Enabled by Software FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: D9C25399C696B8549EDCDB1497A950B3A20DDFB6 Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) Certificate 1 Name : NPC ASIC Index : CMT 0 Certificate 2 Name : CCC ASIC Index : CMT 0 Certificate 3 Name : HWC ASIC Index : CMT 0 Certificate 4 Name : R&D ASIC Index : CMT 0 STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3 STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5 : No Error - 0 (0x00) StartErase_DCT5... BlockLength : 0xB1 (177) ERASE Blocks : 0x04 (4) 0 ERASE_AREA_BB5 0x12 Block Length : 0x1B (27) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 00040000-007FFFFF 1 : 00A00000-0759FFFF 2 : 0F1C0000-0F8BFFFF 1 FORMAT_PARTITION_BB5 0x19 Block Length : 0x2F (47) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Format Info ID : 0x00000000 Format Info : 000000000000000B0000000000000002000000640000000300 000001000000010000000000000000 2 FORMAT_PARTITION_BB5 0x19 Block Length : 0x2F (47) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Format Info ID : 0x00000000 Format Info : 00000000000000090000000000000001000000640000000400 000001000000010000000000000000 3 FORMAT_PARTITION_BB5 0x19 Block Length : 0x2F (47) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Format Info ID : 0x00000000 Format Info : 000000000000000A0000000000000002000000640000000300 000001000000010000000000000000 Erase_SendEraseBlock_BB5_NAND Task in Progress... Please Wait... Erase_SendFormatPartition_BB5_NAND Task in Progress... Please Wait... Erase_SendFormatPartition_BB5_NAND Task in Progress... Please Wait... Erase_SendFormatPartition_BB5_NAND Task in Progress... Please Wait... Successfully erased.. Time Taken to Erase : 00:00:01 Flashing Speed: 15.00 Mhz Processing : rm437_501.21.001_prd.c00 Total blocks to write : 532 >> CMT Rootkey Hash CERT : ADA >> CMT Rootkey Hash CERT : KEYS >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : RAP3NAND >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : PAPUBKEYS >> CMT Rootkey Hash CERT : SOS*UPDAPP >> CMT Rootkey Hash CERT : SOS*DSP0 >> CMT Rootkey Hash CERT : SOS*ISASW >> CMT Rootkey Hash CERT : SOS*CORE >> CMT Rootkey Hash CERT : SOS+ROFS ContinueFlash_DCT5 Complete Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:16 Processing Image File : C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-437\rm437_501.21.001_prd.v20 CMT Type : BB5 CMT Algorithm : XSR 1.5 Secondary Sending Speed : 650000 Hz Algorithm Sending Speed : 6500000 Hz Program Sending Speed : 6500000 Hz Message Reading Speed : 98000 Hz Number of Blocks : 197 Entry Point : 0x0169 Page Format : 128K Maximum Page Size : 0x00020000 StartErase_DCT5... BlockLength : 0x3F (63) ERASE Blocks : 0x02 (2) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 05420000-0759FFFF 1 FORMAT_PARTITION_BB5 0x19 Block Length : 0x2F (47) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Format Info ID : 0x00000000 Format Info : 00000000000000090000000000000001000000640000000400 000001000000010000000000000000 Erase_SendEraseBlock_BB5_NAND Task in Progress... Please Wait... Erase_SendFormatPartition_BB5_NAND Task in Progress... Please Wait... Successfully erased.. Time Taken to Erase : 00:00:00 Flashing Speed: 15.00 Mhz Processing : rm437_501.21.001_prd.v20 Total blocks to write : 197 >> CMT Rootkey Hash CERT : SOS+ROFX ContinueFlash_DCT5 Complete Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:06 Processing Image File : C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-437\rm437_501.21.001.33U CMT Type : BB5 CMT Algorithm : XSR 1.5 Secondary Sending Speed : 650000 Hz Algorithm Sending Speed : 6500000 Hz Program Sending Speed : 6500000 Hz Message Reading Speed : 98000 Hz Number of Blocks : 142 Entry Point : 0x0122 Page Format : 128K Maximum Page Size : 0x00020000 StartErase_DCT5... BlockLength : 0x32 (50) ERASE Blocks : 0x01 (1) 0 FORMAT_PARTITION_BB5 0x19 Block Length : 0x2F (47) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Format Info ID : 0x00000000 Format Info : 00000000000000080000000000000001000000640000000A00 000001000000010000000000000000 Erase_SendFormatPartition_BB5_NAND Task in Progress... Please Wait... Successfully erased.. Time Taken to Erase : 00:00:00 Flashing Speed: 15.00 Mhz Processing : rm437_501.21.001.33U Total blocks to write : 142 ContinueFlash_DCT5 Complete Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:05 Processing Image File : C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-437\sofie_erase_y_drive.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.5 Secondary Sending Speed : 650000 Hz Algorithm Sending Speed : 6500000 Hz Program Sending Speed : 6500000 Hz Message Reading Speed : 98000 Hz Number of Blocks : 0 Entry Point : 0x0000 Page Format : 128K Maximum Page Size : 0x00020000 StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 0F020000-0F1BFFFF Erase_SendEraseBlock_BB5_NAND Task in Progress... Please Wait... Successfully erased.. Time Taken to Erase : 00:00:00 Flashing Speed: 15.00 Mhz Processing : sofie_erase_y_drive.fpsx No FLASHDATA TO WRITE Time Taken to Flash : 00:00:00 Processing Image File : C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-437\RM437_ENO_008.07.45_100.71.920.a01.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.5 Secondary Sending Speed : 650000 Hz Algorithm Sending Speed : 6500000 Hz Program Sending Speed : 6500000 Hz Message Reading Speed : 98000 Hz Number of Blocks : 16 Entry Point : 0x0143 Page Format : 128K Maximum Page Size : 0x00020000 StartErase_DCT5... BlockLength : 0x10 (16) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x13 Block Length : 0x0D (13) BB ASIC Index : 0x00 CMT Erase_SendEraseBlock_BB5_NAND Task in Progress... Please Wait... Successfully erased.. Time Taken to Erase : 00:00:00 Flashing Speed: 15.00 Mhz Processing : RM437_ENO_008.07.45_100.71.920.a01.fpsx Total blocks to write : 16 >> CMT Rootkey Hash CERT : SOS*ENO ContinueFlash_DCT5 Complete Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:00 Total Flash Write Time (Flashing Only) : 00:00:29 Total Flashing Time (Booting + Erase + Flashing) : 00:00:32 Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000001 Additional Bad : 00000001 Correctable ECC : 00000000 Waiting for Phone to Go Online... Elapsed Time: 1s Elapsed Time: 2s Elapsed Time: 3s Elapsed Time: 4s Elapsed Time: 5s Elapsed Time: 6s Elapsed Time: 7s Elapsed Time: 8s Elapsed Time: 9s Elapsed Time: 10s ================================================ Basic Phone Information ================================================ |
